LlamaPi v0.3.3 Released: Reranking API and HOUMO XH2 Platform Support
Changelog
[0.3.3] - 2026-10-23
Added
  • Added the /v1/rerank reranking endpoint with an API style similar to Jina / Cohere, supporting both plain-text and text/image documents.
  • Added inference platform support:
    • HOUMO XH2 (xh2/m50)
  • Added model support:
    • rknn3/rk1820, rknn3/rk1828: MiniCPM5-2B, Qwen3-VL-Reranker, bge-reranker-v2-m3
    • xh2/m50: Qwen3.5 series, Gemma4 series
  • llamapi ls -o no longer lists models when the number of locally available compute devices is below the model’s minimum requirement.
  • llamapi run now supports image and audio attachment input.
  • Added Tab completion for CLI commands.
Changed
  • Breaking change: the llamapi run prompt is now passed via the -p/--prompt option.
  • Increased the per-request body size limit from 64 MiB to 128 MiB.
Fixed
  • Fixed an issue on rkllm/rk3588 where sampling parameters only took effect for the first request.
  • Fixed incorrect display of model names and parameter sizes (e.g. 4b, 9b) in the CLI.
Security
  • Upgraded transport-layer dependencies with known vulnerabilities.
