编译Android内核时提示java版本不正穷
刚接触这个,按照开荒教程操作,编译Android内核出现如下提示,怎么破。。。。
Checking build tools versions…
You are attempting to build with the incorrect version
of java.
Your version is: java version “1.6.0_45” Java™ SE Runtime Environment (build 1.6.0_45-b06) Java HotSpot™ 64-Bit Server VM (build 20.45-b01, mixed mode).
The required version is: “1.7.x”
Please follow the machine setup instructions at
https://source.android.com/source/initializing.html
编译lollipop需要jdk7:http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_android_lollipop
使用Firefly-RK3288-Reload 编译内核:
cd ~/proj/firefly-rk3288-lollipop/kernel
make firefly-rk3288-reload_defconfig
make -j8 firefly-rk3288-reload.img
:‘(:’(:cry: error:
make[1]: “arch/arm/boot/dts/firefly-rk3288-reload.dtb”是最新的。
GEN drivers/video/rockchip/screen/lcd.h
Kernel: arch/arm/boot/Image is ready
LZO arch/arm/boot/compressed/piggy.lzo
/bin/sh: 1: lzop: not found
make[2]: *** [arch/arm/boot/compressed/piggy.lzo] 错误 1
make[1]: *** [arch/arm/boot/compressed/vmlinux] 错误 2
make: *** [zImage] 错误 2
make: INTERNAL: Exiting with 9 jobserver tokens available; should be 8!
#### make failed to build some targets (6 seconds) ####
help!!!:cry:
你的环境还是没装好,上面那个链接再查一下那些工具忘记忘记装了
还是没成功,到编译Android 内核时 make -j8 失败;
是完全按照你给的链接操作,还是要结合开荒贴。。。
真心不懂,望详细解释下,大神。。。。
我重新弄了一次,还是不行。。。。。跪求解答。。。。
Please submit a full bug report,
with preprocessed source if appropriate.
See http://source.android.com/source/report-bugs.html for instructions.
make: *** [out/target/product/rk3288_box/obj/STATIC_LIBRARIES/v8_tools_gyp_v8_base_gyp_intermediates/v8/src/compiler/js-graph.o] 错误 1
make: *** 正在等待未完成的任务…
#### make failed to build some targets (54:35 (mm:ss)) ####
搞好编译环境了吗?WIKI里提到的工具都必须安装,不能有遗漏哦。
由樓上大大提醒
我去此網站 http://source.android.com/source/initializing.html
sudo apt-get update
sudo dpkg -i {downloaded.deb file}
之後再執行 http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_android
14.04LTS 版本
sudo apt-get install git-core gnupg flex bison gperf libsdl1.2-dev
libesd0-dev libwxgtk2.8-dev squashfs-tools build-essential zip curl
libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils
xsltproc lzop libc6-dev schedtool g+±multilib lib32z1-dev lib32ncurses5-dev
lib32readline-gplv2-dev gcc-multilib libswitch-perl
可以解決
/bin/sh: 1: lzop: not found 問題
成功
Kernel: arch/arm/boot/zImage is ready
Image: kernel.img is ready
Pack to resource.img successed!
Image: resource.img (with firefly-rk3288.dtb logo.bmp) is ready
