[hr]I have followed this guide for Firefly SDK Buildroot and I am unable to get the shell on uart2 or fiq-debugger port.
I have checked multiple blogs, tickets, and forums, and edited .dts and .dtsi to:
Disable fiq-debugger and use uart2 as shell
Disable uart2 and enable fiq-debugger (default file mode)
Route fiq-debugger to uart 0x00 by editing serial ID and other configs to use uart2 (ttyS2)
…but I failed to get shell access.
I am a beginner in this, so I apologize in advance as I feel there might be a small issue I am unable to identify.
Here are the relevant files/content:
DDR V1.18 f366f69a7d typ 23/07/17-15:48:58
ln
LP4/4x derate en, other dram:1x trefi
ddrconfig:0
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
tdqss: cs0 dqs0: -24ps, dqs1: -72ps, dqs2: -72ps, dqs3: -120ps,
change to: 324MHz
clk skew:0x62
change to: 528MHz
clk skew:0x58
change to: 780MHz
clk skew:0x58
change to: 1056MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x39
cs 0:
the read training result:
DQS0:0x3d, DQS1:0x40, DQS2:0x3d, DQS3:0x3c,
min : 0x3 0x4 0x3 0x1 0x4 0x2 0x3 0x2 , 0x2 0x6 0x6 0x6 0x1 0x4 0x9 0x5 ,
0x4 0x1 0x4 0x4 0x4 0x3 0x4 0x2 , 0x2 0x1 0x2 0x2 0x2 0x2 0x5 0x1 ,
mid :0x22 0x23 0x22 0x21 0x24 0x21 0x21 0x22 ,0x22 0x26 0x26 0x26 0x21 0x25 0x28 0x24 ,
0x24 0x21 0x23 0x22 0x22 0x23 0x23 0x22 ,0x22 0x20 0x21 0x20 0x21 0x20 0x25 0x21 ,
max :0x41 0x42 0x41 0x41 0x44 0x40 0x40 0x43 ,0x42 0x47 0x46 0x46 0x42 0x46 0x47 0x44 ,
0x44 0x41 0x42 0x41 0x41 0x43 0x42 0x43 ,0x42 0x3f 0x41 0x3e 0x41 0x3f 0x45 0x41 ,
range:0x3e 0x3e 0x3e 0x40 0x40 0x3e 0x3d 0x41 ,0x40 0x41 0x40 0x40 0x41 0x42 0x3e 0x3f ,
0x40 0x40 0x3e 0x3d 0x3d 0x40 0x3e 0x41 ,0x40 0x3e 0x3f 0x3c 0x3f 0x3d 0x40 0x40 ,
the write training result:
DQS0:0x36, DQS1:0x30, DQS2:0x30, DQS3:0x29,
min :0x50 0x54 0x53 0x52 0x52 0x51 0x52 0x54 0x52 ,0x48 0x4c 0x4b 0x4c 0x4a 0x4d 0x4d 0x4d 0x4a ,
0x4a 0x49 0x4c 0x4b 0x4b 0x4b 0x4b 0x4c 0x4a ,0x42 0x44 0x43 0x44 0x44 0x43 0x46 0x45 0x43 ,
mid :0x6d 0x70 0x70 0x6e 0x6f 0x6d 0x6e 0x70 0x6d ,0x64 0x67 0x67 0x68 0x66 0x68 0x68 0x68 0x65 ,
0x67 0x66 0x68 0x68 0x67 0x67 0x67 0x67 0x67 ,0x5e 0x5f 0x5e 0x60 0x5f 0x5f 0x63 0x60 0x5f ,
max :0x8a 0x8d 0x8d 0x8a 0x8c 0x8a 0x8a 0x8d 0x89 ,0x81 0x82 0x83 0x84 0x82 0x83 0x83 0x83 0x80 ,
0x84 0x84 0x84 0x85 0x83 0x83 0x83 0x83 0x85 ,0x7a 0x7a 0x79 0x7c 0x7b 0x7b 0x80 0x7b 0x7b ,
range:0x3a 0x39 0x3a 0x38 0x3a 0x39 0x38 0x39 0x37 ,0x39 0x36 0x38 0x38 0x38 0x36 0x36 0x36 0x36 ,
0x3a 0x3b 0x38 0x3a 0x38 0x38 0x38 0x37 0x3b ,0x38 0x36 0x36 0x38 0x37 0x38 0x3a 0x36 0x38 ,
CA Training result:
cs:0 min :0x4b 0x45 0x4a 0x3f 0x4a 0x40 0x47 ,0x48 0x3f 0x46 0x40 0x49 0x3b 0x48 ,
cs:0 mid :0x86 0x88 0x84 0x83 0x84 0x83 0x72 ,0x83 0x83 0x82 0x82 0x82 0x7e 0x72 ,
cs:0 max :0xc1 0xcb 0xbf 0xc7 0xbf 0xc6 0x9d ,0xbf 0xc7 0xbe 0xc5 0xbc 0xc2 0x9d ,
cs:0 range:0x76 0x86 0x75 0x88 0x75 0x86 0x56 ,0x77 0x88 0x78 0x85 0x73 0x87 0x55 ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-ge4e124926e-230922 #lxh (Sep 25 2023 - 11:07:45), fwver: v1.13
unknown raw ID 0 0 0
Trying to boot from MMC2
mmc_init: -95, time 9
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(b5946ac63d...) + OK
## Checking uboot 0x00a00000 ... sha256(e6faaa00e4...) + OK
## Checking fdt 0x00b47be8 ... sha256(b3854af6ad...) + OK
## Checking atf-2 0xfdcc1000 ... sha256(b8dca786b4...) + OK
## Checking atf-3 0x0006b000 ... sha256(2f91089eb7...) + OK
## Checking atf-4 0xfdcce000 ... sha256(86ef885748...) + OK
## Checking atf-5 0xfdcd0000 ... sha256(0b2b146c60...) + OK
## Checking atf-6 0x00069000 ... sha256(a9a1e63bef...) + OK
## Checking optee 0x08400000 ... sha256(28fba8b7d7...) + OK
Total: 126.587/185.741 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-645-g8cea6ab0b:cl, fwver: v1.44
NOTICE: BL31: Built : 16:36:43, Sep 19 2023
INFO: pmu v1 is valid 220114
INFO: l3 cache partition cfg-0
INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-791-g185dc3c92 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Tue Apr 16 10:47:32 CST 2024 aarch64, fwver: v2.12
I/TC: OP-TEE memory: TEEOS 0x200000 TA 0xc00000 SHM 0x200000
I/TC: CRYPTO_CRYPTO_VERSION_NEW no support. Skip all algo mode check.
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: 30d6e6f55d2b943c0910c3f69ccf4d302272ee71)(sdk version: rk356x_linux5.10_release_20241220_v1.4.0c.xml)-g30d6e6f55d-231220 #nehaldev (Jul 22 2025 - 10:30:06 -0700)
Model: Rockchip RK3568 Evaluation Board
MPIDR: 0x81000000
PreSerial: 2, raw, 0xfe660000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7d217000
Relocation fdt: 7b9f88c8 - 7b9fece0
CR: M/C/I
optee api revision: 2.0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v1
=================begin===================
106508 bytes read in 7 ms (14.5 MiB/s)
DTB(Distro): rk-kernel.dtb
boot mode: recovery (misc)
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu 643750 uV
PMIC: RK8090 (on=0x10, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
INFO: ddr dmc_fsp already initialized in loader.
Model: AIO-3566JD4 HDMI(Linux)
MPIDR: 0x81000000
RESC: 'recovery', blk@0x0005eae7
resource: sha256+
VOP have 3 active VP
ERROR: rk3566 only support 2 display output!!
vp0 have layer nr:3[0 2 4 ], primary plane: 4
vp1 have layer nr:2[1 5 ], primary plane: 5
vp2 have layer nr:1[3 ], primary plane: 3
hdmi@fe0a0000 disconnected
No FDT memory address configured. Default at 0x08300000
apll 1104000 KHz
dpll 528000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 1104000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000
Hit key to stop autoboot('CTRL+C'): 0
ANDROID: reboot reason: "recovery"
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image at 0x78e9aa80 with size 0x0295ce00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 78e9aa80 ...
Using 'conf' configuration
## Verified-boot: 0
Trying 'kernel' kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x78eb5480
Data Size: 36561408 Bytes = 34.9 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00280000
Entry Point: 0x00280000
Hash algo: sha256
Hash value: b12af2b2485d11ed5f9706dfad4788a4776d010e9614a3d4f863a0151e596709
Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 78e9aa80 ...
Trying 'ramdisk' ramdisk subimage
Type: RAMDisk Image
Data Start: 0x7b193680
Data Size: 6701181 Bytes = 6.4 MiB
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 53fdec76a15dedc516f33c96b7a9ca26f7c75d65af1267d6b92b3d79f48234eb
Loading ramdisk from 0x7b193680 to 0x0a200000
## Loading fdt from FIT Image at 78e9aa80 ...
Trying 'fdt' fdt subimage
Type: Flat Device Tree
Data Start: 0x78e9b280
Data Size: 106508 Bytes = 104 KiB
Load Address: 0x08300000
Hash algo: sha256
Hash value: 0bb2879bdb23b63bb09a009f2c2321a762c220b3d3b15bfac7d4debae95bc47e
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0x78eb5480 to 0x00280000 ... OK
kernel loaded at 0x00280000, end = 0x0255e200
Using Device Tree in place at 0000000008300000, end 000000000831d00b
vp0, plane_mask:0x15, primary-id:4, curser-id:-1
vp1, plane_mask:0x22, primary-id:5, curser-id:-1
vp2, plane_mask:0x8, primary-id:3, curser-id:-1
## reserved-memory:
drm-logo@00000000: addr=7df00000 size=2e0000
drm-cubic-lut@00000000: addr=7ff00000 size=8000
ramoops@110000: addr=110000 size=f0000
Adding bank: 0x09400000 - 0x80000000 (size: 0x76c00000)
No RNG device
== DO RELOCATE == Kernel from 0x00280000 to 0x00200000
Total: 917.178/965.724 ms
Starting kernel ...
[ 0.970849] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.970873] Linux version 5.10.198 (nehaldev@ubuntu) (firefly: 34d433bc5e75/2507221023) (sdk version: rk356x_linux5.10_release_20241220_v1.4.0c.xml) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #19 SMP Tue Jul 22 10:23:42 PDT 2025
[ 0.975043] Machine model: AIO-3566JD4 HDMI(Linux)
[ 0.975113] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[ 0.980068] printk: bootconsole [uart8250] enabled
[ 0.981513] efi: UEFI not found.
[ 1.016509] Zone ranges:
[ 1.016765] DMA [mem 0x0000000000200000-0x000000007fffffff]
[ 1.017356] DMA32 empty
[ 1.017630] Normal empty
[ 1.017904] Movable zone start for each node
[ 1.018307] Early memory node ranges
[ 1.018646] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 1.019237] node 0: [mem 0x0000000009400000-0x000000007fffffff]
[ 1.019831] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff]
[ 1.035796] cma: Reserved 16 MiB at 0x000000007e800000
[ 1.036368] psci: probing for conduit method from DT.
[ 1.036857] psci: PSCIv1.1 detected in firmware.
[ 1.037294] psci: Using standard PSCI v0.2 function IDs
[ 1.037791] psci: Trusted OS migration not required
[ 1.038256] psci: SMC Calling Convention v1.2
[ 1.039067] percpu: Embedded 30 pages/cpu s83480 r8192 d31208 u122880
[ 1.039792] Detected VIPT I-cache on CPU0
[ 1.040213] CPU features: detected: GIC system register CPU interface
[ 1.040822] CPU features: detected: Virtualization Host Extensions
[ 1.041412] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 1.042080] alternatives: patching kernel code
[ 1.044493] Built 1 zonelists, mobility grouping on. Total pages: 511496
[ 1.045144] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.verifiedbootstate=orange rootwait earlyprintk rw earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1 swiotlb=0x10000 net.ifnames=0 comm-07/22/2025 androidboot.fwver=spl-v1.13,bl31-v1.44,bl32-v2.12,uboot--boot
[ 1.050165] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.051152] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.051884] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 1.078889] Memory: 1975368K/2078720K available (19264K kernel code, 3256K rwdata, 6308K rodata, 6784K init, 593K bss, 86968K reserved, 16384K cma-reserved)
[ 1.080335] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 1.080990] ftrace: allocating 57783 entries in 226 pages
[ 1.160246] ftrace: allocated 226 pages with 4 groups
[ 1.161064] rcu: Hierarchical RCU implementation.
[ 1.161516] rcu: RCU event tracing is enabled.
[ 1.161945] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 1.162561] Rude variant of Tasks RCU enabled.
[ 1.162989] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 1.163702] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 1.168909] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 1.170727] GICv3: GIC: Using split EOI/Deactivate mode
[ 1.171233] GICv3: 320 SPIs implemented
[ 1.171597] GICv3: 0 Extended SPIs implemented
[ 1.172048] GICv3: Distributor has no Range Selector support
[ 1.172588] GICv3: 16 PPIs implemented
[ 1.172978] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[ 1.173740] ITS [mem 0xfd440000-0xfd45ffff]
[ 1.174208] ITS@0x00000000fd440000: allocated 8192 Devices @29d0000 (indirect, esz 8, psz 64K, shr 0)
[ 1.175110] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @29e0000 (flat, esz 2, psz 64K, shr 0)
[ 1.176072] ITS: using cache flushing for cmd queue
[ 1.176825] GICv3: using LPI property table @0x00000000029f0000
[ 1.177500] GIC: using cache flushing for LPI property table
[ 1.178042] GICv3: CPU0: using allocated LPI pending table @0x0000000002a00000
[ 1.207663] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 1.208255] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 1.209276] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 1.210925] Console: colour dummy device 80x25
[ 1.211379] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 1.212352] pid_max: default: 32768 minimum: 301
[ 1.212917] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.213627] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.215864] rcu: Hierarchical SRCU implementation.
[ 1.217048] Platform MSI: interrupt-controller@fd440000 domain created
[ 1.218054] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 1.219141] EFI services will not be available.
[ 1.219887] smp: Bringing up secondary CPUs ...
[ 1.221627] Detected VIPT I-cache on CPU1
[ 1.221662] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 1.221683] GICv3: CPU1: using allocated LPI pending table @0x0000000002a10000
[ 1.221736] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 1.223095] Detected VIPT I-cache on CPU2
[ 1.223124] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 1.223142] GICv3: CPU2: using allocated LPI pending table @0x0000000002a20000
[ 1.223180] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 1.224489] Detected VIPT I-cache on CPU3
[ 1.224515] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 1.224532] GICv3: CPU3: using allocated LPI pending table @0x0000000002a30000
[ 1.224567] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 1.224663] smp: Brought up 1 node, 4 CPUs
[ 1.232076] SMP: Total of 4 processors activated.
[ 1.232530] CPU features: detected: Privileged Access Never
[ 1.233056] CPU features: detected: User Access Override
[ 1.233559] CPU features: detected: 32-bit EL0 Support
[ 1.234044] CPU features: detected: Common not Private translations
[ 1.234634] CPU features: detected: RAS Extension Support
[ 1.235143] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
// logs removed for being too long
[ 2.117544] rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[ 2.118159] rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[ 2.118747] rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[ 2.119906] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.121212] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[ 2.122125] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 2.123361] fdd50000.serial: ttyS0 at MMIO 0xfdd50000 (irq = 24, base_baud = 1500000) is a 16550A
[ 2.125109] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 71, base_baud = 1500000) is a 16550A
[ 2.126565] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 72, base_baud = 1500000) is a 16550A
[ 2.127886] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 73, base_baud = 1500000) is a 16550A
[ 2.129179] fe690000.serial: ttyS5 at MMIO 0xfe690000 (irq = 74, base_baud = 1500000) is a 16550A
[ 2.130486] fe6a0000.serial: ttyS6 at MMIO 0xfe6a0000 (irq = 75, base_baud = 1500000) is a 16550A
[ 2.131758] fe6b0000.serial: ttyS7 at MMIO 0xfe6b0000 (irq = 76, base_baud = 1500000) is a 16550A
[ 2.133056] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 77, base_baud = 1500000) is a 16550A
[ 2.134402] fe6d0000.serial: ttyS9 at MMIO 0xfe6d0000 (irq = 78, base_baud = 1500000) is a 16550A
[ 2.138222] random: crng init done
[ 2.138919] rockchip-vop2 fe040000.vop: Adding to iommu group 8
[ 2.146901] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[ 2.147847] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[ 2.148777] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[ 2.150013] [drm] failed to init overlay plane Cluster0-win1
[ 2.150589] [drm] failed to init overlay plane Cluster1-win1
[ 2.151294] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffffc0093e2a50)
[ 2.152334] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
//removed part as its too long
[ 2.609472] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.610084] [BT_RFKILL]: ** disable irq
[ 2.610543] [BT_RFKILL]: bt_default device registered.
[ 2.611166] Key type dns_resolver registered
[ 2.612943] imx415 4-0037: driver version: 00.01.08
[ 2.613469] imx415 4-0037: Get hdr mode failed! no hdr default
[ 2.614048] imx415 4-0037: detect imx415 lane 4
[ 2.614533] imx415 4-0037: Failed to get power-gpios
[ 2.615009] imx415 4-0037: could not get default pinstate
[ 2.615521] imx415 4-0037: could not get sleep pinstate
[ 2.616060] imx415 4-0037: supply dvdd not found, using dummy regulator
[ 2.616883] imx415 4-0037: supply dovdd not found, using dummy regulator
[ 2.617585] imx415 4-0037: supply avdd not found, using dummy regulator
[ 2.626069] mmc0: Host Software Queue enabled
[ 2.626519] mmc0: new HS200 MMC card at address 0001
[ 2.627713] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 2.628392] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 2.629231] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 2.630116] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB, chardev (236:0)
[ 2.633933] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.687012] imx415 4-0037: Unexpected sensor id(000000), ret(-5)
[ 2.688370] xc7160 4-001b: T-chip firefly camera driver version: 00.01.04
[ 2.689254] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 2.689982] xc7160 4-001b: supply avdd not found, using dummy regulator
[ 2.690741] xc7160 4-001b: supply dovdd not found, using dummy regulator
[ 2.691419] xc7160 4-001b: supply dvdd not found, using dummy regulator
[ 2.692095] xc7160 4-001b: could not get default pinstate
[ 2.692609] xc7160 4-001b: could not get sleep pinstate
[ 2.693139] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 2.709524] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 2.710436] xc7160: probe of 4-001b failed with error -5
[ 2.711629] Loading compiled-in X.509 certificates
[ 2.713775] pstore: Using crash dump compression: deflate
[ 2.715361] rga: rga2, irq = 31, match scheduler
[ 2.716500] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[ 2.717169] rga: rga2 probe successfully
[ 2.717896] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[ 2.718548] vendor storage:20190527 ret = 0
[ 2.718742] rga: Module initialized. v1.3.1
[ 2.741684] rockchip-pinctrl pinctrl: pin gpio3-9 already requested by fe680000.serial; cannot claim for fe010000.ethernet
[ 2.742745] rockchip-pinctrl pinctrl: pin-105 (fe010000.ethernet) status -22
[ 2.743467] rockchip-pinctrl pinctrl: could not request pin 105 (gpio3-9) from group gmac1m0-rx-bus2 on device rockchip-pinctrl
[ 2.744559] rk_gmac-dwmac fe010000.ethernet: Error applying setting, reverse things back
[ 2.745357] rk_gmac-dwmac: probe of fe010000.ethernet failed with error -22
[ 2.747547] rockchip-pinctrl pinctrl: pin gpio2-3 already requested by fe6a0000.serial; cannot claim for fe2c0000.dwmmc
[ 2.747636] mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 5
[ 2.748581] rockchip-pinctrl pinctrl: pin-67 (fe2c0000.dwmmc) status -22
[ 2.749355] mpp_rkvenc fdf40000.rkvenc: probing start
[ 2.749822] rockchip-pinctrl pinctrl: could not request pin 67 (gpio2-3) from group sdmmc1-bus4 on device rockchip-pinctrl
[ 2.749828] dwmmc_rockchip fe2c0000.dwmmc: Error applying setting, reverse things back
[ 2.750772] mpp_rkvenc fdf40000.rkvenc: bin=0
[ 2.751383] dwmmc_rockchip: probe of fe2c0000.dwmmc failed with error -22
[ 2.752117] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[ 2.753767] mpp_rkvenc fdf40000.rkvenc: pvtm = 87290, from nvmem
[ 2.754344] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[ 2.755018] mpp_rkvenc fdf40000.rkvenc: avs=0
[ 2.755552] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[ 2.756181] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[ 2.756833] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[ 2.758288] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 2.759171] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 6
[ 2.760012] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[ 2.760907] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 2.761505] rkvdec2_init:1022: No niu aclk reset resource define
[ 2.762078] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 2.762671] rkvdec2_init:1025: No niu hclk reset resource define
[ 2.763433] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[ 2.763990] mpp_rkvdec2 fdf80200.rkvdec: leakage=54
[ 2.764462] mpp_rkvdec2 fdf80200.rkvdec: leakage-volt-sel=0
[ 2.765022] mpp_rkvdec2 fdf80200.rkvdec: pvtm = 87290, from nvmem
[ 2.765604] mpp_rkvdec2 fdf80200.rkvdec: pvtm-volt-sel=1
[ 2.766285] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[ 2.766850] mpp_rkvdec2 fdf80200.rkvdec: failed to find power_model node
[ 2.767487] mpp_rkvdec2 fdf80200.rkvdec: failed to initialize power model
[ 2.768130] mpp_rkvdec2 fdf80200.rkvdec: failed to get dynamic-coefficient
[ 2.768912] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 2.769533] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 2.770149] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 2.770654] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 2.771152] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 2.771691] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 2.772319] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 2.774052] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 2.774230] mali fde60000.gpu: Kernel DDK version g18p0-01eac0
[ 2.774997] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 2.775837] mali fde60000.gpu: bin=0
[ 2.776497] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 2.776748] mali fde60000.gpu: leakage=8
[ 2.777657] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 2.777936] mali fde60000.gpu: pvtm = 87290, from nvmem
[ 2.778860] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 2.779242] mali fde60000.gpu: pvtm-volt-sel=2
[ 2.780203] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 2.780508] mali fde60000.gpu: soc version=0, speed=2
[ 2.781379] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 2.782310] mali fde60000.gpu: avs=0
[ 2.782706] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 2.782984] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 2.784415] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 2.785772] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 2.786643] mali fde60000.gpu: No priority control manager is configured
[ 2.787705] mali fde60000.gpu: No memory group manager is configured
[ 2.790289] mali fde60000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.792775] mali fde60000.gpu: Probed as mali0
[ 2.794971] RKNPU fde40000.npu: Adding to iommu group 0
[ 2.795974] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 2.796997] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[ 2.798361] [drm] Initialized rknpu 0.9.3 20231121 for fde40000.npu on minor 1
[ 2.799592] RKNPU fde40000.npu: bin=0
[ 2.800027] RKNPU fde40000.npu: leakage=4
[ 2.800445] RKNPU fde40000.npu: pvtm = 87290, from nvmem
[ 2.800961] RKNPU fde40000.npu: pvtm-volt-sel=2
[ 2.801401] RKNPU fde40000.npu: soc version=0, speed=2
[ 2.802437] RKNPU fde40000.npu: avs=0
[ 2.802977] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.804312] RKNPU fde40000.npu: failed to find power_model node
[ 2.804879] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 2.805507] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 2.807453] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.815368] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
more info here
