大神帮俺看看,pwm也是按照官网上配置的,但那时申请出错。
pwm1 = pwm_request(1,“backlight_pwm”);
if(IS_ERR(pwm1))
printk(“1111111111111111111\n”);
return -1;
pwm_config(pwm1,25000,50000);
pwm_enable(pwm1)
这是写在驱动里的代码,
&pwm1 {
compatible = “rockchip,rk-pwm”;
reg = <0xff680010 0x10>;
#pwm-cells = <2>;
pinctrl-names = “default”;
pinctrl-0 = <&pwm1_pin>;
clocks = <&clk_gates11 11>;
clock-names = “pclk_pwm”;
status = “okay”;
上面是注册到firefly-rk3288.dts的代码,
申请出错的log发出来
zhansb 发表于 2016-3-25 14:32
申请出错的log发出来
楼主,这个问题怎么解决的?
楼主行了吗
楼主行了吗
