各位大神,有没有遇到过3288的板子进入休眠模式后放了一段时间就死掉了,即按POWER按键无任何反应也无打印,但是各路供电还是正常,各位有没有遇到过这样的情况,帮忙分析下是什么原因?
烧哪个固件啊,把对应官方固件的log发上来
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-01 (Apr 07 2016 - 16:20:43)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
pmic:act8846
powerstate IReadLoaderFlag()=0
pmic_act8846_shut_down
Memory OK
Memory OK
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
powerstate=0,shuld power down
voltage=7423
fg:adc-battery
#Boot ver: 2016-04-07#2.19
empty serial no.
checkKey
wlt_checkRecovery key2=1,key6=1,key5=0
vbus = 0
voltage=7415
voltage=7328
read logo_on switch from dts [1]
pll_src = 0, dclk_hz = 120000000, dclk_div = 3
load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
mipi_dsi v1.3 2014-04-17
voltage=8098
base_offset=2000
Found entry:
path:
offset:0 size:172710
rk_pwm_config:brightness:180
failed to load fdt from boot!
kernel @ 0x02000000 (0x00587ef8)
ramdisk @ 0x04bf0000 (0x00124246)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0450c000, end 0452a388 … OK
[ 0.000000] Linux version 3.10.0 (tiantao@wlt) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #7 SMP PREEMPT Thu Apr 7 14:40:43 CST 2016
[ 0.000000] ion heap(cma): base(0) size(20000000) align(0)
[ 0.000000] cma: CMA: reserved 512 MiB at 60000000
[ 0.000000] ion_reserve: cma reserved base 60000000 size 536870912
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1cc2000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00180000@0x00414000(sys_update),-@0x00594000(user) storagemedia=emmc loader.timestamp=2016-04-07_16:20:43
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1520672k/1520672k available, 576480k reserved, 794624K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc09bba68 (9935 kB)
[ 0.000000] .init : 0xc09bc000 - 0xc0aa76c0 ( 942 kB)
[ 0.000000] .data : 0xc0aa8000 - 0xc0b6ce78 ( 788 kB)
[ 0.000000] .bss : 0xc0b6ce78 - 0xc0c8442c (1118 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 31
[ 0.000000] rkclk_init_clks: aclk_vio0 has been inited in uboot, ingored
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:19
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:15
[ 0.337520] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.337536] pid_max: default: 32768 minimum: 301
[ 0.337642] Security Framework initialized
[ 0.337659] SELinux: Initializing.
[ 0.337729] Mount-cache hash table entries: 512
[ 0.338372] Initializing cgroup subsys debug
[ 0.338387] Initializing cgroup subsys memory
[ 0.338413] Initializing cgroup subsys freezer
[ 0.338443] CPU: Testing write buffer coherency: ok
[ 0.338757] /cpus/cpu@0 missing clock-frequency property
[ 0.338770] /cpus/cpu@1 missing clock-frequency property
[ 0.338780] /cpus/cpu@2 missing clock-frequency property
[ 0.338788] /cpus/cpu@3 missing clock-frequency property
[ 0.338851] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.338901] Setting up static identity map for 0xc070f1e0 - 0xc070f238
[ 0.342290] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1699 (version 3.0)
[ 0.415617] CPU1: Booted secondary processor
[ 0.415649] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.435301] CPU2: Booted secondary processor
[ 0.435325] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.455011] CPU3: Booted secondary processor
[ 0.455035] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.455138] Brought up 4 CPUs
[ 0.455165] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.455174] CPU: All CPU(s) started in SVC mode.
[ 0.455908] devtmpfs: initialized
[ 0.460678] pinctrl core: initialized pinctrl subsystem
[ 0.460932] regulator-dummy: no parameters
[ 0.470130] NET: Registered protocol family 16
[ 0.471838] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.472125] ion_snapshot: 0x2e230000 map to 0xf0107000 and copy to 0xc0c5fbc4 (version 0.1)
[ 0.472452] Registered FIQ tty driver
[ 0.472882] fiq-debugger is disabled in device tree
[ 0.473384] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.473405] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.473421] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.473437] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.473527] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.473589] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.473650] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.473710] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.473780] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.473843] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.473902] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.473962] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.474029] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.474094] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.474108] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.474119] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.474130] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.474684] rockchip_interrupts_register:bank_num=7
[ 0.476645] rockchip_pinctrl_probe:init ok
[ 0.482776] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.482867] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.482881] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.483041] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.483118] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.483130] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.483289] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.483361] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.483374] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.483530] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.483601] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.483613] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.483783] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.483856] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.483869] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.484026] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.484099] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.484112] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.484315] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.484391] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.484404] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.486448] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.486462] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.486659] DDR DEBUG: version 1.00 20140603
[ 0.486690] DDR DEBUG: Channel a:
[ 0.486698] DDR DEBUG: DDR3 Device
[ 0.486711] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.486720] DDR DEBUG: Channel b:
[ 0.486727] DDR DEBUG: DDR3 Device
[ 0.486739] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.486748] DDR DEBUG: addr=0xb74000
[ 0.486757] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.486766] DDR DEBUG: socAddr[0]=0xb74000, socAddr[1]=0xb74100
[ 0.486775] DDR DEBUG: chAddr[0]=0xb74000, chAddr[1]=0xb74000
[ 0.486785] DDR DEBUG: dtar[0]=0x4016e000, dtar[1]=0x4016e000
[ 0.487027] DDR DEBUG: init success!!! freq=300MHz
[ 0.487035] DDR DEBUG: Channel a:
[ 0.487047] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487060] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487072] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487084] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487096] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.487105] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.487113] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.487120] DDR DEBUG: Channel b:
[ 0.487131] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487143] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487155] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487167] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487178] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.487186] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.487195] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.507702] bio: create slab at 0
[ 0.508506] SCSI subsystem initialized
[ 0.508649] usbcore: registered new interface driver usbfs
[ 0.508689] usbcore: registered new interface driver hub
[ 0.508768] usbcore: registered new device driver usb
[ 0.509024] rk3288-usb-control usb_control.33: invalid host gpio-2
[ 0.509044] rk3288-usb-control usb_control.33: invalid otg gpio-2
[ 0.510151] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.512272] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.512581] i2c i2c-2: 1 i2c clients have been registered at 0x1a
[ 0.513212] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.514000] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.514124] media: Linux media interface: v0.10
[ 0.514167] Linux video capture interface: v2.00
[ 0.514203] pps_core: LinuxPPS API ver. 1 registered
[ 0.514212] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.514231] PTP clock support registered
[ 0.514697] Rockchip ion module is successfully loaded (v1.0)
[ 0.514860] Advanced Linux Sound Architecture Driver Initialized.
[ 0.515406] cfg80211: Calling CRDA to update world regulatory domain
[ 0.516559] act8846_i2c_probe,line=901
[ 0.517537] act8846_parse_dt,line=746
[ 0.518199] lhm invalid gpio: -2
[ 0.518218] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.518237] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.518251] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.520077] act_dcdc1: 1200 mV
[ 0.522800] vccio: 3300 mV
[ 0.524661] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.527371] act_dcdc4: 2000 mV
[ 0.528619] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.530696] act_ldo2: 1000 mV
[ 0.532786] act_ldo3: 2500 mV
[ 0.534860] act_ldo4: 3300 mV
[ 0.536940] act_ldo5: 3300 mV
[ 0.539012] act_ldo6: 1000 mV
[ 0.541108] vcc_18: 1800 mV
[ 0.543183] act_ldo8: 1800 mV
[ 0.547964] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.552683] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.553411] Switching to clocksource arch_sys_counter
[ 0.573333] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.573344] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.573755] rk-screen rk_screen.8: rockchip screen probe success
[ 0.573924] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.573942] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.574249] rk32-edp ff970000.edp: screen is not edp!
[ 0.574264] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.574410] rk32-dsi
[ 0.574556] dsi->host.irq =51
[ 0.574574] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
[ 0.574582] mipi_dsi v1.3 2014-04-17
[ 0.574634] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 0.574646] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.575158] rk3288-lcdc lcdc0: request mipi_lcd_en gpio fail:-16
[ 0.575193] rk3288-lcdc lcdc0: request mipi_lcd_rst gpio fail:-16
[ 0.575421] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.575762] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.575911] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.576054] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.617626] rk3288-lcdc lcdc0: lcdc0: dclk:120000000>>fps:43
[ 0.617640] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.644487] alloc_buffer:ion_phy_addr=0x60000000
[ 0.657958] fb0:phy:60000000>>vir:f0171000>>len:0x1b00000
[ 0.657974] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
[ 0.658122] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.658134] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.658321] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.658607] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.658758] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.658908] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.707961] alloc_buffer:ion_phy_addr=0x61b00000
[ 0.707977] fb0:phy:61b00000>>vir: (null)>>len:0x3200000
[ 0.707992] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
[ 0.708645] rockchip_set_mux:warning ignore bank num 15
[ 0.708786] rockchip_set_mux:warning ignore bank num 15
[ 0.708893] rockchip_set_mux:warning ignore bank num 15
[ 0.708999] rockchip_set_mux:warning ignore bank num 15
[ 0.709109] rockchip_set_mux:warning ignore bank num 15
[ 0.709212] rockchip_set_mux:warning ignore bank num 15
[ 0.709771] rockchip_set_mux:warning ignore bank num 15
[ 0.709920] rockchip_set_mux:warning ignore bank num 15
[ 0.710467] rockchip_set_mux:warning ignore bank num 15
[ 0.710600] rockchip_set_mux:warning ignore bank num 15
[ 0.711155] rockchip_set_mux:warning ignore bank num 15
[ 0.711287] rockchip_set_mux:warning ignore bank num 15
[ 0.711842] rockchip_set_mux:warning ignore bank num 15
[ 0.711980] rockchip_set_mux:warning ignore bank num 15
[ 0.713336] NET: Registered protocol family 2
[ 0.713776] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.713908] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.714041] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.714089] TCP: reno registered
[ 0.714104] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.714137] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.714328] NET: Registered protocol family 1
[ 0.714508] Unpacking initramfs…
[ 0.777182] Freeing initrd memory: 1168K (c4bf0000 - c4d14000)
[ 0.777673] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.778154] probe device ff9a0000.vpu_service
[ 0.778330] vpu_service: power on
[ 0.779382] checking hw id 4831
[ 0.779749] vpu_service set to auto frequency mode
[ 0.779824] vpu_service: power off…
[ 0.779861] done
[ 0.779870] init success
[ 0.779916] probe device ff9c0000.hevc_service
[ 0.780106] hevc_service: power on
[ 0.781141] checking hw id 6867
[ 0.781365] hevc_service: power off…
[ 0.781402] done
[ 0.781409] init success
[ 0.781526] rknandbase v1.0 2014-03-31
[ 0.781619] rknand ff400000.nandc0: no irq resource?
[ 0.781742] rknand_driver:ret = 0
[ 0.782441] rk_dts_sensor_probe:Get ov2659 rockchip,powerdown failed!
[ 0.783003] audit: initializing netlink socket (disabled)
[ 0.783041] type=2000 audit(0.450:1): initialized
[ 0.783775] bounce pool size: 64 pages
[ 0.788207] fuse init (API version 7.22)
[ 0.788540] msgmni has been set to 1452
[ 0.790298] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.790311] io scheduler noop registered
[ 0.790320] io scheduler deadline registered
[ 0.790401] io scheduler cfq registered (default)
[ 0.793874] rga2 ff920000.rga: rga ion client create success!
[ 0.794007] rga: Driver loaded succesfully
[ 0.794626] IEP Driver loaded succesfully
[ 0.794720] Module initialized.
[ 0.795555] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.795571] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.796800] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.796816] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.797085] pwm-voltage-regulator pwm_regulator.28: unable to request PWM, trying legacy API
[ 0.797098] pwm-voltage-regulator pwm_regulator.28: unable to request legacy PWM
[ 0.797107] pwm_regulator_probe:error
[ 0.797129] platform pwm_regulator.28: Driver pwm-voltage-regulator requests probe deferral
[ 0.797457] rk_serial.c v1.8 2014-03-04
[ 0.797662] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.797841] serial ff180000.serial: membase f1c72000
[ 0.797990] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.798162] serial ff190000.serial: membase f1c74000
[ 0.798284] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 2.482762] console [ttyS2] enabled
[ 2.486378] serial ff690000.serial: membase fed60000
[ 2.491424] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 2.499144] serial ff1b0000.serial: membase f1c76000
[ 2.504178] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4
[ 2.511894] serial ff1c0000.serial: membase f1c7e000
[ 2.519434] loop: module loaded
[ 2.522778] wlt_keypad_init_driver
[ 2.526249] wlt_keypad_probe
[ 2.529558] input: wlt-keyboard as /devices/virtual/input/input0
[ 2.535527] wlt_gpio_init_driver
[ 2.538960] wlt_gpio_probe
[ 2.541782] rockchip_gpio_request:GPIO7-13
[ 2.545969] name:search_line – gpio:264 – is_use:use – gpio_or_irq:gpio
[ 2.552910] name:white_light – gpio:156 – is_use:use – gpio_or_irq:gpio
[ 2.559844] name:red_light – gpio:237 – is_use:use – gpio_or_irq:gpio
[ 2.566612] name:tdr_enable – gpio:79 – is_use:use – gpio_or_irq:gpio
[ 2.573377] name:dmm_clk – gpio:245 – is_use:use – gpio_or_irq:gpio
[ 2.579975] name:dmm_cd – gpio:236 – is_use:use – gpio_or_irq:gpio
[ 2.586486] name:uart_send_led – gpio:7 – is_use:use – gpio_or_irq:gpio
[ 2.593422] name:uart_recv_led – gpio:13 – is_use:use – gpio_or_irq:gpio
[ 2.600453] name:S485RE – gpio:176 – is_use:use – gpio_or_irq:gpio
[ 2.606954] name:S485DE – gpio:171 – is_use:use – gpio_or_irq:gpio
[ 2.613472] name:poe_emac_enable – gpio:179 – is_use:use – gpio_or_irq:gpio
[ 2.620750] name:poe_48V_enable – gpio:197 – is_use:use – gpio_or_irq:gpio
[ 2.627944] name:poe_12V_status – gpio:-1 – is_use:use – gpio_or_irq:gpio
[ 2.635052] name:poe_36V_status – gpio:-1 – is_use:use – gpio_or_irq:gpio
[ 2.642159] name:poe_45V_status – gpio:-1 – is_use:use – gpio_or_irq:gpio
[ 2.649266] name:poe_78V_status – gpio:-1 – is_use:use – gpio_or_irq:gpio
[ 2.656466] ioctl num:4
[ 2.658980] wlt_poe_init_driver
[ 2.662201] wlt_i2c_init
[ 2.664754] wlt_gpio_pull_init_driver
[ 2.668484] gt9xx_ts_init==
[ 2.671331] gt9xx : io request ok – wakeup_gpio : 259 int_gpio:257 IC Version: 928_1060
[ 2.780195] gt9xx : in my_gtp_read_version !=================
[ 2.785928] version :1060 gt9xx max x:1920 y:1200 ~~~~~~~~~~~~~~~~~~~~
[ 2.793297] input: gt9xx as /devices/virtual/input/input1
[ 2.798751] ret=0
[ 2.800847] gpio_reques gpio-sda 0
[ 2.804492] gpio_reques gpio-scl 0
[ 2.808107] userspace_i2c_probe
userspace_i2c_init_driver,ret=0
[ 2.814235] wlt_battery_detect_init_driver
[ 2.818464] rk1000_init
[ 2.820923] rk1000_control_probe ok
[ 2.824540] ============ misc_wlt_probe
misc_wlt_init_driver,ret=0
[ 2.831296] SCSI Media Changer driver v0.25
[ 2.835798] tun: Universal TUN/TAP device driver, 1.6
[ 2.840785] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.846983] vmac_init.
[ 2.849819] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 2.856513] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 2.863441] stmmac_probe_config_dt: clock input or output? (input).
[ 2.869618] stmmac_probe_config_dt: TX delay(0x30).
[ 2.874427] stmmac_probe_config_dt: RX delay(0x20).
[ 2.879266] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 2.884573] stmmc_pltfr_init:
[ 2.887777] stmmc_pltfr_init: init for RGMII
[ 2.891977] tx delay=0x30
[ 2.891977] rx delay=0x20
[ 2.897567] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.902533] Normal descriptors
[ 2.905637] Ring mode enabled
[ 2.908641] DMA HW capability register supported
[ 2.913095] RX Checksum Offload Engine supported (type 2)
[ 2.918689] TX Checksum insertion supported
[ 2.922887] Wake-Up On Lan supported
[ 2.926524] Enable RX Mitigation via HW Watchdog Timer
[ 2.932072] PPP generic driver version 2.4.2
[ 2.936432] PPP BSD Compression module registered
[ 2.941073] PPP Deflate Compression module registered
[ 2.946063] PPP MPPE Compression module registered
[ 2.950774] NET: Registered protocol family 24
[ 2.955173] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 2.964683] CSLIP: code copyright 1989 Regents of the University of California.
[ 2.971869] Rockchip WiFi SYS interface (V1.00) …
[ 2.976838] usbcore: registered new interface driver rtl8150
[ 2.982433] usbcore: registered new interface driver r8152
[ 2.987843] hso: drivers/net/usb/hso.c: Option Wireless
[ 2.993037] usbcore: registered new interface driver hso
[ 2.998274] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.007059] ehci_rk_probe f1d00000 f1d00010
[ 3.011178] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 3.018649] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 3.027068] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 3.052833] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 3.059412] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.066103] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.073215] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 3.079477] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 3.084798] usb usb1: SerialNumber: ff500000.usb
[ 3.089732] hub 1-0:1.0: USB hub found
[ 3.093448] hub 1-0:1.0: 1 port detected
[ 3.121711] ehci_rk_probe ok
[ 3.124668] usbcore: registered new interface driver cdc_wdm
[ 3.130233] usb20_otg: version 3.10a 21-DEC-2012
[ 3.135122] f1d80040
[ 3.137276] Core Release: 3.10a
[ 3.140370] Setting default values for core params
[ 3.145220] Using Buffer DMA mode
[ 3.148482] Periodic Transfer Interrupt Enhancement - disabled
[ 3.154228] Multiprocessor Interrupt Enhancement - disabled
[ 3.159706] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.164001] ^^^^^^^^^^^^^^^^^Device Mode
[ 3.167873] Dedicated Tx FIFOs mode
[ 3.171321] pcd_init otg_dev = c49b5b00
[ 3.175234] usb20_otg ff580000.usb: DWC OTG Controller
[ 3.180300] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.187687] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 3.193442] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.200120] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.207234] usb usb2: Product: DWC OTG Controller
[ 3.211883] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.217448] usb usb2: SerialNumber: ff580000.usb
[ 3.222338] hub 2-0:1.0: USB hub found
[ 3.226037] hub 2-0:1.0: 1 port detected
[ 3.230194] usb20_host: version 3.10a 21-DEC-2012
[ 3.237282] f1e00040
[ 3.239436] Core Release: 3.10a
[ 3.242541] Setting default values for core params
[ 3.247336] Using Buffer DMA mode
[ 3.250611] Periodic Transfer Interrupt Enhancement - disabled
[ 3.256356] Multiprocessor Interrupt Enhancement - disabled
[ 3.261845] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.266128] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.269927] usb20_host ff540000.usb: DWC OTG Controller
[ 3.275077] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 3.282555] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 3.288369] Init: Power Port (0)
[ 3.291597] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.298274] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.305399] usb usb3: Product: DWC OTG Controller
[ 3.310037] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.315602] usb usb3: SerialNumber: ff540000.usb
[ 3.320507] hub 3-0:1.0: USB hub found
[ 3.324203] hub 3-0:1.0: 1 port detected
[ 3.328945] usbcore: registered new interface driver xpad
[ 3.334290] usbcore: registered new interface driver usb_acecad
[ 3.340159] usbcore: registered new interface driver aiptek
[ 3.345669] usbcore: registered new interface driver gtco
[ 3.351036] usbcore: registered new interface driver hanwang
[ 3.356628] usbcore: registered new interface driver kbtab
[ 3.362070] usbcore: registered new interface driver wacom
[ 3.372377] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 3.378691] i2c /dev entries driver
[ 3.382743] usbcore: registered new interface driver uvcvideo
[ 3.388412] USB Video Class driver (1.1.1)
[ 3.392459] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0
[ 3.402042] rockchip_temp_probe,line=362
[ 3.456290] tsadc ff280000.tsadc: initialized
[ 3.460934] device-mapper: uevent: version 1.0.3
[ 3.465692] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 3.477255] cpufreq version 1.0, suspend freq 1200 MHz
[ 3.482487] cpuidle: using governor ladder
[ 3.486551] cpuidle: using governor menu
[ 3.490436] Synopsys Designware Multimedia Card Interface Driver
[ 3.496601] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 3.502663] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 3.509669] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 3.516116] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 3.521958] 1390..dw_mci_set_ios: no card. [mmc0]
[ 3.544829] 1390..dw_mci_set_ios: no card. [mmc0]
[ 3.564540] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 3.564606] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 3.564647] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 3.565019] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 3.595085] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 3.602169] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
[ 3.608554] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 3.614422] mmc1: no vmmc regulator found
[ 3.618545] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 3.625382] 1390..dw_mci_set_ios: no card. [mmc1]
[ 3.643226] 1390..dw_mci_set_ios: no card. [mmc1]
[ 3.647963] mmc0: BKOPS_EN bit is not set
[ 3.653836] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 3.663526] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 3.663611] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 3.663621] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 3.663930] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.665716] usbcore: registered new interface driver usbhid
[ 3.665723] usbhid: USB HID core driver
[ 3.666091] zram: Created 1 device(s) …
[ 3.666491] ashmem: initialized
[ 3.666630] logger: created 256K log ‘log_main’
[ 3.666756] logger: created 256K log ‘log_events’
[ 3.666875] logger: created 256K log ‘log_radio’
[ 3.666995] logger: created 256K log ‘log_system’
[ 3.667895] wlt_battery_detect_probe
[ 3.668316] charge_detect probe ok[78] !
[ 3.669003] input: rk29-keypad as /devices/ff100000.adc/key.40/input/input2
[ 3.670009] wm8960_i2c_probe tiantao added
[ 3.670155] wm8960_i2c_probe() Can not read snd_soc_register_codec ret=0
[ 3.752785] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
[ 3.759403] mmc0: new high speed MMC card at address 0001
[ 3.765085] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB
[ 3.769802] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 3.770621] wm8960_probe request gpio_request tiantao enterwm8960_probe request gpio_request tiantao exit
[ 3.770625] wm8960 2-001a-1: ASoC: Failed to create MICB debugfs file
[ 3.770884] wm8960_hifi_codec_set_dai_sysclk freq=11289600
[ 3.784616] capacity:72
[ 3.798815] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 3.804144] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 3.809546] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 3.814950] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 3.820370] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 3.825775] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 3.825911] rockchip-wm8960 rockchip-wm8960.32: WM8960 HiFi ↔ rockchip-i2s.0 mapping ok
[ 3.826334] input: RK_WM8960 Headphone Jack as /devices/rockchip-wm8960.32/sound/card0/input3
[ 3.847679] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 3.853165] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 3.858471] system: 0x012400000 – 0x042400000 (768 MB)
[ 3.863976] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 3.864079] rockchip-hdmi-i2s rockchip-hdmi-i2s.31: rk-hdmi-i2s-hifi ↔ rockchip-i2s.0 mapping ok
[ 3.864480] u32 classifier
[ 3.864484] Actions configured
[ 3.864492] Netfilter messages via NETLINK v0.30.
[ 3.864536] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.864839] ctnetlink v0.93: registering with nfnetlink.
[ 3.864893] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 3.864897] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 3.865132] xt_time: kernel timezone is -0000
[ 3.865322] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.865440] arp_tables: (C) 2002 David S. Miller
[ 3.865474] TCP: cubic registered
[ 3.865479] Initializing XFRM netlink socket
[ 3.865678] NET: Registered protocol family 10
[ 3.866171] mip6: Mobile IPv6
[ 3.866192] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.866299] sit: IPv6 over IPv4 tunneling driver
[ 3.866597] NET: Registered protocol family 17
[ 3.866615] NET: Registered protocol family 15
[ 3.866664] Bridge firewalling registered
[ 3.866671] Ebtables v2.0 registered
[ 3.866724] l2tp_core: L2TP core driver, V2.0
[ 3.866736] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.866740] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.866901] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.866908] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtkwifi
[ 3.866915] [WLAN_RFKILL]: wlan_platdata_parse_dt: Can’t get sdio vref.
[ 3.866917] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.866922] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 3.866926] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.866943] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 262, flags = 0.
[ 3.866955] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.866974] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.867012] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.867927]
[ 3.867927] ----------------lcd drv name: lcdc0 id:0
[ 3.867927] ----------------lcd drv name: lcdc1 id:1
[ 3.867934] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 3.868437] rk_cam_cif(3090):rk312x-camera version: v0.1.9 Zoom by ipp
[ 3.868455] rk_sensor_io_init_end=0here test
[ 3.868582] soc-camera-pdrv ov2659_back_3: Probing ov2659_back_3
[ 3.908946] camera power=0camera power=1ret: 0
[ 3.948556] min_w = 720,min_h = 480 ,max_real_w = 720,max_real_h = 576,max_w = 720,max_h =576
[ 3.967969] ov2659_back_3(rk_cam_sensor:720): error: mismatched pid = 0x0,but contiued by tt
[ 3.967969]
[ 3.968108] rk_camera_probe succeed
[ 4.104639] VFP support v0.3: [ 4.104666] userdata: 0x042800000 – 0x082800000 (1024 MB)
[ 4.104671] sys_update: 0x082800000 – 0x0b2800000 (768 MB)
[ 4.104676] user: 0x0b2800000 – 0x1d1c00000 (4596 MB)
[ 4.104696] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1]
[ 4.133549] implementor 41 architecture 3 part 30 variant d rev 0
[ 4.139726] rk3288_init_suspend
[ 4.142812] rk3288_suspend_init enter
[ 4.146547] rk3288_suspend_init: pm_ctrbits =200007
[ 4.151355] gpio_get_dts_info suspend:4
[ 4.155130] gpio_get_dts_info resume:4
[ 4.158811] rockchip,pmic-suspend_gpios:4007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 4.166806] rockchip,pmic-resume_gpios:1007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 4.174807] clks_gating_suspend_init:clkgt info ok
[ 4.179587] Registering SWP/SWPB emulation handler
[ 4.184557] ddrfreq: verion 1.2 20140526
[ 4.188414] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
[ 4.199463] ddrfreq: auto-freq=0
[ 4.202642] ddrfreq: auto-freq-table[0] 240MHz
[ 4.207023] ddrfreq: auto-freq-table[1] 324MHz
[ 4.211398] ddrfreq: auto-freq-table[2] 396MHz
[ 4.215775] ddrfreq: auto-freq-table[3] 528MHz
[ 4.231864] regulator-dummy: disabling
[ 4.235760] rk1000_tve_init
[ 4.253320] parse_dt_and_reset_gpio::259
[ 4.470666] rk1000 tvencoder ver 2.0 probe ok
[ 4.475856] pcd_pullup, is_on 0
[ 4.479294] file system registered
[ 4.489186] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 4.496160] android_usb gadget: Number of LUNs=2
[ 4.500938] lun0: LUN: removable file: (no medium)
[ 4.505788] lun1: LUN: removable file: (no medium)
[ 4.511609] android_usb gadget: android_usb ready
[ 4.517023] rtc_hym8563 0-0051: setting system clock to 2011-01-02 06:50:52 UTC (1293951052)
[ 4.554227] rk_spdif:rk_spdif_init
[ 4.557870] rk_spdif:Entered spdif_probe
[ 4.562119] rk_spdif:spdif:spdif probe ok!
[ 4.566654] ALSA device list:
[ 4.569622] #0: RK_WM8960
[ 4.572400] #1: RK-HDMI-I2S
[ 4.576461] Freeing unused kernel memory: 940K (c09bc000 - c0aa7000)
[ 4.590789] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 4.598820] SELinux: the above unknown classes and permissions will be denied
[ 4.656753] only power
[ 4.659249] capacity:100
[ 4.827792] type=1403 audit(1293951052.810:2): policy loaded auid=4294967295 ses=4294967295
[ 4.836124] SELinux: Loaded policy from /sepolicy
[ 4.842623] type=1404 audit(1293951052.820:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 5.099561] rk_ehci_hcd_enable, enable host controller
[ 5.345569] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host
[ 5.494682] usb 1-1: New USB device found, idVendor=0bda, idProduct=8179
[ 5.501269] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.508297] usb 1-1: Product: 802.11n WLAN NIC
[ 5.512663] usb 1-1: Manufacturer: Realtek
[ 5.807331] init: could not import file ‘/init.usbstorage.rc’ from ‘/init.rc’
[ 5.814415] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 5.893082] init: /dev/hw_random not found
[ 5.897252] keychord: using input dev rk29-keypad for fevent
[ 5.909063] fs_mgr: parse_link_device : path = NULL
[ 5.913877] fs_mgr: parse_link_device : path = NULL
[ 5.918718] fs_mgr: parse_link_device : path = NULL
[ 5.923574] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 5.942215] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 5.960542] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 5.977781] EXT4-fs (mmcblk0p8): recovery complete
[ 5.982992] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 5.993969] EXT4-fs (mmcblk0p11): warning: mounting unchecked fs, running e2fsck is recommended
[ 6.003043] EXT4-fs (mmcblk0p11): mounted filesystem without journal. Opts: noauto_da_alloc,discard
[ 6.117994] EXT4-fs (mmcblk0p12): warning: mounting fs with errors, running e2fsck is recommended
[ 6.127318] EXT4-fs (mmcblk0p12): recovery complete
[ 6.132582] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 6.162535] mali pd enabled
[ 6.165282] clk enabled
[ 6.168846] MALI_DVFS_STEP=5,div_dvfs=7
[ 6.172647] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
[ 6.179658] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77
[ 6.186877] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84
[ 6.194104] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
[ 6.201293] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
[ 6.208695] gpufreq_input_connect
[ 6.211987] turn on mali power
[ 6.214994] kbase_platform_rk_init,register_reboot_notifier
[ 6.220485] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 6.227300] mali ffa30000.gpu: Probed as mali0
[ 6.234443] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 6.255077] init: /dev/hw_random not found
[ 6.266546] binder: 149:149 transaction failed 29189, size 0-0
[ 6.289764] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 6.297663] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 6.307467] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 6.339624] warning: `daemonsu’ uses 32-bit capabilities (legacy support in use)
[ 6.388645] userspace_i2c_ioctl,cmd=-2147194624
[ 6.453048] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 6.461139] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 6.466637] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
[ 6.477208] userspace_i2c_ioctl,cmd=-2147194623
[ 6.481900] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
[ 6.492762] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
[ 6.503573] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
[ 6.515775] android_usb: already disabled
[ 6.522112] read descriptors
[ 6.524957] read strings
[ 6.527562] pcd_pullup, is_on 1
[ 6.536245] userspace_i2c_ioctl,cmd=-2147194624
shell@rk3288:/ $ [ 6.560169] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
[ 6.624809] userspace_i2c_ioctl,cmd=-2147194623
[ 6.635404] fs_mgr: parse_link_device : path = NULL
[ 6.640236] fs_mgr: parse_link_device : path = NULL
[ 6.645159] fs_mgr: parse_link_device : path = NULL
[ 6.672690] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
[ 6.683843] userspace_i2c_ioctl,cmd=-2147194624
[ 6.772468] userspace_i2c_ioctl,cmd=-2147194623
[ 6.785267] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
[ 6.832497] userspace_i2c_ioctl,cmd=-2147194624
[ 7.466653] ov2659_back_3(rk_cam_sensor:1229): generic_sensor_ioctl cmd(0x3) is unknown !
[ 7.466653]
[ 7.476233] camera power=1camera power=1ret: 0
[ 7.550145] ret: 0
[ 7.726917] g_ts_data.irq: 196 [ 7.954976] rk3288-lcdc lcdc0: blank mode:0
[ 8.037487] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
[ 13.040879] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 13.133813] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 13.140877] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 13.146186] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 13.151630] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 13.157133] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 13.162678] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 13.168158] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 13.397005] wifi_driver_write: wifi driver already rmmod
[ 13.414968] phy_power_on: enable = 1
[ 13.458000] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 13.464539] eth0: device MAC address aa:c3:2b:40:2b:de
[ 13.473655] libphy: stmmac: probed
[ 13.477005] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 13.482992] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 13.629881] acc_open
[ 13.632121] acc_release
[ 14.437847] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 14.493502] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
[ 14.506244] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec
[ 14.513609] init: no such service ‘fuse_internal_sd’
[ 15.031664] init: sys_prop: permission denied uid:10023 name:sys.gmali.version
[ 15.053068] init: sys_prop: permission denied uid:10006 name:sys.gmali.version
[ 16.129370] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 16.271597] f2ad9234,f2ad9234,f2ad9234
[ 17.040403] type=1400 audit(1293951065.220:4): avc: denied { getattr } for pid=935 comm=“doujia.phoenix2” path=“/data/app” dev=“mmcblk0p12” ino=24578 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir permissive=1
[ 17.469141] type=1400 audit(1293951065.660:5): avc: denied { setattr } for pid=954 comm=“chmod” name=“tmp” dev=“mmcblk0p12” ino=25 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:shell_data_file:s0 tclass=dir permissive=1
[ 17.486111] type=1400 audit(1293951065.670:6): avc: denied { setattr } for pid=957 comm=“chmod” name=“.udid” dev=“mmcblk0p12” ino=410 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:shell_data_file:s0 tclass=file permissive=1
[ 28.278269]
[ 28.278269] ------------------- gt9xx_early_suspend
[ 28.293371] <<-GTP-INFO->> GTP enter sleep!
[ 28.361705] rk3288-hdmi ff980000.hdmi: Removed.
[ 28.604010] rk3288-lcdc lcdc0: blank mode:4
[ 65.311768] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 73.283733] PM: suspend entry 2011-01-02 06:52:02.384842949 UTC
[ 73.289701] PM: Syncing filesystems … done.
[ 73.317378] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 73.327962] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 73.337753] Suspending console(s) (use no_console_suspend to debug)
01-armoff-logdp-osc_offddrc_off2345dDd543210
[ 73.346107] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 73.346119] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 73.346129] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 73.348007] dwc_otg_hcd_suspend, usb device mode
[ 73.349853] hym8563_rtc_set_alarm:diff_sec= 4s , use time
[ 73.352221] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 73.352930] phy_power_on: enable = 0
[ 73.381333] PM: suspend of devices complete after 35.864 msecs
[ 73.382499] PM: late suspend of devices complete after 1.159 msecs
[ 73.383916] PM: noirq suspend of devices complete after 1.416 msecs
[ 73.383927] Disabling non-boot CPUs …
[ 73.386289] CPU1: shutdown
[ 73.391640] CPU2: shutdown
[ 73.396291] CPU3: shutdown
[ 73.399901] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 73.399969] rkpm_enter:
[ 73.399987] GPIO0_INTEN: 00000020
[ 73.399995] GPIO6_INTEN: 00400000
[ 73.400006] GPIO7_INTEN: 00000010
[ 73.482890] Resume caused by IRQ 120
[ 73.482929] Resume but desc dont’t have name
[ 73.482955] wakeup irq: 00000000 00000000 01000000 00000000
[ 73.482967] wakeup gpio7: 00000010
[ 73.483161] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 73.483191] Suspended for 0.000 seconds
[ 73.484103] Enabling non-boot CPUs …
[ 73.484852] CPU1: Booted secondary processor
[ 73.486146] CPU1 is up
[ 73.486550] CPU2: Booted secondary processor
[ 73.487192] CPU2 is up
[ 73.487617] CPU3: Booted secondary processor
[ 73.488240] CPU3 is up
[ 73.490759] PM: noirq resume of devices complete after 2.522 msecs
[ 73.491626] PM: early resume of devices complete after 0.503 msecs
[ 73.492012] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 73.492029] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 73.492504] 1390..dw_mci_set_ios: no card. [mmc1]
[ 73.492705] dwc_otg_hcd_resume, usb device mode
[ 73.497744] phy_power_on: enable = 1
[ 73.532570] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 73.758075] usb 1-1: reset high-speed USB device number 2 using rockchip_ehci_host
[ 73.906332] PM: resume of devices complete after 421.418 msecs
[ 73.906588] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 73.906602] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 73.906612] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 74.129285] Restarting tasks … done.
[ 74.135260] PM: suspend exit 2011-01-02 06:52:06.611130334 UTC
[ 74.146316] PM: suspend entry 2011-01-02 06:52:06.622364167 UTC
[ 74.152267] PM: Syncing filesystems … done.
[ 74.161077] Freezing user space processes … (elapsed 0.005 seconds) done.
[ 74.173554] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 74.183295] Suspending console(s) (use no_console_suspend to debug)
[ 74.191879] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 74.191901] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 74.191914] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 74.193870] dwc_otg_hcd_suspend, usb device mode
[ 74.195861] hym8563_rtc_set_alarm:diff_sec= 48s , use time
[ 74.198254] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 74.199009] phy_power_on: enable = 0
[ 74.212254] PM: suspend of devices complete after 20.769 msecs
[ 74.213382] PM: late suspend of devices complete after 1.122 msecs
[ 74.214584] PM: noirq suspend of devices complete after 1.195 msecs
[ 74.214605] Disabling non-boot CPUs …
[ 74.216904] CPU1: shutdown
[ 74.220718] CPU2: shutdown
[ 74.223691] CPU3: shutdown
[ 74.225291] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 74.225351] rkpm_enter:
[ 74.225369] GPIO0_INTEN: 00000020
[ 74.225385] GPIO6_INTEN: 00400000
[ 74.225393] GPIO7_INTEN: 00000010
[ 74.308617] Resume caused by IRQ 120
[ 74.308653] Resume but desc dont’t have name
[ 74.308678] wakeup irq: 00000000 00000000 01000000 00000000
[ 74.308687] wakeup gpio7: 00000010
[ 74.308878] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 74.308912] Suspended for 0.000 seconds
[ 74.309817] Enabling non-boot CPUs …
[ 74.310551] CPU1: Booted secondary processor
[ 74.311867] CPU1 is up
[ 74.312271] CPU2: Booted secondary processor
[ 74.312921] CPU2 is up
[ 74.313348] CPU3: Booted secondary processor
[ 74.313952] CPU3 is up
[ 74.316758] PM: noirq resume of devices complete after 2.815 msecs
[ 74.317614] PM: early resume of devices complete after 0.499 msecs
[ 74.318062] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 74.318079] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 74.318365] 1390..dw_mci_set_ios: no card. [mmc1]
[ 74.318562] dwc_otg_hcd_resume, usb device mode
[ 74.323608] phy_power_on: enable = 1
[ 74.358351] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 74.360717] PM: resume of devices complete after 43.771 msecs
[ 74.361024] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 74.361040] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 74.361050] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 74.576821] Restarting tasks … done.
[ 74.586666] PM: suspend exit 2011-01-02 06:52:54.230759083 UTC
[ 74.633863] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 74.641066] PM: suspend entry 2011-01-02 06:52:54.286058792 UTC
[ 74.646972] PM: Syncing filesystems … done.
[ 74.665085] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 74.675747] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 74.685854] Suspending console(s) (use no_console_suspend to debug)
[ 74.694262] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 74.694292] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 74.694304] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 74.696265] dwc_otg_hcd_suspend, usb device mode
[ 74.698327] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 74.700825] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 74.701544] phy_power_on: enable = 0
[ 74.703168] PM: suspend of devices complete after 9.124 msecs
[ 74.704286] PM: late suspend of devices complete after 1.111 msecs
[ 74.705615] PM: noirq suspend of devices complete after 1.333 msecs
[ 74.705636] Disabling non-boot CPUs …
[ 74.707813] CPU1: shutdown
[ 74.711837] CPU2: shutdown
[ 74.715379] CPU3: shutdown
[ 74.718039] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 74.718091] rkpm_enter:
[ 74.718112] GPIO0_INTEN: 00000020
[ 74.718125] GPIO6_INTEN: 00400000
[ 74.718133] GPIO7_INTEN: 00000010
[ 74.801577] Resume caused by IRQ 120
[ 74.801612] Resume but desc dont’t have name
[ 74.801635] wakeup irq: 00000000 00000000 01000000 00000000
[ 74.801644] wakeup gpio7: 00000010
[ 74.801836] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 74.801868] Suspended for 0.000 seconds
[ 74.802781] Enabling non-boot CPUs …
[ 74.803537] CPU1: Booted secondary processor
[ 74.804853] CPU1 is up
[ 74.805267] CPU2: Booted secondary processor
[ 74.805938] CPU2 is up
[ 74.806349] CPU3: Booted secondary processor
[ 74.806962] CPU3 is up
[ 74.809568] PM: noirq resume of devices complete after 2.615 msecs
[ 74.810462] PM: early resume of devices complete after 0.520 msecs
[ 74.810953] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 74.810970] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 74.811440] 1390..dw_mci_set_ios: no card. [mmc1]
[ 74.811622] dwc_otg_hcd_resume, usb device mode
[ 74.816661] phy_power_on: enable = 1
[ 74.851414] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 75.077108] usb 1-1: reset high-speed USB device number 2 using rockchip_ehci_host
[ 75.225511] PM: resume of devices complete after 421.772 msecs
[ 75.225862] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 75.225873] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 75.225885] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 75.448789] Restarting tasks … done.
[ 75.454626] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 75.460718] PM: suspend exit 2011-01-02 06:53:54.617744459 UTC
[ 75.556993] PM: suspend entry 2011-01-02 06:53:54.715579667 UTC
[ 75.563038] PM: Syncing filesystems … done.
[ 75.574720] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 75.585605] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 75.595507] Suspending console(s) (use no_console_suspend to debug)
[ 75.603791] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 75.603816] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 75.603826] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 75.605811] dwc_otg_hcd_suspend, usb device mode
[ 75.608980] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 75.611383] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 75.612138] phy_power_on: enable = 0
[ 75.613751] PM: suspend of devices complete after 10.179 msecs
[ 75.614869] PM: late suspend of devices complete after 1.109 msecs
[ 75.616160] PM: noirq suspend of devices complete after 1.282 msecs
[ 75.616182] Disabling non-boot CPUs …
[ 75.618390] CPU1: shutdown
[ 75.621988] CPU2: shutdown
[ 75.624901] CPU3: shutdown
[ 75.627434] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 75.627497] rkpm_enter:
[ 75.627508] GPIO0_INTEN: 00000020
[ 75.627517] GPIO6_INTEN: 00400000
[ 75.627528] GPIO7_INTEN: 00000010
[ 75.710617] Resume caused by IRQ 120
[ 75.710652] Resume but desc dont’t have name
[ 75.710677] wakeup irq: 00000000 00000000 01000000 00000000
[ 75.710689] wakeup gpio7: 00000010
[ 75.710876] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 75.710909] Suspended for 0.000 seconds
[ 75.712323] Enabling non-boot CPUs …
[ 75.713019] CPU1: Booted secondary processor
[ 75.714212] CPU1 is up
[ 75.714615] CPU2: Booted secondary processor
[ 75.715213] CPU2 is up
[ 75.715639] CPU3: Booted secondary processor
[ 75.716224] CPU3 is up
[ 75.718812] PM: noirq resume of devices complete after 2.594 msecs
[ 75.719646] PM: early resume of devices complete after 0.520 msecs
[ 75.720033] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 75.720057] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 75.720309] 1390..dw_mci_set_ios: no card. [mmc1]
[ 75.720485] dwc_otg_hcd_resume, usb device mode
[ 75.725597] phy_power_on: enable = 1
[ 75.760373] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 75.977496] usb 1-1: reset high-speed USB device number 2 using rockchip_ehci_host
[ 76.125997] PM: resume of devices complete after 412.932 msecs
[ 76.126364] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 76.126379] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 76.126388] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 76.349063] Restarting tasks … done.
[ 76.354826] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 76.360691] PM: suspend exit 2011-01-02 06:54:54.608663125 UTC
[ 76.423772] PM: suspend entry 2011-01-02 06:54:54.672803250 UTC
[ 76.429621] PM: Syncing filesystems … done.
[ 76.444447] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 76.455295] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 76.465203] Suspending console(s) (use no_console_suspend to debug)
[ 76.473720] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 76.473745] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 76.473755] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 76.476654] dwc_otg_hcd_suspend, usb device mode
[ 76.477554] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 76.479992] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 76.480693] phy_power_on: enable = 0
[ 76.482470] PM: suspend of devices complete after 8.951 msecs
[ 76.483600] PM: late suspend of devices complete after 1.122 msecs
[ 76.484860] PM: noirq suspend of devices complete after 1.259 msecs
[ 76.484878] Disabling non-boot CPUs …
[ 76.487108] CPU1: shutdown
[ 76.490964] CPU2: shutdown
[ 76.493778] CPU3: shutdown
[ 76.495460] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 76.495526] rkpm_enter:
[ 76.495545] GPIO0_INTEN: 00000020
[ 76.495560] GPIO6_INTEN: 00400000
[ 76.495568] GPIO7_INTEN: 00000010
[ 76.578682] Resume caused by IRQ 120
[ 76.578717] Resume but desc dont’t have name
[ 76.578743] wakeup irq: 00000000 00000000 01000000 00000000
[ 76.578755] wakeup gpio7: 00000010
[ 76.578946] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 76.578976] Suspended for 0.000 seconds
[ 76.579882] Enabling non-boot CPUs …
[ 76.580618] CPU1: Booted secondary processor
[ 76.581965] CPU1 is up
[ 76.582373] CPU2: Booted secondary processor
[ 76.583134] CPU2 is up
[ 76.583559] CPU3: Booted secondary processor
[ 76.584154] CPU3 is up
[ 76.586694] PM: noirq resume of devices complete after 2.548 msecs
[ 76.587542] PM: early resume of devices complete after 0.483 msecs
[ 76.587936] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 76.587950] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 76.588394] 1390..dw_mci_set_ios: no card. [mmc1]
[ 76.588606] dwc_otg_hcd_resume, usb device mode
[ 76.593759] phy_power_on: enable = 1
[ 76.628536] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 76.848333] usb 1-1: reset high-speed USB device number 2 using rockchip_ehci_host
[ 76.996873] PM: resume of devices complete after 415.953 msecs
[ 76.997112] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 76.997124] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 76.997137] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 77.219859] Restarting tasks … [ 77.225199] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 77.225399] PM: suspend exit 2011-01-02 06:55:54.605271917 UTC
done.
[ 77.294606] PM: suspend entry 2011-01-02 06:55:54.675580209 UTC
[ 77.301144] PM: Syncing filesystems … done.
[ 77.311472] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 77.322230] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 77.332233] Suspending console(s) (use no_console_suspend to debug)
[ 77.340532] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 77.340545] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 77.340561] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 77.342416] dwc_otg_hcd_suspend, usb device mode
[ 77.344568] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 77.346846] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 77.347601] phy_power_on: enable = 0
[ 77.361603] PM: suspend of devices complete after 21.447 msecs
[ 77.362845] PM: late suspend of devices complete after 1.228 msecs
[ 77.364175] PM: noirq suspend of devices complete after 1.323 msecs
[ 77.364191] Disabling non-boot CPUs …
[ 77.366426] CPU1: shutdown
[ 77.370032] CPU2: shutdown
[ 77.372721] CPU3: shutdown
[ 77.374542] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 77.374601] rkpm_enter:
[ 77.374623] GPIO0_INTEN: 00000020
[ 77.374635] GPIO6_INTEN: 00400000
[ 77.374643] GPIO7_INTEN: 00000010
[ 77.458070] Resume caused by IRQ 120
[ 77.458104] Resume but desc dont’t have name
[ 77.458130] wakeup irq: 00000000 00000000 01000000 00000000
[ 77.458142] wakeup gpio7: 00000010
[ 77.458340] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 77.458378] Suspended for 0.000 seconds
[ 77.459280] Enabling non-boot CPUs …
[ 77.460008] CPU1: Booted secondary processor
[ 77.461282] CPU1 is up
[ 77.461702] CPU2: Booted secondary processor
[ 77.462364] CPU2 is up
[ 77.462770] CPU3: Booted secondary processor
[ 77.463365] CPU3 is up
[ 77.466140] PM: noirq resume of devices complete after 2.787 msecs
[ 77.466988] PM: early resume of devices complete after 0.516 msecs
[ 77.467378] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 77.467392] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 77.467699] 1390..dw_mci_set_ios: no card. [mmc1]
[ 77.467903] dwc_otg_hcd_resume, usb device mode
[ 77.472960] phy_power_on: enable = 1
[ 77.507717] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 77.729358] usb 1-1: reset high-speed USB device number 2 using rockchip_ehci_host
[ 77.877736] PM: resume of devices complete after 417.405 msecs
[ 77.878091] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 77.878102] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 77.878115] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 78.101500] Restarting tasks … done.
[ 78.107042] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 78.113475] PM: suspend exit 2011-01-02 06:56:54.614278292 UTC
[ 78.178974] PM: suspend entry 2011-01-02 06:56:54.680815917 UTC
[ 78.185008] PM: Syncing filesystems … done.
[ 78.195630] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 78.206692] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 78.216496] Suspending console(s) (use no_console_suspend to debug)
[ 78.224885] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 78.224903] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 78.224915] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 78.226890] dwc_otg_hcd_suspend, usb device mode
[ 78.228846] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 78.231320] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 78.232062] phy_power_on: enable = 0
[ 78.233805] PM: suspend of devices complete after 9.107 msecs
[ 78.234883] PM: late suspend of devices complete after 1.061 msecs
[ 78.236123] PM: noirq suspend of devices complete after 1.235 msecs
[ 78.236148] Disabling non-boot CPUs …
[ 78.238312] CPU1: shutdown
[ 78.241840] CPU2: shutdown
[ 78.244523] CPU3: shutdown
[ 78.246308] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 78.246368] rkpm_enter:
[ 78.246389] GPIO0_INTEN: 00000020
[ 78.246402] GPIO6_INTEN: 00400000
[ 78.246413] GPIO7_INTEN: 00000010
[ 78.329559] Resume caused by IRQ 120
[ 78.329593] Resume but desc dont’t have name
[ 78.329624] wakeup irq: 00000000 00000000 01000000 00000000
[ 78.329636] wakeup gpio7: 00000010
[ 78.329828] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 78.329863] Suspended for 0.000 seconds
[ 78.330756] Enabling non-boot CPUs …
[ 78.331513] CPU1: Booted secondary processor
[ 78.332831] CPU1 is up
[ 78.333232] CPU2: Booted secondary processor
[ 78.333874] CPU2 is up
[ 78.334280] CPU3: Booted secondary processor
[ 78.335100] CPU3 is up
[ 78.337691] PM: noirq resume of devices complete after 2.594 msecs
[ 78.338463] PM: early resume of devices complete after 0.497 msecs
[ 78.338851] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 78.338867] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 78.339224] 1390..dw_mci_set_ios: no card. [mmc1]
[ 78.339426] dwc_otg_hcd_resume, usb device mode
[ 78.344503] phy_power_on: enable = 1
[ 78.379217] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 78.381588] PM: resume of devices complete after 43.802 msecs
[ 78.381906] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 78.381917] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 78.381927] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 78.597724] Restarting tasks … done.
[ 78.603274] PM: suspend exit 2011-01-02 06:57:54.226420250 UTC
[ 78.655260] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 78.674007] PM: suspend entry 2011-01-02 06:57:54.298323958 UTC
[ 78.679912] PM: Syncing filesystems … done.
[ 78.692376] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 78.703003] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 78.712904] Suspending console(s) (use no_console_suspend to debug)
[ 78.721207] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 78.721223] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 78.721232] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 78.724339] dwc_otg_hcd_suspend, usb device mode
[ 78.725045] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 78.727478] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 78.728298] phy_power_on: enable = 0
[ 78.730156] PM: suspend of devices complete after 9.141 msecs
[ 78.731318] PM: late suspend of devices complete after 1.144 msecs
[ 78.732642] PM: noirq suspend of devices complete after 1.322 msecs
[ 78.732662] Disabling non-boot CPUs …
[ 78.734862] CPU1: shutdown
[ 78.738391] CPU2: shutdown
[ 78.740951] CPU3: shutdown
[ 78.742753] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 78.742820] rkpm_enter:
[ 78.742838] GPIO0_INTEN: 00000020
[ 78.742854] GPIO6_INTEN: 00400000
[ 78.742861] GPIO7_INTEN: 00000010
[ 78.826033] Resume caused by IRQ 120
[ 78.826072] Resume but desc dont’t have name
[ 78.826095] wakeup irq: 00000000 00000000 01000000 00000000
[ 78.826104] wakeup gpio7: 00000010
[ 78.826294] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 78.826324] Suspended for 0.000 seconds
[ 78.827227] Enabling non-boot CPUs …
[ 78.827936] CPU1: Booted secondary processor
[ 78.829206] CPU1 is up
[ 78.829623] CPU2: Booted secondary processor
[ 78.830263] CPU2 is up
[ 78.830670] CPU3: Booted secondary processor
[ 78.831248] CPU3 is up
[ 78.834093] PM: noirq resume of devices complete after 2.857 msecs
[ 78.834919] PM: early resume of devices complete after 0.457 msecs
[ 78.835323] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 78.835338] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 78.835755] 1390..dw_mci_set_ios: no card. [mmc1]
[ 78.835993] dwc_otg_hcd_resume, usb device mode
[ 78.841063] phy_power_on: enable = 1
[ 78.875853] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 79.097226] usb 1-1: reset high-speed USB device number 2 using rockchip_ehci_host
[ 79.245694] PM: resume of devices complete after 417.409 msecs
[ 79.245901] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 79.245918] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 79.245931] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 79.469287] Restarting tasks … done.
[ 79.475849] PM: suspend exit 2011-01-02 06:58:54.608482292 UTC
[ 79.479286] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 79.544487] PM: suspend entry 2011-01-02 06:58:54.678215709 UTC
[ 79.550387] PM: Syncing filesystems … done.
[ 79.563296] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 79.574209] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 79.584339] Suspending console(s) (use no_console_suspend to debug)
[ 79.592661] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 79.592683] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 79.592693] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 79.594595] dwc_otg_hcd_suspend, usb device mode
[ 79.596598] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 79.599147] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 79.599921] phy_power_on: enable = 0
[ 79.601581] PM: suspend of devices complete after 9.118 msecs
[ 79.602653] PM: late suspend of devices complete after 1.057 msecs
[ 79.604010] PM: noirq suspend of devices complete after 1.357 msecs
[ 79.604029] Disabling non-boot CPUs …
[ 79.606211] CPU1: shutdown
[ 79.609572] CPU2: shutdown
[ 79.612383] CPU3: shutdown
[ 79.614080] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 79.614140] rkpm_enter:
[ 79.614162] GPIO0_INTEN: 00000020
[ 79.614175] GPIO6_INTEN: 00400000
[ 79.614182] GPIO7_INTEN: 00000010
[ 79.696968] Resume caused by IRQ 120
[ 79.697003] Resume but desc dont’t have name
[ 79.697025] wakeup irq: 00000000 00000000 01000000 00000000
[ 79.697037] wakeup gpio7: 00000010
[ 79.697232] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 79.697267] Suspended for 0.000 seconds
[ 79.698167] Enabling non-boot CPUs …
[ 79.698908] CPU1: Booted secondary processor
[ 79.700126] CPU1 is up
[ 79.700539] CPU2: Booted secondary processor
[ 79.701161] CPU2 is up
[ 79.701570] CPU3: Booted secondary processor
[ 79.702328] CPU3 is up
[ 79.704804] PM: noirq resume of devices complete after 2.480 msecs
[ 79.705635] PM: early resume of devices complete after 0.489 msecs
[ 79.706050] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 79.706071] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 79.706385] 1390..dw_mci_set_ios: no card. [mmc1]
[ 79.706610] dwc_otg_hcd_resume, usb device mode
[ 79.711633] phy_power_on: enable = 1
[ 79.746388] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 79.967747] usb 1-1: reset high-speed USB device number 2 using rockchip_ehci_host
[ 80.116153] PM: resume of devices complete after 417.163 msecs
[ 80.116422] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 80.116436] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 80.116446] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 80.339099] Restarting tasks … [ 80.344558] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 80.348139] PM: suspend exit 2011-01-02 06:59:54.610166667 UTC
done.
[ 80.442083] PM: suspend entry 2011-01-02 06:59:54.705560334 UTC
[ 80.448712] PM: Syncing filesystems … done.
[ 80.460410] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 80.470918] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 80.480855] Suspending console(s) (use no_console_suspend to debug)
[ 80.489323] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 80.489332] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 80.489342] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 80.491346] dwc_otg_hcd_suspend, usb device mode
[ 80.493245] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 80.495622] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 80.496355] phy_power_on: enable = 0
[ 80.510545] PM: suspend of devices complete after 21.612 msecs
[ 80.511658] PM: late suspend of devices complete after 1.099 msecs
[ 80.513061] PM: noirq suspend of devices complete after 1.392 msecs
[ 80.513072] Disabling non-boot CPUs …
[ 80.515428] CPU1: shutdown
[ 80.519318] CPU2: shutdown
[ 80.522076] CPU3: shutdown
[ 80.523816] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 80.523877] rkpm_enter:
[ 80.523887] GPIO0_INTEN: 00000020
[ 80.523900] GPIO6_INTEN: 00400000
[ 80.523911] GPIO7_INTEN: 00000010
[ 80.606770] Resume caused by IRQ 120
[ 80.606810] Resume but desc dont’t have name
[ 80.606836] wakeup irq: 00000000 00000000 01000000 00000000
[ 80.606851] wakeup gpio7: 00000010
[ 80.607042] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 80.607077] Suspended for 0.000 seconds
[ 80.607990] Enabling non-boot CPUs …
[ 80.608686] CPU1: Booted secondary processor
[ 80.609957] CPU1 is up
[ 80.610349] CPU2: Booted secondary processor
[ 80.610980] CPU2 is up
[ 80.611384] CPU3: Booted secondary processor
[ 80.612189] CPU3 is up
[ 80.614688] PM: noirq resume of devices complete after 2.504 msecs
[ 80.615562] PM: early resume of devices complete after 0.514 msecs
[ 80.616012] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 80.616029] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 80.616407] 1390..dw_mci_set_ios: no card. [mmc1]
[ 80.616620] dwc_otg_hcd_resume, usb device mode
[ 80.621659] phy_power_on: enable = 1
[ 80.656544] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 80.658954] PM: resume of devices complete after 44.069 msecs
[ 80.659283] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 80.659297] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 80.659305] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 80.875211] Restarting tasks … done.
[ 80.881642] PM: suspend exit 2011-01-02 07:00:54.227504375 UTC
[ 80.932717] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 80.952072] PM: suspend entry 2011-01-02 07:00:54.299058666 UTC
[ 80.958099] PM: Syncing filesystems … done.
[ 80.968520] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 80.979474] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 80.989377] Suspending console(s) (use no_console_suspend to debug)
[ 80.997675] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 80.997698] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 80.997707] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 80.999667] dwc_otg_hcd_suspend, usb device mode
[ 81.001589] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 81.003967] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 81.004732] phy_power_on: enable = 0
[ 81.016932] PM: suspend of devices complete after 19.626 msecs
[ 81.018142] PM: late suspend of devices complete after 1.200 msecs
[ 81.019486] PM: noirq suspend of devices complete after 1.346 msecs
[ 81.019503] Disabling non-boot CPUs …
[ 81.021727] CPU1: shutdown
[ 81.025261] CPU2: shutdown
[ 81.028437] CPU3: shutdown
[ 81.030334] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 81.030407] rkpm_enter:
[ 81.030426] GPIO0_INTEN: 00000020
[ 81.030441] GPIO6_INTEN: 00400000
[ 81.030449] GPIO7_INTEN: 00000010
[ 81.113610] Resume caused by IRQ 120
[ 81.113646] Resume but desc dont’t have name
[ 81.113669] wakeup irq: 00000000 00000000 01000000 00000000
[ 81.113678] wakeup gpio7: 00000010
[ 81.113867] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 81.113898] Suspended for 0.000 seconds
[ 81.114803] Enabling non-boot CPUs …
[ 81.115500] CPU1: Booted secondary processor
[ 81.116828] CPU1 is up
[ 81.117248] CPU2: Booted secondary processor
[ 81.117884] CPU2 is up
[ 81.118295] CPU3: Booted secondary processor
[ 81.118983] CPU3 is up
[ 81.121517] PM: noirq resume of devices complete after 2.539 msecs
[ 81.122376] PM: early resume of devices complete after 0.486 msecs
[ 81.122765] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 81.122783] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 81.123163] 1390..dw_mci_set_ios: no card. [mmc1]
[ 81.123367] dwc_otg_hcd_resume, usb device mode
[ 81.128407] phy_power_on: enable = 1
[ 81.163169] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 81.165577] PM: resume of devices complete after 43.869 msecs
[ 81.165881] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 81.165898] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 81.165908] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 81.381665] Restarting tasks … done.
[ 81.388077] PM: suspend exit 2011-01-02 07:01:54.227293208 UTC
[ 81.439241] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 81.456675] PM: suspend entry 2011-01-02 07:01:54.296965375 UTC
[ 81.462536] PM: Syncing filesystems … done.
[ 81.473115] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 81.484251] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 81.494322] Suspending console(s) (use no_console_suspend to debug)
[ 81.502759] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 81.502784] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 81.502796] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ed81d3c0
[ 81.504769] dwc_otg_hcd_suspend, usb device mode
[ 81.506794] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 81.509104] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 81.509849] phy_power_on: enable = 0
[ 81.523848] PM: suspend of devices complete after 21.470 msecs
[ 81.524970] PM: late suspend of devices complete after 1.113 msecs
[ 81.526206] PM: noirq suspend of devices complete after 1.240 msecs
[ 81.526228] Disabling non-boot CPUs …
[ 81.528558] CPU1: shutdown
[ 81.532070] CPU2: shutdown
[ 81.534720] CPU3: shutdown
[ 81.536714] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 81.536780] rkpm_enter:
[ 81.536798] GPIO0_INTEN: 00000020
[ 81.536810] GPIO6_INTEN: 00400000
[ 81.536818] GPIO7_INTEN: 00000010
[ 81.619885] Resume caused by IRQ 120
[ 81.619921] Resume but desc dont’t have name
[ 81.619943] wakeup irq: 00000000 00000000 01000000 00000000
[ 81.619955] wakeup gpio7: 00000010
[ 81.620154] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 81.620186] Suspended for 0.000 seconds
[ 81.621078] Enabling non-boot CPUs …
[ 81.621815] CPU1: Booted secondary processor
[ 81.623113] CPU1 is up
[ 81.623519] CPU2: Booted secondary processor
[ 81.624143] CPU2 is up
[ 81.624549] CPU3: Booted secondary processor
[ 81.625153] CPU3 is up
[ 81.627988] PM: noirq resume of devices complete after 2.847 msecs
[ 81.628848] PM: early resume of devices complete after 0.518 msecs
[ 81.629291] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 81.629310] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 81.629708] 1390..dw_mci_set_ios: no card. [mmc1]
[ 81.629948] dwc_otg_hcd_resume, usb device mode
[ 81.635008] phy_power_on: enable = 1
[ 81.669736] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 81.891293] usb 1-1: reset high-speed USB device number 2 using rockchip_ehci_host
[ 82.039647] PM: resume of devices complete after 417.448 msecs
[ 82.040008] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 82.040019] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 82.040032] cpufreq: cpufreq_resume: Failed to start governor for policy: ed81d3c0
[ 82.262756] Restarting tasks … done.
[ 82.269174] PM: suspend exit 2011-01-02 07:02:54.607870375 UTC
[ 82.272733] healthd: battery l=100 v=8 t=2.6 h=2 st=3 chg=au
[ 82.338421] PM: suspend entry 2011-01-02 07:02:54.678223583 UTC
[ 82.344475] PM: Syncing filesystems … done.
[ 82.354980] Freezing user space processes … (elapsed 0.003 seconds) done.
[ 82.366021] Freezing remaining freezable tasks … (elapsed 0.005 seconds) done.
[ 82.378304] Suspending console(s) (use no_console_suspend to debug)
-------------烧录的是4.4固件
zhansb 发表于 2016-4-8 09:48
烧哪个固件啊,把对应官方固件的log发上来
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-01 (Apr 07 2016 - 16:20:43)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
pmic:act8846
powerstate IReadLoaderFlag()=0
pmic_act8846_shut_down
Memory OK
Memory OK
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
powerstate=0,shuld power down
voltage=7423
fg:adc-battery
#Boot ver: 2016-04-07#2.19
empty serial no.
checkKey
wlt_checkRecovery key2=1,key6=1,key5=0
vbus = 0
voltage=7415
voltage=7328
read logo_on switch from dts [1]
pll_src = 0, dclk_hz = 120000000, dclk_div = 3
load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
mipi_dsi v1.3 2014-04-17
voltage=8098
base_offset=2000
Found entry:
path:
offset:0 size:172710
rk_pwm_config:brightness:180
failed to load fdt from boot!
kernel @ 0x02000000 (0x00587ef8)
ramdisk @ 0x04bf0000 (0x00124246)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0450c000, end 0452a388 … OK
[ 0.000000] Linux version 3.10.0 (tiantao@wlt) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #7 SMP PREEMPT Thu Apr 7 14:40:43 CST 2016
[ 0.000000] ion heap(cma): base(0) size(20000000) align(0)
[ 0.000000] cma: CMA: reserved 512 MiB at 60000000
[ 0.000000] ion_reserve: cma reserved base 60000000 size 536870912
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1cc2000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00180000@0x00414000(sys_update),-@0x00594000(user) storagemedia=emmc loader.timestamp=2016-04-07_16:20:43
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1520672k/1520672k available, 576480k reserved, 794624K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc09bba68 (9935 kB)
[ 0.000000] .init : 0xc09bc000 - 0xc0aa76c0 ( 942 kB)
[ 0.000000] .data : 0xc0aa8000 - 0xc0b6ce78 ( 788 kB)
[ 0.000000] .bss : 0xc0b6ce78 - 0xc0c8442c (1118 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 31
[ 0.000000] rkclk_init_clks: aclk_vio0 has been inited in uboot, ingored
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:19
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:15
[ 0.337520] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.337536] pid_max: default: 32768 minimum: 301
[ 0.337642] Security Framework initialized
[ 0.337659] SELinux: Initializing.
[ 0.337729] Mount-cache hash table entries: 512
[ 0.338372] Initializing cgroup subsys debug
[ 0.338387] Initializing cgroup subsys memory
[ 0.338413] Initializing cgroup subsys freezer
[ 0.338443] CPU: Testing write buffer coherency: ok
[ 0.338757] /cpus/cpu@0 missing clock-frequency property
[ 0.338770] /cpus/cpu@1 missing clock-frequency property
[ 0.338780] /cpus/cpu@2 missing clock-frequency property
[ 0.338788] /cpus/cpu@3 missing clock-frequency property
[ 0.338851] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.338901] Setting up static identity map for 0xc070f1e0 - 0xc070f238
[ 0.342290] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1699 (version 3.0)
[ 0.415617] CPU1: Booted secondary processor
[ 0.415649] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.435301] CPU2: Booted secondary processor
[ 0.435325] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.455011] CPU3: Booted secondary processor
[ 0.455035] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.455138] Brought up 4 CPUs
[ 0.455165] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.455174] CPU: All CPU(s) started in SVC mode.
[ 0.455908] devtmpfs: initialized
[ 0.460678] pinctrl core: initialized pinctrl subsystem
[ 0.460932] regulator-dummy: no parameters
[ 0.470130] NET: Registered protocol family 16
[ 0.471838] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.472125] ion_snapshot: 0x2e230000 map to 0xf0107000 and copy to 0xc0c5fbc4 (version 0.1)
[ 0.472452] Registered FIQ tty driver
[ 0.472882] fiq-debugger is disabled in device tree
[ 0.473384] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.473405] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.473421] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.473437] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.473527] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.473589] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.473650] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.473710] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.473780] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.473843] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.473902] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.473962] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.474029] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.474094] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.474108] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.474119] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.474130] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.474684] rockchip_interrupts_register:bank_num=7
[ 0.476645] rockchip_pinctrl_probe:init ok
[ 0.482776] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.482867] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.482881] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.483041] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.483118] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.483130] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.483289] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.483361] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.483374] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.483530] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.483601] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.483613] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.483783] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.483856] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.483869] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.484026] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.484099] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.484112] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.484315] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.484391] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.484404] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.486448] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.486462] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.486659] DDR DEBUG: version 1.00 20140603
[ 0.486690] DDR DEBUG: Channel a:
[ 0.486698] DDR DEBUG: DDR3 Device
[ 0.486711] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.486720] DDR DEBUG: Channel b:
[ 0.486727] DDR DEBUG: DDR3 Device
[ 0.486739] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.486748] DDR DEBUG: addr=0xb74000
[ 0.486757] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.486766] DDR DEBUG: socAddr[0]=0xb74000, socAddr[1]=0xb74100
[ 0.486775] DDR DEBUG: chAddr[0]=0xb74000, chAddr[1]=0xb74000
[ 0.486785] DDR DEBUG: dtar[0]=0x4016e000, dtar[1]=0x4016e000
[ 0.487027] DDR DEBUG: init success!!! freq=300MHz
[ 0.487035] DDR DEBUG: Channel a:
[ 0.487047] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487060] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487072] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487084] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487096] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.487105] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.487113] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.487120] DDR DEBUG: Channel b:
[ 0.487131] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487143] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487155] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487167] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.487178] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.487186] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.487195] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.507702] bio: create slab at 0
[ 0.508506] SCSI subsystem initialized
[ 0.508649] usbcore: registered new interface driver usbfs
[ 0.508689] usbcore: registered new interface driver hub
[ 0.508768] usbcore: registered new device driver usb
[ 0.509024] rk3288-usb-control usb_control.33: invalid host gpio-2
[ 0.509044] rk3288-usb-control usb_control.33: invalid otg gpio-2
[ 0.510151] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.512272] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.512581] i2c i2c-2: 1 i2c clients have been registered at 0x1a
[ 0.513212] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.514000] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.514124] media: Linux media interface: v0.10
[ 0.514167] Linux video capture interface: v2.00
[ 0.514203] pps_core: LinuxPPS API ver. 1 registered
[ 0.514212] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.514231] PTP clock support registered
[ 0.514697] Rockchip ion module is successfully loaded (v1.0)
[ 0.514860] Advanced Linux Sound Architecture Driver Initialized.
[ 0.515406] cfg80211: Calling CRDA to update world regulatory domain
[ 0.516559] act8846_i2c_probe,line=901
[ 0.517537] act8846_parse_dt,line=746
[ 0.518199] lhm invalid gpio: -2
[ 0.518218] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.518237] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.518251] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.520077] act_dcdc1: 1200 mV
[ 0.522800] vccio: 3300 mV
[ 0.524661] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.527371] act_dcdc4: 2000 mV
[ 0.528619] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.530696] act_ldo2: 1000 mV
[ 0.532786] act_ldo3: 2500 mV
[ 0.534860] act_ldo4: 3300 mV
[ 0.536940] act_ldo5: 3300 mV
[ 0.539012] act_ldo6: 1000 mV
[ 0.541108] vcc_18: 1800 mV
[ 0.543183] act_ldo8: 1800 mV
[ 0.547964] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.552683] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.553411] Switching to clocksource arch_sys_counter
[ 0.573333] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.573344] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.573755] rk-screen rk_screen.8: rockchip screen probe success
[ 0.573924] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.573942] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.574249] rk32-edp ff970000.edp: screen is not edp!
[ 0.574264] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.574410] rk32-dsi
[ 0.574556] dsi->host.irq =51
[ 0.574574] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
[ 0.574582] mipi_dsi v1.3 2014-04-17
[ 0.574634] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 0.574646] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.575158] rk3288-lcdc lcdc0: request mipi_lcd_en gpio fail:-16
[ 0.575193] rk3288-lcdc lcdc0: request mipi_lcd_rst gpio fail:-16
[ 0.575421] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.575762] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.575911] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.576054] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.617626] rk3288-lcdc lcdc0: lcdc0: dclk:120000000>>fps:43
[ 0.617640] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.644487] alloc_buffer:ion_phy_addr=0x60000000
[ 0.657958] fb0:phy:60000000>>vir:f0171000>>len:0x1b00000
[ 0.657974] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
[ 0.658122] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.658134] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.658321] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.658607] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.658758] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.658908] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.707961] alloc_buffer:ion_phy_addr=0x61b00000
[ 0.707977] fb0:phy:61b00000>>vir: (null)>>len:0x3200000
[ 0.707992] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
[ 0.708645] rockchip_set_mux:warning ignore bank num 15
[ 0.708786] rockchip_set_mux:warning ignore bank num 15
[ 0.708893] rockchip_set_mux:warning ignore bank num 15
[ 0.708999] rockchip_set_mux:warning ignore bank num 15
[ 0.709109] rockchip_set_mux:warning ignore bank num 15
[ 0.709212] rockchip_set_mux:warning ignore bank num 15
[ 0.709771] rockchip_set_mux:warning ignore bank num 15
[ 0.709920] rockchip_set_mux:warning ignore bank num 15
[ 0.710467] rockchip_set_mux:warning ignore bank num 15
[ 0.710600] rockchip_set_mux:warning ignore bank num 15
[ 0.711155] rockchip_set_mux:warning ignore bank num 15
[ 0.711287] rockchip_set_mux:warning ignore bank num 15
[ 0.711842] rockchip_set_mux:warning ignore bank num 15
[ 0.711980] rockchip_set_mux:warning ignore bank num 15
[ 0.713336] NET: Registered protocol family 2
[ 0.713776] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.713908] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.714041] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.714089] TCP: reno registered
[ 0.714104] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.714137] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.714328] NET: Registered protocol family 1
[ 0.714508] Unpacking initramfs…
[ 0.777182] Freeing initrd memory: 1168K (c4bf0000 - c4d14000)
[ 0.777673] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.778154] probe device ff9a0000.vpu_service
[ 0.778330] vpu_service: power on
[ 0.779382] checking hw id 4831
[ 0.779749] vpu_service set to auto frequency mode
[ 0.779824] vpu_service: power off…
[ 0.779861] done
[ 0.779870] init success
[ 0.779916] probe device ff9c0000.hevc_service
[ 0.780106] hevc_service: power on
[ 0.781141] checking hw id 6867
[ 0.781365] hevc_service: power off…
[ 0.781402] done
[ 0.781409] init success
[ 0.781526] rknandbase v1.0 2014-03-31
[ 0.781619] rknand ff400000.nandc0: no irq resource?
[ 0.781742] rknand_driver:ret = 0
[ 0.782441] rk_dts_sensor_probe:Get ov2659 rockchip,powerdown failed!
[ 0.783003] audit: initializing netlink socket (disabled)
[ 0.783041] type=2000 audit(0.450:1): initialized
[ 0.783775] bounce pool size: 64 pages
[ 0.788207] fuse init (API version 7.22)
[ 0.788540] msgmni has been set to 1452
[ 0.790298] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.790311] io scheduler noop registered
[ 0.790320] io scheduler deadline registered
[ 0.790401] io scheduler cfq registered (default)
[ 0.793874] rga2 ff920000.rga: rga ion client create success!
[ 0.794007] rga: Driver loaded succesfully
[ 0.794626] IEP Driver loaded succesfully
[ 0.794720] Module initialized.
[ 0.795555] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.795571] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.796800] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.796816] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.797085] pwm-voltage-regulator pwm_regulator.28: unable to request PWM, trying legacy API
[ 0.797098] pwm-voltage-regulator pwm_regulator.28: unable to request legacy PWM
[ 0.797107] pwm_regulator_probe:error
[ 0.797129] platform pwm_regulator.28: Driver pwm-voltage-regulator requests probe deferral
[ 0.797457] rk_serial.c v1.8 2014-03-04
[ 0.797662] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.797841] serial ff180000.serial: membase f1c72000
[ 0.797990] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.798162] serial ff190000.serial: membase f1c74000
[ 0.798284] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 2.482762] console [ttyS2] enabled
[ 2.486378] serial ff690000.serial: membase fed60000
[ 2.491424] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 2.499144] serial ff1b0000.serial: membase f1c76000
[ 2.504178] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4
[ 2.511894] serial ff1c0000.serial: membase f1c7e000
[ 2.519434] loop: module loaded
[ 2.522778] wlt_keypad_init_driver
[ 2.526249] wlt_keypad_probe
[ 2.529558] input: wlt-keyboard as /devices/virtual/input/input0
[ 2.535527] wlt_gpio_init_driver
[ 2.538960] wlt_gpio_probe
[ 2.541782] rockchip_gpio_request:GPIO7-13
[ 2.545969] name:search_line – gpio:264 – is_use:use – gpio_or_irq:gpio
[ 2.552910] name:white_light – gpio:156 – is_use:use – gpio_or_irq:gpio
[ 2.559844] name:red_light – gpio:237 – is_use:use – gpio_or_irq:gpio
[ 2.566612] name:tdr_enable – gpio:79 – is_use:use – gpio_or_irq:gpio
[ 2.573377] name:dmm_clk – gpio:245 – is_use:use – gpio_or_irq:gpio
[ 2.579975] name:dmm_cd – gpio:236 – is_use:use – gpio_or_irq:gpio
[ 2.586486] name:uart_send_led – gpio:7 – is_use:use – gpio_or_irq:gpio
[ 2.593422] name:uart_recv_led – gpio:13 – is_use:use – gpio_or_irq:gpio
[ 2.600453] name:S485RE – gpio:176 – is_use:use – gpio_or_irq:gpio
[ 2.606954] name:S485DE – gpio:171 – is_use:use – gpio_or_irq:gpio
[ 2.613472] name:poe_emac_enable – gpio:179 – is_use:use – gpio_or_irq:gpio
[ 2.620750] name:poe_48V_enable – gpio:197 – is_use:use – gpio_or_irq:gpio
[ 2.627944] name:poe_12V_status – gpio:-1 – is_use:use – gpio_or_irq:gpio
[ 2.635052] name:poe_36V_status – gpio:-1 – is_use:use – gpio_or_irq:gpio
[ 2.642159] name:poe_45V_status – gpio:-1 – is_use:use – gpio_or_irq:gpio
[ 2.649266] name:poe_78V_status – gpio:-1 – is_use:use – gpio_or_irq:gpio
[ 2.656466] ioctl num:4
[ 2.658980] wlt_poe_init_driver
[ 2.662201] wlt_i2c_init
[ 2.664754] wlt_gpio_pull_init_driver
[ 2.668484] gt9xx_ts_init==
[ 2.671331] gt9xx : io request ok – wakeup_gpio : 259 int_gpio:257 IC Version: 928_1060
[ 2.780195] gt9xx : in my_gtp_read_version !=================
[ 2.785928] version :1060 gt9xx max x:1920 y:1200 ~~~~~~~~~~~~~~~~~~~~
[ 2.793297] input: gt9xx as /devices/virtual/input/input1
[ 2.798751] ret=0
[ 2.800847] gpio_reques gpio-sda 0
[ 2.804492] gpio_reques gpio-scl 0
[ 2.808107] userspace_i2c_probe
userspace_i2c_init_driver,ret=0
[ 2.814235] wlt_battery_detect_init_driver
[ 2.818464] rk1000_init
[ 2.820923] rk1000_control_probe ok
[ 2.824540] ============ misc_wlt_probe
misc_wlt_init_driver,ret=0
[ 2.831296] SCSI Media Changer driver v0.25
[ 2.835798] tun: Universal TUN/TAP device driver, 1.6
[ 2.840785] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.846983] vmac_init.
[ 2.849819] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 2.856513] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 2.863441] stmmac_probe_config_dt: clock input or output? (input).
[ 2.869618] stmmac_probe_config_dt: TX delay(0x30).
[ 2.874427] stmmac_probe_config_dt: RX delay(0x20).
[ 2.879266] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 2.884573] stmmc_pltfr_init:
[ 2.887777] stmmc_pltfr_init: init for RGMII
[ 2.891977] tx delay=0x30
[ 2.891977] rx delay=0x20
[ 2.897567] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.902533] Normal descriptors
[ 2.905637] Ring mode enabled
[ 2.908641] DMA HW capability register supported
[ 2.913095] RX Checksum Offload Engine supported (type 2)
[ 2.918689] TX Checksum insertion supported
[ 2.922887] Wake-Up On Lan supported
[ 2.926524] Enable RX Mitigation via HW Watc
具体固件名字是?
zhansb 发表于 2016-4-8 10:29
具体固件名字是?
用的就是官方的4.4编译出来的固件啊
4.4有两个版本,默认版和PAD版
自己编译的话,仓库更新到哪里
没有这些信息,比较难给你分析
是firefly的板子吗
zhansb 发表于 2016-4-8 14:51
4.4有两个版本,默认版和PAD版
自己编译的话,仓库更新到哪里
板子是按照firefly参考自制的,用的是PAD版本的…
4.4有两个版本,默认版和PAD版
自己编译的话,仓库更新到哪里
仓库更新到20150422
更新到最新的代码后再试试
请问解决了吗
淡定,淡定,淡定……
请问这个问题有没有解决?如果有能麻烦告知一下吗?谢谢。
请问这个问题解决了么
