AIBOX-K3 AI Computer Zenow Application Usage
Zenow
Zenow is a locally-run AI knowledge assistant desktop application. All data processing occurs on-device, ensuring complete privacy — no data ever leaves the machine. It supports multi-model management, intelligent conversations, knowledge base Q&A, and voice interaction.
Key Features
  • Privacy-first: All data is processed locally and never uploaded to the cloud.
  • Multi-model support: Run LLM, Embedding, and Reranking models simultaneously.
  • Knowledge base Q&A: Perform intelligent Q&A over your local documents.
  • Multi-turn conversations: Maintain contextual memory across continuous dialogue sessions.
Platform Support
Platform & OS
Acceleration Supported
K1 Buildroot
:cross_mark: No
K1 OpenHarmony
:cross_mark: No
K1 Bianbu LXQT/GNOME
:cross_mark: No
K3 Buildroot
:cross_mark: No
K3 OpenHarmony
:cross_mark: No
K3 Bianbu LXQT/GNOME
:white_check_mark: Yes
ArchitectureCore Technology StackZenow is built on the following technologies:
  • LLM SDK — Large language model inference engine
  • Multi-turn dialogue
  • Frontend
  • Electron — Cross-platform desktop application framework
  • React + TypeScript — User interface
  • Vite — Build tooling
  • Backend
  • FastAPI — High-performance API service
  • Python — Runtime environment
  • SQLite — Local data storage
System Architecture Diagram
Data Flow
  • Chat flow: User input → Frontend → Backend session manager → LLM Server → Streaming response
  • Knowledge base Q&A: User query → Embed initial retrieval → Weighted fusion (Embed + BM25 + Rerank) → LLM generates answer
Installation
Run the following commands in a terminal to install Zenow:
sudo apt update
sudo apt install llama.cpp-tools-spacemit spacemit-onnxruntime python3-spacemit-ort
sudo apt install zenow
Quick Start
1. Launch the Application
Open the application menu from the bottom-left corner, search for zenow, and click to launch.
Tip: Right-click the application icon and select Add to Desktop, then mark it as trusted for quick access in future sessions.
2
. Download ModelsOn first launch, AI models must be downloaded before use:
  • Click the Settings icon in the left sidebar.
  • Locate the desired model in the model list.
  • Click the model name to begin downloading.
You can download multiple models simultaneously:
3. Start a Model
Once a model has downloaded, click its name again to start it. Model status is indicated by a colored indicator:
Indicator
Status
Red
Stopped
Yellow
Starting
Green
Running
:warning: Important: To use the full knowledge base feature, download and start at least one model of each type:
  • LLM model — Generates conversational responses
  • Embed model — Encodes text into vector representations
  • Rerank model — Re-scores and ranks retrieval results
Features
Intelligent Chat
Start a New Conversation
  • Click Chat in the left sidebar.
  • Confirm the LLM model status shows green.
  • Enter a question in the input dialog box
  • Press Enter, or click the send button.
The application automatically creates a conversation session and supports multi-turn dialogue with persistent context memory.
Knowledge Base Management
Pre-loaded Knowledge BaseA SpacemiT knowledge base is included by default and can be used to query topics covered within it, such as the K3’s computing performance.
Create a Knowledge Base
  • Click Knowledge Base in the left sidebar.
  • Click the Create Knowledge Base button.
  • Enter a name and description for the knowledge base.
  • Optionally, select a custom avatar.
Import Documents
  • Open a knowledge base.
  • Click the Add Material button.
  • Select the files or folder to upload (hold Ctrl to select multiple files).
  • Wait for document processing to complete.
  • If the page is navigated away from before vectorization finishes, a prompt will appear — click Continue Vectorization and wait for the process to complete.
Chat with a Knowledge Base
  • Start a new conversation or select an existing session.
  • In the input dialogue box, type @ and select the target knowledge base.
  • Enter a question and press Enter.
    The AI will respond based on the knowledge base content.
Advanced Settings
Parameters
The following LLM parameters can be configured on the Settings page:
LLM Parameters
  • Temperature: Controls output randomness. Default: 0.7. Range: 0.0–2.0. Higher values produce more varied responses.
  • repeat Penalty: Reduces repetitive output. Default: 1.1.
  • Max Tokens: Maximum number of tokens per response. Default: 2048.
Conversation System Prompt
  • Defines the AI’s role, behavior, and response style.
  • Applies to standard chat mode (when no knowledge base is selected).
RAG Parameters
Knowledge base Q&A uses a two-stage retrieval and weighted fusion strategy. The following parameters can be configured:
LLM Client Parameters (RAG mode)
  • Temperature: Default: 0 (deterministic output).
  • Repeat Penalty: Default: 1.1.
  • Max Tokens: Default: 120.
Retrieval Parameters
  • Top K (final result count)
  • Number of document chunks returned to the LLM after weighted fusion.
  • Default: 5. Range: 1–20.
  • Affects context length and generation quality.
  • Initial K (initial retrieval count)
  • Number of candidate documents retrieved in the first-stage Embed vector search.
  • Default: 10. Range: 5–100.
  • Higher values improve recall but increase computational cost.
  • Min Similarity (minimum similarity threshold)
  • Similarity threshold below which results are filtered out.
  • Default: -1 (no filtering). Range: -1.0–1.0.
Fusion Weight Parameters
  • Embed Weight (embedding weight)
  • Weight of the Embed vector similarity score in the fusion formula.
  • Default: 0.4. Range: 0.0–1.0.
  • Controls the importance of semantic similarity.
  • BM25 Weight (keyword weight)
  • Weight of the BM25 keyword matching score in the fusion formula.
  • Default: 0.2. Range: 0.0–1.0.
  • Controls the importance of exact keyword matching.
  • Rerank Weight (reranking weight)
  • Weight of the Rerank model score in the fusion formula.
  • Controls the importance of deep semantic understanding.
Weight note: The three weights should sum to 1.0. The system normalizes them automatically. Setting a weight to 0 disables the corresponding retriever.
Toggle Parameters
  • Enable BM25: Enables BM25 keyword retrieval. Default: true.
  • Use Rerank: Enables Rerank re-scoring. Default: true.
Retrieval Pipeline
  • Stage 1 — Embed initial filtering
  • Performs vector similarity search using the Embed model.
  • Retrieves initial_k candidate document chunks.
  • Stage 2 — Weighted fusion
  • Embed score: Semantic relevance based on cosine similarity.
  • BM25 score: Keyword matching using pre-processed tokenization results (if enabled).
  • Rerank score: Deep semantic understanding via the Rerank model (if enabled).
  • Fusion formula: final_score = embed_weight × embed_score + bm25_weight × bm25_score + rerank_weight × rerank_score
  • Stage 3 — Final output
  • Results are sorted by fusion score.
  • Results below min_similarity are filtered out.
  • The top top_k results are passed to the LLM.
  • Injected into the {context} placeholder in the RAG system prompt.
Performance tip: BM25 uses pre-processed tokenization stored in the database, eliminating the need for real-time tokenization. Adjust weights and toggles to balance recall and precision.
RAG System Prompt Template (rag_system_prompt_template)
  • Used in knowledge base Q&A mode.
  • Must contain the {context} placeholder.
  • Takes effect when a knowledge base is selected via @.
  • {context} is replaced with the retrieved document content at query time.
Troubleshooting
Model download fails
  • Check that the network connection is active.
  • Verify that sufficient disk space is available.
  • Try initiating the download again.
Model fails to start (red indicator)
  • Check that system memory is sufficient. The 30B model requires 32 GB of RAM or more.
Knowledge base Q&A quality is poor
  • Ensure that LLM, Embed, and Rerank models are all running.
  • Tune the RAG parameters (e.g., top_k, initial_k, embed_weight, bm25_weight).
  • Verify that the uploaded documents contain content relevant to the queries.
How to improve response speed
  • Use a smaller model (e.g., 2B instead of 30B).
  • Reduce the context window size.
