Hi, thanks for the detailed info. Before diving deeper into register-level debugging, I’d suggest a quick hardware-vs-software isolation step:
Have you tried flashing the official Firefly POC-RK3568-PC firmware (available at Firefly Community) and tested whether the TX issue still occurs after a power cycle?
If the official firmware works fine, then the problem is likely in your custom OS/U-boot initialization sequence (e.g. PHY reset timing, clock setup, or RGMII delay configuration). If the issue persists with the official firmware too, it’s more likely a hardware-level problem (e.g. PHY power rail stability, reference clock, or PCB routing).
Thanks for the update. To help narrow this down further, could you please share:
U-Boot and kernel boot logs
Please upload the full serial console log from power-on, including the U-Boot stage and the Linux boot log, both for the working case (after soft reset) and the failing case (after hard reset).
Which SDK your build is based on
Which Firefly SDK version or release date are you using? For example, is it from the official Firefly Linux SDK rk356x_linux_release / rk356x_linux_bsp_release, or a custom downstream version?
The U-Boot GitHub link you are using
Could you share the exact U-Boot repository URL and branch/commit you are building from? Firefly’s U-Boot for RK356x is normally managed through the Firefly Linux SDK repo, and the standalone GitHub version may not match the one used in the shipped POC-RK3568-PC image.
With these logs and version details, we can check whether the issue comes from a different U-Boot version, device tree, PHY reset configuration, or loader/rkbin mismatch.
