各位大牛,帮我看看,自己编的update.img,循环启动
这是我打印的log,纠结死了,我的步骤都是正确的啊,每次都是最后几行就跑不下去了。
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Nov 26 2014 - 09:28:44)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2014-11-26#2.17
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
read logo_on switch from dts [1]
hdmi baseparamer 0x0@0-0
Hdmi Devices Not Exist.
pll_src = 0, dclk_hz = 148500000, dclk_div = 4
ERROR: yrgb scale exceed 8,srcW=0,srcH=0,dstW=1920,dstH=1080
scale_yrgb_x 0 scale_yrgb_y 2no fuel gauge found
yrgb:h_fac=17024,v_fac=30338,gt4=0,gt2=0
scale_yrgb_x 17024 scale_yrgb_y 30338got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x02000000 (0x006aa180)
ramdisk @ 0x04bf0000 (0x002b99d4)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480b000, end 04826a70 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (archermind@archermind) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #68 SMP PREEMPT Wed Apr 6 16:25:53 CST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] hdmi init vic is -1 [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 58000000 [ 0.000000] ion_reserve: cma reserved base 58000000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f2a000 s13376 r8192 d15296 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768 [ 0.000000] Kernel command line: console=tty0 console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x00394000(user) storagemedia=emmc loader.timestamp=2014-11-26_09:28:44 hdmi.vic=-1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1385528k/1385528k available, 711624k reserved, 663552K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0bad774 (11926 kB) [ 0.000000] .init : 0xc0bae000 - 0xc0c18440 ( 426 kB) [ 0.000000] .data : 0xc0c1a000 - 0xc0dae000 (1616 kB) [ 0.000000] .bss : 0xc0dae000 - 0xc0eceb3c (1155 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.00
建议分开单个img的形式烧录,这样就好定位具体是那部分的原因了
楼主有解决吗?
q182545666 发表于 2016-4-8 12:25
**** 作者被禁止或删除 内容自动屏蔽 ****
我单个的可以,但是做成update.img就多次重启然后就停止了,偶尔也能进去
请问,循环启动什么意思?
