Hermes Agent (Cloud Compute)Hermes Agent is an open-source AI agent framework that supports multiple LLM providers. It offers capabilities such as tool calling, scheduled tasks, MCP protocol support, and web access, and can be used from a terminal CLI or integrated into messaging platforms such as Telegram and Discord.
Platform Support
Platform & OS
Supported
K1 Buildroot
No
K1 OpenHarmony
No
K1 Bianbu LXQT/GNOME
Yes
K3 Buildroot
No
K3 OpenHarmony
No
K3 Bianbu LXQT/GNOME
Yes
Installation
Option 1: apt Installation (Recommended)Install it directly through apt on Bianbu OS:
sudo apt update
sudo apt install hermes-agent
After installation, you can run the hermes command directly without any additional environment configuration.
Option 2: Source Installation (For Developers)This method is intended for users who need to modify the codebase or contribute to development.
Prerequisites
- Python 3.11+ (uv will download it automatically)
- libffi8 (runtime library, included in the system)
- libffi-dev headers (must be extracted manually, see below)
1. Clone the Repositor
[b]
git clone https://github.com/NousResearch/hermes-agent.git
cd hermes-agent
[/b]2. Install uv
[b]
curl -LsSf https://astral.sh/uv/install.sh | sh
source ~/.bashrc
[/b]3. Extract libffi-dev HeadersBuilding cffi and cryptography on riscv64 requires ffi.h, but the system includes only the runtime library and not the header files. Use apt-get download to fetch the .deb package without installing it or requiring sudo, then extract the headers with dpkg-deb -x:
apt-get download libffi-dev
mkdir -p /tmp/libffi-dev
dpkg-deb -x libffi-dev_*.deb /tmp/libffi-dev
/tmp/libffi-dev is removed after a reboot. If you need to reinstall dependencies, run this step again. Existing virtual environments are not affected.
4. Create a Virtual Environment and Install Dependencies
cd hermes-agent
export PKG_CONFIG_PATH="/tmp/libffi-dev/usr/lib/riscv64-linux-gnu/pkgconfig:$PKG_CONFIG_PATH"
export C_INCLUDE_PATH="/tmp/libffi-dev/usr/include/riscv64-linux-gnu:$C_INCLUDE_PATH"
export CPATH="/tmp/libffi-dev/usr/include/riscv64-linux-gnu:$CPATH"
export LIBRARY_PATH="/tmp/libffi-dev/usr/lib/riscv64-linux-gnu:$LIBRARY_PATH"
uv venv venv --python 3.11
source venv/bin/activate
uv pip install -e ".[cron,cli,dev,mcp,web]"
The voice and messaging extras have limitations on riscv64. See Unavailable Features for details.
Configuration
1. Configure the API KeyEdit ~/.hermes/.env (generated automatically on first run, or create it manually). The following example uses the MiniMax China endpoint.
MINIMAX_CN_API_KEY=your_key_here
MINIMAX_CN_BASE_URL=https://api.minimaxi.com/v1
For a source installation, you can also edit the .env file directly under the project directory:
cp .env.example .env
2. Configure the ModelEdit ~/.hermes/config.yaml (generated automatically on first run, or create it manually):
model:
default: MiniMax-M2.7-highspeed
provider: custom
base_url: https://api.minimaxi.com/v1
api_mode: chat_completions
custom_providers:
- name: minimax-cn
api_key: your_key_here
model: MiniMax-M2.7-highspeed
The MiniMax API accepts only the plain model name, for example MiniMax-M2.7-highspeed. Provider-prefixed formats such as minimax-cn/MiniMax-M2.7-highspeed are not supported.
Start the AgentFor an apt installation, run:
hermes
For a source installation, activate the virtual environment each time you open a new terminal:
cd hermes-agent
./hermes
Supported LLM ProvidersSet the corresponding key in .env to switch providers.
Provider
Environment Variable
OpenRouter
OPENROUTER_API_KEY
Google Gemini
GOOGLE_API_KEY
Kimi / Moonshot
KIMI_API_KEY
MiniMax (Global)
MINIMAX_API_KEY
MiniMax (China)
MINIMAX_CN_API_KEY
GLM / z.ai
GLM_API_KEY
Hugging Face
HF_TOKEN
Unavailable FeaturesThe following features are currently unavailable because of riscv64 platform limitations:
Feature
Reason
voice (speech recognition)
ctranslate2 has no riscv64 wheel; faster-whisper depends on it
Local STT (speech-to-text)
Same as above
messaging Discord encryption
pynacl depends on cffi and is skipped because libffi headers are unavailable
Messaging Feature (Optional)The messaging feature allows Hermes Agent to connect to messaging platforms such as Telegram, Discord, Slack, WhatsApp, Signal, and Matrix. After configuring the bot token for the target platform, you can interact with the agent directly from those applications.
To enable it in a source installation, first set the libffi environment variables, and then install it separately:
uv pip install -e ".[messaging]"
Start the messaging gateway:
./hermes gateway
