---Firefly 3288 5.1.1 点屏问题请求大家帮忙看看
  1. 普通 LVDS 高清屏幕
  2. 屏的背光和电源都是硬件强制打开的
  3. .config: CONFIG_DUAL_LCDC_DUAL_DISP_IN_KERNEL=y
    目前的问题是屏幕没显示, 大家帮忙看看是什么问题:
dts:
入口:
&lcdc0 {
status = “okay”;
rockchip,mirror = <NO_MIRROR>;
rockchip,cabc_mode = <0>;
power_ctr: power_ctr {
rockchip,debug = <1>;
&lcdc1 {
status = “okay”;
rockchip,iommu-enabled = <0>;
Timming:
native-mode = <&timing0>;
timing0: timing0 {
screen-type = <SCREEN_LVDS>;
lvds-format = <LVDS_8BIT_1>;
out-face = <OUT_P888>;
color-mode = <COLOR_RGB>;
clock-frequency = <148500000>;
hactive = <1920>;
vactive = <1080>;
hback-porch = <100>;
hfront-porch = <60>;
vback-porch = <20>;
vfront-porch = <20>;
hsync-len = <20>;
vsync-len = <4>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
pixelclk-active = <1>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
------------------kernel boot log-------------------------
shell@firefly:/ $
shell@firefly:/ $ su
shell@firefly:/ # dmesg
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (bill@ccc2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #9 SMP PREEMPT Fri Mar 11 14:07:06 CS
T 2016
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<6>[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
<6>[ 0.000000] hdmi init vic is 16
<6>[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(drm): base(0) size(0) align(0)
<6>[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 640 MiB at 55c00000
<6>[ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0d74b00, node_mem_map c0e9e000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ef7000 s13376 r8192 d15296 u36864
<7>[ 0.000000] pcpu-alloc: s13376 r8192 d15296 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.cons
ole=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x
0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x000020
00@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(use
rdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2015-07-20_1
0:28:11 hdmi.vic=16
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 1354896k/1354896k available, 742256k reserved, 884736K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0b8f4d0 (11806 kB)
<5>[ 0.000000] .init : 0xc0b90000 - 0xc0be9440 ( 358 kB)
<5>[ 0.000000] .data : 0xc0bea000 - 0xc0d7c140 (1609 kB)
<5>[ 0.000000] .bss : 0xc0d7c140 - 0xc0e9d77c (1158 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start!
<3>[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
<3>[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 28
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 2
<6>[ 0.000000] channel:0, lkg:12
<6>[ 0.000000] target-temp:95
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:10
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.341358] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.341374] pid_max: default: 32768 minimum: 301
<6>[ 0.341486] Security Framework initialized
<6>[ 0.341503] SELinux: Initializing.
<7>[ 0.341539] SELinux: Starting in permissive mode
<6>[ 0.341577] Mount-cache hash table entries: 512
<6>[ 0.342218] Initializing cgroup subsys debug
<6>[ 0.342232] Initializing cgroup subsys memory
<6>[ 0.342259] Initializing cgroup subsys freezer
<6>[ 0.342287] CPU: Testing write buffer coherency: ok
<3>[ 0.342608] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.342622] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.342631] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.342640] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.342692] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.342744] Setting up static identity map for 0xc0850810 - 0xc0850868
<6>[ 0.345035] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x180f (version 3.1)
<4>[ 0.419517] CPU1: Booted secondary processor
<6>[ 0.419549] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.439193] CPU2: Booted secondary processor
<6>[ 0.439218] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.458902] CPU3: Booted secondary processor
<6>[ 0.458925] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.459027] Brought up 4 CPUs
<6>[ 0.459055] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.459064] CPU: All CPU(s) started in SVC mode.
<6>[ 0.459796] devtmpfs: initialized
<6>[ 0.464045] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<6>[ 0.465138] pinctrl core: initialized pinctrl subsystem
<6>[ 0.465388] regulator-dummy: no parameters
<6>[ 0.489931] NET: Registered protocol family 16
<6>[ 0.491793] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.492182] ion_snapshot: 0x1eaa0000 map to 0xe0907000 and copy to 0xc0e78a8c (version 0.1)
<6>[ 0.492422] Registered FIQ tty driver
<3>[ 0.492820] fiq-debugger is disabled in device tree
<4>[ 0.493510] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.493531] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.493548] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.493565] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.493658] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.493723] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.493784] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.493845] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.493905] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.493965] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.494025] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.494086] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.494153] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.494218] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.494231] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.494243] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.494254] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.494335] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.494390] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.494445] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.494505] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.494560] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.494615] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.494674] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.494728] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.494781] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.494835] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.494866] rockchip_interrupts_register:bank_num=7
<7>[ 0.496798] of_get_named_gpio_flags exited with status 256
<4>[ 0.496809] of_get_gpio_init_config:gpio[0] = 256, value = 0
<7>[ 0.496820] of_get_named_gpio_flags exited with status 233
<4>[ 0.496829] of_get_gpio_init_config:gpio[1] = 233, value = 0
<7>[ 0.496840] of_get_named_gpio_flags exited with status 136
<4>[ 0.496849] of_get_gpio_init_config:gpio[2] = 136, value = 0
<4>[ 0.496910] rockchip_pinctrl_probe:init ok
<6>[ 0.503272] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.503363] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.503376] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.503544] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.503613] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.503626] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.503798] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.503868] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.503880] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.504050] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.504122] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504134] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.504325] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.504399] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504411] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.504574] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.504647] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504659] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.504835] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.504911] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504924] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.506753] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.506767] hw-breakpoint: maximum watchpoint size is 4 bytes.
<3>[ 0.507341] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
<4>[ 0.507365] DDR DEBUG: version 1.00 20150126
<4>[ 0.507393] DDR DEBUG: Channel a:
<4>[ 0.507401] DDR DEBUG: DDR3 Device
<4>[ 0.507415] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.507423] DDR DEBUG: Channel b:
<4>[ 0.507430] DDR DEBUG: DDR3 Device
<4>[ 0.507442] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.507451] DDR DEBUG: addr=0xd86000
<4>[ 0.507461] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.507470] DDR DEBUG: socAddr[0]=0xd86000, socAddr[1]=0xd86100
<4>[ 0.507479] DDR DEBUG: chAddr[0]=0xd86000, chAddr[1]=0xd86000
<4>[ 0.507490] DDR DEBUG: dtar[0]=0x601b0000, dtar[1]=0x601b0000
<4>[ 0.507544] DDR DEBUG: init success!!! freq=200MHz
<4>[ 0.507552] DDR DEBUG: Channel a:
<4>[ 0.507564] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.507577] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.507589] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.507602] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.507613] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.507622] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.507631] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.507638] DDR DEBUG: Channel b:
<4>[ 0.507649] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.507662] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.507674] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.507686] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.507697] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.507706] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.507714] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.532269] bio: create slab at 0
<6>[ 0.532805] Rockchip hdmi driver version 2.0
<6>[ 0.532805] .
<5>[ 0.533946] SCSI subsystem initialized
<6>[ 0.534103] usbcore: registered new interface driver usbfs
<6>[ 0.534148] usbcore: registered new interface driver hub
<6>[ 0.534240] usbcore: registered new device driver usb
<7>[ 0.534492] of_get_named_gpio_flags exited with status 14
<7>[ 0.534529] of_get_named_gpio_flags exited with status 12
<7>[ 0.535572] of_get_named_gpio_flags exited with status 15
<7>[ 0.535591] of_get_named_gpio_flags exited with status 16
<6>[ 0.536862] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.536977] of_get_named_gpio_flags exited with status 260
<7>[ 0.536997] of_get_named_gpio_flags exited with status 261
<6>[ 0.537535] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.537641] of_get_named_gpio_flags exited with status 201
<7>[ 0.537659] of_get_named_gpio_flags exited with status 202
<6>[ 0.538009] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.538109] of_get_named_gpio_flags exited with status 81
<7>[ 0.538127] of_get_named_gpio_flags exited with status 80
<6>[ 0.538263] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.538360] of_get_named_gpio_flags exited with status 241
<7>[ 0.538379] of_get_named_gpio_flags exited with status 242
<6>[ 0.539221] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.539349] media: Linux media interface: v0.10
<6>[ 0.539389] Linux video capture interface: v2.00
<6>[ 0.539445] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.539455] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.539475] PTP clock support registered
<4>[ 0.539534] i2c-core: driver [bq24296] using legacy suspend method
<4>[ 0.539543] i2c-core: driver [bq24296] using legacy resume method
<4>[ 0.540229] ion_drm_heap_create: 0@0
<6>[ 0.540358] Rockchip ion module is successfully loaded (v1.1)
<6>[ 0.540520] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.540941] Bluetooth: Core ver 2.16
<6>[ 0.540979] NET: Registered protocol family 31
<6>[ 0.540989] Bluetooth: HCI device and connection manager initialized
<6>[ 0.541005] Bluetooth: HCI socket layer initialized
<6>[ 0.541019] Bluetooth: L2CAP socket layer initialized
<6>[ 0.541045] Bluetooth: SCO socket layer initialized
<6>[ 0.541275] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.541989] act8846_i2c_probe,line=898
<4>[ 0.543009] act8846_parse_dt,line=746
<7>[ 0.543436] of_get_named_gpio_flags exited with status 238
<7>[ 0.543450] of_get_named_gpio_flags exited with status 1
<7>[ 0.543462] of_get_named_gpio_flags exited with status 234
<7>[ 0.543473] of_get_named_gpio_flags exited with status 259
<4>[ 0.543493] act8846_i2c_probe: act8846_pmic_hold=1
<4>[ 0.543514] act8846_i2c_probe: act8846_pmic_sleep=1
<4>[ 0.543530] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
<4>[ 0.543545] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
<6>[ 0.545629] act_dcdc1: 1200 mV
<6>[ 0.548605] vccio: 3300 mV
<6>[ 0.550469] vdd_logic: 700 ↔ 1500 mV at 1100 mV
<6>[ 0.553445] act_dcdc4: 2000 mV
<6>[ 0.554692] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.557004] act_ldo2: 1050 mV
<6>[ 0.559329] act_ldo3: 2800 mV
<6>[ 0.561664] act_ldo4: 3300 mV
<6>[ 0.563962] act_ldo5: 3300 mV
<6>[ 0.566286] act_ldo6: 1100 mV
<6>[ 0.568585] vcc_18: 1800 mV
<6>[ 0.570888] act_ldo8: 1850 mV
<6>[ 0.575653] vdd_arm: 712 ↔ 1500 mV at 1000 mV
<6>[ 0.580355] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
<4>[ 0.581107] rk808_i2c_probe,line=1355
<4>[ 0.582437] The device is not rk808 -11
<4>[ 0.582521] rk808: probe of 0-001b failed with error -11
<4>[ 0.582598] i2c-core: driver [rk818] using legacy suspend method
<4>[ 0.582608] i2c-core: driver [rk818] using legacy resume method
<6>[ 0.584333] Switching to clocksource arch_sys_counter
<6>[ 0.608394] rga: Module initialized.
<6>[ 0.609115] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.609293] rga: Driver loaded succesfully
<6>[ 0.609488] fb disp policy is box
<7>[ 0.609499] uboot-logo-on:1
<6>[ 0.609531] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.609543] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.609836] rk-screen rk_screen.8: rockchip screen probe success
<6>[ 0.610086] rk32-lvds rk32-lvds: rk32 lvds driver probe success
<3>[ 0.610385] rk32-edp ff970000.edp: screen is not edp!
<4>[ 0.610406] rk32-edp: probe of ff970000.edp failed with error -22
<6>[ 0.611082] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.611389] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.611562] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.611723] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.611957] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:63
<6>[ 0.611971] rk3288-lcdc lcdc0: wakeup from standby!
<4>[ 0.636044] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.637181] alloc_buffer:ion_phy_addr=0x55c00000
<6>[ 0.650007] fb0:phy:55c00000>>vir:e0991000>>len:0x1800000
<6>[ 0.656154] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
<3>[ 0.656346] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
<4>[ 0.656358] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.656608] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.656929] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.657098] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.657262] graphics fb7: rockchip framebuffer registerd:fb7
<6>[ 0.657556] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:1046
<6>[ 0.657570] rk3288-lcdc lcdc1: wakeup from standby!
<6>[ 0.657584] fb4:phy:55c00000>>vir:e0991000>>len:0x1800000
<6>[ 0.657595] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
<4>[ 0.658502] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.658642] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.658775] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.658906] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.659019] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.659141] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.659714] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.659872] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.660414] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.660579] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.661122] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.661267] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.661815] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.661963] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.663502] NET: Registered protocol family 2
<6>[ 0.664178] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.664259] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.664332] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.664394] TCP: reno registered
<6>[ 0.664409] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.664432] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.664618] NET: Registered protocol family 1
<6>[ 0.665245] Unpacking initramfs…
<6>[ 0.731671] Freeing initrd memory: 1248K (c5bf0000 - c5d28000)
<6>[ 0.732475] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.733011] vcodec_service: probe device ff9a0000.vpu_service
<4>[ 0.733204] vcodec_service: No reset resource define
<6>[ 0.733374] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 0.733460] vcodec_service: probe device ff9a0000.vpu_service
<6>[ 0.733474] vcodec_service: checking hw id 4831
<6>[ 0.734465] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 0.734509] vcodec_service: done
<6>[ 0.734518] vcodec_service: init success
<6>[ 0.734585] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.734920] vcodec_service: ff9c0000.hevc_service: power on
<6>[ 0.734980] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.734994] vcodec_service: checking hw id 6867
<6>[ 0.735240] vcodec_service: ff9c0000.hevc_service: power off…
<6>[ 0.735280] vcodec_service: done
<6>[ 0.735289] vcodec_service: init success
<4>[ 0.735426] rknandbase v1.0 2014-03-31
<4>[ 0.735561] rknand: probe of ff400000.nandc failed with error -1
<4>[ 0.735669] rknand_driver:ret = 0
<6>[ 0.736811] audit: initializing netlink socket (disabled)
<5>[ 0.736855] type=2000 audit(0.390:1): initialized
<4>[ 0.737715] bounce pool size: 64 pages
<6>[ 0.742353] fuse init (API version 7.22)
<6>[ 0.742724] msgmni has been set to 952
<7>[ 0.742775] SELinux: Registering netfilter hooks
<6>[ 0.744525] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 0.744541] io scheduler noop registered
<6>[ 0.744551] io scheduler deadline registered
<6>[ 0.744645] io scheduler cfq registered (default)
<7>[ 0.745083] of_get_named_gpio_flags exited with status 225
<3>[ 0.745262] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 0.745276] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 0.745304] platform backlight.20: Driver pwm-backlight requests probe deferral
<6>[ 0.746056] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
<4>[ 0.746778] IEP Driver loaded succesfully
<4>[ 0.746868] Module initialized.
<6>[ 0.747686] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.747704] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.749172] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.749189] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<3>[ 0.749465] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
<3>[ 0.749480] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
<4>[ 0.749489] pwm_regulator_probe:error
<6>[ 0.749510] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
<4>[ 0.749695] rk_serial.c v1.8 2014-03-04
<6>[ 0.749927] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.750109] serial ff180000.serial: membase e097e000
<6>[ 0.750258] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<6>[ 0.751931] console [ttyS2] enabled
<6>[ 0.752101] serial ff690000.serial: membase fed60000
<6>[ 0.754872] loop: module loaded
<6>[ 0.755242] zram: Created 1 device(s) …
<4>[ 0.755332] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 0.755345] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 0.755363] mpu_init: Probe name mpu6050B1
<6>[ 0.755530] ak8963_mod_init: Probe name ak8963_mod
<6>[ 0.756230] SCSI Media Changer driver v0.25
<6>[ 0.756552] tun: Universal TUN/TAP device driver, 1.6
<6>[ 0.756565] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 0.756697] vmac_init.
<3>[ 0.757254] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<6>[ 0.757271] stmmac_probe_config_dt: clock input/output? (input).
<6>[ 0.757285] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 0.757297] stmmac_probe_config_dt: RX delay(0x20).
<7>[ 0.757311] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 0.757326] of_get_named_gpio_flags exited with status 136
<7>[ 0.757335] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 0.757346] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 0.757358] stmmc_pltfr_init:
<3>[ 0.757368] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<7>[ 0.757382] _gpio_request: gpio-136 (gmac_phy_reset) status -16
<3>[ 0.757391] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
<6>[ 0.757408] stmmc_pltfr_init: init for RGMII
<6>[ 0.757420] tx delay=0x30
<6>[ 0.757420] rx delay=0x20
<6>[ 0.757436] tx delay=0x30
<6>[ 0.757436] rx delay=0x20
<6>[ 0.757914] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 0.757926] Normal descriptors
<6>[ 0.757936] Ring mode enabled
<6>[ 0.757946] DMA HW capability register supported
<6>[ 0.757959] RX Checksum Offload Engine supported (type 2)
<6>[ 0.757969] TX Checksum insertion supported
<6>[ 0.757978] Wake-Up On Lan supported
<6>[ 0.758018] Enable RX Mitigation via HW Watchdog Timer
<6>[ 0.758515] PPP generic driver version 2.4.2
<6>[ 0.758670] PPP BSD Compression module registered
<6>[ 0.758683] PPP Deflate Compression module registered
<6>[ 0.758705] PPP MPPE Compression module registered
<6>[ 0.758719] NET: Registered protocol family 24
<6>[ 0.758756] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 0.758770] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 0.758783] Rockchip WiFi SYS interface (V1.00) …
<4>[ 0.758818] esp_mem_init enter date Mar 11 2016 10:21:25
<4>[ 0.758829] esp_mem_init VERSION [V2.5]
<4>[ 0.758875] esp_mem_init complete
<6>[ 0.758964] usbcore: registered new interface driver catc
<6>[ 0.759005] usbcore: registered new interface driver kaweth
<6>[ 0.759020] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 0.759061] usbcore: registered new interface driver pegasus
<6>[ 0.759104] usbcore: registered new interface driver rtl8150
<6>[ 0.759145] usbcore: registered new interface driver r8152
<6>[ 0.759157] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 0.759226] usbcore: registered new interface driver hso
<6>[ 0.759278] usbcore: registered new interface driver asix
<6>[ 0.759330] usbcore: registered new interface driver ax88179_178a
<6>[ 0.759390] usbcore: registered new interface driver cdc_ether
<6>[ 0.759432] usbcore: registered new interface driver cdc_eem
<6>[ 0.759480] usbcore: registered new interface driver dm9601
<6>[ 0.759521] usbcore: registered new interface driver dm9620
<6>[ 0.759567] usbcore: registered new interface driver smsc75xx
<6>[ 0.759618] usbcore: registered new interface driver smsc95xx
<6>[ 0.759659] usbcore: registered new interface driver gl620a
<6>[ 0.759698] usbcore: registered new interface driver net1080
<6>[ 0.759736] usbcore: registered new interface driver plusb
<6>[ 0.759775] usbcore: registered new interface driver rndis_host
<6>[ 0.759813] usbcore: registered new interface driver cdc_subset
<6>[ 0.759850] usbcore: registered new interface driver zaurus
<6>[ 0.759896] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 0.759959] usbcore: registered new interface driver int51x1
<6>[ 0.760002] usbcore: registered new interface driver kalmia
<6>[ 0.760042] usbcore: registered new interface driver ipheth
<6>[ 0.760083] usbcore: registered new interface driver sierra_net
<6>[ 0.760122] usbcore: registered new interface driver cx82310_eth
<6>[ 0.760173] usbcore: registered new interface driver cdc_ncm
<6>[ 0.760215] usbcore: registered new interface driver qmi_wwan
<6>[ 0.760261] usbcore: registered new interface driver cdc_mbim
<6>[ 0.760273] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<6>[ 0.762728] EHCI: ehci_rk_probe e4240000 e4240010
<6>[ 0.762747] rockchip_ehci_host ff500000.usb: EHCI Host Controller
<6>[ 0.762777] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 0.763167] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 0.781206] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
<6>[ 0.781290] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.781307] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.781322] usb usb1: Product: EHCI Host Controller
<6>[ 0.781335] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 0.781349] usb usb1: SerialNumber: ff500000.usb
<6>[ 0.781814] hub 1-0:1.0: USB hub found
<6>[ 0.781841] hub 1-0:1.0: 1 port detected
<6>[ 0.782034] EHCI: ehci_rk_probe ok
<6>[ 0.782146] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<6>[ 0.782355] usbcore: registered new interface driver cdc_acm
<6>[ 0.782368] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 0.782422] usbcore: registered new interface driver usblp
<6>[ 0.782465] usbcore: registered new interface driver cdc_wdm
<6>[ 0.782536] usbcore: registered new interface driver usb-storage
<6>[ 0.782578] usbcore: registered new interface driver ums-alauda
<6>[ 0.782618] usbcore: registered new interface driver ums-cypress
<6>[ 0.782657] usbcore: registered new interface driver ums-datafab
<6>[ 0.782694] usbcore: registered new interface driver ums_eneub6250
<6>[ 0.782732] usbcore: registered new interface driver ums-freecom
<6>[ 0.782771] usbcore: registered new interface driver ums-isd200
<6>[ 0.782816] usbcore: registered new interface driver ums-jumpshot
<6>[ 0.782858] usbcore: registered new interface driver ums-karma
<6>[ 0.782913] usbcore: registered new interface driver ums-onetouch
<6>[ 0.782961] usbcore: registered new interface driver ums-sddr09
<6>[ 0.783002] usbcore: registered new interface driver ums-sddr55
<6>[ 0.783041] usbcore: registered new interface driver ums-usbat
<6>[ 0.783136] usbcore: registered new interface driver usbserial
<6>[ 0.783177] usbcore: registered new interface driver usbserial_generic
<6>[ 0.783211] usbserial: USB Serial support registered for generic
<6>[ 0.783252] usbcore: registered new interface driver option
<6>[ 0.783282] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 0.783361] usbcore: registered new interface driver trancevibrator
<6>[ 0.783374] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 0.783807] e4280040
<4>[ 0.783848] Core Release: 3.10a
<4>[ 0.783861] Setting default values for core params
<4>[ 0.783989] Using Buffer DMA mode
<4>[ 0.784001] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.784013] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.784025] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.784036] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 0.784051] Dedicated Tx FIFOs mode
<4>[ 0.784069] pcd_init otg_dev = ddf56380
<6>[ 0.846963] hdmi output corlor mode is 3
<4>[ 0.846982] hdmi connect to lcdc1
<6>[ 0.846995] switch:en=1,lcdc_id=1,screen type=6,cur type=2
<4>[ 0.883253] Using Buffer DMA mode
<4>[ 0.883267] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.883279] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.883291] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.883301] ^^^^^^^^^^^^^^^^^Device Mode
<6>[ 0.883332] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 0.883364] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 0.883400] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 0.883457] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.883473] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.883488] usb usb2: Product: DWC OTG Controller
<6>[ 0.883501] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 0.883514] usb usb2: SerialNumber: ff580000.usb
<6>[ 0.883946] hub 2-0:1.0: USB hub found
<6>[ 0.883972] hub 2-0:1.0: 1 port detected
<6>[ 0.884283] usb20_host: version 3.10a 21-DEC-2012
<4>[ 0.886811] e4300040
<4>[ 0.886823] Core Release: 3.10a
<4>[ 0.886834] Setting default values for core params
<4>[ 0.886946] Using Buffer DMA mode
<4>[ 0.886958] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.886969] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.886981] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.886991] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 0.887019] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 0.887045] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 0.887076] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 0.887168] Init: Power Port (0)
<6>[ 0.887223] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.887240] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.887255] usb usb3: Product: DWC OTG Controller
<6>[ 0.887268] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 0.887281] usb usb3: SerialNumber: ff540000.usb
<6>[ 0.887667] hub 3-0:1.0: USB hub found
<6>[ 0.887690] hub 3-0:1.0: 1 port detected
<6>[ 0.888382] usbcore: registered new interface driver xpad
<6>[ 0.888443] usbcore: registered new interface driver usb_acecad
<6>[ 0.888492] usbcore: registered new interface driver aiptek
<6>[ 0.888538] usbcore: registered new interface driver gtco
<6>[ 0.888586] usbcore: registered new interface driver hanwang
<6>[ 0.888631] usbcore: registered new interface driver kbtab
<6>[ 0.888684] usbcore: registered new interface driver wacom
<7>[ 0.888789] of_get_named_gpio_flags exited with status 263
<7>[ 0.888802] of_get_named_gpio_flags exited with status 169
<3>[ 0.909743] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 1
<3>[ 0.939580] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 2
<3>[ 0.969104] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 3
<4>[ 0.978066] dwc_otg_hcd_suspend, usb device mode
<3>[ 0.998623] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 4
<3>[ 1.028146] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 5
<3>[ 1.057659] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 6
<3>[ 1.087182] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 7
<6>[ 1.096083] rk_fb_switch_screen: wait update_regs_wait timeout
<6>[ 1.096118] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:60
<6>[ 1.096163] pixel clk is 148500000 tmds clk is 148500000
<3>[ 1.116696] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 8
<3>[ 1.146212] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 9
<3>[ 1.175732] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 10
<3>[ 1.204324] synaptics_dsx_i2c 1-0020: synaptics_rmi4_set_input_dev: Failed to query device
<3>[ 1.204348] synaptics_dsx synaptics_dsx.0: synaptics_rmi4_probe: Failed to set up input device
<4>[ 1.204373] synaptics_dsx: probe of synaptics_dsx.0 failed with error -5
<4>[ 1.204690] sensor_register_slave:mma8452,id=17
<4>[ 1.204705] sensor_register_slave:gs_mc3230,id=23
<4>[ 1.204716] gsensor_init
<4>[ 1.204726] sensor_register_slave:mpu6880_acc,id=24
<4>[ 1.204737] sensor_register_slave:mpu6500_acc,id=25
<4>[ 1.204748] sensor_register_slave:cm3217,id=48
<4>[ 1.204759] sensor_register_slave:cm3218,id=49
<3>[ 1.204997] .. rk pwm remotectl v1.1 init
<6>[ 1.205254] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
<7>[ 1.208300] of_get_named_gpio_flags exited with status 228
<6>[ 1.210289] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 1.210343] i2c /dev entries driver
<6>[ 1.211055] IR NEC protocol handler initialized
<6>[ 1.211069] IR RC5(x) protocol handler initialized
<6>[ 1.211080] IR RC6 protocol handler initialized
<6>[ 1.211090] IR JVC protocol handler initialized
<6>[ 1.211100] IR Sony protocol handler initialized
<6>[ 1.211110] IR RC5 (streamzap) protocol handler initialized
<6>[ 1.211121] IR SANYO protocol handler initialized
<6>[ 1.211131] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 1.211289] usbcore: registered new interface driver uvcvideo
<6>[ 1.211301] USB Video Class driver (1.1.1)
<4>[ 1.211314] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
<7>[ 1.212744] of_get_named_gpio_flags exited with status 236
<4>[ 1.212757] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
<7>[ 1.212772] of_get_named_gpio_flags exited with status 236
<4>[ 1.212782] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
<4>[ 1.212801] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
<4>[ 1.212820] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
<4>[ 1.212860] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
<4>[ 1.212860]
<4>[ 1.212934] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 1.213082] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
<4>[ 1.213715] D1:camsys_platform_probe(1447): ff910000.isp memory:
<4>[ 1.213733] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
<4>[ 1.213749] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1def4000 vir: 0xddef4000 size: 0x1000)
<4>[ 1.213764] D1:camsys_init_ext_fsh_module(20): init external flash module
<4>[ 1.213776] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
<6>[ 1.214252] not find test_power_init dev node
<4>[ 1.214314] i2c-core: driver [bq27320] using legacy suspend method
<4>[ 1.214326] i2c-core: driver [bq27320] using legacy resume method
<4>[ 1.214660] rockchip_temp_probe,line=362
<6>[ 1.273204] tsadc ff280000.tsadc: initialized
<6>[ 1.273573] device-mapper: uevent: version 1.0.3
<6>[ 1.273843] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 1.274143] Bluetooth: HCI UART driver ver 2.2
<6>[ 1.274159] Bluetooth: HCI H4 protocol initialized
<6>[ 1.274170] Bluetooth: HCILL protocol initialized
<6>[ 1.274181] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
<6>[ 1.274193] rtk_btusb: Register usb char device interface for BT driver
<6>[ 1.274374] usbcore: registered new interface driver rtk_btusb
<4>[ 1.277749] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 1.277936] cpuidle: using governor ladder
<6>[ 1.277949] cpuidle: using governor menu
<6>[ 1.277993] Synopsys Designware Multimedia Card Interface Driver
<6>[ 1.278005] MHSC version = Ver 2.00 2015-06-10
<4>[ 1.278303] dw cru_regsbase addr 0x1d8.
<4>[ 1.278316] dw cru_reset_offset val 3.
<6>[ 1.278331] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<3>[ 1.278374] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.278691] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 1.278859] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<7>[ 1.278888] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.278984] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.292895] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.312603] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 1.312626] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 1.312645] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<4>[ 1.312973] dw cru_regsbase addr 0x1d8.
<4>[ 1.312986] dw cru_reset_offset val 0.
<6>[ 1.313000] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<3>[ 1.313043] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.313300] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 1.313468] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
<7>[ 1.313498] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.314270] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 1.314362] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 1.332250] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.351953] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 1.351966] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<4>[ 1.352245] dw cru_regsbase addr 0x1d8.
<4>[ 1.352253] dw cru_reset_offset val 1.
<6>[ 1.352263] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<3>[ 1.352289] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.352467] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 1.352587] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<7>[ 1.352605] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.352834] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.364365] mmc0: BKOPS_EN bit is not set
<4>[ 1.366225] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
<6>[ 1.368498] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
<4>[ 1.368523] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<6>[ 1.368544] [mmc0] tuning regsbase addr 0x218.
<3>[ 1.369223] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 1.369233] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 1.369263] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
<3>[ 1.369288] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
<3>[ 1.369297] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 1.369328] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
<3>[ 1.369467] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-214 (20 len)
<3>[ 1.369479] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 248-282 (4 len)
<3>[ 1.369490] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-214 (20 len)
<3>[ 1.369500] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 113
<6>[ 1.369544] mmc0: new HS200 MMC card at address 0001
<6>[ 1.369805] mmcblk0: mmc0:0001 008GE0 7.28 GiB
<6>[ 1.370127] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 1.370140] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 1.370149] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 1.370158] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 1.370167] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 1.370175] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 1.370184] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 1.370193] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 1.370201] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 1.370209] system: 0x012400000 – 0x072400000 (1536 MB)
<6>[ 1.370218] metadata: 0x072400000 – 0x073400000 (16 MB)
<6>[ 1.370227] baseparamer: 0x073400000 – 0x073800000 (4 MB)
<6>[ 1.370235] userdata: 0x073800000 – 0x0b3800000 (1024 MB)
<6>[ 1.370243] radical_update: 0x0b3800000 – 0x0b7800000 (64 MB)
<6>[ 1.370252] user: 0x0b7800000 – 0x1d1c00000 (4516 MB)
<4>[ 1.371610] vbus detect**
<4>[ 1.371618] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.370280] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p151358..dw_mci_set_ios: no card. [mmc1]
<4>[ 1.391296] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.391319] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 1.391331] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<4>[ 1.391624] leds-gpio leds.30: pins are not configured from the driver
<7>[ 1.391647] of_get_named_gpio_flags exited with status 257
<7>[ 1.391655] of_get_named_gpio_flags exited with status 258
<7>[ 1.391663] of_get_named_gpio_flags exited with status 257
<7>[ 1.391744] of_get_named_gpio_flags exited with status 258
<6>[ 1.391847] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 1.393343] usbcore: registered new interface driver usbhid
<6>[ 1.393353] usbhid: USB HID core driver
<6>[ 1.393474] ashmem: initialized
<6>[ 1.393579] logger: created 256K log ‘log_main’
<6>[ 1.393668] logger: created 256K log ‘log_events’
<6>[ 1.393771] logger: created 256K log ‘log_radio’
<6>[ 1.393860] logger: created 256K log ‘log_system’
<7>[ 1.394716] of_get_named_gpio_flags exited with status 5
<7>[ 1.394726] of_get_named_gpio_flags exited with status 5
<6>[ 1.394958] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input1
<3>[ 1.395807] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
<3>[ 1.395824] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
<3>[ 1.395835] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
<3>[ 1.395847] ES8323 2-0010: Error applying setting, reverse things back
<7>[ 1.395871] of_get_named_gpio_flags exited with status 10
<7>[ 1.395882] of_get_named_gpio_flags exited with status 239
<4>[ 1.396566] es8323 probe error
<4>[ 1.396583] ES8323: probe of 2-0010 failed with error -11
<6>[ 1.397297] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
<3>[ 1.397790] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.397822] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.397838] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<6>[ 1.398016] u32 classifier
<6>[ 1.398023] Actions configured
<6>[ 1.398035] Netfilter messages via NETLINK v0.30.
<6>[ 1.398102] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 1.398443] ctnetlink v0.93: registering with nfnetlink.
<6>[ 1.398514] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 1.398523] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 1.398809] xt_time: kernel timezone is -0000
<6>[ 1.399025] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.399161] arp_tables: (C) 2002 David S. Miller
<6>[ 1.399200] TCP: cubic registered
<6>[ 1.399207] Initializing XFRM netlink socket
<6>[ 1.399437] NET: Registered protocol family 10
<6>[ 1.399984] mip6: Mobile IPv6
<6>[ 1.400014] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.400141] sit: IPv6 over IPv4 tunneling driver
<6>[ 1.400475] NET: Registered protocol family 17
<6>[ 1.400506] NET: Registered protocol family 15
<5>[ 1.400563] Bridge firewalling registered
<6>[ 1.400576] Ebtables v2.0 registered
<6>[ 1.400732] Bluetooth: RFCOMM TTY layer initialized
<6>[ 1.400759] Bluetooth: RFCOMM socket layer initialized
<6>[ 1.400768] Bluetooth: RFCOMM ver 1.11
<6>[ 1.400776] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 1.400783] Bluetooth: BNEP filters: protocol multicast
<6>[ 1.400795] Bluetooth: BNEP socket layer initialized
<6>[ 1.400803] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 1.400816] Bluetooth: HIDP socket layer initialized
<6>[ 1.400846] l2tp_core: L2TP core driver, V2.0
<6>[ 1.400861] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 1.400869] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 1.401080] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 1.401096] [WLAN_RFKILL]: can’t find rockchip,grf property
<6>[ 1.401127] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 1.401138] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 1.401148] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 1.401158] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 1.401174] of_get_named_gpio_flags exited with status 156
<6>[ 1.401181] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 1.401191] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.401198] of_get_named_gpio_flags exited with status 158
<6>[ 1.401205] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 1.401214] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 1.401242] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 1.401252] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 1.401300] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 1.401439] of_get_named_gpio_flags exited with status 147
<6>[ 1.401447] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 1.401458] of_get_named_gpio_flags exited with status 155
<6>[ 1.401466] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
<7>[ 1.401475] of_get_named_gpio_flags exited with status 157
<6>[ 1.401481] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 1.401491] of_get_named_gpio_flags exited with status 154
<6>[ 1.401497] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 1.401506] of_get_named_gpio_flags exited with status 159
<6>[ 1.401512] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 1.401559] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 1.401664] [BT_RFKILL]: ** disable irq
<6>[ 1.401769] [BT_RFKILL]: ap6335 device registered.
<4>[ 1.402594] rk3288_init_suspend
<4>[ 1.402606] rk3288_suspend_init enter
<4>[ 1.402806] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 1.402839] gpio_get_dts_info suspend:4
<4>[ 1.402847] gpio_get_dts_info resume:4
<4>[ 1.402854] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.402886] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.403042] clks_gating_suspend_init:clkgt info ok
<5>[ 1.403145] Registering SWP/SWPB emulation handler
<6>[ 1.403159] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
<6>[ 1.406513] ddrfreq: verion 1.2 20140526
<6>[ 1.406530] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
<6>[ 1.406541] ddrfreq: auto-freq=0
<6>[ 1.406549] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 1.406556] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 1.406564] ddrfreq: auto-freq-table[2] 456MHz
<6>[ 1.406570] ddrfreq: auto-freq-table[3] 528MHz
<6>[ 1.418576] regulator-dummy: disabling
<7>[ 1.418777] of_get_named_gpio_flags exited with status 225
<3>[ 1.418840] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.418849] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 1.418866] platform backlight.20: Driver pwm-backlight requests probe deferral
<3>[ 1.419160] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.419183] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.419194] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<4>[ 1.419224] =======================================================
<4>[ 1.419232] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 1.419238] =======================================================
<4>[ 1.419244] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
<4>[ 1.419301] dhd_module_init: in
<4>[ 1.419308] ======== bcm_wlan_set_plat_data ========
<6>[ 1.419314] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
<4>[ 1.419334] host_oob_irq: 195
<4>[ 1.419339] host_oob_irq_flags=4
<4>[ 1.419344] dhd_wifi_platform_load: Enter
<4>[ 1.419359] Power-up adapter ‘DHD generic adapter’
<4>[ 1.419364] pcd_pullup, is_on 0
<4>[ 1.419387] wifi_platform_set_power = 1
<4>[ 1.419392] ======== PULL WL_REG_ON HIGH! ========
<6>[ 1.419398] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 1.419401] file system registered
<6>[ 1.419409] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 1.419415] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 1.419956] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 1.419964] android_usb gadget: Number of LUNs=2
<6>[ 1.419972] lun0: LUN: removable file: (no medium)
<6>[ 1.419979] lun1: LUN: removable file: (no medium)
<6>[ 1.420117] android_usb gadget: android_usb ready
<6>[ 1.420208] sensor_init: Probe name sensors
<4>[ 1.420225] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 1.420757] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:59:42 UTC (1293886782)
<6>[ 1.427095] rockchip-spdif-card rockchip-spdif-card.26: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
<7>[ 1.427550] of_get_named_gpio_flags exited with status 225
<3>[ 1.427620] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.427629] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 1.427645] platform backlight.20: Driver pwm-backlight requests probe deferral
<6>[ 1.427800] usbcore: registered new interface driver snd-usb-audio
<6>[ 1.427808] ALSA device list:
<6>[ 1.427813] #0: RK-SPDIF-CARD
<3>[ 1.427865] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.427887] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.427899] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<6>[ 1.428177] Freeing unused kernel memory: 356K (c0b90000 - c0be9000)
<6>[ 1.519200] [WLAN_RFKILL]: wifi turn on power. 156
<7>[ 1.539062] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 1.540578] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 1.540595] SELinux: 1 users, 2 roles, 442 types, 0 bools, 1 sens, 1024 cats
<7>[ 1.540603] SELinux: 86 classes, 5368 rules
<7>[ 1.541382] SELinux: Completing initialization.
<7>[ 1.541388] SELinux: Setting up existing superblocks.
<7>[ 1.541403] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 1.541419] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 1.541469] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 1.541479] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 1.541491] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.541505] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 1.541661] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 1.550519] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 1.550533] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 1.550542] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 1.550555] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 1.550572] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 1.550616] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 1.550624] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.550643] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<5>[ 1.630789] type=1403 audit(1293886782.710:2): policy loaded auid=4294967295 ses=4294967295
<11>[ 1.657985] init: invalid gid ‘trace’
<4>[ 1.725851] wifi_platform_bus_enumerate device present 1
<4>[ 1.725869] ======== Card detection to detect SDIO card! ========
<6>[ 1.725889] mmc2:mmc host rescan start!
<11>[ 1.756574] init: /dev/hw_random not found
<6>[ 1.756644] keychord: using input dev ff680000.pwm for fevent
<6>[ 1.756660] keychord: using input dev rk29-keypad for fevent
<7>[ 1.757141] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 1.757407] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.757688] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 1.758958] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.759114] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.760349] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 1.761635] init: /dev/hw_random not found
<14>[ 1.762564] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 1.763386] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
<4>[ 1.766016] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
<6>[ 1.770168] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.770196] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 1.770259] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
<14>[ 1.771115] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 1.776058] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.776105] e2fsck: system: clean, 1866/86976 files, 118527/393216 blocks
<6>[ 1.779531] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 1.779556] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 1.779600] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 1.786610] EXT4-fs (mmcblk0p8): recovery complete
<6>[ 1.787090] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 1.787109] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 1.787148] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<4>[ 1.787520] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
<6>[ 1.790980] EXT4-fs (mmcblk0p11): recovery complete
<6>[ 1.790997] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.791014] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 1.791048] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
<14>[ 1.791851] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
<14>[ 1.796191] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.796227] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
<6>[ 1.800038] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 1.800062] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 1.800107] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<14>[ 1.800151] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 1.801063] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
<14>[ 1.801102] fsck.f2fs: fsck.f2fs terminated by exit(255)
<14>[ 1.801358] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 1.801704] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
<6>[ 1.869550] EXT4-fs (mmcblk0p13): recovery complete
<6>[ 1.870036] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.870060] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 1.870120] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 1.871907] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 1.876724] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.876763] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 732/65536 files, 31323/262144 blocks
<6>[ 1.880638] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 1.880663] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 1.880702] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 1.880723] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 i
nstead of f2fs
<7>[ 1.881380] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<6>[ 1.894808] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
<6>[ 1.894893] mali ffa30000.gpu: Continuing without Mali clock control
<4>[ 1.894940] mali pd enabled
<4>[ 1.894953] clk enabled
<4>[ 1.894966] MALI_DVFS_STEP = 4, div_dvfs = 10
<6>[ 1.894977] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
<6>[ 1.894986] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
<6>[ 1.894997] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
<6>[ 1.895007] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
<3>[ 1.895100] turn on mali power
<6>[ 1.895114] kbase_platform_rk_init,register_reboot_notifier
<4>[ 1.895158] hrtimer: interrupt took 11375 ns
<6>[ 1.895259] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<6>[ 1.897487] mali ffa30000.gpu: Probed as mali0
<7>[ 1.897664] of_get_named_gpio_flags exited with status 225
<3>[ 1.897774] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.897792] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 1.897814] platform backlight.20: Driver pwm-backlight requests probe deferral
<3>[ 1.898122] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.898153] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.898170] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<3>[ 1.898492] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 1.899120] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 1.899696] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 1.900459] zram0: detected capacity change from 0 to 533413888
<4>[ 1.942345] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<6>[ 1.946069] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<3>[ 1.977581] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
<4>[ 1.983554] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 1.985084] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<14>[ 1.986356] bat_cap: oldcap path is /sys/devices/ff100000.adc
<11>[ 1.986411] bat_cap: oldcap_path no exist
<6>[ 1.986566] binder: 152:152 transaction failed 29189, size 0-0
<4>[ 1.986656] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<11>[ 1.987117] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<4>[ 1.989453] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<11>[ 1.990965] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 1.990996] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 1.991243] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 1.991793] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.991810] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.991827] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.991838] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.991859] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.991869] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.991885] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.991894] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<11>[ 2.017007] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 2.018632] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 2.019101] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 2.019329] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<11>[ 2.019581] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
<6>[ 2.032179] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 2.032204] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 2.032269] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
<6>[ 2.033507] mmc2: new high speed SDIO card at address 0001
<7>[ 2.034066] of_get_named_gpio_flags exited with status 225
<3>[ 2.034190] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 2.034200] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 2.034217] platform backlight.20: Driver pwm-backlight requests probe deferral
<3>[ 2.034469] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 2.034492] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 2.034505] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<4>[ 2.049845] bcmsdh_register: register client driver
<4>[ 2.049959] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 2.050041] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 2.050050] bus num (host idx)=2, slot num (rca)=1
<4>[ 2.050056] found adapter info ‘DHD generic adapter’
<7>[ 2.050106] of_get_named_gpio_flags exited with status 225
<3>[ 2.050204] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 2.050214] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 2.050231] platform backlight.20: Driver pwm-backlight requests probe deferral
<4>[ 2.050291] F1 signature read @0x18000000=0x16044330
<3>[ 2.050484] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 2.050508] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 2.050521] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<4>[ 2.052075] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
<4>[ 2.052343] DHD: dongle ram size is set to 294912(orig 294912) at 0x0
<4>[ 2.052491] wifi_platform_get_mac_addr
<4>[ 2.052498] ======== bcm_wlan_get_mac_address ========
<6>[ 2.052505] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 2.052514] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 2.052521] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 2.052530] dhd_conf_set_chiprev: chip=0x4330, chiprev=4
<4>[ 2.052572] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<4>[ 2.052894] wl_create_event_handler(): thread:wl_event_handler:a8 started
<4>[ 2.052900] tsk Enter, tsk = 0xdd70149c
<4>[ 2.053038] dhd_attach(): thread:dhd_watchdog_thread:a9 started
<4>[ 2.053086] dhd_attach(): thread:dhd_dpc:aa started
<4>[ 2.053098] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
<4>[ 2.053142] dhd_attach(): thread:dhd_rxf:ab started
<4>[ 2.053152] dhd_deferred_work_init: work queue initialized
<4>[ 2.053222] dhdsdio_probe_init: set use_rxchain 0 from config.txt
<4>[ 2.058728] Dongle Host Driver, version 1.201.59.5 (r506368)
<4>[ 2.058728] Compiled in drivers/net/wireless/bcmdhd on Mar 11 2016 at 10:21:32
<4>[ 2.059082] Register interface [wlan0] MAC: e0:76:d0:3b:bd:31
<4>[ 2.059082]
<4>[ 2.059095] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 2.059133] bcmsdh_oob_intr_unregister: Enter
<4>[ 2.059140] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 2.059150] dhd_txglom_enable: enable 0
<4>[ 2.059156] dhd_bus_devreset: WLAN OFF DONE
<4>[ 2.059188] wifi_platform_set_power = 0
<4>[ 2.059194] ======== PULL WL_REG_ON LOW! ========
<6>[ 2.059200] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 2.158802] [WLAN_RFKILL]: wifi shut off power.
<6>[ 2.158814] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 2.158820] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 2.158872] dhd_module_init: Exit err=0
<7>[ 2.159016] of_get_named_gpio_flags exited with status 225
<3>[ 2.159112] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 2.159121] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 2.159136] platform backlight.20: Driver pwm-backlight requests probe deferral
<3>[ 2.159351] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 2.159375] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 2.159386] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<38>[ 2.212283] logd.auditd: start
<7>[ 2.231043] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<6>[ 2.759050] EHCI: rk_ehci_hcd_enable, disable host controller
<7>[ 2.831841] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<3>[ 2.832824] android_usb: already disabled
<6>[ 2.835128] read descriptors
<6>[ 2.835141] read strings
<4>[ 2.835167] pcd_pullup, is_on 1
<4>[ 2.857455] dwc_otg_hcd_enable, enable host controller
<11>[ 2.971180] healthd: No charger supplies found
<12>[ 2.971193] healthd: No battery devices found
<4>[ 2.990398] Using Buffer DMA mode
<4>[ 2.990410] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 2.990416] Multiprocessor Interrupt Enhancement - disabled
<4>[ 2.990423] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 2.990429] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 3.034645] Init: Power Port (0)
<4>[ 3.034684] ff540000.usb resume, HPRT0:0x21401
<4>[ 3.172368] Indeed it is in host mode hprt0 = 00021501
<6>[ 3.186548] rk3288-lcdc lcdc0: blank mode:0
<4>[ 3.339625] soft reconnect
<6>[ 3.349463] usb 3-1: new high-speed USB device number 2 using usb20_host
<4>[ 3.349533] Indeed it is in host mode hprt0 = 00001101
<4>[ 3.518850] Using Buffer DMA mode
<4>[ 3.518863] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.518870] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.518876] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.518881] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 3.518921] soft connect!!!
<6>[ 3.546488] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
<6>[ 3.546500] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 3.546507] usb 3-1: Product: USB 2.0 Hub
<6>[ 3.547046] hub 3-1:1.0: USB hub found
<6>[ 3.547112] hub 3-1:1.0: 4 ports detected
<7>[ 3.547531] of_get_named_gpio_flags exited with status 225
<3>[ 3.547629] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 3.547638] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 3.547653] platform backlight.20: Driver pwm-backlight requests probe deferral
<3>[ 3.547860] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 3.547881] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 3.547892] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<4>[ 3.688992] USB RESET
<6>[ 3.754589] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 3.758130] USB RESET
<6>[ 3.841602] android_usb gadget: high-speed config #1: android
<6>[ 3.841682] usb 3-1.4: new low-speed USB device number 3 using usb20_host
<6>[ 3.841731] android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 3.963992] usb 3-1.4: New USB device found, idVendor=1d57, idProduct=0008
<6>[ 3.964004] usb 3-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 3.964011] usb 3-1.4: Product: 2.4G Wireless Optical Mouse
<6>[ 3.967217] input: 2.4G Wireless Optical Mouse as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.0/input/input2
<6>[ 3.967475] hid-generic 0003:1D57:0008.0001: input,hidraw0: USB HID v1.10 Mouse [2.4G Wireless Optical Mouse] on usb-ff540000.usb-1.4/inpu
t0
<7>[ 3.967635] of_get_named_gpio_flags exited with status 225
<3>[ 3.967736] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 3.967749] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 3.967764] platform backlight.20: Driver pwm-backlight requests probe deferral
<3>[ 3.968001] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 3.968023] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 3.968033] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<4>[ 4.263237] USB RESET
<4>[ 4.328880] USB RESET
<6>[ 4.408163] android_usb gadget: high-speed config #1: android
<6>[ 4.408289] android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 4.474038] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
<4>[ 4.479487] USB RESET
<4>[ 4.545342] USB RESET
<6>[ 4.624470] android_usb gadget: high-speed config #1: android
<6>[ 4.624589] android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 4.730831] android_usb gadget: high-speed config #1: android
<6>[ 4.730972] android_work: sent uevent USB_STATE=CONFIGURED
<4>[ 5.651514] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.651526] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.651534] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 5.651613] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 5.651624] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 5.651635] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 5.651651] of_get_named_gpio_flags exited with status 237
<7>[ 5.651655] of_get_named_gpio_flags exited with status 237
<4>[ 5.651660] rockchip_gpio_request:GPIO7-13
<4>[ 5.651670] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 5.651675] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 5.651682] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 5.651691] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7602,result=0x7602
<4>[ 5.651698] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 5.651717] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 5.656755] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 5.656766] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 5.656870] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 5.656896] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 5.657960] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 5.659024] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 5.660080] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 5.858665] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 5.858681] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 6.055456] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 6.055472] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 6.055569] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 6.055580] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 6.055592] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 6.056686] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 6.056719] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 6.058772] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 6.058786] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 6.058795] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 6.058801] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 6.058807] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<4>[ 6.065856] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 6.065867] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 6.065874] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 6.065968] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 6.065980] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 6.065990] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 6.065998] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 6.066085] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 6.071145] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 6.071157] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 6.071261] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 6.071287] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 6.072358] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 6.073426] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 6.074486] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<3>[ 6.271956] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 6.271971] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 6.272060] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 6.272072] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 6.272083] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 6.273173] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 6.273223] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 6.275282] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 6.275296] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 6.275306] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 6.275312] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 6.275319] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<4>[ 6.277036] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 6.277046] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 6.277053] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 6.277115] D1:camsys_extdev_register(243): Get RK30_PIN7_PA5(229) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 6.277128] D1:camsys_extdev_register(243): Get RK30_PIN8_PB0(264) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 6.277140] D1:camsys_extdev_register(243): Get RK30_PIN7_PC5(245) gpio(active: 1) for dev_id 0x1000000 success!
<4>[ 6.277147] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 6.277171] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 6.282212] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 6.282236] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 6.282341] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 6.282368] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<4>[ 6.283435] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(245) set 1
<4>[ 6.284517] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(264) set 1
<4>[ 6.285590] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(229) set 1
<3>[ 6.289102] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 6.290592] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<4>[ 6.290701] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(229) set 0
<4>[ 6.290716] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(264) set 0
<4>[ 6.290726] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(245) set 0
<4>[ 6.291826] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 6.291863] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 6.293936] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 6.293955] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 6.293966] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 6.293972] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 6.293978] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<38>[ 6.296100] type=1400 audit(1293886787.450:3): avc: denied { execute } for pid=503 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=317
scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 6.296312] type=1400 audit(1293886787.450:4): avc: denied { read open } for pid=503 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk
0p10” ino=317 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 6.296429] type=1400 audit(1293886787.450:5): avc: denied { execute_no_trans } for pid=503 comm=“mediaserver” path=“/system/bin/sh” dev=
“mmcblk0p10” ino=317 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 6.298238] type=1400 audit(1293886787.450:6): avc: denied { getattr } for pid=503 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10”
ino=330 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 6.298384] type=1400 audit(1293886787.450:7): avc: denied { execute } for pid=503 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=330 scon
<38>[ 6.298457] type=1400 audit(1293886787.450:8): avc: denied { read open } for pid=503 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10
" ino=330 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 6.298536] type=1400 audit(1293886787.450:9): avc: denied { execute_no_trans } for pid=503 comm=“sh” path=”/system/bin/toolbox" dev=“mmc
blk0p10” ino=330 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<12>[ 7.229424] healthd: battery none chg=
<6>[ 7.409166] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 7.409179] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 7.409185] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 7.409190] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 7.409195] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 7.409200] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 7.409205] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 7.753387] acc_open
<6>[ 7.753418] acc_release
<4>[ 7.869738] phy_power_on: enable = 1
<4>[ 7.909141] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 7.909182] eth0: device MAC address b6:e4:2a:d0:99:46
<6>[ 7.913293] libphy: stmmac: probed
<6>[ 7.913305] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
<6>[ 7.913313] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
<7>[ 7.913525] of_get_named_gpio_flags exited with status 225
<3>[ 7.913631] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 7.913641] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 7.913658] platform backlight.20: Driver pwm-backlight requests probe deferral
<3>[ 7.913936] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 7.913961] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 7.913974] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<4>[ 8.242648] dwc_otg_hcd_resume, usb device mode
<4>[ 8.242858] dwc_otg_hcd_suspend, usb device mode
<4>[ 8.634552] FAT-fs (mmcblk0p15): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 8.634605] SELinux: initialized (dev mmcblk0p15, type vfat), uses genfs_contexts
<11>[ 8.667758] init: no such service ‘fuse_internal_sd’
<6>[ 8.672900] [otg id chg] last id -1 current id 1
<6>[ 8.794608] pm policy 0 → 1
<38>[ 9.230987] type=1400 audit(1293886790.430:10): avc: denied { write } for pid=836 comm=“droid.launcher3” name=“property_service” dev=“tmp
fs” ino=8491 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_file permissive=1
<38>[ 9.231167] type=1400 audit(1293886790.430:11): avc: denied { connectto } for pid=836 comm=“droid.launcher3” path=“/dev/socket/property_s
ervice” scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
<12>[ 9.231445] avc: denied { set } for property=persist.sys.default_launcher scontext=u:r:untrusted_app:s0 tcontext=u:object_r:system_prop
:s0 tclass=property_service
<4>[ 10.109610] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.109634] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.109644] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 10.109723] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 10.109737] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 10.109750] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 10.109768] of_get_named_gpio_flags exited with status 237
<7>[ 10.109775] of_get_named_gpio_flags exited with status 237
<7>[ 10.109781] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 10.109789] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 10.109796] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 10.109806] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 10.109816] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207622,result=0x207622
<4>[ 10.109825] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 10.109847] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 10.114921] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.114937] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.115044] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.115077] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 10.116149] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 10.117212] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 10.118273] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 10.316165] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 10.316187] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 10.512975] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 10.512998] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 10.513084] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 10.513098] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 10.513111] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 10.514201] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.514235] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.516284] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 10.516298] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.516309] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.516317] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.516325] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<4>[ 10.517519] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.517530] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.517539] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 10.517631] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 10.517646] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 10.517658] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 10.517668] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 10.517765] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 10.522842] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.522854] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.522959] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.522989] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 10.524067] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 10.525151] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 10.526259] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<38>[ 10.676871] type=1400 audit(1293886791.900:12): avc: denied { write } for pid=1022 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysf
s” ino=12455 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
<4>[ 10.677160] force_usb_mode_store 2->1
<3>[ 10.719606] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 10.719620] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 10.719716] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 10.719728] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 10.719739] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 10.720820] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.720847] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.722891] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 10.722903] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.722911] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.722917] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.722923] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<4>[ 10.723544] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.723553] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.723560] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 10.723627] D1:camsys_extdev_register(243): Get RK30_PIN7_PA5(229) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 10.723640] D1:camsys_extdev_register(243): Get RK30_PIN8_PB0(264) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 10.723653] D1:camsys_extdev_register(243): Get RK30_PIN7_PC5(245) gpio(active: 1) for dev_id 0x1000000 success!
<4>[ 10.723660] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 10.723682] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 10.728705] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.728714] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.728818] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.728836] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<4>[ 10.729895] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(245) set 1
<4>[ 10.730948] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(264) set 1
<4>[ 10.732001] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(229) set 1
<3>[ 10.735469] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 10.736912] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<4>[ 10.736965] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(229) set 0
<4>[ 10.736976] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(264) set 0
<4>[ 10.736986] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(245) set 0
<4>[ 10.738057] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.738077] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.740120] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 10.740132] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.740140] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.740146] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.740152] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<4>[ 10.775653] Using Buffer DMA mode
<4>[ 10.775662] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 10.775668] Multiprocessor Interrupt Enhancement - disabled
<4>[ 10.775674] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 10.775679] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 10.775811] android_work: sent uevent USB_STATE=DISCONNECTED
<4>[ 10.818048] Init: Power Port (0)
<4>[ 10.818058] rk_battery_charger_detect_cb , battery_charger_detect 5
<4>[ 10.818089] ff580000.usb resume, HPRT0:0x1000
<4>[ 10.818138] ff580000.usb suspend, HPRT0:0x1000
<4>[ 10.846539] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.846550] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.846557] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 10.846638] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 10.846650] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 10.846660] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 10.846677] of_get_named_gpio_flags exited with status 237
<7>[ 10.846682] of_get_named_gpio_flags exited with status 237
<7>[ 10.846687] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 10.846694] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 10.846699] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 10.846708] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 10.846716] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207622,result=0x207622
<4>[ 10.846723] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 10.846744] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 10.851794] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.851807] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.851912] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.851940] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 10.853025] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 10.854100] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 10.855166] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<4>[ 10.898773] force_usb_mode_store 1->2
<4>[ 10.898788] PortPower off
<4>[ 10.898794] rk_battery_charger_detect_cb , battery_charger_detect 6
<3>[ 11.044325] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 11.044339] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<4>[ 11.096644] Using Buffer DMA mode
<4>[ 11.096650] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 11.096655] Multiprocessor Interrupt Enhancement - disabled
<4>[ 11.096661] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 11.096665] ^^^^^^^^^^^^^^^^^Device Mode
<3>[ 11.241127] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 11.241142] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 11.241225] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 11.241237] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 11.241248] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 11.242328] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 11.242358] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 11.244403] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 11.244416] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 11.244424] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 11.244430] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 11.244436] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<4>[ 11.245476] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 11.245485] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 11.245492] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 11.245572] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 11.245583] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 11.245593] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 11.245601] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 11.245688] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 11.250720] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 11.250729] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 11.250833] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 11.250855] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 11.251915] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 11.252969] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 11.254020] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<4>[ 11.388727] vbus detect**
<4>[ 11.390908] rk_battery_charger_detect_cb , battery_charger_detect 1
<3>[ 11.447766] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 11.447779] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 11.447854] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 11.447866] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 11.447876] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 11.448953] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 11.448982] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 11.451025] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 11.451036] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 11.451045] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 11.451050] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 11.451057] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<4>[ 11.451676] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 11.451685] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 11.451692] D1:camsys_open(739): camsys_marvin(ddf50210) is opened!
<4>[ 11.451751] D1:camsys_extdev_register(243): Get RK30_PIN7_PA5(229) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 11.451764] D1:camsys_extdev_register(243): Get RK30_PIN8_PB0(264) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 11.451776] D1:camsys_extdev_register(243): Get RK30_PIN7_PC5(245) gpio(active: 1) for dev_id 0x1000000 success!
<4>[ 11.451783] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 11.451804] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 11.456826] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 11.456834] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 11.456938] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 11.456955] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<4>[ 11.458013] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(245) set 1
<4>[ 11.459067] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(264) set 1
<4>[ 11.460120] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(229) set 1
<3>[ 11.463591] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 11.465034] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<4>[ 11.465086] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(229) set 0
<4>[ 11.465097] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(264) set 0
<4>[ 11.465107] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(245) set 0
<4>[ 11.466178] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 11.466195] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 11.468239] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 11.468251] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 11.468259] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 11.468266] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 11.468272] D1:camsys_release(763): camsys_marvin(ddf50210) is closed
<4>[ 11.568147] Using Buffer DMA mode
<4>[ 11.568159] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 11.568165] Multiprocessor Interrupt Enhancement - disabled
<4>[ 11.568171] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 11.568176] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 11.568216] soft connect!!!
<4>[ 11.754308] USB RESET
<6>[ 11.823369] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 11.826839] USB RESET
<6>[ 11.910411] android_usb gadget: high-speed config #0: unconfigured
<4>[ 12.314454] USB RESET
<4>[ 12.391022] USB RESET
<4>[ 12.482354] force_usb_mode_store 2->1
<4>[ 12.580849] Using Buffer DMA mode
<4>[ 12.580874] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 12.580885] Multiprocessor Interrupt Enhancement - disabled
<4>[ 12.580897] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 12.580906] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 12.581366] android_work: sent uevent USB_STATE=DISCONNECTED
<4>[ 12.628630] Init: Power Port (0)
<4>[ 12.628651] rk_battery_charger_detect_cb , battery_charger_detect 5
<4>[ 12.628691] ff580000.usb resume, HPRT0:0x1000
<4>[ 12.628764] ff580000.usb suspend, HPRT0:0x1000
<4>[ 14.707790] force_usb_mode_store 1->2
<4>[ 14.707840] PortPower off
<4>[ 14.707857] rk_battery_charger_detect_cb , battery_charger_detect 6
<4>[ 14.905724] Using Buffer DMA mode
<4>[ 14.905759] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 14.905775] Multiprocessor Interrupt Enhancement - disabled
<4>[ 14.905790] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 14.905804] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 15.197005] vbus detect**
<4>[ 15.199294] rk_battery_charger_detect_cb , battery_charger_detect 1
<4>[ 15.376171] Using Buffer DMA mode
<4>[ 15.376197] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 15.376206] Multiprocessor Interrupt Enhancement - disabled
<4>[ 15.376216] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 15.376224] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 15.376268] soft connect!!!
<4>[ 15.532915] USB RESET
<6>[ 15.602253] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 15.605436] USB RESET
<6>[ 15.685639] android_usb gadget: high-speed config #0: unconfigured
<4>[ 16.090799] USB RESET
<4>[ 16.156457] USB RESET
<4>[ 16.307120] USB RESET
<4>[ 16.373071] USB RESET
<6>[ 17.797850] android_usb gadget: high-speed config #1: android
<6>[ 17.799810] android_work: sent uevent USB_STATE=CONFIGURED
shell@firefly:/ #
屏没显示主要有几个方面,要一一排除:
1、各路电源上电时序是否是对
2、行场信号参数是否匹配
3、主控输出的数据是否匹配
你那个屏应该是双8的吧
双8?
lvds-format = <LVDS_8BIT_2>;
我改了这个也没行啊?
你把屏的规格书给我看看
rockchip,mirror = <NO_MIRROR>;这里改下,看看
根据这个:http://developer.t-firefly.com/thread-945-1-1.html 搞好了
关键是要有: screen-type = <SCREEN_DUAL_LVDS>;
感谢大家提示!
