miniroot 定制根文件系统
版主,您好
首先我的板子刷了一份能正常启动的固件Ubuntu 14.04 201512031755 版,能正常启动到 Lubuntu 的桌面,然后按照 http://wiki.t-firefly.com/index. … 88/Build_Ubuntu_rfs 所述一步步操作下去,没能正确启动到 miniroot,在 starting kernel 后然后出来一大堆的东西,然后就无限重启下去
我用的是 Android 开发工具 V2.35,勾选了Boot项(地址为 0x00016000),是不是刷入的偏移地址有问题?
不甚感激各位前辈们!!!
现在刷的是正常能用的双系统,linux-boot-miniroot.img 刷到 recovery 分区, misc.img 刷到 misc 分区,也是无限重启下去
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-02 (Nov 13 2015 - 10:22:31)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
Enter power_led_init
#Boot ver: 2015-11-13#2.17
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x02000000 (0x0069b560)
ramdisk @ 0x04bf0000 (0x001a958c)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480b000, end 048261a4 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-g5 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchi8 [ 0.000000] hdmi init vic is -1 [ 0.000000] rockchip_ion_reserve [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1e65000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa8 [ 0.000000] Kernel command line: console=tty0 console=ttyFIQ0 earlyprintk an1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memos [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 2042764k/2042764k available, 54388k reserved, 1318912K hm [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b99378 (11845 kB) [ 0.000000] .init : 0xc0b9a000 - 0xc0bf46c0 ( 362 kB) [ 0.000000] .data : 0xc0bf6000 - 0xc0d0beb8 (1112 kB) [ 0.000000] .bss : 0xc0d0beb8 - 0xc0e2d4fc (1158 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 32 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 2 [ 0.000000] channel:0, lkg:15 [ 0.000000] target-temp:95 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:0, lkg:15 [ 0.000000] target-temp:95 [ 0.000000] channel:1, lkg:14 [ 0.000000] target-temp:95 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps eves [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty0] enabled [ 0.537338] Calibrating delay loop (skipped), value calculated using timer f) [ 0.537445] pid_max: default: 32768 minimum: 301 [ 0.537807] Security Framework initialized [ 0.537875] SELinux: Initializing. [ 0.538132] Mount-cache hash table entries: 512 [ 0.540206] Initializing cgroup subsys debug [ 0.540281] Initializing cgroup subsys memory [ 0.540394] Initializing cgroup subsys freezer [ 0.540516] CPU: Testing write buffer coherency: ok [ 0.541392] /cpus/cpu@0 missing clock-frequency property [ 0.541473] /cpus/cpu@1 missing clock-frequency property [ 0.541536] /cpus/cpu@2 missing clock-frequency property [ 0.541596] /cpus/cpu@3 missing clock-frequency property [ 0.541752] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.541899] Setting up static identity map for 0xc08483a8 - 0xc0848400 [ 0.545721] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, s) [ 0.621103] CPU1: Booted secondary processor [ 0.621194] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.640846] CPU2: Booted secondary processor [ 0.640928] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.660627] CPU3: Booted secondary processor [ 0.660709] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.661084] Brought up 4 CPUs [ 0.661373] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.661436] CPU: All CPU(s) started in SVC mode. [ 0.663687] devtmpfs: initialized [ 0.682182] pinctrl core: initialized pinctrl subsystem [ 0.682967] regulator-dummy: no parameters [ 0.684624] NET: Registered protocol family 16 [ 0.690547] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.691551] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e08a8) [ 0.692104] Registered FIQ tty driver [ 0.695809] console [ttyFIQ0] enabled [ 0.696415] Registered fiq debugger ttyFIQ0 [ 0.698930] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.699060] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff7f [ 0.699247] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xfff [ 0.699390] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff7b [ 0.699704] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 staf [ 0.699994] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 staf [ 0.700284] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 staf [ 0.700574] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 staf [ 0.700861] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 staf [ 0.701147] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 staf [ 0.701433] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 staf [ 0.701722] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 staf [ 0.702029] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 stf [ 0.702321] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.702412] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.702503] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.702593] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.704405] rockchip_interrupts_register:bank_num=7 [ 0.711315] of_get_gpio_init_config:gpio[0] = 256, value = 0 [ 0.711440] of_get_gpio_init_config:gpio[1] = 233, value = 0 [ 0.711554] of_get_gpio_init_config:gpio[2] = 136, value = 0 [ 0.711797] rockchip_pinctrl_probe:init ok [ 0.732426] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.732694] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM fro. [ 0.732808] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.733410] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.733646] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM fro. [ 0.733756] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.734342] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.734578] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM fr. [ 0.734688] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.735271] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.735525] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM fr. [ 0.735636] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.736257] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.736507] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM fr. [ 0.736617] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.737207] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.737455] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM fro. [ 0.737565] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.738213] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.738462] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM fro. [ 0.738570] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.744505] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint. [ 0.744615] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.745275] DDR DEBUG: version 1.00 20150126 [ 0.745387] DDR DEBUG: Channel a: [ 0.745449] DDR DEBUG: DDR3 Device [ 0.745521] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total CapabiliB [ 0.745609] DDR DEBUG: Channel b: [ 0.745663] DDR DEBUG: DDR3 Device [ 0.745729] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total CapabiliB [ 0.745818] DDR DEBUG: addr=0xd15000 [ 0.745879] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.745949] DDR DEBUG: socAddr[0]=0xd15000, socAddr[1]=0xd15100 [ 0.746022] DDR DEBUG: chAddr[0]=0xd15000, chAddr[1]=0xd15000 [ 0.746098] DDR DEBUG: dtar[0]=0x501a2000, dtar[1]=0x501a2000 [ 0.746295] DDR DEBUG: init success!!! freq=200MHz [ 0.746359] DDR DEBUG: Channel a: [ 0.746430] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 [ 0.746541] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 [ 0.746651] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 [ 0.746762] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 [ 0.746868] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.746946] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.747014] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.747077] DDR DEBUG: Channel b: [ 0.747145] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 [ 0.747254] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 [ 0.747364] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 [ 0.747472] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 [ 0.747576] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.747653] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.747721] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.833444] bio: create slab at 0 [ 0.835122] Rockchip hdmi driver version 2.0 . [ 0.839188] SCSI subsystem initialized [ 0.839759] usbcore: registered new interface driver usbfs [ 0.839959] usbcore: registered new interface driver hub [ 0.840305] usbcore: registered new device driver usb [ 0.845305] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.849955] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.851531] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.853078] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.853958] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.856897] media: Linux media interface: v0.10 [ 0.857080] Linux video capture interface: v2.00 [ 0.857575] pps_core: LinuxPPS API ver. 1 registered [ 0.857655] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom> [ 0.857795] PTP clock support registered [ 0.858034] i2c-core: driver [bq24296] using legacy suspend method [ 0.858114] i2c-core: driver [bq24296] using legacy resume method [ 0.860342] Rockchip ion module is successfully loaded (v1.1) [ 0.860915] Advanced Linux Sound Architecture Driver Initialized. [ 0.862194] Bluetooth: Core ver 2.16 [ 0.862353] NET: Registered protocol family 31 [ 0.862426] Bluetooth: HCI device and connection manager initialized [ 0.862519] Bluetooth: HCI socket layer initialized [ 0.862601] Bluetooth: L2CAP socket layer initialized [ 0.862726] Bluetooth: SCO socket layer initialized [ 0.863493] cfg80211: Calling CRDA to update world regulatory domain [ 0.866032] act8846_i2c_probe,line=880 [ 0.867645] act8846_parse_dt,line=744 [ 0.869125] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.869229] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.871831] act_dcdc1: 1200 mV [ 0.875682] vccio: 3300 mV [ 0.878496] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 0.882393] act_dcdc4: 2000 mV [ 0.884328] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.887382] act_ldo2: 1050 mV [ 0.890391] act_ldo3: 2800 mV [ 0.893380] act_ldo4: 3300 mV [ 0.896376] act_ldo5: 3300 mV [ 0.899454] act_ldo6: 1100 mV [ 0.902439] vcc_18: 1800 mV [ 0.905418] act_ldo8: 1850 mV [ 0.912157] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.918732] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.920365] rk808_i2c_probe,line=1355 [ 0.922063] The device is not rk808 -11 [ 0.922355] rk808: probe of 0-001b failed with error -11 [ 0.922661] i2c-core: driver [rk818] using legacy suspend method [ 0.922741] i2c-core: driver [rk818] using legacy resume method [ 0.926733] Switching to clocksource arch_sys_counter [ 0.939456] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.992556] rk-fb rockchip-fb: rk fb ion client create success! [ 0.992670] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.993805] rk-screen rk_screen.9: rockchip screen probe success [ 0.994672] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.995869] rk32-edp ff970000.edp: screen is not edp! [ 0.995977] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.997185] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 0.997966] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.999105] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.999718] graphics fb2: rockchip framebuffer registerd:fb2 [ 1.000329] graphics fb3: rockchip framebuffer registerd:fb3 [ 1.002351] rk3288 set GPLL BW 20 for HDMI! [ 1.002818] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 1.002929] rk3288-lcdc lcdc0: wakeup from standby! [ 1.003017] rk-fb rockchip-fb: failed to ion_alloc:-19 [ 1.003148] Unable to handle kernel NULL pointer dereference at virtual addr0 [ 2.039342] pgd = c0004000 [ 2.042053] [00000000] *pgd=00000000 [ 2.045643] Internal error: Oops: 805 [#1] PREEMPT SMP ARM [ 2.051087] Modules linked in: [ 2.054164] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #72 [ 2.060129] task: ee098000 ti: ee07a000 task.ti: ee07a000 [ 2.065506] PC is at cfb_imageblit+0x3ac/0x434 [ 2.069937] LR is at fb_do_show_logo+0x34/0x168 [ 2.074452] pc : [] lr : [] psr: 60000113 [ 2.074452] sp : ee07bd68 ip : 00000000 fp : 00000010 [ 2.085827] r10: 00000050 r9 : 00000000 r8 : ee3d6000 [ 2.091015] r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000010 [ 2.097489] r3 : 00000010 r2 : 00000000 r1 : 00000001 r0 : c0bea7c5 [ 2.103967] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kerl [ 2.111222] Control: 10c5387d Table: 0000406a DAC: 00000015 [ 2.116921] [ 2.116921] PC: 0xc02a5290: [ 2.121181] 5290 e1a07005 e598b054 e594001c e26b3020 e58d9010 e58d300c e5944 [ 2.129447] 52b0 e3560000 e594c008 e1a09006 e58d4018 15952000 13e01000 e58d6 [ 2.137708] 52d0 11c22611 01a03006 01a02006 e1a0c005 e3a01000 ea000010 e5982 [ 2.145967] 52f0 13560004 e7d06001 059d4010 07946106 e59d400c e1530004 e1823 [ 2.154225] 5310 e48c2004 12632020 11a02236 03a02000 e083300b e2811001 e2034 [ 2.162483] 5330 e1510004 1affffeb e3530000 e0800001 e1a06009 e59d4018 159c0 [ 2.170742] 5350 e24aa001 10013319 11833002 158c3000 e59dc008 e5983108 e35c3 [ 2.178998] 5370 159d2008 10877103 13c75003 10866002 1206601f e35a0000 1affc [ 2.187261] [ 2.187261] LR: 0xc029cc9c: [ 2.191520] cc9c e2833001 e1530006 13a04000 1088a003 11a0c004 1afffff5 e592c [ 2.199779] ccbc e5924004 e582300c e582c008 e592c000 e5824000 e5900040 e0633 [ 2.208037] ccdc e5823004 e582101c e8bd87f0 e92d40f8 e2527000 e1a05000 e1a03 [ 2.216294] ccfc 0a00000b ea000013 e5953238 e1a00005 e1a01004 e2877001 e5933 [ 2.224551] cd1c e5942000 e5943008 e0823003 e2833008 e5843000 e1570006 08bd0 [ 2.232809] cd3c e5942008 e0822003 e595303c e1520003 9affffec e8bd80f8 e3570 [ 2.241066] cd5c ea00000b e5953238 e1a00005 e1a01004 e2877001 e5933034 e12f0 [ 2.249323] cd7c e5942008 e2433008 e0623003 e5843000 ea000000 e3a07000 e1570 [ 2.257584] [ 2.257584] SP: 0xee07bce8: [ 2.261843] bce8 ed8108dc c03076a0 c0af3439 ee07bda4 53425553 45545359 6c701 [ 2.270100] bd08 44006d72 c02a5310 60000113 ffffffff ee07bd54 c000d598 c0be1 [ 2.278357] bd28 00000000 00000010 00000010 00000000 00000000 00000000 ee3d0 [ 2.286611] bd48 00000050 00000010 00000000 ee07bd68 c029cd1c c02a5310 6000f [ 2.294867] bd68 00000029 000000c0 00000000 00000010 ed810c00 00000050 ee073 [ 2.303121] bd88 ee3d4c18 c03076c0 00000003 ee07bdd0 ee3d6000 00000004 00000 [ 2.311375] bda8 00000000 00000000 00000004 c029cd1c 00000004 ee3d6000 c0be0 [ 2.319629] bdc8 00000000 c029e9cc 00000000 00000000 00000050 00000050 ee3d0 [ 2.327885] [ 2.327885] R0: 0xc0bea745: [ 2.332144] a744 2e2e7a9a 64700620 36aad64e 7c062f46 85b45870 06466224 a33ae [ 2.340402] a764 0772a708 ca5e92a2 a6e045a2 3287ae0a ce2e96be 85a32aa2 487ad [ 2.348659] a784 22322e6e 0676af06 9e073650 3c5b2476 326e8a06 82066398 667a6 [ 2.356918] a7a4 7c224256 568a0650 1e425606 864c565e 566a0656 223e523a 64422 [ 2.365174] a7c4 20202042 20202020 20202020 20202020 20202020 20202020 20200 [ 2.373430] a7e4 20202020 22212120 21212222 20202021 20202020 20202020 20200 [ 2.381687] a804 20202020 20202020 20202020 20202020 20202020 20202020 20200 [ 2.389942] a824 20202020 20202020 20202020 20202020 22212020 26252423 25268 [ 2.398200] a844 20202020 20202020 20202020 20202020 20202020 20202020 20200 [ 2.406459] [ 2.406459] R8: 0xee3d5f80: [ 2.410717] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000 [ 2.418969] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000 [ 2.427220] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000 [ 2.435470] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000 [ 2.443720] 6000 00000001 00000000 00000000 00000001 00000000 ee3d6014 ee3d0 [ 2.451973] 6020 00000000 00000001 00000000 ee3d602c ee3d602c 00000000 00000 [ 2.460228] 6040 00000438 00000780 00000438 00000000 00000000 00000010 4387b [ 2.468482] 6060 00000005 00000000 00000005 00000006 00000000 00000000 00000 [ 2.476743] Process swapper/0 (pid: 1, stack limit = 0xee07a238) [ 2.482703] Stack: (0xee07bd68 to 0xee07c000) [ 2.487048] bd60: 00000029 000000c0 00000000 00000010 ed810 [ 2.495171] bd80: ee07bdd0 00000003 ee3d4c18 c03076c0 00000003 ee07bdd0 ee3d4 [ 2.503290] bda0: 00000001 ee3d5010 00000000 00000000 00000004 c029cd1c 00000 [ 2.511408] bdc0: c0bed80c ed810c00 00000000 c029e9cc 00000000 00000000 00000 [ 2.519528] bde0: ee3d6214 00000000 ee3d6008 c0bea7c5 00000000 c02a10b4 00000 [ 2.527649] be00: 00000000 00000000 ee3d4c28 ee3d4c18 ee3d6000 ee334310 00008 [ 2.535771] be20: 00000004 ee3d4c28 ed8108dc c02aa54c ee3ead10 ee3d4c10 00000 [ 2.543891] be40: ee3d4c10 0000002f 00000000 c00a0054 ee3eacc0 ee3d4c10 ee270 [ 2.552014] be60: ee27f000 c0d0c000 c0befc90 c0b9a5f0 00000000 c02b9020 00000 [ 2.560135] be80: ee3d4c10 ee27f010 ee27f018 00000001 c0c31d98 00000000 ee270 [ 2.568256] bea0: c0c31d98 c030bf58 c030bf44 c030ad20 ee27f010 c0c31d98 c0c30 [ 2.576378] bec0: c0d0c000 c030af7c 00000000 ee27f010 ee27f044 c030aff4 c0c38 [ 2.584500] bee0: c030af94 c03097d0 ee18065c ee2604b4 c0c31d98 c0c31d98 ee330 [ 2.592621] bf00: 00000000 c030a580 c0a745ef c0a745f3 c0c31d98 c0bbfef4 ee070 [ 2.600742] bf20: c0d0c000 c030b4d0 c030bf7c 00000005 c0bbfef4 ee07a000 00000 [ 2.608864] bf40: c0b9a5f0 c00086a4 c0bbfef4 0000159c 00000005 c0be7abc c0be0 [ 2.616985] bf60: 000001fc c0b9ab28 00000005 00000005 c0b9a5f0 00000000 c0bec [ 2.625103] bf80: 00000000 00000000 00000000 00000000 00000000 c0b9abe8 ee070 [ 2.633223] bfa0: c0826728 c0826730 00000000 c000da98 00000000 00000000 00000 [ 2.641339] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000 [ 2.649458] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 dbfff [ 2.657603] [] (cfb_imageblit+0x3ac/0x434) from [] (fb_d) [ 2.666606] [] (fb_do_show_logo+0x34/0x168) from [] (fb_) [ 2.676973] [] (fb_show_logo_line.constprop.9+0x1d0/0x210) from [<) [ 2.687340] [] (rk_fb_register+0x7b4/0x88c) from [] (rk3) [ 2.696683] [] (rk3288_lcdc_probe+0x214/0x2b0) from [] () [ 2.706190] [] (platform_drv_probe+0x14/0x18) from [] (r) [ 2.715177] [] (really_probe+0xa8/0x20c) from [] (driver) [ 2.724248] [] (driver_probe_device+0x30/0x48) from [] () [ 2.733491] [] (__driver_attach+0x60/0x84) from [] (bus_) [ 2.742475] [] (bus_for_each_dev+0x50/0x90) from [] (bus) [ 2.751459] [] (bus_add_driver+0xac/0x20c) from [] (driv) [ 2.760448] [] (driver_register+0x9c/0x138) from [] (do_) [ 2.769444] [] (do_one_initcall+0x34/0xc8) from [] (do_i) [ 2.778091] [] (do_initcalls+0x70/0xa0) from [] (kernel_) [ 2.787262] [] (kernel_init_freeable+0x90/0x130) from []) [ 2.796261] [] (kernel_init+0x8/0xe4) from [] (ret_from_) [ 2.804557] Code: e59d400c e1530004 e1822316 3a000003 (e48c2004) [ 2.810735] ---[ end trace 7fd5b784cef025a4 ]--- [ 2.815401] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0b [ 2.815401] [ 2.824490] CPU3: stopping [ 2.827227] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 3.10.0 #72 [ 2.834179] [] (unwind_backtrace+0x0/0xe0) from [] (show) [ 2.842662] [] (show_stack+0x10/0x14) from [] (handle_IP) [ 2.850881] [] (handle_IPI+0x154/0x2c8) from [] (gic_han) [ 2.859441] [] (gic_handle_irq+0x50/0x58) from [] (__irq) [ 2.867723] Exception stack(0xee0c9f80 to 0xee0c9fc8) [ 2.872758] 9f80: ffffffed 00000000 0128f000 00000000 ee0c8000 ee0c8000 10c08 [ 2.880882] 9fa0: 0000406a 410fc0d1 00000000 00000000 00000000 ee0c9fc8 c0008 [ 2.888990] 9fc0: 60000113 ffffffff [ 2.892493] [] (__irq_svc+0x40/0x70) from [] (arch_cpu_i) [ 2.900718] [] (arch_cpu_idle+0x30/0x38) from [] (cpu_id) [ 2.909451] [] (cpu_idle_loop+0x1b8/0x224) from [] (free) [ 2.918505] CPU2: stopping [ 2.921238] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 3.10.0 #72 [ 2.928181] [] (unwind_backtrace+0x0/0xe0) from [] (show) [ 2.936661] [] (show_stack+0x10/0x14) from [] (handle_IP) [ 2.944880] [] (handle_IPI+0x154/0x2c8) from [] (gic_han) [ 2.953440] [] (gic_handle_irq+0x50/0x58) from [] (__irq) [ 2.961719] Exception stack(0xee0c7f80 to 0xee0c7fc8) [ 2.966754] 7f80: ffffffed 00000000 01286000 00000000 ee0c6000 ee0c6000 10c08 [ 2.974877] 7fa0: 0000406a 410fc0d1 00000000 00000000 00000000 ee0c7fc8 c0008 [ 2.982985] 7fc0: 60000113 ffffffff [ 2.986489] [] (__irq_svc+0x40/0x70) from [] (arch_cpu_i) [ 2.994712] [] (arch_cpu_idle+0x30/0x38) from [] (cpu_id) [ 3.003445] [] (cpu_idle_loop+0x1b8/0x224) from [] (free) [ 3.012498] CPU0: stopping [ 3.015228] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 3.10.0 #72 [ 3.022169] [] (unwind_backtrace+0x0/0xe0) from [] (show) [ 3.030649] [] (show_stack+0x10/0x14) from [] (handle_IP) [ 3.038865] [] (handle_IPI+0x154/0x2c8) from [] (gic_han) [ 3.047425] [] (gic_handle_irq+0x50/0x58) from [] (__irq) [ 3.055705] Exception stack(0xc0bf7f58 to 0xc0bf7fa0) [ 3.060725] 7f40: ffff0 [ 3.068848] 7f60: 01274000 00000000 c0bf6000 c0bf6000 00000000 c084ce98 00001 [ 3.076969] 7f80: 00000000 00000000 00000000 c0bf7fa0 c000e754 c000e758 6000f [ 3.085103] [] (__irq_svc+0x40/0x70) from [] (arch_cpu_i) [ 3.093321] [] (arch_cpu_idle+0x30/0x38) from [] (cpu_id) [ 3.102051] [] (cpu_idle_loop+0x1b8/0x224) from [] (free) [ 3.111121] [<c0077c00+-----------------------------+) from [] (0x) [ 3.118885] CRU: | | [ 3.120755] 00000000: | Cannot open /dev/ttyUSB0! |0008 [ 3.126128] 00000010: | |0008 [ 3.131498] 00000020: +-----------------------------+000a [ 3.136864] 00000030: 00000107 9fff00c5 0fff0014 00000008 [ 3.142231] 00000040: 00000b00 9fff0270 0fff0138 00000008 [ 3.147597] 00000050: 00005011 00000000 00000000 00000000 [ 3.152963] 00000060: 00004031 0000b108 00000020 00000200 [ 3.158330] 00000070: 00008300 00008200 00008342 00010014 [ 3.163697] 00000080: 00010014 00010014 0000a101 00002743 [ 3.169062] 00000090: 00004380 00008a00 00000200 00000200 [ 3.174429] 000000a0: 00000200 0bb8ea60 00010014 00010014 [ 3.179796] 000000b0: 00010014 00000900 00000900 001f05dc [ 3.185161] 000000c0: 00001703 00000707 00000e40 00000101 [ 3.190528] 000000d0: 00000242 00000742 00004141 00004040 [ 3.195894] 000000e0: 00004141 00000505 00008042 00008f8f [ 3.201260] 000000f0: 00000000 00000631 00001ee5 00004007 [ 3.206625] 00000100: 00001200 00010014 00004141 00000000 [ 3.211989] 00000110: 00000000 00000000 00000000 00000000 [ 3.217353] 00000120: 00000000 00000000 00000000 00000000 [ 3.222717] 00000130: 00000000 00000000 00000000 00000000 [ 3.228081] 00000140: 00000000 00000000 00000000 00000000 [ 3.233445] 00000150: 00000000 00000000 00000000 00000000 [ 3.238808] 00000160: 00000000 00000000 00000000 00000000 [ 3.244173] 00000170: 00000000 00000000 0000e000 00000000 [ 3.249536] 00000180: 00000000 00000000 0000000c 00000000 [ 3.254900] 00000190: 00000000 00000000 00000000 00000000 [ 3.260264] 000001a0: 00000000 00000000 00000000 00000000 [ 3.265620] 000001b0: 00000000 00000000 00000000 00000000 [ 3.270983] 000001c0: 00000000 00000000 00000000 00000000 [ 3.276348] 000001d0: 00000000 00000000 00000000 00000000 [ 3.281714] 000001e0: 00000000 00000000 00000000 00640064 [ 3.287077] 000001f0: 00000004 00000000 00000002 00000000 [ 3.292442] 00000200: 00000002 00000000 00000002 00000000 [ 3.297806] 00000210: 00000002 00000000 00000004 00000000 [ 3.303165] Rebooting in 5 seconds..
地址0x00016000修改为0x00008000就可以正常启动miniroot。
你的根文件系统制作成功了吗?
请问最后制作成功了吗,我也遇到和你一样的问题。
