请问编译Android时,板子要不要连接到机子上,我没连,一直在机子上编译(ubuntu) 一直有错!
host StaticLib: libLLVMBitWriter_3_2_32 (out/host/linux-x86/obj32/STATIC_LIBRARIES/libLLVMBitWriter_3_2_intermediates/libLLVMBitWriter_3_2.a)
host SharedLib: libbcinfo_32 (out/host/linux-x86/obj32/lib/libbcinfo.so)
host SharedLib: libbcc_32 (out/host/linux-x86/obj32/lib/libbcc.so)
host Executable: bcc (out/host/linux-x86/obj32/EXECUTABLES/bcc_intermediates/bcc)
Install: out/host/linux-x86/lib/libbcinfo.so
Install: out/host/linux-x86/lib/libbcc.so
Install: out/host/linux-x86/bin/bcc
Install: out/host/linux-x86/bin/dalvikvm32
Symlink: out/host/linux-x86/bin/dalvikvm → dalvikvm32
Install: out/host/linux-x86/bin/dalvikvm64
host SharedLib: libart_32 (out/host/linux-x86/obj32/lib/libart.so)
clang: error: unable to execute command: Segmentation fault (core dumped)
clang: error: linker command failed due to signal (use -v to see invocation)
make: *** [out/host/linux-x86/obj32/lib/libart.so] 错误 254
#### make failed to build some targets (04:45 (mm:ss)) ####
