我根据hongyin的提示把板子里的root弄到了9G大小的linuxroot.img里,然后根据http://wiki.t-firefly.com/index. … ze_android_firmware 把这个linuxroot.img 替换到从官网下载的Firefly-RK3288_Ubuntu14.04_201512031755.img里。最后板子启动的时候遇到如下错误:
[ 6.836140] hub 3-1:1.0: USB hub found
[ 6.858777] hub 3-1:1.0: 4 ports detected
[ 6.874961] 2, baud is:115200
[ 6.880143] Freeing unused kernel memory: 2368K (c0a9c000 - c0cec000)
Loading, please wait…
[ 6.906364] udevd[147]: starting version 175
Begin: Loading essential drivers … FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
done.
Begin: Running /scripts/init-premount … done.
ext4
Begin: Running /scripts/local-premount … FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
done.
[ 8.040147] JBD2: no valid journal superblock found
[ 8.049623] EXT4-fs (mmcblk0p5): error loading journal
mount: mounting /dev/block/mtd/by-name/linuxroot on /root failed: Invalid argument
Begin: Running /scripts/local-bottom … done.
done.
Begin: Running /scripts/init-bottom … mount: mounting /dev on /root/dev failed: No such file or directory
done.
mount: mounting /sys on /root/sys failed: No such file or directory
mount: mounting /proc on /root/proc failed: No such file or directory
Target filesystem doesn’t have requested /sbin/init.
No init found. Try passing init= bootarg.
/bin/sh: can’t access tty; job control turned off
(initramfs) [ 11.751428] [otg id chg] last id -1 current id 1
[ 11.773911] PortPower off
[ 11.794151] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 11.917758] Using Buffer DMA mode
[ 11.922865] Periodic Transfer Interrupt Enhancement - disabled
[ 11.930489] Multiprocessor Interrupt Enhancement - disabled
[ 11.937847] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 11.944053] ^^^^^^^^^^^^^^^^^Device Mode
[ 11.987771] es8323_create file error
[ 12.440211] vbus detect**
[ 12.465902] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 592.980432]
[ 592.980432] rk_fb_switch_screen lcdc_id 0 type 1 enable 0
[ 592.980470] VGA SUSPEND
[ 592.980544] rk_iommu ff930300.vopb_mmu: (vopb) Disabled
[ 592.980558] rk_iommu ff930300.vopb_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e23b000
[ 593.005209] rk3288-lcdc lcdc0: blank mode:1
