主从模式的建立连接和发送数据问题
把论坛的帖子都看了一遍,还是不太能看懂。如何通过主机写mac地址数据连接从机
主机发起对从设备的链接请求的api可以在app_gap.c中找到:
 * @brief Create connection with the remote BLE device.        *//**
 * @param[in] addr The address of the remote device to which the connection will be created
 * @param[in] addr_type The address type of the remote device, possible values are:
 * - ADDR_PUBLIC
 * - ADDR_RAND
 * @param[in] own_addr_type Own address type, possible values are:
 * - ADDR_PUBLIC
 * - ADDR_RAND
 * @param[in] conn_intv_min  Minimum of connection interval
 * @param[in] conn_intv_max  Maximum of connection interval
 * @param[in] cnnn_timeout   Link supervision timeout
 * @response  GAP_LE_CREATE_CONN_REQ_CMP_EVT
 * @description
 * This function is used to create a Link Layer connection to a connectable device.
 * This is initiated by central device, which will become the master of the link.
#if (BLE_CENTRAL)
void app_gap_le_create_conn_req(struct bd_addr *addr, uint8_t addr_type, uint8_t own_addr_type,
                                uint16_t conn_intv_min, uint16_t conn_intv_max, uint16_t cnnn_timeout)
其中参数1为从机的广播地址,也就是楼主所说的mac地址,实际上的协议栈里面并没有通过MAC连接从机的api,只有bd_addr,这个地址是固化在NVDS中的。第二个参数是地址类型,共有* - ADDR_PUBLIC &* - ADDR_RAND 两个选项,既然你要制定bd addr,那么必须是ADDR_PUBLIC 。第三个是自身的地址,也是ADDR_PUBLIC 。接下来三个参数都是连接间隔时间参数。设置好之后如果该BD addr的设备有在广播的话,那么应该是可以连接得上的。
