关于点亮lvds屏问题
根据论坛里的帖子,尝试去点亮一块单通道lvds接口的屏幕主要参考这两个帖子
http://developer.t-firefly.com/thread-945-1-1.html
http://developer.t-firefly.com/forum.php?mod=viewthread&tid=1575&extra=&highlight=��&page=1
其中一个帖子有补丁,我没有直接打上内核而是手动增添,我新建了一个LCD_XXX.dtsi文件,直接将lcd-b101ew05.dtsi文件的内容复制到我新建的文件,并根据我的屏幕datasheet修改了参数,最后修改rk3128-fireprime.dts将我的头文件包括进去,并去掉之前的#include “lcd-box.dtsi”。但目前屏幕依然没点亮,求教哪里还有疏忽的地方
附上启动log
[mw_shl_code=applescript,false]#Boot ver: 2015-06-12#2.25
empty serial no.
checkKey
vbus = 1
rockusb key pressed.
DDR Version 2.04 20150121
1A1A2A2B 0
1A1A2828 3
LPDDR2
27282828 F
Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Die Bus-Width=32 Size=1024MB
mach:14
Boot1 Release Time: 2015-05-25, version: 2.25
ChipType = a 1374
No.1 FLASH ID:ad de 14 a7 42 4a
ECC:60
*Vซk%นฅั๕0 20
StorageInit ok = 675757
theLฟHจHจีฝฝั2014.10-RK3128-10 (Dec 28 2015 - 14:53:17)
CPU: rk3128
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dma.ืK…•init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk312x!
Unknow param: MACHINE_ID:007!
power key: bank-3 pin-23
can’t find dts node for act8846
can’t find dts node for rk808
cpu_det GPIO pull up
pmic:rk818
can’t find dts node for ADC
Enter power_led_init
empty serial no.
checkKey
vbus = 1
use dc chg rk818_charger_setting iset1:0x79 chgiset:0x75 current 1
read logo_on switch from dts [1]
failed to find part:logo
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x62000000 (0x0069f108)
ramdisk @ 0x65bf0000 (0x0029a22c)
bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 65616640 … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (root@h2c-H435) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #18 SMP PREEMPT Wed Apr 20 18:32:58 CST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128 [ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@9dc00000, offset:0 [ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@9dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(800000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 8 MiB at 9d400000 [ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608 [ 0.000000] cma: CMA: reserved 16 MiB at 7f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1665000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120 [ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0,115200 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00010000@0x0000E000(boot),0x00020000@0x0001E000(backup),-@0x0003E000(linuxroot) storagemedia=nand uboot_logo=0x02000000@0x9dc00000 loader.timestamp=2015-12-28_14:53:17 [ 0.000000] rockchip jtag enabled [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 962916k/962916k available, 85660k reserved, 483328K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b9e614 (11866 kB) [ 0.000000] .init : 0xc0b9f000 - 0xc0bf96c0 ( 362 kB) [ 0.000000] .data : 0xc0bfa000 - 0xc0d1bef8 (1160 kB) [ 0.000000] .bss : 0xc0d1bef8 - 0xc0e3cf7c (1157 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 25 [ 0.000000] rkclk_init_clks: cnt_rate = 17 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:24 [ 0.000000] target-temp:85 [ 0.000000] FirePrime hardware version: V00 [ 0.000000] channel:0, lkg:24 [ 0.000000] target-temp:85 [ 0.000000] channel:0, lkg:24 [ 0.000000] target-temp:85 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.000000] Console: colour dummy device 80x30 [ 0.546090] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.546116] pid_max: default: 32768 minimum: 301 [ 0.546315] Security Framework initialized [ 0.546343] SELinux: Initializing. [ 0.546478] Mount-cache hash table entries: 512 [ 0.547709] Initializing cgroup subsys debug [ 0.547739] Initializing cgroup subsys memory [ 0.547790] Initializing cgroup subsys freezer [ 0.547851] CPU: Testing write buffer coherency: ok [ 0.548399] /cpus/cpu@0 missing clock-frequency property [ 0.548428] /cpus/cpu@1 missing clock-frequency property [ 0.548447] /cpus/cpu@2 missing clock-frequency property [ 0.548466] /cpus/cpu@3 missing clock-frequency property [ 0.548541] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 0.548617] Setting up static identity map for 0xc0851998 - 0xc08519f0 [ 0.550556] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x165e (version 3.0) [ 0.623888] CPU1: Booted secondary processor [ 0.623945] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 0.643587] CPU2: Booted secondary processor [ 0.643632] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 0.663337] CPU3: Booted secondary processor [ 0.663383] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 0.663569] Brought up 4 CPUs [ 0.663622] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.663637] CPU: All CPU(s) started in SVC mode. [ 0.665049] devtmpfs: initialized [ 0.674627] pinctrl core: initialized pinctrl subsystem [ 0.675139] regulator-dummy: no parameters [ 0.676669] NET: Registered protocol family 16 [ 0.679808] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.680491] ion_snapshot: 0x7e998000 map to 0xe0907000 and copy to 0xc0e18504 (version 0.1) [ 0.680743] Registered FIQ tty driver [ 0.683131] console [ttyFIQ0] enabled [ 0.683549] Registered fiq debugger ttyFIQ0 [ 0.685039] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff [ 0.685180] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff [ 0.685264] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff [ 0.685342] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff [ 0.685431] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff [ 0.685502] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5 [ 0.685533] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7 [ 0.685561] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3 [ 0.685589] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137 [ 0.685618] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103 [ 0.688347] rockchip_pinctrl_probe:init ok [ 0.696181] rk_iommu 1010e300.vop_mmu: (vop) Enter [ 0.696239] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq [ 0.696332] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.696362] rk_iommu 1010e300.vop_mmu: (vop) Initialized [ 0.696648] rk_iommu 10104440.hevc_mmu: (hevc) Enter [ 0.696794] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.696825] rk_iommu 10104440.hevc_mmu: (hevc) Initialized [ 0.697090] rk_iommu 10106800.vpu_mmu: (vpu) Enter [ 0.697217] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.697248] rk_iommu 10106800.vpu_mmu: (vpu) Initialized [ 0.697515] rk_iommu 10108800.iep_mmu: (iep) Enter [ 0.697641] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.697672] rk_iommu 10108800.iep_mmu: (iep) Initialized [ 0.699285] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.699317] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.699608] DDR DEBUG: version 1.02 20140828 [ 0.699633] DDR DEBUG: DRAM Type:LPDDR2 [ 0.699659] DDR DEBUG: 2 CS, ROW=14, Bank=8, COL=10, Total Capability=1024MB [ 0.699706] DDR DEBUG: init success!!! freq=300MHz [ 0.754148] bio: create slab at 0 [ 0.755207] Rockchip hdmi driver version 2.0 . [ 0.757097] SCSI subsystem initialized [ 0.757457] usbcore: registered new interface driver usbfs [ 0.757564] usbcore: registered new interface driver hub [ 0.757774] usbcore: registered new device driver usb [ 0.760027] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter [ 0.762333] media: Linux media interface: v0.10 [ 0.762427] Linux video capture interface: v2.00 [ 0.762634] pps_core: LinuxPPS API ver. 1 registered [ 0.762659] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.762707] PTP clock support registered [ 0.762805] i2c-core: driver [bq24296] using legacy suspend method [ 0.762829] i2c-core: driver [bq24296] using legacy resume method [ 0.764254] Rockchip ion module is successfully loaded (v1.1) [ 0.764537] Advanced Linux Sound Architecture Driver Initialized. [ 0.765299] Bluetooth: Core ver 2.16 [ 0.765376] NET: Registered protocol family 31 [ 0.765399] Bluetooth: HCI device and connection manager initialized [ 0.765432] Bluetooth: HCI socket layer initialized [ 0.765462] Bluetooth: L2CAP socket layer initialized [ 0.765514] Bluetooth: SCO socket layer initialized [ 0.765970] cfg80211: Calling CRDA to update world regulatory domain [ 0.767639] act8931_i2c_probe,line=715 [ 0.768443] The device is not act8931 [ 0.769104] rk818_i2c_probe,line=1282 [ 0.769407] rk818_pre_init,line=1197 [ 0.776962] ------------[ cut here ]------------ [ 0.777000] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4() [ 0.777022] autorequest GPIO-25 [ 0.777038] Modules linked in: [ 0.777068] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #18 [ 0.777119] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 0.777160] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 0.777201] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c) [ 0.777242] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4) [ 0.777284] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0) [ 0.777328] [] (gpiod_direction_output+0x80/0x2b0) from [] (rk818_parse_dt+0x170/0x20c) [ 0.777372] [] (rk818_parse_dt+0x170/0x20c) from [] (rk818_i2c_probe+0xf8/0x344) [ 0.777416] [] (rk818_i2c_probe+0xf8/0x344) from [] (i2c_device_probe+0xa8/0xd4) [ 0.777458] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c) [ 0.777497] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 0.777536] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 0.777574] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 0.777611] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 0.777650] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 0.777691] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac) [ 0.777735] [] (i2c_register_driver+0x40/0xac) from [] (rk818_module_init+0x10/0x34) [ 0.777774] [] (rk818_module_init+0x10/0x34) from [] (do_one_initcall+0x34/0xc8) [ 0.777816] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 0.777859] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 0.777900] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 0.777940] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 0.777998] ---[ end trace 8c88a9ab6626809e ]--- [ 0.778038] cpu_det_gpio up [ 0.778093] ------------[ cut here ]------------ [ 0.778121] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4() [ 0.778142] autorequest GPIO-69 [ 0.778158] Modules linked in: [ 0.778184] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #18 [ 0.778225] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 0.778264] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 0.778303] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c) [ 0.778343] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4) [ 0.778383] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0) [ 0.778425] [] (gpiod_direction_output+0x80/0x2b0) from [] (rk818_parse_dt+0x1c4/0x20c) [ 0.778468] [] (rk818_parse_dt+0x1c4/0x20c) from [] (rk818_i2c_probe+0xf8/0x344) [ 0.778510] [] (rk818_i2c_probe+0xf8/0x344) from [] (i2c_device_probe+0xa8/0xd4) [ 0.778550] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c) [ 0.778588] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 0.778626] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 0.778664] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 0.778701] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 0.778739] [] (bus_add_driver+&ฌ,ึ๙] (driver_register+0x9c/0x138) [ 0.778780] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac) [ 0.778821] [] (i2c_register_driver+0x40/0xac) from [] (rk818_module_init+0x10/0x34) [ 0.778860] [] (rk818_module_init+0x10/0x34) from [] (do_one_initcall+0x34/0xc8) [ 0.778900] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 0.778942] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 0.778982] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 0.779020] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 0.779045] ---[ end trace 8c88a9ab6626809f ]--- [ 0.779074] power_hold_gpio up [ 0.779115] rk818_i2c_probe: rk818_pmic_sleep=0 [ 0.783113] vdd_arm: 712 <--> 1500 mV at 1100 mV [ 0.787421] vdd_logic: 712 <--> 1500 mV at 1100 mV [ 0.791254] rk818_dcdc3: 1200 mV [ 0.795537] vccio: 1800 <--> 3300 mV at 3000 mV [ 0.799390] rk818_ldo1: 3300 mV [ 0.803165] rk818_ldo2: 3000 mV [ 0.806982] rk818_ldo3: 1100 mV [ 0.810801] rk818_ldo4: 2800 mV [ 0.814618] rk818_ldo5: 3000 mV [ 0.818418] rk818_ldo6: 1200 mV [ 0.822286] rk818_ldo7: 1800 mV [ 0.826102] rk818_ldo8: 1800 mV [ 0.828969] vcc_sd: 1800 <--> 3000 mV at 3000 mV [ 0.830429] rk818_ldo10: at 3000 mV [ 0.832257] rk818_irq_init: rk818_pmic_irq=1 [ 0.832877] fireprime_rk818_hdmi_5v_en enable:1 [ 0.833732] i2c-core: driver [rk818] using legacy suspend method [ 0.833759] i2c-core: driver [rk818] using legacy resume methoing, 0.83wait. .witching to clocksource arch_sys_counter [ 0.858234] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.872468] fb disp policy is box [ 0.872587] rk-fb rockchip-fb: rk fb ion client create success! [ 0.872616] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.873126] rk-screen rk_screen.9: rockchip screen probe success [ 0.873738] rk31xx-lvds 20038000.lvds: screen is not lvds/rgb! [ 0.873787] rk31xx-lvds: probe of 20038000.lvds failed with error -22 [ 0.874906] rk312x-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 0.874938] rk_fb_trsm_ops_get:un supported transmitter:6! [ 0.875528] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.876312] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.876729] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.877354] rk312x-lcdc lcdc0: set lcdc0 dclk failed [ 0.877389] rk312x-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60 [ 0.877415] rk312x-lcdc lcdc0: wakeup from standby! [ 0.895325] alloc_buffer:ion_phy_addr=0x10000000 [ 0.900795] fb0:phy:10000000>>vir:e0930000>>len:0xb00000 [ 0.910278] rk312x-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 0.926676] NET: Registered protocol family 2 [ 0.927602] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.927739] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.927853] TCP: Hash tables configured (established 4096 bind 4096) [ 0.927976] TCP: reno registered [ 0.928008] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.928057] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.928438] NET: Registered protocol family 1 [ 0.930566] rk818-battery rk818-battery: invalid fcc(0x0), use design capacity [ 0.931425] rk818-battery rk818-battery: update fcc : 2100 [ 0.931716] rk818-battery rk818-battery: not battery, enter test power mode [ 0.953194] rk818-battery rk818-battery: v=4200, ov=4200, rv=0, c=0, pwroff_min=0 [ 0.959306] rk818-battery rk818-battery: c=0, v=4200, relax=0, ocv=4200, est=4200, calib=-1 [ 0.960083] rk818-battery rk818-battery: reg soc=0, init soc = 0, init cap=0 [ 0.988474] rk818-battery rk818-battery: battery driver version 4.0.0 [ 0.989256] Unpacking initramfs... [ 1.271303] Freeing initrd memory: 2664K (c5bf0000 - c5e8a000) [ 1.272585] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available [ 1.273289] vcodec_service: probe device vpu_combo.10 [ 1.273326] vcodec_service: No reset resource define [ 1.273346] vcodec_service: No reset resource define [ 1.273363] vcodec_service: No reset resource define [ 1.273488] vcodec vpu_combo.10: failed on clk_get clk_cabac [ 1.273602] vcodec_service: vpu_combo.10: power on [ 1.273756] vcodec_service: probe device 10106000.vpu_service [ 1.273816] vcodec_service: checking hw id 4831 [ 1.275141] vcodec_service: probe device 10104000.hevc_service [ 1.275211] vcodec_service: checking hw id 6867 [ 1.276183] vcodec_service: vpu_combo.10: power off... [ 1.276256] vcodec_service: done [ 1.276275] vcodec_service: init success [ in:27o4di] esanntise dri0ers 4..3-31 [ 1.276729] rknand_probe clk rate = 148500000 [ 1.276920] rknand_driver:ret = 0 [ 1.278442] rk_dts_sensor_probe:Get s5k4ec rockchip,power failed! [ 1.278483] s5k4ec_io==1 [ 1.278578] the gpiorst1 is 107 [ 1.278616] the gpiorst2 is 107 [ 1.278676] rk_dts_sensor_probe:Get ov2659 rockchip,power failed! [ 1.278709] s5k4ec_io==2 [A :.278ld7]otklotd /lensmodules/3.10.0/modules.dep: No such file or directory or_probe:Get gc0329 rockchip,power failed! [ 1.278779] s5k4ec_io==2 [ 1.278814] rk_dts_sensor_probe:Get gc2035 rockchip,powerdown failed! [ 1.278844] s5k4Ac_L: Cou [ o 1.278903] s5k4ec_io==2 [ 1.280496] audit: initializing netlink socket (di /llb/m)du[e /3112.0/mo]ulyp.d20:0 ausuchiti0.740: o): inectarized [ 1.281965] bounce pool size: 64 pages [ 1.292359] fuse init (API version 7.22) du e /..96.83moduoek lep:r SCSu h neric rbsgr dtivy version 0.4 loaded (major 246) [ 1.296821] io scheduler noop registered [ 1.296841] io scheduler deadline FAgAs: rodl [not l.2d9/0i8] ooulcheduler cfq registered (default) [ 1.302692] rga 1010c000.rga: rga ion clients/3.ate0smoduses.de : No su h f3le026] rga: Driver loaded succesfully [ 1.303156] rga: Module initialized. [ or d4r6cto]yr -hdmi 20034000.onm.: rockchip_hdmiv1_set_pwr_mode change pwr_mode 0 --> 1 [ 1.406809] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode LOegi_PWRun[i g /.cri0ts] rkthpmemount40.0 hdmi: hdmi probe success. [ 1.407987] IEP Power ON [ 1.408066] iep ion client create success! [ 1.408528] IEP Power OFF [ 1.408563] IEP Driver loaded succesfully [ 1.408712] Module initialized. [ 1.409234] cvbs connect to lcdc0 [ 1.409302] rk312x-lcdc lcdc0: lcdc0: dclk:27000000>>fps:63 [ 1.409506] rk3036-tve 1010e200.tve: rockchip,rk312x-tve tv encoder probe ok [ 1.412422] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.412462] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16 [ 1.413342] rk_serial.c v1.8 2014-03-04 [ 1.413692] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 52) is a rk29_serial.0 [ 1.414115] serial 20060000.serial: membase e3452000 [ 1.420439] loop: module loaded [ 1.420569] i2c-core: driver [mpu6050B1] using legacy suspend method [ 1.420594] i2c-core: driver [mpu6050B1] using legacy resume method [ 1.420621d np. u_init: Probe name mpu6050B1 [ 1.420969] ak8963_mod_init: Probe name ak8963_mod [ 1.422322] SCSI Media Changer driver v0.25 [ 1.422969] tun: Universal TUN/TAP device driver, 1.6 [ 1.422996] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.423295] vmac_init. [ 1.424411] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 1.424443] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 1.424468] stmmac_probe_config_dt: clock input or output? (input). [ 1.424491] stmmac_probe_config_dt: TX delay(0x30). [ 1.424512] stmmac_probe_config_dt: RX delay(0x10). [ 1.424611] stmmac_probe_config_dt: is rockchip,rk312x-gmac [ 1.424631] stmmc_pltfr_init: [ 1.424649] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 1.424745] stmmc_pltfr_init: init for RGMII [ 1.424771] tx delay=0x30 [ 1.424771] rx delay=0x10 [ 1.425005] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.425027] Normal descriptors [ 1.425043] Ring mode enabled [ 1.425061] DMA HW capability register supported [ 1.425080] RX Checksum Offload Engine supported (type 2) [ 1.425100] TX Checksum insertion supported [ 1.425116] Wake-Up On Lan supported [ 1.425199] Enable RX Mitigation via HW Watchdog Timer [ 1.426209] PPP generic driver version 2.4.2 [ 1.426587] PPP BSD Compression module registered [ 1.426614] PPP Deflate Compression module registered [ 1.426649] PPP MPPE Compression module registered [ 1.426671] NET: Registered protocol family 24 [ 1.426725] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 1.426751] CSLIP: code copyright 1989 Regents of the University of California. [ 1.426774] Rockchip WiFi SYS interface (V1.00) ... [ 1.426850] esp_mem_init enter date Apr 20 2016 18:32:01 [ 1.426871] esp_mem_init VERSION [V2.5] [ 1.426957] esp_mem_init complete [ 1.427116] usbcore: registered new interface driver catc [ 1.427211] usbcore: regint Mou nin inoorfaceedsystr kaw.th [ 1.427237] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Eteeinet dniver [c pt./loc34- osbc.. : rone.t red new interface driver pegasus [ 1.427423] usbcore: registered new interface driverext48 50 [ 1.427510] usbcore: registered new interface driver r8152 [ 1.427534] hso: drivers/net/usb/hso.c: Option Wireless eg n 1.un76ng]/ucsbporel ceg-ptermdune ..n erface driver hso [ 1.427804] usbcore: registered new interface driver asix [ 1.427897] usbcALe Creld ner l ae iit/moduees/3.er.0/8od7l_s7dap: N 1.42fil5 ousbiorctoregistered new interface driver cdc_ether [ 1.428074] usbcore: registered new interface driver cdc_eem [ 1.428175] usbcore: registered new interface driver dm9601 [ 1.428257] usbcdon: gistered new interface driver dm9620 [ 1.428354] usbcore: registered new interface driver smsc75xx [ 1.428466] usbcore: registered new interface driver smsc95xx [ FA42L5 0ouud note: registered loaintlrfamo uris/3 g062/modul .1.428633] udec: N: regi fered new interfaor dr1080 ne [ 1.428714] usbcore: registered new interface driver plusb [ 1.428794] usbcore: registered new interface driver rndis_host [ 1.428875] usbcore: registered new interface driver cdc_subset [ 1.428955] usbcore: registered new interface driver zaurus [ 1.429049] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.429178] usbcore: registered new interface driver int51x1 [ 1.429262] usbcore: registered new interface driver kalmia [ 1.429343] usbcore: registered new interface driver ipheth [ 1.429431] usbcore: registered new interface driver sierra_net [ 1.429513] usbcore: registered new interface driver cx82310_eth [ 1.429614] usbcore: registered new interface driver cdc_ncm [ 1.429708] usbcore: registered new interface driver qmi_wwan [ 1.429791] usbcore: registered new interface driver cdc_mbim [ 1.429815] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.431765] EHCI: ehci_rk_probe e3480000 e3480010 [ 1.431801] rockchip_ehci_host 101c0000.usb: EHCI Host Controller [ 1.431863] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1 [ 1.432508] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000 [ 1.445863] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00 [ 1.446016] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.446048] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.446075] usb usb1: Product: EHCI Host Controller [ 1.446099] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 1.446123] usb usb1: SerialNumber: 101c0000.usb [ 1.447056] hub 1-0:1.0: USB hub found [ 1.447105] hub 1-0:1.0: 1 port detected [ 1.447488] EHCI: ehci_rk_probe ok [ 1.447671] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.447904] ohci-rockchip 101e0000.usb: RK OHCI Host Controller [ 1.447958] ohci-rockchip 101e0000.usb: new USB bus registered, assigned bus number 2 [ 1.448042] ohci-rockchip 101e0000.usb: irq 64, io mem 0x101e0000 [ 1.508924] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.508959] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.508987] usb usb2: Product: RK OHCI Host Controller [ 1.509012] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd [ 1.509035] usb usb2: SerialNumber: 101e0000.usb [ 1.509870] hub 2-0:1.0: USB hub found [ 1.509930] hub 2-0:1.0: 1 port detected [ 1.510563] usbcore: registered new interface driver cdc_acm [ 1.510590] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.510709] usbcore: registered new interface driver usblp [ 1.510805] usbcore: registered new interface driver cdc_wdm [ 1.510954] usbcore: registered new interface driver usb-storage [ 1.511039] usbcore: registered new interface driver ums-alauda [ 1.511133] usbcore: registered new interface driver ums-cypress [ 1.511218] usbcore: registered new interface driver ums-datafab [ 1.511299] usbcore: registered new interface driver ums_eneub6250 [ 1.511379] usbcore: registered new interface driver ums-freecom [ 1.511462] usbcore: registered new interface driver ums-isd200 [ 1.511542] usbcore: registered new interface driver ums-jumpshot [ 1.511623] usbcore: registered new interface driver ums-karma [ 1.511703] usbcore: registered new interface driver ums-onetouch [ 1.511788] usbcore: registered new interface driver ums-sddr09 [ 1.511870] usbcore: registered new interface driver ums-sddr55 [ 1.511950] usbcore: registered new interface driver ums-usbat [ 1.512146] usbcore: registered new interface driver usbserial [ 1.512233] usbcore: registered new interface driver usbserial_generic [ 1.512305] usbserial: USB Serial support registered for generic [ 1.512391] usbcore: registered new interface driver ftdi_sio [ 1.512459] usbserial: USB Serial support registered for FTDI USB Serial Device [ 1.512636] usbcore: registered new interface driver option [ 1.512705] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.512927] usbcore: registered new interface driver trancevibrator [ 1.512952] usb20_otg: version 3.10a 21-DEC-2012 [ 1.513621] e3500040 [ 1.513650] Core Release: 2.91a [ 1.513671] Setting default values for core params [ 1.513928] Using Buffer DMA mode [ 1.513952] Periodic Transfer Interrupt Enhancement - disabled [on 5done.] Multiprocessor Interrupt EnhanceBegin: Running /s[ 1.513994]t OmG.V. PARAM: 0, OTG VER FLAG: 0 [ 1.514012] ^^^^^^^^^^^^^^^^^Device Mode [ 1.514037] Dedicated Tx FIFOs mode [ 1.514073] pcd_init otg_dev = c5a12200 [ 1.514432] usb20_otg 10180000.usb: DWC OTG Controller [ 1.514499] usb20_otg 10180000.usb: new USB bus regdone.ed, assigned bus number 3 [ 1.514560] usb20_otg 10180000.usb: irq 42, io mem 0x00000000 [ 1.514771] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.514806] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.514833] usb usb3: Product: DWC OTG Controller [ 1.514858] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.514882] usb usb3: SerialNumber: 10180000.usb [ 1.515783] hub 3-0:1.0: USB hub found [ 1.515832] hub 3-0:1.0: 1 port detected [ 1.516456] usb20_host: version 3.10a 21-DEC-2012 [ 1.517400] usbcore: registered new interface driver xpad [ 1.517524] usbcore: registered new interface driver usb_acecad [ 1.517638] usbcore: registered new interface driver aiptek [ 1.517740] usbcore: registered new interface driver gtco [ 1.517837] usbcore: registered new interface driver hanwang [ 1.517932] usbcore: registered new interface driver kbtab [ 1.518044] usbcore: registered new interface driver wacom [ 1.518066] ==gsl_ts_init== [ 1.518166] GSLX680 Enter gsl_ts_probe [ 1.613241] dwc_otg_hcd_suspend, usb device mode [ 1.760767] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host [ 1.839452] gsl_ts_probe--1269, i2c_master_recv fail [ 1.839498] gslX680: probe of 0-0041 failed with error -11 [ 1.839575] ret=0 [ 1.840231] sensor_register_slave:mma8452,id=17 [ 1.840259] sensor_register_slave:gs_mc3230,id=23 [ 1.840277] gsensor_init [ 1.840296] sensor_register_slave:mpu6880_acc,id=24 [ 1.840316] sensor_register_slave:cm3217,id=47 [ 1.840336] sensor_register_slave:cm3218,id=48 [ 1.840736] .. rk pwm remotectl v1.1 init [ 1.841146] input: 20050030.pwm as /devices/20050030.pwm/input/input0 [ 1.847452] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 1.847541] i2c /dev entries driver [ 1.848189] IR NEC protocol handler initialized [ 1.848216] IR RC5(x) protocol handler initialized [ 1.848235] IR RC6 protocol handler initialized [ 1.848253] IR JVC protocol handler initialized [ 1.848271] IR Sony protocol handler initialized [ 1.848289] IR RC5 (streamzap) protocol handler initialized [ 1.848308] IR SANYO protocol handler initialized [ 1.848327] IR MCE Keyboard/mouse protocol handler initialized [ 1.848824] usbcore: registered new interface driver uvcvideo [ 1.848850] USB Video Class driver (1.1.1) [ 1.848873] CamSys driver version: v0.27.1, CamSys head file version: v0.10.0 [ 1.848900] E:camsys_soc_init(87): camsys isn't support soc: 0x31260001! [ 1.851160] i2c-core: driver [bq27320] using legacy suspend method [ 1.851192] i2c-core: driver [bq27320] using legacy resume method [ 1.851958] device-mapper: uevent: version 1.0.3 [ 1.852494] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 1.853203] Bluetooth: HCI UART driver ver 2.2 [ 1.853232] Bluetooth: HCI H4 protocol initialized [ 1.853252] Bluetooth: HCILL protocol initialized [ 1.853272] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.19 [ 1.853293] rtk_btusb: Register usb char device interface for BT driver [ 1.853702] usbcore: registered new interface driver rtk_btusb [ 1.859417] cpufreq version 1.0, suspend freq 1008 MHz [ 1.859793] cpuidle: using governor ladder [ 1.859817] cpuidle: using governor menu [ 1.859888] Synopsys Designware Multimedia Card Interface Driver [ 1.859911] MHSC version = Ver 2.00 2015-06-10 [ 1.860355] dw cru_regsbase addr 0x124. [ 1.860380] dw cru_reset_offset val 3. [ 1.860408] dwmmc_rockchip 1021c000.rksdmmc: Version ID is 270a [ 1.860470] dwmmc_rockchip 1021c000.rksdmmc: failed to get hpclk_mmc [ 1.860915] dwmmc_rockchip 1021c000.rksdmmc: Using external DMA controller. [ 1.861317] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc0] [ 1.861601] 1358..dw_mci_set_ios: no card. [mmc0] [ 1.878874] 1358..dw_mci_set_ios: no card. [mmc0] [ 1.898593] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaro Welcome to Uor init[mmc0] [ 1.898631] dwmmc_rockchip 1021c000.rksdmmc: DW MMC controller at irq 48, 32 bit host data width, 256 deep fifo [ 1.898651] dwmmc_rockchip 1021c000.rksdmmc: 1 slots initialized [ 1.899184] dw cru_regsbase addr 0x124. [ 1.899212] dw cru_reset_offset val 1. [ 1.899239] dwmmc_rockchip 10214000.rksdmmc: Version ID is 270a [ 1.899300] dwmmc_rockchip 10214000.rksdmmc: failed to get hpclk_mmc [ 1.900131] dwmmc_rockchip 10214000.rksdmmc: Using external DMA controller. [ 1.900456] dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1] [ 1.901117] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.908964] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101 [ 1.908991] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.909011] usb 1-1: Product: USB 2.0 Hub [MTT] [ 1.909757] hub 1-1:1.0: USB hub found [ 1.909946] hub 1-1:1.0: 4 ports detected [ 1.918218] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.937888] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.937918] dwmmc_rockchip 10214000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo [ 1.937935] dwmmc_rockchip 10214000.rksdmmc: 1 slots initialized [ 1.938268] dw cru_regsbase addr 0x124. [ 1.938282] dw cru_reset_offset val 2. [ 1.938297] dwmmc_rockchip 10218000.rksdmmc: Version ID is 270a [ 1.938338] dwmmc_rockchip 10218000.rksdmmc: failed to get hpclk_mmc [ 1.938608] dwmmc_rockchip 10218000.rksdmmc: Using external DMA controller. [ 1.938913] dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc2] [ 1.939129] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.957548] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.977234] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.977262] dwmmc_rockchip 10218000.rksdmmc: DW MMC controller at irq 47, 32 bit host data width, 256 deep fifo [ 1.977279] dwmmc_rockchip 10218000.rksdmmc: 1 slots initialized [ 1.977569] leds-gpio leds.18: pins are not configured from the driver [ 1.977976] hidraw: raw HID events driver (C) Jiri Kosina [ 1.980446] usbcore: registered new interface driver usbhid [ 1.980467] usbhid: USB HID core driver [ 1.981068] zram: Created 1 device(s) ... [ 1.981658] ashmem: initialized [ 1.981855] logger: created 256K log 'log_main' [ 1.982031] logger: created 256K log 'log_events' [ 1.982221] logger: created 256K log 'log_radio' [ 1.982380] logger: created 256K log 'log_system' [ 1.983918] input: rk29-keypad as /devices/2006c000.adc/key.21/input/input1 [ 1.985303] ------------[ cut here ]------------ [ 1.985327] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4() [ 1.985339] autorequest GPIO-27 [ 1.985348] Modules linked in: [ 1.985365] CPU: 1 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #18 [ 1.985395] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 1.985417] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 1.985438] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c) [ 1.985458] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4) [ 1.985479] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0) [ 1.985503] [] (gpiod_direction_input+0x58/0x1f0) from [] (rk312x_platform_probe+0x46c/0x5a4) [ 1.985529] [] (rk312x_platform_probe+0x46c/0x5a4) from [] (platform_drv_probe+0x14/0x18) [ 1.985550] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c) [ 1.985570] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 1.985590] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 1.985609] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 1.985628] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+[xac/0x20c) [ 1.985647] [<c030wdac iver_reg OK ] Listening on ude [] (driver_registe[ OK om [] (yo_ene_initc l+0x34/0[ OK 691] [] sdo_onetty.slice. 34/0xc8[rom [L (do_initcallsurnal Socket. 1.985713] [] (do_initcal +0 0Sa0)tfno Remo0b9fbe8>] nd Kernei it_f Seatle+0x90 0x130)[2 1.9857[4m] ] (terneryited foleabse+0x90/0x13[32om [] (keinel_inidevx8/0xe4) [ e 1 85755] [] (kernel_init+0x8/0xe4) from c000 Star (ngtCfeate Sra+ix 4/vxce)N [e in 9dev..] --[ end trace 8c88a9ab662680a0 ]--- eady.eni9g6o2 /deo/icitp-spdif 1ti040l0ts dam:d Pipf d t2m 2K m0. [ 1.9885[9[3amdioKrk3[0x Lditeni3g2o. Jo rnk312xdhifi c->t.o kchip-i2s.[ mapping ok ] C1eated0s] audio-rk312x audio-rS31cx.14: rk312x-voice <-> rockchip-i2s.1 map i k [ rt1n9893e5] oldpo-g 3llxDevice-...12x.14: noKsink wi Ret fountarget icmote F [ 1.98s 6P] a.dio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Jack -> direct -> Mic Bias [ 1.989376] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic B 1.9ting L au ie-nel1Mo312x.14:[C: FOKle addstouin Min Biarn-l diceet -> ev/log[ ias989404] audio-rk312x audio-rk312x.14: ASo : o Surct wg geurfou deforcM.c. d to add route Mic Bias -> direct -> MICN Mounket. [ ebug8F4i2e Susto-.k3 x audio-rk312x.14: ASoC: no sink widget found for Mic Bias [ 1.989446] audi2rk 1K2 aum] ireak31 sl.c4:system-s riASoC:dgeiled tt ydslioe. Headse[a2m -O ir[ct] >eMihediaar e Slic1.98 461] audio-rk312x audio-rk312x.14: ASoC: no s[ur32m OKg t 0ou d afor PeUTun rt[ l Co.s8le.: ASoC: Failed to add [2 H OU R -> ] Stcrt-d Eet S V audio-rk312x audio-rk312x.[ A3oC:Ano sr]e wilee to suar ooaH OUrLe 9503See "iyste3c2l sudiu- k312em.14: uSeC-load.serti e"d rr de aiOsTL -> direct -> Ext Spk [ 1.989517] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR [ 1.989531] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR -> direct -> Headphone Jack [ 1.989546] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL [ 1.989559] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL -> direct -> Headphone Jack [ 1.991551] rockchip-hdmi-spdif rockchip-hdmi-spdif.13: rk-hdmi-spdif-hifi <-> 10204000.spdif mapping ok [ 1.992333] u32 classifier [ 1.992351] Actions configured [ 1.992365] Netfilter messages via NETLINK v0.30. [ 1.992450] nf_conntrack version 0.5.0 (15471 buckets, 61884 max) [ 1.992944] ctnetlink v0.93: registering with nfnetlink. [ [32m 1O99 0[0m6] ]NM_TntOd DY: gTFils aystem.ent proxy support initialized, version 4.1.0 [ 1.993048] NF_TPROXY: Mounting FUSE Control File System... Copyright (c) 2006-2007 BalaBit IT Ltd. [ 1 Mounting C3nf4guration FiletStsmem .. kernel timezone is -0000 [ 1.993915] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.994115] arp_tables: (C) 2002 David S. Miller [ 1.994180] TCP: cubic registered [a i 1l9945.6] NET: Registered protocol family 10 995460] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.995662] sit: IPv6 over IPv4 tunneling driver [ 1.996224] NET: Registered protocol family 17 ] Mouyted 395] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 1.985[nf uration 6ile]SBridge.ack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) emi te ed 395] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ M u1t9d 382] Conabol File ystemteck+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) irewalli[5438] [] (warn_sloedath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c) [ [0 1.9tar37] ulevtCotdp: RFaOl eei 1.11yer in[t[aliz Ofrom [] (gpio_ensure_requested+0x4c/0xb4) m2ma iKn) [0m]1Start Lo.d/Save]Raldetooeed.BNEP filters: protocol multicastc>] (rk312x_platform_probe+0x46c/0x5a4[ 1.996776] Bluetooth: BNEP socket layer initialized [ 1.996787] Bluetooth: HIDP (Human Interface Emulation) ver 1.2om [] (platform_drv_probe+0x14/0x18) [ 1.996804] Bluetooth: HIDP socket layer initialized18) from [] (really_probe+0xa8/0x20c) [ 1.996904] l2tp_core: L2TP core driver, V2[0x20c) from [] (driver_probe_device+0x30/0x48) [ 1.985590] [] (driver_probe_devic K 9969m] St2tt_d A: PP oL2nP keaniabdri.er, V2.0/0x84) [ 1.996945] [WLAN_RFKILL]: Enter rfkill_wlan_init84) from [] (bus_for_each_dev+0x50/0x90) [ 1.997155] [WLAN_RFKILL]: Enter rfkill_wlan_probe90) from [] (bus_add_driver+[xac/0x20c) [ 1.997174] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 1.997186] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.4>] (yo_ene_initc [ 1.997198] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 1.997210] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 1.997266] [WLAN_RFKILL]: wla[_platdata_par0m] etdt: get properSty: WIFI,poweren_gpio = 43, flags = 0. [ 1.997299] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 2, flags = 0.2 1.9857[4m][ 1.997312] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio6 >] (keinel_inidevx8/0xe4) [ 1.997345] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.997410] [BT_RFKILL]: Enter rfkill_rk_init c000 Star (ngtCfeate Sra+ix 4/vxce)N [ 1.997629] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 17.in 9dev..] [ 1.997666] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 35. [ 1.997689] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 42. [[ 3 m1.OK [ Reached target Local File Systemseup hosush Journal to Persistke_host_irq. . [ 1.992m ] [ Rm]IRL]: ** dargete oca kchip-i2s.[ mapping ok ] C1eated0s] audio-rk312x au] [BT_RFKILL]: ap6212 device registered.p-i2s.1 map i k 1.14 Zoom by ippactmng L(B:8R)ise3n2x-crm iatvrfaion: v0 [ rt1n9893e5] oldpo-g 3llxDevice-...12x.14: noKsink wite 1.998469] rk_cif 1010a 0. if rtactieg Tcll_ilmuxuch Td Wrt eeO cif_ptnma D ta..t [ 98 oc]cameca-pdrv s5k4ec_back_3: Probing sk312x audio-rk312x.14: ASoC: Failed to add route Mic Jack -> direct -4ec_back_3 [ 1.999349] VFP support v0.3: imple nt St1rainh tee cunsol2 parma30 .aor Mic B 1.9ting L au ie-nel1Mo312x.14:[C: FOKle addstouin Min Biarn-l diceet -> ev/log[ iant 7 rev 5 . 9ta90ingku12x_susnend_initx.14: ASo : o Surct wg geurfou deforcM.c. [ 1...99647] Registering SWP/SWPB emulation handlerket. [ 1.999666] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 2000000@9dc00000 [ 2.004956] ddrfreq: verion 1.2 20140526nd for Mic Bias [ 2.004986] ddrfreq: normal 492MHz v[d[o;10mFAp E40M0z ]iFao_4k 396MHz duSlv ew s96e keidap 0MHz seepeny 1emcHl sebtus 492sHz ir[ct] >eMihediaar -freq=0004999] ddrfreq: aut e Slic1.98 [ 2.005009] ddrfreq: auto-freq-table[0] 240MHzaudio-rk312x audio-rk312x.14: ASoC: no s[ur32m OKg t 0ou d afor [ 2.005018] ddrfreq: auto-freq-table[1] 324MHz [ 2.005027] ddrfreq: auto-freq-table[2] 396MHz] Stcrt-d Eet S V [ 2.005037] ddrfreq: auto-freq-table[3] 528MHzto suar ooaH OUrLe [ 2.032966] rk818_ldo8: disabling uSeC-load.serti e"d rr de aiOsTL -> direct -> Ext Spk [ 2.033890] rk818_ldo4: disabling312x.14: ASoC: no source widget found for HPOUTR [ 2.034565] regulator-dummy: disabling14: ASoC: Failed to add route HPOUTR -> direct -> Headphone Jack [ 2.[34341] O=====] S===t====l=sh ========== P==si=t=n==Storage. found for HPOUTL [ 2.034758] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== HPOUTL -> direct -> Headphone Jack [ 2.034770] =======================================================dif-hifi <-> 10204000.spdif mapping ok [ 2.034783] WiFi driver ( o r bySRockingp,Vea e.10.aFDleOF.64biandinire [rie ..034886] dhd_module_init: inred [ 2.034904] ======== bcm_wlan_set_plat_data ======== [ 2.034916] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter4 max) [ 2.034967] host_oob_irq: 169 egistering with nfnetlink. [ 2.034978] host_oob_irq_flags=4gTFils aystem.ent proxy support initialized, version 4.1.0 [ [3034 OK] wifi_rlet Teml Pldm Ent ro W ite Ou3 020] mewDatap adapter 'DHD generic adapter' [ 2.035037] pcd_pullup, is_on 0T Ltd. [ 2.035076] wifi_platform_set_power = 1tStsmem .. [ 2.035089] ======== PULL WL_REG_ON HIGH! ======== [ 2.035101] [WLAN_RFKILL]: rockchip_wifi_power: 1re Team [ 2.035114] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1 [ 2.035127] [WL[N_2m O 0hi] wtfrtee Crolte V: oiatiie Fifes ane volectercos.r [a i 1l9945.6] NET: Registered protocol family 10 l is disabled. [ 2.035133] file system registeredfilter Core Team [ 2.036592] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 2.036614] android_usb gadget: Number of LUNs=2 [ 2.036628] lun0: LUN abStarilng Neo med Tm)e S r.0iz6t1] .lun1: LUN: removable file: (no medium) [ 2.036985] and o _ Startieg: andte U_MP beut Sys 2o0t/1h9t owns.r_ nit: Probe name sensors [ 2.037141] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 2.037734] rtc_hym8563 0-0051: setting system clock to 2011-01-02 05:20:56 UTC (1293945656) [ 2.044645] usbcore: registered new interface driver snd-usb-audio [ 2.044669] ALSA device list: [ 2.044681] #0: RK_RK312X [ 2.044691] #1: RK-HDMI-SPDIF [ 2.045296] Freeing unused kernel memory: 360K (c0b9f000 - c0bf9000) [ 2.084878] rk30xxnand_ko: module license '' taints kernel. [ 2.084906] Disabling lock debugging due to kernel taint [ 2.086676] rknand_init: [ 2.086758] No.1 FLASH ID:ad de 14 a7 42 4a [ 2.093168] FTL version: 5.0.25 20150515 [ 2.105204] Cam_Powerdowm [ 2.105318] rk818_ldo8: operation not allowed [ 2.134644] [WLAN_RFKILL]: wifi turn on power. 43 [ 2.174114] rkl do4: opera]iSt not aUldwed U[ bo1t3Sys]emsboot/S1utdown. l-speed USB device number 3 using rockchip_ehci_host [ 2.213359] ret: 0 [ 2.238490] min_w = 800,min_h = 600 ,max_real_w = 2592,max_real_h = 1944,max_w = 2592,max_h =1944 [ 2.240037] s5k4ec_back_3(rk_cam_sensor:169): write reg(0xfcfc, val:0xd000) failed, try to write again! ta get2.2y3022] ime4ecnchcon3zrd_cam_sensor:169): write reg(0xfcfc, val:0xd000) failed, try to write again! [ 2.243053] s5k4ec_back_3(rk_cam_sensor:387): write array failed! [ 2.243068] s5k4ec_back_3(rk_cam_sensor:671): soft reset failed [ 2.243068] [ 2.264071] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again! [ 2.265571] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again! [ 2.267066] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again! [ 2.268561] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2e, val:0x1a4) failed, try to write again! [ 2.270057] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2e, val:0x1a4) failed, try to write again[ 2K2 150m] sta4tcd uaev K(rkelaDeveneoManag): write reg(0x2e, val:0x1a[32iled, tt] wrice agaarget[Pat 2. 3367] s5k4ec_back_3(rk_cam_sensor:335): read reg(0xf12 val:0x0) failed, try to re gain!t r ng C273398les5k4nerbtck 3hrk_cam_sensor:718): error: mismatched pid = 0xffff s r ..2.73oot] 96281] usb 1-1.1: New USB device found, idVendor=24ae, idProduct=2010 [ 2.296308] usb 1-1.1: New USB device str[3: fr=1, Prm] St=r,eS CopyNruber 0 e t 2.w9i32 the root was ro. ] usb 1-1.1: Product: Rapoo 2.4G Wireless Device [ 2.296343] usb 1-1.1: Manufacturer: RAPOO [ 2.299846] input: RAPOO Rapoo 2.4G Wireless Device as /devices/101c0000.usb/usb1/1-1/1-1.1/1-1.1:1.0/input/input2 [ 2.300342] hid-generic 0003:24AE:2010.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-101c0000.usb-1.1/input0 [ 2.302138] FtlInit 0 [ 2.302822] nand part : offset end flag [ 2.302882] rknand_uboot : 2000 - 4000 (00) [ 2.303624] rknand_misc : 4000 - 6000 (00) [ 2.303710] input: RAPOO Rapoo 2.4G Wireless Device as /devices/101c0000.usb/usb1/1-1/1-1.1/1-1.1:1.1/input/input3 [ 2.304070] rknand_resource : 6000 - e000 (00) [ 2.304439] hid-generic 0003:24AE:2010.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-101c0000.usb-1.1/input1 [ 2.304507] rknand_boot : e000 - 1e000 (00) [ 2.304929] rknand_backup : 1e000 - 3e000 (00) [ 2.305427] rknand_linuxroot : 3e000 - e5c000 (00) [ 2.307627] init_nand_blk_dev:ret = 0 [ 2.329436] udevd[137]: starting version 175 [ 2.341351] wifi_platform_bus_enumerate device present 1 [ 2.341374] ret: 0 [ 2.341391] ======== Card detection to detect SDIO card! ======== [ 2.341409] mmc2:mmc host rescan start! se n t2.3k in6erhic-g..APOO Rapoo 2.4G Wireless Device as /devices/101c0000.usb/usb1/1-321 1.1/1m] S2/inedt/Snp Ra 2. St274ing R_sowredSomnd C 2.ta89...sb-1.1/input2aRionO s[a e 2u55So4k] rk_sdmmc: BOOT dw_mcarilng Neo med Tm)e _setup_bus: argue c kOm mkaroead od t80000 Sz forketi.[mmc2] (no medium) wn CIS tuple 0x80 (2 bytes)uimg unknandte U_MP beut Sys 2o0t/1h9t owns.r_ [ 2.604331] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) nit: Probe name sensors [ 2.606385] mmc2: queuing unknow IS Sla 0xn0 (ccbunts)S between two gsensors 2013-09-01 [ 2.037734] rtc_hym8563 0-0051: setting system clock to 201rv e...05:20:56 UTC (1293945656) [ 2.044645] usbcore: registered new interface driver snd-usb-audio 939] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)044669] ALSA device list: [ 2.715373] Cam_Powerdowm2X [ 2.7 6774] rtcng s-Bumc2: Busystem Messa spees (..o S art2.7T6rn ]n kifd.mc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 2.747068] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[ c ]Star ng.Tur596n min_w = 80 Wifn_. = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200/1h9t owns.r_ [ . 5 9 2] mScar inw heghtrueed SDIO ecocar aamebdffss ... nit: Probe name sensors [ 2.606385] mmc2: queuing unknow IS Sla 0xn0 (ccbunts)S between two gsensors 2013-09-01 Starting Net_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again! [ 2.044645] usbcor[ k 2nage77..new interface driver snd-usb-audio 939] mmc2: queuing unknown CIS tuple 0x80 (7v2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again! [ 2.7551 v26 9tfronng4(rB: Smt ens C:169)equenty Seal0ng03, ean:0r1) f"oled,and" to write again! [ 2.755241] ov2659_front_4(rk_cam_sensor:387): write array failed! [ 2.755259] ov2659_front_4(rk_cam_sensor:671): soft reset failed00Hz (slot req 37500000Hz, actual 3750 [ 2.755259] rk30xxnand_ko: module license '' taints kernel. [ 2.767952] bcmsdh_register: register client drivertaint o[ com2.7u97o3]h cisdw_se.m.ad mrdh_sdmmc_probe Enter bcmsdh_sdmmc_probe EnterH ID:ad de 14 a7 42 4a c[ ron7jobs.9] found adapter info 'DHD generic adapter' [ 2.770437] F1 na u Strrad @ x18 a0a0ron job0..a6 r:335): read reg(0x300a val:0x0) failed, try to read again!v:0x0 pkg:0x4 [ 2.777240] ov2659_fron k cam_sensotart9): road Sepvide...iled [ 2.777386] DHD: dongle ram size is set to 524288(ori[ 8OKat [00]/S1utdown. l-speed USB device number 3 using rockchip_ehci_host Re h2. t7rg8] wifi_s. form_get_ Starting Console System Startup Logging... mac_addr38490] min_w = 800,min_h = 600 ,max_real_w = 2592,max_real_h = 1944,max_w = 2592,max_h =1944 [ 2.777713] ======== bcm_wlan_get_mac_address ========g(0xfcfc, val:0xd000) failed, try to write again! [ 2.777728] [WLAN_RFKILL]: rockchip_wi[i2mac_K dr[0e] Stnree.fc, val:0xd000) failed, try to write again! LL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]ite array failed! [ 2.777765] [WLAN_RFKILL]: This mac address is not valid, ignored... [ 2.777789] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=0 [ 2.777875] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txtrite again! [ 2.778879] wl_create_event_handler(): thread:wl_event_handler:f6 started failed, try to write again! [ 2.779211] tsk Enter, tsk = 0xddba149c:169): write reg(0x2c, val:0x7000) failed, try to write again! [ 2.782271] dhd_attach(): thread:dhd_watchdog_thread:f7 startedal:0x1a4) failed, try to write again! [ 2.782486] dhd_attach(): thread:dhd_dpc:f8 started reg(0x2e, val:0x1a4) failed, try to write again[ [ 2.782634] dhd_dpc_thread: set dpc_cpucore 0 from config.txt 2K2 150m][ 2.782769] dhd_attach(): thread:dhd_rxf:fa startedl:0x1a[32iled, tt] wrice agaarget[Pat 2. [ 2.782806] dhd_deferred_work_init: work queue initialized ) failed, try to re gain!t [ 2.783267] dhdsdio_probe_init: set use_rxchain 0 from config.txt r ng C273398les5k4nerbt[ 2.801490] Dongle Host Driver, version 1.201.59.5 (r506368) [ 2.801490] Compiled in drivers/net/wireless/bcmdhd on Apr 20 2016 at 18:32:17 [ 2.802392] Register interface [wlan0] MAC: 04:e6:76:52:b1:dcProduct=2010 [ 2.802392] usb 1-1.1: New USB device str[3: fr=1, Prm] St=r,eS CopyNruber 0 [ 2.802431] dhd_prot_ioctl : bus is down. we have nothing to do [ 2.802538] bcmsdh_oob_intr_unregister: Enter [ 2.802555] bcmsdh_oob_intr_unregister: irq is not registered [ 2.802579] dhd_txglom_enable: enable 0eless Device as /devices/101c0000.usb/usb1/1-1/1-1.1/1-1.1:1.0/input/inpu[ 2.802593] dhd_bus_devreset: WLAN OFF DONE [ 2.802705] wifi_platform_set_power = 00001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Devic[ 2.802722] ======== PULL WL_REG_ON LOW! ======== [ 2.802736] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 2.882570] Cam_Powerdowm : offset end flag [ 2.902201] [WLAN_RFKILL]: wifi shut off power.000 (00) [ 2.902232] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0) [ 2.902246] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.1/input/inpu[ 2.902369] dhd_module_init: Exit err=0 [ 2.951408] ret: 0_resource : 6000 - e000 (00) [ 2.980959] soc-camera-pdrv gc0329_front_5: Probing gc0329_front_5: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wirel[ 3.049802] ret: 01c0000.usb-1.1/input1 [ 3.197360] Cam_Powerdowm : e000 - 1e000 (00) [ 3.202750] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480 [ 3.218477] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again! [ 3.219468] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again! [ 3.220447] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again! [ 3.220567] EXT4-fs (rknand_linuxroot): 1 orphan inode deleted [ 3.220586] EXT4-fs (rknand_linuxroot): recovery complete [ 3.232828] EXT4-fs (rknand_linuxroot): mounted filesystem with ordered data mode. Opts: (null) [ 3.248043] gc0329_front_5(rk_cam_sensor:335): read reg(0x0 val:0x0) failed, try to read again! [ 3.248088] gc0329(917): gc0329 read chip id high byte failedes/101c0000.usb/usb1/1-321 1.1/1m] S2/inedt/Snp Ra [ 3.248088] ng R_sowredSomnd C 2.ta89...sb-1.1/input2aRionO [ 3.248110] gc0329(924): error: gc0329 mismatched pid = 0x0 [ 3.248110] [ 3.248133] gc0329_front_5(rk_cam_sensor:718): error: mismatched pid = 0x0 [ 3.248133] [ 3.354822] Cam_Powerdowm [ 3.423771] ret: 0 [ 3.453297] soc-camera-pdrv gc2035_back_6: Probing gc2035_back_6 [ 3.541871] ret: 0 [ 3.601255] systemd[1]: Failed to insert module 'autofs4' [ 3.620995] systemd[1]: systemd 219 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN) [ 3.621400] systemd[1]: Detected architecture arm. [ 3.627140] systemd[1]: Set hostname to . [ 3.689406] Cam_Powerdowm [ 3.689440] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed [ 3.689535] soc-camera-pdrv gc2035_back_6: Cannot get I2C adapter #2. No driver? [ 3.797649] Cam_Powerdowm [ 3.797683] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed [ 3.797701] rk_cam_io(1117):SENSOR_PWRSEQ_HWRST failed [ 3.866525] ret: 0 [ 3.896081] soc-camera-pdrv gc0308_front_7: Probing gc0308_front_7 [ 3.949764] systemd[1]: [/lib/systemd/system/fbset.service:7] Unknown lvalue 'type' in section 'Service' [ 3.954155] systemd[1]: [/lib/systemd/system/wifi-on.service:7] Unknown lvalue 'type' in section 'Service' [ 3.977372] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 3.981401] systemd[1]: Reached target Swap. [ 3.981499] systemd[1]: Starting Swap. [ 3.984748] ret: 0 [ 3.985742] systemd[1]: Created slice Root Slice. [ 3.985826] systemd[1]: Starting Root Slice. [ 3.990679] systemd[1]: Listening on udev Kernel Socket. [ 3.990766] systemd[1]: Starting udev Kernel Socket. [ 3.991087] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 3.991162] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 3.995644] systemd[1]: Created slice System Slice. [ 3.995753] systemd[1]: Starting System Slice. [ 4.000832] systemd[1]: Created slice system-getty.slice. [ 4.000914] systemd[1]: Starting system-getty.slice. [ 4.005532] systemd[1]: Listening on Journal Socket. [ 4.005644] systemd[1]: Starting Journal Socket. [ 4.008340] systemd[1]: Starting Remount Root and Kernel File Systems... [ 4.013837] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 4.018813] systemd[1]: Reached target Encrypted Volumes. [ 4.018920] systemd[1]: Starting Encrypted Volumes. [ 4.024054] systemd[1]: Listening on udev Control Socket. [ 4.024194] systemd[1]: Starting udev Control Socket. [ 4.027610] systemd[1]: Starting Create Static Device Nodes in /dev... [ 4.035801] systemd[1]: Starting Setup Virtual Console... [ 4.046908] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 4.047076] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 4.047650] systemd[1]: Mounted Huge Pages File System. [ 4.052943] systemd[1]: Listening on Journal Audit Socket. [ 4.053054] systemd[1]: Starting Journal Audit Socket. [ 4.058611] systemd[1]: Created slice User and Session Slice. [ 4.058724] systemd[1]: Starting User and Session Slice. [ 4.061507] systemd[1]: Starting udev Coldplug all Devices... [ 4.071615] systemd[1]: Reached target Remote File Systems (Pre). [ 4.071743] systemd[1]: Starting Remote File Systems (Pre). [ 4.085426] systemd[1]: Starting Load Kernel Modules... [ 4.095070] systemd[1]: Listening on Journal Socket (/dev/log). [ 4.095200] systemd[1]: Starting Journal Socket (/dev/log). [ 4.098189] systemd[1]: Starting Journal Service... [ 4.107447] systemd[1]: Listening on Delayed Shutdown Socket. [ 4.107590] systemd[1]: Starting Delayed Shutdown Socket. [ 4.110971] systemd[1]: Mounting Debug File System... [ 4.120039] systemd[1]: Started Set Up Additional Binary Formats. [ 4.120308] systemd[1]: Mounted POSIX Message Queue File System. [ 4.127635] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 4.127750] systemd[1]: Starting system-serial\x2dgetty.slice. [ 4.131784] systemd[1]: Reached target Slices. [ 4.131942] systemd[1]: Starting Slices. [ 4.133132] Cam_Powerdowm [ 4.133302] soc-camera-pdrv gc0308_front_7: Cannot get I2C adapter #2. No driver? [ 4.141162] systemd[1]: Started Remount Root and Kernel File Systems. [ 4.148358] systemd[1]: Started Setup Virtual Console. [ 4.149364] systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE [ 4.161613] systemd[1]: Failed to start Load Kernel Modules. [ 4.161835] systemd[1]: Unit systemd-modules-load.service entered failed state. [ 4.162037] systemd[1]: systemd-modules-load.service failed. [ 4.234566] systemd[1]: Mounted Debug File System. [ 4.240545] Cam_Powerdowm [ 4.247769] systemd[1]: Mounting FUSE Control File System... [ 4.253148] systemd[1]: Mounting Configuration File System... [ 4.279473] systemd[1]: Starting Apply Kernel Variables... [ 4.286391] systemd[1]: Starting Load/Save Random Seed... [ 4.294595] systemd[1]: Started Various fixups to make systemd work better on Debian. [ 4.297781] systemd[1]: Started Rebuild Hardware Database. [ 4.310998] systemd[1]: Mounted Configuration File System. [ 4.316171] systemd[1]: Mounted FUSE Control File System. [ 4.319389] ret: 0 [ 4.323621] systemd[1]: Started Create Static Device Nodes in /dev. [ 4.330226] systemd[1]: Started udev Coldplug all Devices. [ 4.337807] systemd[1]: Started Load/Save Random Seed. [ OK ] Started Restore Sound Card State. [ OK ] Started Set truecolor framebuffer. [ OK ] Started LSB: Set the CPU Frequency Scaling governor to "ondemand". [ OK ] Started Permit User Sessions. [ OK ] Started Console System Startup Logging. [ OK ] Found device /dev/ttyFIQ0. [ OK ] Started Login Service. Starting Authenticate and Authorize Users to Run Privileged Tasks... [ OK ] Created slice system-systemd\x2drfkill.slice. Starting Load/Save RF Kill Switch Status of rfkill0... Starting Load/Save RF Kill Switch Status of rfkill1... Starting Load/Save RF Kill Switch Status of rfkill2... [ OK ] Created slice system-ifup.slice. [ OK ] Started ifup for wlan1. Starting ifup for wlan1... [ OK ] Started ifup for eth0. Starting ifup for eth0... [ OK ] Started ifup for sit0. Starting ifup for sit0... [ OK ] Reached target Sound Card. Starting Light Display Manager... [ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks. [ OK ] Started Load/Save RF Kill Switch Status of rfkill0. [ OK ] Started Load/Save RF Kill Switch Status of rfkill1. [ OK ] Started Load/Save RF Kill Switch Status of rfkill2. [ OK ] Started Accounts Service. [ OK ] Started Network Manager. [ OK ] Reached target Network. Starting /etc/rc.local Compatibility... [ OK ] Started OpenBSD Secure Shell server. Starting OpenBSD Secure Shell server... [ OK ] Started Light Display Manager. [ OK ] Started /etc/rc.local Compatibility. Starting Wait for Plymouth Boot Screen to Quit... [ OK ] Started Wait for Plymouth Boot Screen to Quit. [ OK ] Started Serial Getty on ttyFIQ0. Starting Serial Getty on ttyFIQ0... [ OK ] Started Getty on tty1. Starting Getty on tty1... [ OK ] Reached target Login Prompts. Starting WPA supplicant... [ OK ] Started WPA supplicant. [ OK ] Created slice user-1000.slice. Starting User Manager for UID 1000... [ OK ] Started User Manager for UID 1000.
Ubuntu 15.04 firefly ttyFIQ0
firefly login: firefly (automatic login)[/mw_shl_code]
ps:附上rk3128-fireprime.dts
[mw_shl_code=applescript,false]/dts-v1/;
#include “rk3128.dtsi”
#include “rk3128-cif-sensor.dtsi”
#include “rk312x-sdk.dtsi”
#include “lcd-HJ070NA.dtsi”
/#include “lcd-b101ew05.dtsi”/
#include <dt-bindings/input/input.h>
compatible = “rockchip,rk3128”;
backlight: backlight {
compatible = “pwm-backlight”;
pwms = <&pwm0 0 25000>;
brightness-levels = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255>;
default-brightness-level = <128>;
enable-gpios = <&gpio0 GPIO_D3 GPIO_ACTIVE_HIGH>;
wireless-wlan {
compatible = “wlan-platdata”;
            /* wifi_chip_type - wifi chip define
            * bcmwifi ==> like ap6xxx, rk90, ...x;
            * rtkwifi ==> like rtl8188xx, rtl8723xx, ...;
            * esp8089 ==> esp8089;
            * other   ==> for other wifi;
            wifi_chip_type = "bcmwifi";
            sdio_vref = <3300>; //1800mv or 3300mv
            //keep_wifi_power_on;
            //power_ctrl_by_pmu;
            power_pmu_regulator = "vccio";
            power_pmu_enable_level = <1>; //1->HIGH, 0->LOW
            //vref_ctrl_enable;
            //vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
            //vref_pmu_regulator = "act_ldo3";
            //vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW
            WIFI,poweren_gpio = <&gpio1 GPIO_B3 GPIO_ACTIVE_HIGH>;
            WIFI,host_wake_irq = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
            //WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>;
            status = "okay";
            wireless-bluetooth {
            compatible = "bluetooth-platdata";
            //wifi-bt-power-toggle;
            uart_rts_gpios = <&gpio0 GPIO_C1 GPIO_ACTIVE_LOW>;
            pinctrl-names = "default","rts_gpio";
            pinctrl-0 = <&uart0_rts>;
            pinctrl-1 = <&uart0_rts_gpio>;
            //BT,power_gpio = <&gpio1 GPIO_B3 GPIO_ACTIVE_HIGH>;
            BT,reset_gpio = <&gpio1 GPIO_A3 GPIO_ACTIVE_HIGH>;
            BT,wake_gpio = <&gpio1 GPIO_B2 GPIO_ACTIVE_HIGH>;
            BT,wake_host_irq = <&gpio1 GPIO_B1 GPIO_ACTIVE_LOW>;
    status = "okay";
   leds {
   compatible = "gpio-leds";
   power {
       label = "firefly:blue:power";
       linux,default-trigger = "ir-power-click";
       default-state = "on";
       gpios = <&gpio1 GPIO_C7 GPIO_ACTIVE_LOW>;
    user {
       label = "firefly:yellow:user";
       linux,default-trigger = "ir-user-click";
       default-state = "off";
	   gpios = <&gpio1 GPIO_C6 GPIO_ACTIVE_LOW>;
       gpios-v01 = <&gpio2 GPIO_A3 GPIO_ACTIVE_LOW>;
    rockchip-spdif-card {
            compatible = "rockchip-spdif-card";
            dais {
                    dai0 {
                            audio-codec = <&codec_hdmi_spdif>;
                            audio-controller = <&spdif>;
usb_control {
	compatible = "rockchip,rk3126-usb-control";
	host_drv_gpio = <&gpio3 GPIO_C4 GPIO_ACTIVE_LOW>;
	otg_drv_gpio = <&gpio0 GPIO_D6 GPIO_ACTIVE_LOW>;
	rockchip,remote_wakeup;
	rockchip,usb_irq_wakeup;
    rockchip_suspend {
           rockchip,ctrbits = <
                   (0
                   |RKPM_CTR_PWR_DMNS
                   |RKPM_CTR_GTCLKS
                   |RKPM_CTR_PLLS
                   //|RKPM_CTR_ARMOFF_LPMD
                   |RKPM_CTR_DDR
                   |RKPM_CTR_IDLESRAM_MD
                   |RKPM_CTR_DDR
                   //|RKPM_CTR_BUS_IDLE
                   //|RKPM_CTR_VOLTS
                   //|RKPM_CTR_VOL_PWM1
                   //|RKPM_CTR_VOL_PWM2
           rockchip,pmic-suspend_gpios = <GPIO3_C1>;
test-power {
status = “okay”;
&i2c0 {
status = “okay”;
rtc@51 {
compatible = “rtc,hym8563”;
reg = <0x51>;
irq_gpio = <&gpio0 GPIO_D4 IRQ_TYPE_EDGE_FALLING>;
ts@41 {
compatible = “tchip,gsl3680”;
reg = <0x41>;
touch-gpio = <&gpio1 GPIO_B4 IRQ_TYPE_EDGE_RISING>;
//reset-gpio = <&gpio8 GPIO_A6 GPIO_ACTIVE_LOW>;
max-x = <1280>;
max-y = <800>;
&fb {
rockchip,disp-mode = <NO_DUAL>;
rockchip,disp-policy = <DISPLAY_POLICY_BOX>;
rockchip,uboot-logo-on = <1>;
&disp_timings {
native-mode = <&timing0>;
&rk_screen {
display-timings = <&disp_timings>;
&lvds {
status = “okay”;
pinctrl-names = "lcdc";
pinctrl-0 = <&lcdc0_lcdc_d>;
&lcdc {
status = “okay”;
rockchip,fb-win-map = <FB0_WIN0_FB1_WIN1_FB2_WIN2>;
&hdmi {
/status = “okay”;/
status = “disabled”;
rockchip,hdmi_audio_source = <1>;
&tve {
/status = “okay”;/
test_mode = <0>;
&uart0 {
status = “okay”;
clock-frequency = “<24000000>”;
dma-names = “!tx”, “!rx”;
pinctrl-0 = <&uart0_xfer &uart0_cts>;
&sdmmc {
status = “okay”;
cd-gpios = <&gpio1 GPIO_C1 GPIO_ACTIVE_HIGH>;/CD GPIO/
&key {
power-key {
gpios = <&gpio3 GPIO_C7 GPIO_ACTIVE_LOW>;
linux,code = <116>;
label = “power”;
gpio-key,wakeup;
recovery-key {
linux,code = <113>;
label = “recovery”;
rockchip,adc_value = <4>;
&dwc_control_usb {
usb_uart {
&codec {
spk_ctl_io = <&gpio3 GPIO_C5 GPIO_ACTIVE_HIGH>;
aux_det_io = <&gpio0 GPIO_D3 GPIO_ACTIVE_HIGH>;
spk-mute-delay = <200>;
hp-mute-delay = <100>;
rk312x_for_mid = <0>;
is_rk3128 = <0>;
spk_volume = <25>;
hp_volume = <25>;
capture_volume = <26>;
gpio_debug = <1>;
codec_hp_det = <0>;
&rk3128_cif_sensor{
status = “okay”;
&i2c2 {
&gmac_clkin {
clock-frequency = <125000000>;
&gmac {
//pmu_regulator = “act_ldo5”;
//pmu_enable_level = <1>; //1->HIGH, 0->LOW
//power-gpio = <&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
reset-gpio = <&gpio2 GPIO_D0 GPIO_ACTIVE_LOW>;
phyirq-gpio = <&gpio0 GPIO_D0 GPIO_ACTIVE_LOW>;
phy-mode = “rgmii”;
clock_in_out = “input”;
tx_delay = <0x30>;
rx_delay = <0x10>;
&pwm1 {
status = “okay”;
&clk_core_dvfs_table {
operating-points = <
/* KHz uV /
216000 925000
408000 925000
600000 950000
696000 975000
816000 1050000
1008000 1175000
1200000 1300000
1296000 1350000
1320000 1375000
virt-temp-limit-1-cpu-busy = <
target-temp limit-freq /
75 1008000
85 1200000
95 1200000
100 1200000
virt-temp-limit-2-cpu-busy = <
75 912000
85 1008000
95 1104000
100 1200000
virt-temp-limit-3-cpu-busy = <
75 816000
85 912000
95 100800
100 110400
virt-temp-limit-4-cpu-busy = <
target-temp limit-freq */
75 816000
85 912000
95 100800
100 110400
temp-limit-enable = <1>;
target-temp = <85>;
status=“okay”;
&clk_gpu_dvfs_table {
/* KHz uV */
200000 950000
300000 975000
400000 1075000
//480000 1175000
status=“okay”;
&clk_ddr_dvfs_table {
/* KHz uV */
200000 1250000
300000 1250000
400000 1250000
operating-points-v01 = <
	/* KHz    uV */
	200000 950000
	300000 950000
	400000 1200000
	533000 1250000
freq-table = <
	/*status		freq(KHz)*/
	SYS_STATUS_NORMAL	500000
	SYS_STATUS_SUSPEND	200000
	SYS_STATUS_VIDEO_1080P  240000
	SYS_STATUS_VIDEO_4K     400000
	SYS_STATUS_PERFORMANCE  528000
	SYS_STATUS_DUALVIEW	400000
	SYS_STATUS_BOOST	324000
	SYS_STATUS_ISP		533000
auto-freq-table = <
	240000
	324000
	396000
	528000
auto-freq=<0>;
status="okay";
&remotectl {
handle_cpu_id = <2>;
ir_key1{
rockchip,usercode = <0xff00>;
rockchip,key_table =
<0xeb KEY_POWER>,
<0xa3 250>,
<0xec KEY_MENU>,
<0xfc KEY_UP>,
<0xfd KEY_DOWN>,
<0xf1 KEY_LEFT>,
<0xe5 KEY_RIGHT>,
<0xf8 KEY_REPLY>,
<0xb7 KEY_HOME>,
<0xfe KEY_BACK>,
<0xa7 KEY_VOLUMEDOWN>,
<0xf4 KEY_VOLUMEUP>;
[/mw_shl_code]
标记下
