📚 Salesforce MKT-101 Dumps - Study Guide and Key Topics
Type: Official Firmware
Filename: Salesforce MKT-101 Dumps - Study Guide and Key Top
Download Address: nathanontario1@gmail.com
Log: Exam_stress_girl.zip
What is MKT-101 Dumps?
The [b]MKT-101 Dumps[/b] is officially called:
:white_check_mark: Build and Analyze Customer Journeys using Marketing Cloud
It’s part of the Salesforce Marketing Cloud learning path, helping you prove your ability to:
  • Design customer journeys
  • Use Marketing Cloud tools (Email Studio, Journey Builder, Contact Builder, etc.)
  • Analyze and optimize journeys and campaigns
:memo: MKT-101 Exam Overview
Item
Details
Exam Code
MKT-101
Exam Name
Number of Questions
60 (plus 5 unscored)
Time Limit
105 minutes
Passing Score
65%
Format
Multiple Choice/Multiple Select
:fire: Important Topics You MUST Master1. Journey Builder
  • Journey Builder setup and configuration
  • Entry Sources (data extension, Salesforce events)
  • Journey activities (email, SMS, update contact, wait times)
  • Contact Evaluation and Contact Entry modes
2. Email Studio
  • Create/send marketing emails
  • A/B testing
  • Send classifications
  • Personalization strings
3. Automation Studio
  • Setting up automations
  • SQL queries
  • Schedules and triggers
  • Data extract, file transfer activities
4. Contact Builder
  • Data extensions (standard, filtered, synchronized)
  • Attribute groups
  • Subscriber keys
  • Relationships between data objects
5. Analytics & Reporting
  • Tracking reports
  • Journey analytics
  • Email reporting (e.g., open rates, click-through rates)
  • Email send logs
:brain: Study Strategy:white_check_mark: Master Journey Builder First: 35-40% of the exam touches Journey Builder.
:white_check_mark: Understand Data Models: Contact Builder questions trip people up!
:white_check_mark: Practice Automations: Know how to schedule imports, queries, and triggers.
:white_check_mark: Know Metrics: What does a 20% open rate mean? Be ready for reporting questions.
:white_check_mark: Scenario Thinking: Most questions present a business scenario. Choose the best approach, not just “what’s possible.”
:hammer_and_wrench: Sample MKT-101 Practice QuestionsHere are 5 free sample questions I made for you (not dumps — my own based on the exam guide):
Question 1:
A marketer wants to send a welcome email to new subscribers immediately after signup. Which Journey Builder entry source should they use?
:white_check_mark: A) API Event
B) Salesforce Data Event
C) CloudPages Form Submit
D) File Drop
Question 2:
In Marketing Cloud, which field ensures that a subscriber is uniquely identified across multiple channels?
A) Email Address
:white_check_mark: B) Subscriber Key
C) Contact ID
D) Subscriber ID
Question 3:
Which activity in Journey Builder is used to update a field in a data extension when a contact moves through the journey?
A) Decision Split
:white_check_mark: B) Update Contact Activity
C) Wait Activity
D) Random Split
Question 4:
A marketer wants to determine which email subject line performs better. Which feature should they use?
A) Send Throttle
:white_check_mark: B) A/B Test
C) Delivery Profile
D) Test Send
Question 5:
What is the correct order to configure an import automation?
A) SQL Activity > Data Extract > File Transfer
B) Data Extract > File Transfer > SQL Activity
:white_check_mark: C) File Transfer > Data Extract > Import File
D) Import File > File Transfer > Data Extract
:bullseye: Final Tips
  • Spend extra time on Journey Builder and Contact Builder!
  • Know the difference between Subscribers and Contacts.
  • Understand entry events vs automation triggers.
  • Practice building real journeys if possible (even in a free dev environment).
  • Relax — most questions give you clues if you read carefully.
Exam_stress_girl.zip (94.2 KB)
By reading this article, I have gained a deeper understanding of this field. Here’s the free L4M6 hottest certification resource—wishing you success!
This article is truly awe-inspiring, thank you for sharing! Good luck on your exam! Here are the free Free Mule-Dev-202 exam questions resources.
