按照论坛上的方法,7.85寸屏不亮
根据论坛上给的Android5.1的补丁,打补丁和编译都没有报错,但是屏不亮
根据http://wiki.t-firefly.com/index.php/Firefly-RK3288/Peripherals#7.85.E5.AF.B8EDP.E6.B6.B2.E6.99.B6.E5.B1.8F.E6.A8.A1.E7.BB.84的方法
官方固件可以亮吗
可以的话把修改的全部发出来看
官方固件可以
发现HDMI却还有输出,是不是哪里要配置??? 哪位大神指导下啊
修改的补丁
From ae6cc409a868d510f6b2197e1bb7ebb04447390d Mon Sep 17 00:00:00 2001
Date: Fri, 6 May 2016 17:21:42 +0800
Subject: [PATCH] Kernel->driver:add 7.85 module support
device/rockchip/rk3288/rk3288_box/system.prop | 2 ±
…/android/providers/settings/DatabaseHelper.java | 2 ±
kernel/arch/arm/boot/dts/firefly-rk3288.dts | 37 +++++++++++++++±—
kernel/arch/arm/boot/dts/rk3288.dtsi | 2 ±
kernel/arch/arm/configs/firefly-rk3288_defconfig | 2 ±
5 files changed, 34 insertions(+), 11 deletions(-)
diff --git a/device/rockchip/rk3288/rk3288_box/system.prop b/device/rockchip/rk3288/rk3288_box/system.prop
index 6f1135e..81d3b29 100644
— a/device/rockchip/rk3288/rk3288_box/system.prop
+++ b/device/rockchip/rk3288/rk3288_box/system.prop
@@ -44,6 +44,6 @@ wifi.supplicant_scan_interval=15
ro.factory.tool=0
ro.kernel.android.checkjni=0
#set default lcd density to Rockchip tablet
-ro.sf.lcd_density=160
+ro.sf.lcd_density=320
ro.adb.secure=0
persist.demo.hdmirotates=true
diff --git a/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java b/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java
index c5ccf3e..56181f5 100644
— a/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java
+++ b/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java
@@ -2310,7 +2310,7 @@ public class DatabaseHelper extends SQLiteOpenHelper {
SystemProperties.getInt(“ro.rk.screenoff_time”, mContext.getResources().getInteger(R.integer.def_screen_off_timeout)));
         loadSetting(stmt, Settings.System.HIDE_ROTATION_LOCK_TOGGLE_FOR_ACCESSIBILITY,
  •                 "1");
  •                 "0");
           // Set default button lights settings
           loadBooleanSetting(stmt,Settings.System.BUTTON_LIGHTS_ENABLED,
                   R.bool.def_button_lights_enabled);
diff --git a/kernel/arch/arm/boot/dts/firefly-rk3288.dts b/kernel/arch/arm/boot/dts/firefly-rk3288.dts
index 86d1b22..b3d9038 100755
— a/kernel/arch/arm/boot/dts/firefly-rk3288.dts
+++ b/kernel/arch/arm/boot/dts/firefly-rk3288.dts
@@ -1,7 +1,7 @@
/dts-v1/;
#include “rk3288.dtsi”
-#include “lcd-box.dtsi”
+#include “lcd-LP079Qx1.dtsi”
#include <dt-bindings/input/input.h>
@@ -498,7 +498,7 @@
flip-y = <0>;
mt@40 {
  •   status = "disabled";
  •   status = "okay";
              	compatible = "firefly,gsl3680";
             	reg = <0x40>;
              	touch-gpio = <&gpio5 GPIO_B0 IRQ_TYPE_EDGE_RISING>;
@@ -523,7 +523,7 @@
swap-xy = <1>;
mpu6050:mpu@68{
  •        status = "okay";
           compatible = "mpu6050";
           reg = <0x68>;
           mpu-int_config = <0x10>;
@@ -589,7 +589,7 @@
gpio-pwn = <&gpio0 GPIO_C1 GPIO_ACTIVE_HIGH>;
rockchip,source = <0>; //0: LCDC0; 1: LCDC1
rockchip,prop = ;//
  •   status = "okay";
&disp_timings {
  • native-mode = <&timing1>;
  • native-mode = <&timing0>;
&rk_screen {
@@ -624,6 +624,29 @@
status = “okay”;
rockchip,iommu-enabled = <1>;
rockchip,prop = ;
  •   	power_ctr: power_ctr {
  •    rockchip,debug = <1>;
  •    lcd_en:lcd_en {
  •            rockchip,power_type = <GPIO>;
  •            gpios = <&gpio0 GPIO_B5 GPIO_ACTIVE_HIGH>;
  •            rockchip,delay = <10>;
  •    lcd_cs:lcd_cs {
  •            gpios = <&gpio7 GPIO_A4 GPIO_ACTIVE_HIGH>;
  •    lcd_rst:lcd_rst {
  •            gpios = <&gpio5 GPIO_C1 GPIO_ACTIVE_LOW>;
  •            rockchip,delay = <0>;
&lcdc1 {
@@ -703,7 +726,7 @@
&pwm1 {
  • status = “disabled”;
  • status = “okay”;
diff --git a/kernel/arch/arm/boot/dts/rk3288.dtsi b/kernel/arch/arm/boot/dts/rk3288.dtsi
index bff1961..b8501f0 100755
— a/kernel/arch/arm/boot/dts/rk3288.dtsi
+++ b/kernel/arch/arm/boot/dts/rk3288.dtsi
@@ -1276,7 +1276,7 @@
rockchip,ctrbits = <
(0
|RKPM_CTR_PWR_DMNS
  •   	 |RKPM_CTR_GTCLKS
  •   //	 |RKPM_CTR_GTCLKS
      	 |RKPM_CTR_PLLS
                //      |RKPM_CTR_GPIOS
      //	 |RKPM_CTR_SYSCLK_DIV
diff --git a/kernel/arch/arm/configs/firefly-rk3288_defconfig b/kernel/arch/arm/configs/firefly-rk3288_defconfig
index 60e1065..a9d6c81 100644
— a/kernel/arch/arm/configs/firefly-rk3288_defconfig
+++ b/kernel/arch/arm/configs/firefly-rk3288_defconfig
@@ -1536,7 +1536,7 @@ CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_SYNAPTICS_DSX_CORE=y
# CONFIG_TOUCHSCREEN_SYNAPTICS_RK is not set
# CONFIG_TOUCHSCREEN_ZET62XX is not set
-CONFIG_TOUCHSCREEN_GSLX680=y
+CONFIG_TOUCHSCREEN_GSLX680_MT70817V2=y
# CONFIG_TOUCHSCREEN_GT8XX is not set
# CONFIG_TOUCHSCREEN_GT9XX is not set
# CONFIG_TOUCHSCREEN_CT36X_TS is not set
1.7.9.5
rockchip,disp-policy没改到,还有uboot有没有更新
我也是按照那个方法,没点亮。
lzh 发表于 2016-5-22 00:00
我也是按照那个方法,没点亮。
点亮了,原来有个地方理解错了。如下:
&lcdc0 {
status = “okay”;
rockchip,prop = ;
        lcd_en:lcd_en {
        lcd_cs:lcd_cs {
        lcd_rst:lcd_rst {
lzh 发表于 2016-5-23 14:26
点亮了,原来有个地方理解错了。如下:
&lcdc0 {
status = “okay”;
Uboot的编译要用make rk3288_config 不能用make rk3288_box_config。
