[求助]卡在soft connect!!!之后。下面是打印日志。谁知道原原因是什么?
U-Boot 2014.10-RK3288-02 (Nov 26 2014 - 09:28:44)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
Adding bank:0000000000000000(0000000100000000)
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2014-11-26#2.17
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x02000000 (0x005ffad0)
ramdisk @ 0x04bf0000 (0x00410900)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480c000, end 04826e3b … OK
Add bank:0000000000000000, 00000000ff000000
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (zmint@zmint-Vostro-470) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #14 SMP PREEMPT Fri Mar 25 11:29:30 CST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] hdmi init vic is -1 [ 0.000000] rockchip_ion_reserve [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c2ea9000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1042960 [ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-26_09:28:44 hdmi.vic=-1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 4080MB = 4080MB total [ 0.000000] Memory: 4108512k/4108512k available, 69408k reserved, 3399680K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0a8332c (10733 kB) [ 0.000000] .init : 0xc0a84000 - 0xc0cd36c0 (2366 kB) [ 0.000000] .data : 0xc0cd4000 - 0xc0d71608 ( 630 kB) [ 0.000000] .bss : 0xc0d71608 - 0xc0e8be3c (1131 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 32 [ 0.000000] Architected local timer running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:0, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:1, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 1.038621] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 1.038674] pid_max: default: 32768 minimum: 301 [ 1.039010] Security Framework initialized [ 1.039050] SELinux: Initializing. [ 1.039279] Mount-cache hash table entries: 512 [ 1.041316] Initializing cgroup subsys debug [ 1.041360] Initializing cgroup subsys freezer [ 1.041450] CPU: Testing write buffer coherency: ok [ 1.042206] /cpus/cpu@0 missing clock-frequency property [ 1.042250] /cpus/cpu@1 missing clock-frequency property [ 1.042284] /cpus/cpu@2 missing clock-frequency property [ 1.042316] /cpus/cpu@3 missing clock-frequency property [ 1.042440] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 1.042551] Setting up static identity map for 0xc07939c8 - 0xc0793a20 [ 1.045902] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1526 (version 3.0) [ 1.116655] CPU1: Booted secondary processor [ 1.116748] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 1.136374] CPU2: Booted secondary processor [ 1.136456] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 1.156160] CPU3: Booted secondary processor [ 1.156242] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 1.156611] Brought up 4 CPUs [ 1.156710] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 1.156740] CPU: All CPU(s) started in SVC mode. [ 1.158973] devtmpfs: initialized [ 1.176680] pinctrl core: initialized pinctrl subsystem [ 1.177466] regulator-dummy: no parameters [ 1.179093] NET: Registered protocol family 16 [ 1.184309] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 1.185185] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e67454 (version 0.1) [ 1.185697] Registered FIQ tty driver [ 1.189189] console [ttyFIQ0] enabled [ 1.189770] Registered fiq debugger ttyFIQ0 [ 1.191627] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 1.191715] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 1.191787] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 1.191858] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 1.192115] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 1.192344] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 1.192572] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 1.192795] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 1.193015] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 1.193237] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 1.193477] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 1.193709] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 1.193949] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 1.194184] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 1.194241] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 1.194294] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 1.194345] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 1.196153] rockchip_interrupts_register:bank_num=7 [ 1.212832] of_get_gpio_init_config:gpio[0] = 257, value = 0 [ 1.212915] of_get_gpio_init_config:gpio[1] = 136, value = 0 [ 1.213190] rockchip_pinctrl_probe:init ok [ 1.233212] rk_iommu ff900800.iep_mmu: (iep) Enter [ 1.233559] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.233613] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 1.234176] rk_iommu ff950800.vip_mmu: (vip) Enter [ 1.234558] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.234612] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 1.235185] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 1.235506] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.235560] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 1.236111] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 1.236430] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.236483] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 1.237065] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 1.237448] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.237500] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 1.238056] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 1.238372] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.238425] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 1.239015] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 1.239394] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.239447] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 1.244592] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 1.244649] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 1.245267] DDR DEBUG: version 1.00 20140603 [ 1.245347] DDR DEBUG: Channel a: [ 1.245383] DDR DEBUG: DDR3 Device [ 1.245433] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Total Capability=2048MB [ 1.245475] DDR DEBUG: Channel b: [ 1.245506] DDR DEBUG: DDR3 Device [ 1.245551] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Total Capability=2048MB [ 1.245594] DDR DEBUG: addr=0xd77000 [ 1.245634] DDR DEBUG: stride=13, size=256, halfcap=80000000 [ 1.245674] DDR DEBUG: socAddr[0]=0xd77000, socAddr[1]=0xd77100 [ 1.245714] DDR DEBUG: chAddr[0]=0xd77000, chAddr[1]=0xd77000 [ 1.245759] DDR DEBUG: dtar[0]=0x701ae000, dtar[1]=0x701ae000 [ 1.245922] DDR DEBUG: init success!!! freq=200MHz [ 1.245957] DDR DEBUG: Channel a: [ 1.246006] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 1.246065] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 1.246124] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 1.246183] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 1.246236] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 1.246278] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 1.246317] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 1.246350] DDR DEBUG: Channel b: [ 1.246397] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 1.246455] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 1.246513] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 1.246571] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 1.246623] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 1.246665] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 1.246704] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 1.322894] bio: create slab at 0 [ 1.324822] Enter firefly_noatx8_init [ 1.325796] SCSI subsystem initialized [ 1.326291] usbcore: registered new interface driver usbfs [ 1.326446] usbcore: registered new interface driver hub [ 1.326730] usbcore: registered new device driver usb [ 1.330720] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 1.336179] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 1.339198] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 1.340887] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 1.342597] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 1.344989] media: Linux media interface: v0.10 [ 1.345136] Linux video capture interface: v2.00 [ 1.345313] pps_core: LinuxPPS API ver. 1 registered [ 1.345356] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[giometti@linux.it](mailto:giometti@linux.it)> [ 1.345439] PTP clock support registered [ 1.345863] rockchip_temp_probe,line=362 [ 1.346625] tsadc ff280000.tsadc: initialized [ 1.347868] rockchip_ion_parse_dt: num_heaps = 1 [ 1.347931] 0: 0 3 vmalloc 0x (null) [ 1.348670] Rockchip ion module is successfully loaded (v1.0) [ 1.349192] Advanced Linux Sound Architecture Driver Initialized. [ 1.350376] Bluetooth: Core ver 2.16 [ 1.350505] NET: Registered protocol family 31 [ 1.350548] Bluetooth: HCI device and connection manager initialized [ 1.350609] Bluetooth: HCI socket layer initialized [ 1.350661] Bluetooth: L2CAP socket layer initialized [ 1.350752] Bluetooth: SCO socket layer initialized [ 1.351430] cfg80211: Calling CRDA to update world regulatory domain [ 1.353697] nfc: nfc_init: NFC Core ver 0.1 [ 1.353870] NET: Registered protocol family 39 [ 1.354047] act8846_i2c_probe,line=898 [ 1.356218] act8846_parse_dt,line=746 [ 1.357584] invalid gpio: -2 [ 1.357649] lhm invalid gpio: -2 [ 1.357766] act8846_i2c_probe: act8846_pmic_hold=1 [ 1.357879] act8846_i2c_probe: act8846_pmic_sleep=1 [ 1.357916] ------------[ cut here ]------------ [ 1.357987] WARNING: at drivers/gpio/gpiolib.c:126 gpio_to_desc+0x20/0x44() [ 1.358028] invalid GPIO -2 [ 1.358059] Modules linked in: [ 1.358117] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #14 [ 1.358219] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 1.358307] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 1.358391] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c) [ 1.358476] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_to_desc+0x20/0x44) [ 1.358558] [] (gpio_to_desc+0x20/0x44) from [] (gpio_request+0xc/0x18) [ 1.358638] [] (gpio_request+0xc/0x18) from [] (act8846_i2c_probe+0x1fc/0x3ec) [ 1.358722] [] (act8846_i2c_probe+0x1fc/0x3ec) from [] (i2c_device_probe+0xa8/0xd4) [ 1.358810] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa4/0x1e8) [ 1.358893] [] (really_probe+0xa4/0x1e8) from [] (driver_probe_device+0x30/0x48) [ 1.358971] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 1.359048] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 1.359124] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 1.359203] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 1.359284] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac) [ 1.359373] [] (i2c_register_driver+0x40/0xac) from [] (act8846_module_init+0x10/0x34) [ 1.359457] [] (act8846_module_init+0x10/0x34) from [] (do_one_initcall+0x34/0xc8) [ 1.359534] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 1.359604] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 1.359680] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 1.359758] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 1.359838] ---[ end trace 45bb3e4a3b03ef78 ]--- [ 1.359877] gpiod_request: invalid GPIO [ 1.359928] act8846 0-005a: Failed to request gpio -2 with ret:-22 [ 1.369903] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 1.380480] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 1.381607] rk808_i2c_probe,line=1368 [ 1.383907] The device is not rk808 -11 [ 1.384177] rk808: probe of 0-001b failed with error -11 [ 1.390838] Switching to clocksource arch_sys_counter [ 1.431192] usb_battery_charger_detect_synop , battery_charger_detect 1, pass DCD, dcd_state = 1 [ 1.457406] rk-fb rockchip-fb: rk fb ion client create success! [ 1.457476] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 1.458497] rk-screen rk_screen.9: rockchip screen probe success [ 1.459270] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 1.460082] rk32-edp ff970000.edp: screen is not edp! [ 1.460157] rk32-edp: probe of ff970000.edp failed with error -22 [ 1.461263] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 1.462026] graphics fb0: rockchip framebuffer registerd:fb0 [ 1.463093] graphics fb1: rockchip framebuffer registerd:fb1 [ 1.463699] graphics fb2: rockchip framebuffer registerd:fb2 [ 1.464276] graphics fb3: rockchip framebuffer registerd:fb3 [ 1.464876] graphics fb4: rockchip framebuffer registerd:fb4 [ 1.466543] rk_iommu ff930300.vopb_mmu: (vopb) Enabled [ 1.466971] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 1.467043] rk3288-lcdc lcdc0: wakeup from standby! [ 1.601155] alloc_buffer:ion_phy_addr=0x10000000 [ 1.644483] fb0:phy:10000000>>vir:f0191000>>len:0x1800000 [ 1.766087] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 1.767788] rockchip_set_mux:warning ignore bank num 15 [ 1.768766] rockchip_set_mux:warning ignore bank num 15 [ 1.769731] rockchip_set_mux:warning ignore bank num 15 [ 1.770720] rockchip_set_mux:warning ignore bank num 15 [ 1.771669] rockchip_set_mux:warning ignore bank num 15 [ 1.772639] rockchip_set_mux:warning ignore bank num 15 [ 1.773600] rockchip_set_mux:warning ignore bank num 15 [ 1.774603] rockchip_set_mux:warning ignore bank num 15 [ 1.775704] rockchip_set_mux:warning ignore bank num 15 [ 1.776716] rockchip_set_mux:warning ignore bank num 15 [ 1.781280] NET: Registered protocol family 2 [ 1.782720] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 1.783207] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 1.783704] TCP: Hash tables configured (established 8192 bind 8192) [ 1.783860] TCP: reno registered [ 1.783913] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.784043] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.784758] NET: Registered protocol family 1 [ 1.785321] Unpacking initramfs... [ 2.428394] Freeing initrd memory: 4160K (c4bf0000 - c5000000) [ 2.430221] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 2.431617] probe device ff9a0000.vpu_service [ 2.432097] vpu_service: power on [ 2.433254] checking hw id 4831 [ 2.434372] vpu_service set to auto frequency mode [ 2.434545] vcodec vpu_service: vcodec ion client create success! [ 2.435663] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled [ 2.435770] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled [ 2.435823] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26e000 [ 2.435872] vpu_service: power off... [ 2.435958] done [ 2.435991] init success [ 2.436150] probe device ff9c0000.hevc_service [ 2.436745] hevc_service: power on [ 2.437865] checking hw id 6867 [ 2.438740] vcodec hevc_service: vcodec ion client create success! [ 2.439634] rk_iommu ff9c0440.hevc_mmu: (hevc) Enabled [ 2.439738] rk_iommu ff9c0440.hevc_mmu: (hevc) Disabled [ 2.439789] rk_iommu ff9c0440.hevc_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26c000 [ 2.439836] hevc_service: power off... [ 2.439920] done [ 2.439950] init success [ 2.440332] rknandbase v1.0 2014-03-31 [ 2.440959] rknand_probe clk rate = 148500000 [ 2.441323] rknand_driver:ret = 0 [ 2.442445] audit: initializing netlink socket (disabled) [ 2.442557] type=2000 audit(1.410:1): initialized [ 2.445393] bounce pool size: 64 pages [ 2.460711] fuse init (API version 7.22) [ 2.461915] msgmni has been set to 1424 [ 2.467953] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.468018] io scheduler noop registered [ 2.468059] io scheduler deadline registered [ 2.468393] io scheduler cfq registered (default) [ 2.470604] rga ff920000.rga: rga ion client create success! [ 2.471082] rga: Driver loaded succesfully [ 2.472519] IEP Power ON [ 2.472639] iep ion client create success! [ 2.473671] rk_iommu ff900800.iep_mmu: (iep) Enabled [ 2.473764] IEP Power OFF [ 2.473811] rk_iommu ff900800.iep_mmu: (iep) Disabled [ 2.473861] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e261000 [ 2.473924] IEP Driver loaded succesfully [ 2.474205] Module initialized. [ 2.476672] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 2.476745] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 2.481336] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 2.481408] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 2.482129] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API [ 2.482191] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM [ 2.482234] pwm_regulator_probe:error [ 2.482306] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral [ 2.483408] rk_serial.c v1.8 2014-03-04 [ 2.484535] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 2.485140] serial ff180000.serial: membase 0xf0172000 [ 2.494545] loop: module loaded [ 2.495277] Enter bcm2079x_dev_init [ 2.495497] bcm2079x-i2c 1-0077: Driver Version: AMPAK-BCM2079X-DRIVER-VERSION-1.0.0 [ 2.495558] bcm2079x-i2c 1-0077: bcm2079x_probe, probing bcm2079x driver flags = 0 [ 2.495667] bcm2079x-i2c 1-0077: nfc_platdata_parse_dt: get property: en_gpio = 259 [ 2.495759] bcm2079x-i2c 1-0077: nfc_platdata_parse_dt: get property: wake_gpio = 257 [ 2.495848] bcm2079x-i2c 1-0077: nfc_platdata_parse_dt: get property: irq_gpio = 258 [ 2.496084] bcm2079x-i2c: probe of 1-0077 failed with error -16 [ 2.497318] SCSI Media Changer driver v0.25 [ 2.499141] dws->regs: f0174000 [ 2.500970] of_dma_request_slave_channel: dma-names property missing or empty [ 2.501035] rockchip-spi ff130000.spi: Failed to get RX DMA channel [ 2.501090] spi_master (null): DMA init failed,ret=-1 [ 2.501626] rockchip_spi_probe:num_cs=2,irq=78,freq=45692307 ok [ 2.502466] tun: Universal TUN/TAP device driver, 1.6 [ 2.502514] tun: (C) 1999-2004 Max Krasnyansky <[maxk@qualcomm.com](mailto:maxk@qualcomm.com)> [ 2.506151] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 2.506203] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 2.506250] stmmac_probe_config_dt: clock input or output? (input). [ 2.506294] stmmac_probe_config_dt: TX delay(0x30). [ 2.506335] stmmac_probe_config_dt: RX delay(0x10). [ 2.506454] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 2.506494] stmmc_pltfr_init: [ 2.506530] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 2.506605] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed. [ 2.506644] stmmc_pltfr_init: init for RGMII [ 2.506684] tx delay=0x30 [ 2.506684] rx delay=0x10 [ 2.508078] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 2.508119] Normal descriptors [ 2.508151] Ring mode enabled [ 2.508184] DMA HW capability register supported [ 2.508223] RX Checksum Offload Engine supported (type 2) [ 2.508261] TX Checksum insertion supported [ 2.508294] Wake-Up On Lan supported [ 2.508441] Enable RX Mitigation via HW Watchdog Timer [ 2.509770] PPP generic driver version 2.4.2 [ 2.510280] PPP BSD Compression module registered [ 2.510328] PPP Deflate Compression module registered [ 2.510407] PPP MPPE Compression module registered [ 2.510452] NET: Registered protocol family 24 [ 2.510549] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 2.510596] CSLIP: code copyright 1989 Regents of the University of California. [ 2.510642] Rockchip WiFi SYS interface (V1.00) ... [ 2.510894] usbcore: registered new interface driver catc [ 2.511035] usbcore: registered new interface driver kaweth [ 2.511080] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 2.511219] usbcore: registered new interface driver pegasus [ 2.511353] usbcore: registered new interface driver rtl8150 [ 2.511486] usbcore: registered new interface driver r8152 [ 2.511527] hso: drivers/net/usb/hso.c: Option Wireless [ 2.511765] usbcore: registered new interface driver hso [ 2.511930] usbcore: registered new interface driver asix [ 2.512068] usbcore: registered new interface driver ax88179_178a [ 2.512203] usbcore: registered new interface driver cdc_ether [ 2.512336] usbcore: registered new interface driver cdc_eem [ 2.512468] usbcore: registered new interface driver dm9601 [ 2.512599] usbcore: registered new interface driver dm9620 [ 2.512852] usbcore: registered new interface driver smsc75xx [ 2.513034] usbcore: registered new interface driver smsc95xx [ 2.513225] usbcore: registered new interface driver gl620a [ 2.513369] usbcore: registered new interface driver net1080 [ 2.513499] usbcore: registered new interface driver plusb [ 2.513628] usbcore: registered new interface driver rndis_host [ 2.513766] usbcore: registered new interface driver cdc_subset [ 2.513890] usbcore: registered new interface driver zaurus [ 2.514022] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 2.514199] usbcore: registered new interface driver int51x1 [ 2.514328] usbcore: registered new interface driver kalmia [ 2.514456] usbcore: registered new interface driver ipheth [ 2.514597] usbcore: registered new interface driver sierra_net [ 2.514727] usbcore: registered new interface driver cx82310_eth [ 2.514895] usbcore: registered new interface driver cdc_ncm [ 2.515026] usbcore: registered new interface driver qmi_wwan [ 2.515157] usbcore: registered new interface driver cdc_mbim [ 2.515200] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.518416] ehci_rk_probe f1a00000 f1a00010 [ 2.518473] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller [ 2.518570] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 2.519533] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 2.532533] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00 [ 2.532807] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.532872] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.532926] usb usb1: Product: Rockchip On-Chip EHCI Host Controller [ 2.532975] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 2.533021] usb usb1: SerialNumber: ff500000.usb [ 2.534473] hub 1-0:1.0: USB hub found [ 2.534550] hub 1-0:1.0: 1 port detected [ 2.562024] ehci_rk_probe ok [ 2.562458] usbcore: registered new interface driver cdc_acm [ 2.562505] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 2.562687] usbcore: registered new interface driver usblp [ 2.562831] usbcore: registered new interface driver cdc_wdm [ 2.563043] usbcore: registered new interface driver usb-storage [ 2.563179] usbcore: registered new interface driver ums-alauda [ 2.563306] usbcore: registered new interface driver ums-cypress [ 2.563432] usbcore: registered new interface driver ums-datafab [ 2.563556] usbcore: registered new interface driver ums_eneub6250 [ 2.563679] usbcore: registered new interface driver ums-freecom [ 2.563802] usbcore: registered new interface driver ums-isd200 [ 2.563926] usbcore: registered new interface driver ums-jumpshot [ 2.564050] usbcore: registered new interface driver ums-karma [ 2.564186] usbcore: registered new interface driver ums-onetouch [ 2.564318] usbcore: registered new interface driver ums-sddr09 [ 2.564445] usbcore: registered new interface driver ums-sddr55 [ 2.564570] usbcore: registered new interface driver ums-usbat [ 2.564849] usbcore: registered new interface driver usbserial [ 2.564985] usbcore: registered new interface driver usbserial_generic [ 2.565096] usbserial: USB Serial support registered for generic [ 2.565230] usbcore: registered new interface driver option [ 2.565351] usbserial: USB Serial support registered for GSM modem (1-port) [ 2.565589] usbcore: registered new interface driver trancevibrator [ 2.565634] usb20_otg: version 3.10a 21-DEC-2012 [ 2.566657] f1a80040 [ 2.566703] Core Release: 3.10a [ 2.566743] Setting default values for core params [ 2.567158] Using Buffer DMA mode [ 2.567202] Periodic Transfer Interrupt Enhancement - disabled [ 2.567240] Multiprocessor Interrupt Enhancement - disabled [ 2.567282] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 2.567319] ^^^^^^^^^^^^^^^^^Device Mode [ 2.567362] Dedicated Tx FIFOs mode [ 2.567420] pcd_init otg_dev = ed9d2500 [ 2.567880] usb20_otg ff580000.usb: DWC OTG Controller [ 2.567977] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 2.568081] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 2.568267] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.568325] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.568376] usb usb2: Product: DWC OTG Controller [ 2.568422] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 2.568468] usb usb2: SerialNumber: ff580000.usb [ 2.569849] hub 2-0:1.0: USB hub found [ 2.569921] hub 2-0:1.0: 1 port detected [ 2.570811] usb20_host: version 3.10a 21-DEC-2012 [ 2.574382] f1b00040 [ 2.574431] Core Release: 3.10a [ 2.574472] Setting default values for core params [ 2.574902] Using Buffer DMA mode [ 2.574943] Periodic Transfer Interrupt Enhancement - disabled [ 2.574982] Multiprocessor Interrupt Enhancement - disabled [ 2.575023] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 2.575059] ^^^^^^^^^^^^^^^^^^Host Mode [ 2.575142] usb20_host ff540000.usb: DWC OTG Controller [ 2.575229] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 2.575334] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 2.575499] Init: Power Port (0) [ 2.575689] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.575749] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.575801] usb usb3: Product: DWC OTG Controller [ 2.575847] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 2.575893] usb usb3: SerialNumber: ff540000.usb [ 2.577263] hub 3-0:1.0: USB hub found [ 2.577354] hub 3-0:1.0: 1 port detected [ 2.579204] .. rk pwm remotectl v1.0 init [ 2.579450] remotectl probe j=0x0 [ 2.579961] input: ff680000.pwm as /devices/ff680000.pwm/input/input0 [ 2.580555] pwm enable val=0x646205 [ 2.581403] usbcore: registered new interface driver xpad [ 2.581579] usbcore: registered new interface driver usb_acecad [ 2.581811] usbcore: registered new interface driver aiptek [ 2.581973] usbcore: registered new interface driver gtco [ 2.582124] usbcore: registered new interface driver hanwang [ 2.582277] usbcore: registered new interface driver kbtab [ 2.582448] usbcore: registered new interface driver wacom [ 2.583512] sensor_register_slave:mma8452,id=17 [ 2.583562] sensor_register_slave:cm3217,id=44 [ 2.583602] sensor_register_slave:cm3218,id=45 [ 2.588657] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed [ 2.594007] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 2.594168] i2c /dev entries driver [ 2.596483] IR NEC protocol handler initialized [ 2.596532] IR RC5(x) protocol handler initialized [ 2.596569] IR RC6 protocol handler initialized [ 2.596604] IR JVC protocol handler initialized [ 2.596639] IR Sony protocol handler initialized [ 2.596675] IR RC5 (streamzap) protocol handler initialized [ 2.596713] IR SANYO protocol handler initialized [ 2.596750] IR MCE Keyboard/mouse protocol handler initialized [ 2.597020] usbcore: registered new interface driver uvcvideo [ 2.597063] USB Video Class driver (1.1.1) [ 2.597109] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0 [ 2.605029] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236 [ 2.605114] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request [ 2.605225] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0 [ 2.605292] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high [ 2.605507] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 2.605969] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19b0000 size: 0x4000) [ 2.608068] D1:camsys_platform_probe(1208): ff910000.isp memory: [ 2.608130] D1:camsys_platform_probe(1218): Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000) [ 2.608190] D1:camsys_platform_probe(1213): I2c memory (phy: 0x2d9e6000 vir: 0xed9e6000 size: 0x1000) [ 2.608242] D1:camsys_platform_probe(1233): Probe ff910000.isp device success [ 2.611198] device-mapper: uevent: version 1.0.3 [ 2.611952] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [dm-devel@redhat.com](mailto:dm-devel@redhat.com) [ 2.612954] Bluetooth: HCI UART driver ver 2.2 [ 2.613010] Bluetooth: HCI H4 protocol initialized [ 2.613050] Bluetooth: HCILL protocol initialized [ 2.613187] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)! [ 2.617006] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)! [ 3.440235] cpufreq version 1.0, suspend freq 1200 MHz [ 3.440802] cpuidle: using governor ladder [ 3.440848] cpuidle: using governor menu [ 3.440971] Synopsys Designware Multimedia Card Interface Driver [ 3.441772] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 3.442589] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 3.443143] 3230..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 3.443201] Line3235..dw_mci_init_slot: The rk_sdmmc Ver 1.12 2014-07-08 [ 3.443587] 1357..dw_mci_set_ios: no card. [mmc0] [ 3.457516] 1357..dw_mci_set_ios: no card. [mmc0] [ 3.477141] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 3.477155] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 3.477169] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 3.478064] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 3.478355] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 3.478563] 3224..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1] [ 3.478674] mmc1: no vmmc regulator found [ 3.478809] 1357..dw_mci_set_ios: no card. [mmc1] [ 3.496787] 1357..dw_mci_set_ios: no card. [mmc1] [ 3.516790] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 3.516808] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 3.517791] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 3.518029] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 3.518183] 3230..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 3.518303] 1357..dw_mci_set_ios: no card. [mmc2] [ 3.519066] mmc0: BKOPS_EN bit is not set [ 3.520992] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 3.523305] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 3.523333] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 3.536124] 1357..dw_mci_set_ios: no card. [mmc2] [ 3.538320] rk_sdmmc: BOOT [ 3.538320] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID[mmc0] [ 3.538402] mmc0: new HS200 MMC card at address 0001 [ 3.538671] mmcblk0: mmc0:0001 BGND3R 29.1 GiB [ 3.538970] parameter: 0x000000000 -- 0x000400000 (4 MB) [ 3.538983] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 3.538992] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 3.539001] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 3.539010] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 3.539019] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 3.539027] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 3.539036] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 3.539044] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 3.539053] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 3.539061] system: 0x012400000 -- 0x042400000 (768 MB) [ 3.539070] metadata: 0x042400000 -- 0x042800000 (4 MB) [ 3.539079] userdata: 0x042800000 -- 0x082800000 (1024 MB) [ 3.539087] radical_update: 0x082800000 -- 0x086800000 (64 MB) [ 3.539096] user: 0x086800000 -- 0x747800000 (27664 MB) [ 3.539125] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p151357..dw_mci_set_ios: no card. [mmc1] [ 3.555798] 1357..dw_mci_set_ios: no card. [mmc2] [ 3.556186] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 3.556198] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 3.556456] hidraw: raw HID events driver (C) Jiri Kosina [ 3.557786] usbcore: registered new interface driver usbhid [ 3.557796] usbhid: USB HID core driver [ 3.558096] ashmem: initialized [ 3.558218] logger: created 256K log 'log_main' [ 3.558311] logger: created 256K log 'log_events' [ 3.558415] logger: created 256K log 'log_radio' [ 3.558509] logger: created 256K log 'log_system' [ 3.559189] i2c-core: driver [ES8323] using legacy suspend method [ 3.559199] i2c-core: driver [ES8323] using legacy resume method [ 3.559505] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered [ 3.559535] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 3.559555] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral [ 3.559731] u32 classifier [ 3.559739] Actions configured [ 3.559752] Netfilter messages via NETLINK v0.30. [ 3.559815] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 3.560157] ctnetlink v0.93: registering with nfnetlink. [ 3.560228] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 3.560237] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 3.560514] xt_time: kernel timezone is -0000 [ 3.560719] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.560861] arp_tables: (C) 2002 David S. Miller [ 3.560902] TCP: cubic registered [ 3.560909] Initializing XFRM netlink socket [ 3.561135] NET: Registered protocol family 10 [ 3.561666] mip6: Mobile IPv6 [ 3.561695] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.561834] sit: IPv6 over IPv4 tunneling driver [ 3.562174] NET: Registered protocol family 17 [ 3.562201] NET: Registered protocol family 15 [ 3.562259] Bridge firewalling registered [ 3.562271] Ebtables v2.0 registered [ 3.562421] Bluetooth: RFCOMM TTY layer initialized [ 3.562447] Bluetooth: RFCOMM socket layer initialized [ 3.562456] Bluetooth: RFCOMM ver 1.11 [ 3.562466] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.562473] Bluetooth: BNEP filters: protocol multicast [ 3.562485] Bluetooth: BNEP socket layer initialized [ 3.562493] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.562506] Bluetooth: HIDP socket layer initialized [ 3.562531] l2tp_core: L2TP core driver, V2.0 [ 3.562546] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 3.562554] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.562725] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 3.562737] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 3.562747] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 3.562757] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 3.562768] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 3.562791] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 3.562812] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,reset_gpio = 233, flags = 0. [ 3.562829] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 3.562838] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 3.562892] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 3.562936] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 3.562976] [BT_RFKILL]: Enter rfkill_rk_init [ 3.563189] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 3.563217] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 3.563233] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 3.563248] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 3.563265] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 3.563357] [BT_RFKILL]: Request irq for bt wakeup host [ 3.563463] [BT_RFKILL]: ** disable irq [ 3.563549] [BT_RFKILL]: ap6493 &&&&&&&&&&&&&&&&&&&&& [ 3.563557] [BT_RFKILL]: ap6493 device registered. [ 3.564398] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess. [ 3.564802] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 3.564823] rk3288_init_suspend [ 3.564832] rk3288_suspend_init enter [ 3.564953] rk3288_suspend_init: pm_ctrbits =40017 [ 3.564985] gpio_get_dts_info suspend:8 [ 3.564993] gpio_get_dts_info resume:8 [ 3.565000] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 3.565033] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 3.565186] clks_gating_suspend_init:clkgt info ok [ 3.565288] Registering SWP/SWPB emulation handler [ 3.565316] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)! [ 3.565674] ddrfreq: verion 1.2 20140526 [ 3.565688] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz [ 3.565706] ddrfreq: auto-freq=0 [ 3.565713] ddrfreq: auto-freq-table[0] 240MHz [ 3.565721] ddrfreq: auto-freq-table[1] 324MHz [ 3.565727] ddrfreq: auto-freq-table[2] 456MHz [ 3.565734] ddrfreq: auto-freq-table[3] 528MHz [ 3.566282] regulator-dummy: disabling [ 3.566700] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered [ 3.566737] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 3.566756] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral [ 3.566873] pcd_pullup, is_on 0 [ 3.566934] file system registered [ 3.567670] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 3.567683] android_usb gadget: Number of LUNs=2 [ 3.567694] lun0: LUN: removable file: (no medium) [ 3.567702] lun1: LUN: removable file: (no medium) [ 3.567867] android_usb gadget: android_usb ready [ 3.567968] sensor_init: Probe name sensors [ 3.567991] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 3.568592] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:01 UTC (1293883201) [ 3.576611] usbcore: registered new interface driver snd-usb-audio [ 3.576627] ALSA device list: [ 3.576633] No soundcards found. [ 3.578977] Freeing unused kernel memory: 2364K (c0a84000 - c0cd3000) [ 3.579731] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok [ 3.585594] SELinux: Permission attach_queue in class tun_socket not defined in policy. [ 3.585616] SELinux: the above unknown classes and permissions will be denied [ 4.539781] rk_ehci_hcd_enable, enable host controller [ 4.785788] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host [ 4.935028] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608 [ 4.935039] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.935048] usb 1-1: Product: USB2.0 Hub [ 4.935844] hub 1-1:1.0: USB hub found [ 4.936135] hub 1-1:1.0: 4 ports detected [ 5.015886] type=1403 audit(1293883202.960:2): policy loaded auid=4294967295 ses=4294967295 [ 5.016035] SELinux: Loaded policy from /sepolicy [ 5.017561] type=1404 audit(1293883202.960:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 [ 6.142704] init: /dev/hw_random not found [ 6.143527] android_usb: already disabled [ 6.143631] android_usb: Cannot enable 'adb' (-22)init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 6.143766] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' [ 6.409392] iep dpi mode inactivity [ 10.894117] init: /sbin/e2fsck terminated by exit(8) [ 10.894146] init: Operational error while checking volume '/dev/block/platform/emmc/by-name/cache' [ 10.894256] init: Failed to mount /dev/block/platform/emmc/by-name/cache, format it to ext4 now [ 10.896353] init: /dev/hw_random not found [ 10.896482] init: Unable to open persistent property directory /data/property errno: 2 [ 10.897527] init: service 'recovery' requires console [ 10.897542] init: service 'console' requires console [ 10.897620] android_usb: already disabled [ 10.897726] android_usb: Cannot enable 'adb' (-22)pcd_pullup, is_on 1 [ 10.897782] init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead [ 10.897832] init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead [ 10.897877] init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead [ 10.897892] init: property 'ro.serialno' doesn't exist while expanding '$ro.serialno' [ 10.897904] init: cannot expand '$ro.serialno' while writing to '/sys/class/android_usb/android0/iSerial' [ 18.364990] *****************vbus detect******************* [ 18.544282] Using Buffer DMA mode [ 18.544302] Periodic Transfer Interrupt Enhancement - disabled [ 18.544311] Multiprocessor Interrupt Enhancement - disabled [ 18.544320] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 18.544330] ^^^^^^^^^^^^^^^^^Device Mode [ 18.544375] *******************soft connect!!!******************* [ 18.648615] USB RESET [ 18.815996] android_work: sent uevent USB_STATE=CONNECTED [ 18.819455] USB RESET [ 19.032638] WARN::ep0_do_stall:1298: req 80.06 protocol STALL; err -22 [ 19.032638] [ 19.071540] USB RESET [ 19.242563] USB RESET [ 19.537530] WARN::ep0_do_stall:1298: req 80.06 protocol STALL; err -22 [ 19.537530] [ 19.576341] USB RESET [ 19.747464] USB RESET [ 20.029396] WARN::ep0_do_stall:1298: req 80.06 protocol STALL; err -22 [ 20.029396] [ 20.068332] USB RESET [ 20.239205] USB RESET [ 20.541058] WARN::ep0_do_stall:1298: req 80.06 protocol STALL; err -22 [ 20.541058]
rk3288 烧写4.4.2后,卡在这里。改动了dts文件,在kernel->driver->spi中增加了一个spi驱动。
如果把新增的驱动去掉,能正常跑系统,那应该好好查查新增的驱动代码。
去掉新增驱动,还是不能正常启动系统
你是怎么重新升级的啊,我也碰到这个问题了
你重新烧一个完整的,能用的update.img,烧好之后,看下,能正常开机进系统,然后,再按分区烧入你编译的img。但是,不包括,loader和Parameter分区内容。烧成功之后,就可以绕过这个错误。
具体原因,我也不清楚。目前推测,这个错误跟loader有关,但,我又没改loader,所以,我觉得应该是我改dts导致的。
你都改了什么导致这个问题?
解决方式:
修改parameter文件中的CMDLINE字段中,改console=ttyFIQ0(本来是console=ttyS2).然后重新烧入,问题解决。
怎么输出日志的啊
为什么我用logcat输出的格式和你的都不一样啊
那是内核日志,dmesg或者cat /proc/kmsg可以获取
