Unexpected Touch Lag on Embedded Vision UI (RK3568) – Caused by Bitmap Load?
Type: Official Firmware
Filename: Unexpected Touch Lag on Embedded Vision UI (RK3568
Download Address: modhello
Log: iloveimg-resized (69).zip
Hi everyone,
First-time poster here. I’m working on a custom UI layer for an embedded vision product using RK3568 + OpenHarmony 4.0. The interface is mostly gesture-driven and runs quite smoothly — until I add a specific bitmap-based animation triggered on touch.
The Problem:When this animation is active, we notice a ~100ms touch response lag. The rendering is done through a standard EGL + GPU pipeline, and logs show no blocking calls. This only happens during the animation of one particular module — it involves loading fruit-style visuals (PNG sprites, ~80–100KB each). Other similar-sized bitmaps work fine.
My Question:Has anyone else encountered this kind of behavior on embedded devices with vision-focused UI layers? I’m wondering:
  • Is there something obvious we might be missing regarding how bitmaps are preloaded or cached?
  • Could PNG decoding on the fly cause these input delays even when using hardware acceleration?
  • Is it better to convert sprites to raw RGBA arrays beforehand?
Any insight from someone who’s worked with OpenHarmony UI or similar ARM-based boards would be super helpful!
:wrench: Reference Module (with the animation demo):
I’ve isolated the animation and touch layer into a test module, just to get feedback on whether the issue is asset-related or structural. It’s here (hosted externally to keep this post clean):
https://modhello.com/fruit-boom/
No signup or anything – just a standalone sample.
Let me know if this feels like a familiar bottleneck or if you have tools you’d recommend for tracing input latency on OpenHarmony!
Thanks in advance! :folded_hands:
iloveimg-resized (69).zip (770 KB)
Thank you for your article, it truly left me stunned! The Test Mule-101 dumps.zip helped me climb the career ladder and earn a raise. Now, I’m sharing it for free with all of you. Wishing you success!
This is truly a first-rate article, thank you for sharing. Free Cybersecurity-Practitioner authorized pdf test questions—unlock promotions and salary growth today!
Thank you for bringing such a soul-stirring piece of content! The Training FAAA_005 topics content is amazing, and it’s available to you without charge.
