反复修改编译刷机尝试,4.4 默认版、4.4pad版,5.1版,打补丁,修改dts,刷 kernel.img 和 resource.img。无一成功!
均不 出现 /dev/ttyS3 !
翻遍了论坛中所有与此问题有关的帖子,虽然版主大人一再确认没有问题,但没有一个能解决问题。帖子中提问的朋友至今也没有一个人是反馈获得成功了的。
因此,强烈请求版主大人发布一个默认打开 UART3 串口的 RK-3288刷机包! 以便我们刷机之后就可以使用 UART3 串口。
我们是购买了 rk-3288 的客户。
firefly-rk3288.dts 全文:
/dts-v1/;
#include “rk3288.dtsi”
//#include “lcd-b101ew05.dtsi”
// TRULY dual lvds TTR9F0090FPC
//#include “lcd-ttr9f0090fpc.dtsi”
// truly Mipi ips5k0350fpc
#include “lcd-ips5k0350fpc-mipi.dtsi”
fiq-debugger {
status = “disabled”;
wireless-wlan {
compatible = "wlan-platdata";
/* wifi_chip_type - wifi chip define
* bcmwifi ==> like ap6xxx, rk90x;
* rtkwifi ==> like rtl8188xx, rtl8723xx;
* esp8089 ==> esp8089;
* other ==> for other wifi;
wifi_chip_type = "bcmwifi";
sdio_vref = <1800>; //1800mv or 3300mv
//keep_wifi_power_on;
//power_ctrl_by_pmu;
power_pmu_regulator = "act_ldo3";
power_pmu_enable_level = <1>; //1->HIGH, 0->LOW
//vref_ctrl_enable;
//vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
vref_pmu_regulator = "act_ldo3";
vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW
WIFI,poweren_gpio = <&gpio4 GPIO_D4 GPIO_ACTIVE_HIGH>;
WIFI,host_wake_irq = <&gpio4 GPIO_D6 GPIO_ACTIVE_HIGH>;
//WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>;
status = "okay";
wireless-bluetooth {
compatible = "bluetooth-platdata";
//wifi-bt-power-toggle;
uart_rts_gpios = <&gpio4 GPIO_C3 GPIO_ACTIVE_LOW>;
pinctrl-names = "default","rts_gpio";
pinctrl-0 = <&uart0_rts>;
pinctrl-1 = <&uart0_rts_gpio>;
BT,power_gpio = <&gpio4 GPIO_D3 GPIO_ACTIVE_HIGH>;
BT,reset_gpio = <&gpio4 GPIO_D5 GPIO_ACTIVE_HIGH>;
BT,wake_gpio = <&gpio4 GPIO_D2 GPIO_ACTIVE_HIGH>;
BT,wake_host_irq = <&gpio4 GPIO_D7 GPIO_ACTIVE_LOW>;
status = "okay";
hallsensor {
compatible = "hall_och165t";
type = <SENSOR_TYPE_HALL>;
irq-gpio = <&gpio0 GPIO_A6 IRQ_TYPE_EDGE_BOTH>;
pwm_regulator {
compatible = "rockchip_pwm_regulator";
pwms = <&pwm1 0 2000>;
rockchip,pwm_id= <1>;
rockchip,pwm_voltage_map= <925000 950000 975000 1000000 1025000 1050000 1075000 1100000 1125000 1150000 1175000 1200000 1225000 1250000 1275000 1300000 1325000 1350000 1375000 1400000>;
rockchip,pwm_voltage= <1000000>;
rockchip,pwm_min_voltage= <925000>;
rockchip,pwm_max_voltage= <1400000>;
rockchip,pwm_suspend_voltage= <950000>;
rockchip,pwm_coefficient= <475>;
regulators {
#address-cells = <1>;
#size-cells = <0>;
pwm_reg0: regulator@0 {
regulator-compatible = "pwm_dcdc1";
regulator-name= "vdd_logic";
regulator-min-microvolt = <925000>;
regulator-max-microvolt = <1400000>;
regulator-always-on;
regulator-boot-on;
codec_hdmi_i2s: codec-hdmi-i2s {
compatible = "hdmi-i2s";
codec_hdmi_spdif: codec-hdmi-spdif {
compatible = "hdmi-spdif";
rockchip-hdmi-i2s {
compatible = "rockchip-hdmi-i2s";
dais {
dai0 {
audio-codec = <&codec_hdmi_i2s>;
i2s-controller = <&i2s>;
format = "i2s";
//continuous-clock;
//bitclock-inversion;
//frame-inversion;
//bitclock-master;
//frame-master;
rockchip-hdmi-spdif {
compatible = "rockchip-hdmi-spdif";
dais {
dai0 {
audio-codec = <&codec_hdmi_spdif>;
i2s-controller = <&spdif>;
rockchip-rt5631 {
compatible = "rockchip-rt5631";
dais {
dai0 {
audio-codec = <&rt5631>;
format = "i2s";
//continuous-clock;
//frame-inversion;
//bitclock-master;
//frame-master;
rockchip-es8323 {
compatible = "rockchip-es8323";
dais {
dai0 {
audio-codec = <&es8323>;
format = "i2s";
//continuous-clock;
//frame-inversion;
//bitclock-master;
//frame-master;
rockchip-rt3224 {
compatible = "rockchip-rt3261";
dais {
dai0 {
audio-codec = <&rt3261>;
format = "i2s";
//continuous-clock;
//frame-inversion;
//bitclock-master;
//frame-master;
dai1 {
format = "dsp_a";
//continuous-clock;
bitclock-inversion;
//frame-inversion;
//bitclock-master;
//frame-master;
usb_control {
compatible = "rockchip,rk3288-usb-control";
host_drv_gpio = <&gpio0 GPIO_B6 GPIO_ACTIVE_LOW>;
otg_drv_gpio = <&gpio0 GPIO_B4 GPIO_ACTIVE_LOW>;
rockchip,remote_wakeup;
rockchip,usb_irq_wakeup;
leds {
compatible = "gpio-leds";
power {
label = "firefly:blue:power";
linux,default-trigger = "ir-power-click";
default-state = "on";
gpios = <&gpio8 GPIO_A1 GPIO_ACTIVE_LOW>;
user{
label = "firefly:yellow:user";
linux,default-trigger = "ir-user-click";
default-state = "off";
gpios = <&gpio8 GPIO_A2 GPIO_ACTIVE_LOW>;
&gmac {
// power_ctl_by = “gpio”; //“gpio” “pmu”
power-gpio = <&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
// power-pmu = “act_ldo”
reset-gpio = <&gpio4 GPIO_B0 GPIO_ACTIVE_LOW>;
phy-mode = “rgmii”;
clock_in_out = “input”;
tx_delay = <0x30>;
rx_delay = <0x20>;
status = “okay”; //if want to use gmac, please set “okay”
&pinctrl {
//used for init some gpio
gpio0_gpio {
gpio0_c2: gpio0-c2 {
rockchip,pins = <GPIO0_C2>;
rockchip,pull = <VALUE_PULL_DOWN>;
//to add
gpio7_gpio {
gpio7_b7: gpio7-b7 {
rockchip,pins = <GPIO7_B7>;
rockchip,pull = <VALUE_PULL_UP>;
//to add
//could add other pinctrl definition such as gpio
// gmac drive strength
gpio4_gmac {
mac_clk: mac-clk {
rockchip,drive = <VALUE_DRV_12MA>;
mac_txpins: mac-txpins {
mac_rxpins: mac-rxpins {
mac_crs: mac-crs {
mac_mdpins: mac-mdpins {
&nandc0 {
status = “disabled”; // used nand set “disabled” ,used emmc set “okay”
&nandc1 {
&nandc0reg {
status = “okay”; // used nand set “disabled” ,used emmc set “okay”
&emmc {
clock-frequency = <100000000>;
clock-freq-min-max = <400000 100000000>;
supports-highspeed;
supports-emmc;
bootpart-no-access;
//supports-tSD;
//supports-DDR_MODE; //you should set the two value in your project. only close in RK3288-SDK board.
//caps2-mmc-hs200;
ignore-pm-notify;
keep-power-in-suspend;
//poll-hw-reset
status = "okay";
&sdmmc {
clock-frequency = <50000000>;
clock-freq-min-max = <400000 50000000>;
supports-highspeed;
supports-sd;
broken-cd;
card-detect-delay = <200>;
ignore-pm-notify;
vmmc-supply = <&rk808_ldo5_reg>;
status = "okay";
&sdio {
clock-freq-min-max = <200000 50000000>;
supports-highspeed;
supports-sdio;
ignore-pm-notify;
//cap-sdio-irq;
status = “okay”;
&spi0 {
max-freq = <48000000>;
spi_test@00 {
compatible = “rockchip,spi_test_bus0_cs0”;
reg = <0>;
spi-max-frequency = <24000000>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
spi_test@01 {
compatible = "rockchip,spi_test_bus0_cs1";
reg = <1>;
spi-cpha;
spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
&spi1 {
spi_test@10 {
compatible = “rockchip,spi_test_bus1_cs0”;
reg = <0>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
&spi2 {
spi_test@20 {
compatible = “rockchip,spi_test_bus2_cs0”;
reg = <0>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
spi_test@21 {
compatible = "rockchip,spi_test_bus2_cs1";
reg = <1>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
&uart_bt {
status = “okay”;
dma-names = “!tx”, “!rx”;
pinctrl-0 = <&uart0_xfer &uart0_cts>;
&uart_dbg {
status = “okay”;
&uart_bb {
status = “okay”;
pinctrl-0 = <&uart1_xfer &uart1_cts>;
&uart_gps {
status = “okay”;
current-speed = <57600>;
pinctrl-0 = <&uart3_xfer>;
&i2c0 {
status = “okay”;
rk808: rk808@1b {
reg = <0x1b>;
status = “okay”;
rk818: rk818@1c {
reg = <0x1c>;
status = “okay”;
syr827: syr827@40 {
compatible = “silergy,syr82x”;
reg = <0x40>;
status = “okay”;
regulators {
#size-cells = <0>;
syr827_dc1: regulator@0 {
reg = <0>;
regulator-compatible = “syr82x_dcdc1”;
regulator-name = “vdd_arm”;
regulator-min-microvolt = <712500>;
regulator-max-microvolt = <1500000>;
regulator-boot-on;
regulator-initial-mode = <0x2>;
regulator-initial-state = <3>;
regulator-state-mem {
regulator-state-mode = <0x2>;
regulator-state-enabled;
regulator-state-uv = <900000>;
syr828: syr828@41 {
reg = <0x41>;
status = “okay”;
regulators {
#size-cells = <0>;
syr828_dc1: regulator@0 {
reg = <0>;
regulator-name = “vdd_gpu”;
regulator-boot-on;
regulator-state-disabled;
act8846: act8846@5a {
reg = <0x5a>;
status = “okay”;
ricoh619: ricoh619@32 {
reg = <0x32>;
status = "okay";
bq24296: bq24296@6b {
compatible = "ti,bq24296";
reg = <0x6b>;
gpios = <&gpio0 GPIO_A7 GPIO_ACTIVE_HIGH>,<&gpio0 GPIO_B0 GPIO_ACTIVE_HIGH>;
bq24296,chg_current = <1000 2000 3000>;
status = "okay";
bq27320: bq27320@55 {
compatible = "ti,bq27320";
reg = <0x55>;
/* gpios = <&gpio0 GPIO_A7 GPIO_ACTIVE_HIGH>; */
status = "okay";
CW2015@62 {
compatible = "cw201x";
reg = <0x62>;
dc_det_gpio = <&gpio0 GPIO_B0 GPIO_ACTIVE_LOW>;
bat_low_gpio = <&gpio0 GPIO_A7 GPIO_ACTIVE_LOW>;
chg_ok_gpio = <&gpio0 GPIO_B1 GPIO_ACTIVE_HIGH>;
bat_config_info = <0x15 0x42 0x60 0x59 0x52 0x58 0x4D 0x48 0x48 0x44 0x44 0x46 0x49 0x48 0x32
0x24 0x20 0x17 0x13 0x0F 0x19 0x3E 0x51 0x45 0x08 0x76 0x0B 0x85 0x0E 0x1C 0x2E 0x3E 0x4D 0x52 0x52
0x57 0x3D 0x1B 0x6A 0x2D 0x25 0x43 0x52 0x87 0x8F 0x91 0x94 0x52 0x82 0x8C 0x92 0x96 0xFF 0x7B 0xBB
0xCB 0x2F 0x7D 0x72 0xA5 0xB5 0xC1 0x46 0xAE>;
is_dc_charge = <1>;
is_usb_charge = <0>;
rtc@51 {
compatible = "rtc,hym8563";
reg = <0x51>;
irq_gpio = <&gpio7 GPIO_A4 IRQ_TYPE_EDGE_FALLING>;
&i2c1 {
status = “okay”;
rtc@51 {
compatible = “nxp,pcf8563”;
reg = <0x51>;
ts@41 {
compatible = "tchip,gsl3680";
reg = <0x41>;
touch-gpio = <&gpio8 GPIO_A7 IRQ_TYPE_EDGE_RISING>;
//reset-gpio = <&gpio8 GPIO_A6 GPIO_ACTIVE_LOW>;
max-x = <1280>;
max-y = <800>;
synaptics_ts@20 {
compatible = "synaptics,synaptics_dsx";
reg = <0x20>;
touch-gpio = <&gpio8 GPIO_A7 IRQ_TYPE_EDGE_FALLING>;
reset-gpio = <&gpio5 GPIO_B1 GPIO_ACTIVE_LOW>;
//power-gpio = <&gpio0 GPIO_C5 GPIO_ACTIVE_LOW>;
max-x = <1080>;
max-y = <1920>;
flip-x = <0>;
flip-y = <0>;
sensor@1d {
compatible = "gs_mma8452";
reg = <0x1d>;
type = <SENSOR_TYPE_ACCEL>;
irq-gpio = <&gpio8 GPIO_A0 IRQ_TYPE_EDGE_FALLING>;
irq_enable = <1>;
poll_delay_ms = <30>;
layout = <1>;
sensor@19 {
compatible = "gs_lis3dh";
reg = <0x19>;
irq-gpio = <&gpio0 GPIO_A0 IRQ_TYPE_LEVEL_LOW>;
irq_enable = <1>;
layout = <1>;
sensor@0d {
compatible = "ak8963";
reg = <0x0d>;
type = <SENSOR_TYPE_COMPASS>;
irq-gpio = <&gpio8 GPIO_A2 IRQ_TYPE_EDGE_RISING>;
irq_enable = <1>;
layout = <1>;
sensor@6b {
compatible = "l3g20d_gyro";
reg = <0x6b>;
type = <SENSOR_TYPE_GYROSCOPE>;
irq-gpio = <&gpio8 GPIO_A3 IRQ_TYPE_LEVEL_LOW>;
irq_enable = <1>;
layout = <1>;
sensor@10 {
compatible = "ls_cm3218";
reg = <0x10>;
type = <SENSOR_TYPE_LIGHT>;
irq-gpio = <&gpio8 GPIO_A3 IRQ_TYPE_EDGE_FALLING>;
irq_enable = <1>;
layout = <1>;
nfc-bcm2079x@76 {
compatible = "nfc-bcm2079x.ap6441";
reg = <0x76>;
en_gpio = <&gpio4 GPIO_D3 GPIO_ACTIVE_HIGH>;
wake_gpio = <&gpio5 GPIO_C0 GPIO_ACTIVE_HIGH>;
irq_gpio = <&gpio5 GPIO_B7 IRQ_TYPE_EDGE_RISING>;
status = "disabled";
nfc-bcm2079x@77 {
compatible = "nfc-bcm2079x.ap6493";
reg = <0x77>;
&i2c2 {
status = “okay”;
rt5631: rt5631@1a {
compatible = “rt5631”;
reg = <0x1a>;
es8323: es8323@10 {
compatible = “es8323”;
reg = <0x10>;
spk-con-gpio = <&gpio0 GPIO_B2 GPIO_ACTIVE_HIGH>;
hp-det-gpio = <&gpio7 GPIO_B7 GPIO_ACTIVE_HIGH>;
hp-mic-only = <1>;
rt3261: rt3261@1c {
compatible = “rt3261”;
reg = <0x1c>;
// codec-en-gpio = <0>;//sdk default high level
spk-num= <2>;
modem-input-mode = <1>;
lout-to-modem_mode = <1>;
spk-amplify = <2>;
playback-if1-data_control = <0>;
playback-if2-data_control = <0>;
rt5616: rt5616@1b {
compatible = “rt5616”;
reg = <0x1b>;
&i2c3 {
status = “okay”;
&i2c4 {
status = “okay”;
ts@55 {
compatible = “goodix,gt8xx”;
reg = <0x55>;
touch-gpio = <&gpio7 GPIO_A6 IRQ_TYPE_LEVEL_LOW>;
reset-gpio = <&gpio7 GPIO_A5 GPIO_ACTIVE_LOW>;
max-x = <1280>;
max-y = <800>;
ts@01 {
compatible = "ct,vtl_ts";
reg = <0x01>;
screen_max_x = <2048>;
screen_max_y = <1536>;
irq_gpio_number = <&gpio7 GPIO_A6 IRQ_TYPE_LEVEL_LOW>;
rst_gpio_number = <&gpio7 GPIO_A5 GPIO_ACTIVE_HIGH>;
ac@68 {
compatible = "mp6050_ac";
reg = <0x68>;
irq-gpio = <&gpio5 GPIO_B4 IRQ_TYPE_LEVEL_LOW>;
irq_enable = <0>; // disable irq
poll_delay_ms = <20>;
layout = <8>;
gy@68 {
compatible = "mp6050_gy";
reg = <0x68>;
layout = <8>;
&i2c5 {
&fb {
rockchip,disp-mode = ;
rockchip,uboot-logo-on = <0>;
&rk_screen {
display-timings = <&disp_timings>;
/lcdc0 as PRMRY(LCD),lcdc1 as EXTEND(HDMI)/
&lcdc0 {
status = “okay”;
rockchip,mirror = <NO_MIRROR>;
rockchip,cabc_mode = <0>;
power_ctr: power_ctr {
rockchip,debug = <0>;
/lcd_en:lcd_en {
rockchip,power_type = ;
gpios = <&gpio7 GPIO_A3 GPIO_ACTIVE_HIGH>;
rockchip,delay = <10>;
/*lcd_cs:lcd_cs {
rockchip,power_type = <GPIO>;
gpios = <&gpio7 GPIO_A4 GPIO_ACTIVE_HIGH>;
lcd_rst:lcd_rst {
gpios = <&gpio0 GPIO_B5 GPIO_ACTIVE_LOW>;
&lcdc1 {
status = “okay”;
rockchip,mirror = <ROTATE_270>;
&hdmi {
status = “okay”;
rockchips,hdmi_audio_source = <0>;
&adc {
status = “okay”;
rockchip_headset {
compatible = "rockchip_headset";
headset_gpio = <&gpio0 GPIO_C2 GPIO_ACTIVE_LOW>;
pinctrl-names = "default";
pinctrl-0 = <&gpio0_c2>;
io-channels = <&adc 2>;
hook_gpio = ;
hook_down_type = ; //interrupt hook key down status
key {
compatible = "rockchip,key";
io-channels = <&adc 1>;
vol-up-key {
linux,code = <115>;
label = "volume up";
rockchip,adc_value = <1>;
vol-down-key {
linux,code = <114>;
label = "volume down";
rockchip,adc_value = <170>;
power-key {
gpios = <&gpio0 GPIO_A5 GPIO_ACTIVE_LOW>;
linux,code = <116>;
label = "power";
gpio-key,wakeup;
menu-key {
linux,code = <59>;
label = "menu";
rockchip,adc_value = <355>;
home-key {
linux,code = <102>;
label = "home";
rockchip,adc_value = <746>;
back-key {
linux,code = <158>;
label = "back";
rockchip,adc_value = <560>;
camera-key {
linux,code = <212>;
label = "camera";
rockchip,adc_value = <450>;
&pwm0 {
interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
status = “okay”;
&pwm1 {
status = “okay”;
&clk_core_dvfs_table {
operating-points = <
/* KHz uV */
126000 900000
216000 900000
312000 900000
408000 900000
600000 900000
696000 950000
816000 1000000
1008000 1050000
1200000 1100000
1416000 1200000
1512000 1300000
1608000 1350000
1704000 1350000
1800000 1350000
status=“okay”;
&clk_gpu_dvfs_table {
/* KHz uV */
100000 850000
200000 900000
300000 950000
420000 1050000
500000 1150000
status=“okay”;
&clk_ddr_dvfs_table {
/* KHz uV */
200000 950000
300000 950000
400000 1000000
533000 1050000
freq-table = <
/*status freq(KHz)*/
SYS_STATUS_NORMAL 400000
SYS_STATUS_SUSPEND 200000
SYS_STATUS_VIDEO_1080P 240000
SYS_STATUS_VIDEO_4K 400000
SYS_STATUS_PERFORMANCE 528000
SYS_STATUS_DUALVIEW 400000
SYS_STATUS_BOOST 324000
SYS_STATUS_ISP 533000
auto-freq-table = <
240000
324000
396000
528000
auto-freq=<0>;
status="okay";
/include/ “act8846.dtsi”
&act8846 {
gpios =<&gpio7 GPIO_B6 GPIO_ACTIVE_LOW>,<&gpio0 GPIO_A1 GPIO_ACTIVE_HIGH>,<&gpio7 GPIO_B2 GPIO_ACTIVE_HIGH>;
usb_hub_reset_gpio =<&gpio8 GPIO_A3 GPIO_ACTIVE_LOW>;
act8846,system-power-controller;
regulators {
dcdc1_reg: regulator@0{
regulator-name= "act_dcdc1";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
regulator-boot-on;
dcdc2_reg: regulator@1 {
regulator-name= "vccio";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-state-uv = <3300000>;
dcdc3_reg: regulator@2 {
regulator-min-microvolt = <700000>;
regulator-state-uv = <1200000>;
dcdc4_reg: regulator@3 {
regulator-name= "act_dcdc4";
regulator-min-microvolt = <2000000>;
regulator-max-microvolt = <2000000>;
regulator-state-uv = <2000000>;
ldo1_reg: regulator@4 {
regulator-name= "vccio_sd";
regulator-min-microvolt = <1800000>;
ldo2_reg: regulator@5 {
regulator-name= "act_ldo2";
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
ldo3_reg: regulator@6 {
regulator-name= "act_ldo3";
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
ldo4_reg:regulator@7 {
regulator-name= "act_ldo4";
ldo5_reg: regulator@8 {
regulator-name= "act_ldo5";
ldo6_reg: regulator@9 {
regulator-name= "act_ldo6";
ldo7_reg: regulator@10 {
regulator-name= "vcc_18";
regulator-max-microvolt = <1800000>;
ldo8_reg: regulator@11 {
regulator-name= "act_ldo8";
/include/ “rk808.dtsi”
&rk808 {
gpios =<&gpio0 GPIO_A4 GPIO_ACTIVE_HIGH>,<&gpio0 GPIO_B3 GPIO_ACTIVE_LOW>;
rk808,system-power-controller;
regulators {
rk808_dcdc1_reg: regulator@0{
regulator-name= "vdd_arm";
regulator-boot-on;
rk808_dcdc2_reg: regulator@1 {
regulator-name= "vdd_gpu";
//regulator-always-on;
//regulator-boot-on;
rk808_dcdc3_reg: regulator@2 {
regulator-name= "rk_dcdc3";
regulator-boot-on;
rk808_dcdc4_reg: regulator@3 {
regulator-boot-on;
rk808_ldo1_reg: regulator@4 {
regulator-name= "rk_ldo1";
regulator-boot-on;
rk808_ldo2_reg: regulator@5 {
regulator-name= "rk_ldo2";
regulator-boot-on;
rk808_ldo3_reg: regulator@6 {
regulator-name= "rk_ldo3";
regulator-boot-on;
rk808_ldo4_reg:regulator@7 {
regulator-name= "rk_ldo4";
regulator-boot-on;
rk808_ldo5_reg: regulator@8 {
regulator-name= "vcc_sd";
regulator-boot-on;
rk808_ldo6_reg: regulator@9 {
regulator-name= "rk_ldo6";
regulator-boot-on;
rk808_ldo7_reg: regulator@10 {
regulator-name= "rk_ldo7";
regulator-boot-on;
rk808_ldo8_reg: regulator@11 {
regulator-name= "rk_ldo8";
regulator-boot-on;
rk808_ldo9_reg: regulator@12 {
regulator-name= "rk_ldo9";
regulator-boot-on;
rk808_ldo10_reg: regulator@13 {
regulator-name= "rk_ldo10";
regulator-boot-on;
/include/ “ricoh619.dtsi”
&ricoh619 {
gpios =<&gpio0 GPIO_A4 GPIO_ACTIVE_HIGH>,<&gpio0 GPIO_B3 GPIO_ACTIVE_LOW>,<&gpio0 GPIO_B0 GPIO_ACTIVE_HIGH>;
ricoh619,system-power-controller;
regulators {
ricoh619_dcdc1_reg: regulator@0 {
regulator-name = "vccio";
regulator-state-uv = <2800000>;
ricoh619_dcdc2_reg: regulator@1 {
regulator-name = "ricoh619_dcdc2";
ricoh619_dcdc3_reg: regulator@2 {
regulator-name = "vcc_lcd";
ricoh619_dcdc4_reg: regulator@3 {
regulator-name = "vdd_logic";
ricoh619_dcdc5_reg: regulator@4 {
regulator-name = "vcc_ddr";
ricoh619_ldo1_reg: regulator@5 {
regulator-name = "vccio_pmu";
ricoh619_ldo2_reg: regulator@6 {
regulator-name = "ricoh619_ldo2";
ricoh619_ldo3_reg: regulator@7 {
regulator-name = "ricoh619_ldo3";
ricoh619_ldo4_reg: regulator@8 {
regulator-name = "vcc_sd";
ricoh619_ldo5_reg: regulator@9 {
regulator-name = "vcc_wl";
regulator-state-uv = <1800000>;
ricoh619_ldo6_reg: regulator@10 {
regulator-name = "ricoh619_ldo6";
ricoh619_ldo7_reg: regulator@11 {
regulator-name = "ricoh619_ldo7";
regulator-state-uv = <1000000>;
ricoh619_ldo8_reg: regulator@12 {
regulator-name = "ricoh619_ldo8";
ricoh619_ldo9_reg: regulator@13 {
regulator-name = "ricoh619_ldo9";
ricoh619_ldo10_reg: regulator@14 {
regulator-name = "vcc_18";
ricoh619_ldortc1_reg: regulator@15 {
regulator-name = "ricoh619_ldortc1";
regulator-min-microvolt = < 3300000>;
ricoh619_ldortc2_reg: regulator@16 {
regulator-name = "ricoh619_ldortc2";
/include/ “rk818.dtsi”
&rk818 {
rk818,system-power-controller;
regulators {
rk818_dcdc1_reg: regulator@0{
rk818_dcdc2_reg: regulator@1 {
regulator-name= "rk818_dcdc2";
rk818_dcdc3_reg: regulator@2 {
regulator-name= "rk818_dcdc3";
rk818_dcdc4_reg: regulator@3 {
rk818_ldo1_reg: regulator@4 {
regulator-name= "rk818_ldo1";
rk818_ldo2_reg: regulator@5 {
regulator-name= "rk818_ldo2";
rk818_ldo3_reg: regulator@6 {
regulator-name= "rk818_ldo3";
rk818_ldo4_reg:regulator@7 {
regulator-name= "rk818_ldo4";
rk818_ldo5_reg: regulator@8 {
regulator-name= "rk818_ldo5";
rk818_ldo6_reg: regulator@9 {
regulator-name= "rk818_ldo6";
rk818_ldo7_reg: regulator@10 {
regulator-name= "rk818_ldo7";
rk818_ldo8_reg: regulator@11 {
regulator-name= "rk818_ldo8";
rk818_ldo9_reg: regulator@12 {
rk818_ldo10_reg: regulator@13 {
regulator-name= "rk818_ldo10";
battery {
ocv_table = <3350 3677 3693 3719 3752 3770 3775 3778 3785 3796 3812 3839 3881 3907 3933 3958 3978 4033 4087 4123 4174>;
design_capacity = <2100>;
design_qmax = <2200>;
max_overcharge = <100>;
max_charge_currentma = <1500>;
max_charge_voltagemv = <4260>;
max_bat_voltagemv = <4200>;
&lcdc_vdd_domain {
regulator-name = “vcc30_lcd”;
&dpio_vdd_domain{
regulator-name = “vcc18_cif”;
&flash0_vdd_domain{
regulator-name = “vcc_flash”;
&flash1_vdd_domain{
&apio3_vdd_domain{
regulator-name = “vccio_wl”;
&apio5_vdd_domain{
regulator-name = “vccio”;
&apio4_vdd_domain{
&apio1_vdd_domain{
&apio2_vdd_domain{
&sdmmc0_vdd_domain{
regulator-name = “vcc_sd”;
&ion_cma {
reg = <0x40000000 0x28000000>; /* 640MB */
&dwc_control_usb {
usb_uart {
