RK3568 Camera Driver - Interlaced Mode Only Supported in Selfpath
Type: Self-Compiled Firmware
SDK Package Name: Firefly-RK356X_Android11.0_git_20210824
Modification Content: hardware/rockchip/camera
Log: rk3568_camera_interlaced_questions.log.tar.gz
Hi everyone,
I’m currently working on a camera driver using the RK3568 SDK and have modified the kernel to support interlaced mode. According to the documentation, interlaced mode should be supported in the selfpath, and I have set the field parameter as follows:
.field = V4L2_FIELD_INTERLACED,
However, when I run the camera in the Android environment, I only get the following log message:
only selfpath support interlaced
Questions:
  • Has anyone encountered this issue before?
  • Are there any additional configurations required for interlaced mode in RK3568?
  • Could this be a limitation in Android’s Camera HAL or a driver-level issue?
Any insights or suggestions would be greatly appreciated!
Thanks in advance. :rocket:
rk3568_camera_interlaced_questions.log.tar.gz (776 Bytes)
Thank you for sharing this remarkable article, it truly impressed me. I owe my promotion and raise to the Valid test Databricks-Certified-Data-Analyst-Associate cram pdf questions, and today I’m sharing them for free with all of you!
This article is absolutely amazing, thank you for sharing! The New MB-800 exam topics pdf helped me secure a promotion and raise. Now, I’m giving it away for free. May your career paths be filled with success!
Your article is nothing less than magnificent, thank you for sharing! The rich material in PCCP reliable exam dumps sheet is available to you for free, intended to help you.
