[懇請開示] 想開啟 USB Gadget Drivers (Audio Gadget)
請教大神:
應如何開啟並測試. 感謝大神
目前 make menuconfig → search gadget → (1) → 選 Audio Gadget → Save & Exit
x x <*> USB Gadget Drivers (Audio Gadget) —> x x
x x Audio Gadget x x
x x UAC 1.0 (Legacy) x x
重新build kernel 放上板子上跑, 結果如下
root@firefly:~# cat /proc/asound/cards
0 [UAC2Gadget ]: UAC2_Gadget - UAC2_Gadget
UAC2_Gadget 0
1 [RKES8323 ]: RK_ES8323 - RK_ES8323
RK_ES8323
2 [RKHDMISPDIF ]: RK-HDMI-SPDIF - RK-HDMI-SPDIF
RK-HDMI-SPDIF
但連接 rk3288(otg) ↔ Win7 並沒有USB偵測出現新的音效裝置
懇求大神開示 Orz
没有做过,帮顶~
另外, dmesg 常可見
[14196.871991] init: ttyS2 main process (4184) terminated with status 1
[14196.872410] init: ttyS2 main process ended, respawning
[14206.764955] init: ttyS2 main process (4187) terminated with status 1
[14206.765366] init: ttyS2 main process ended, respawning
[14216.652770] init: ttyS2 main process (4189) terminated with status 1
[14216.653227] init: ttyS2 main process ended, respawning
[14226.538692] init: ttyS2 main process (4191) terminated with status 1
[14226.539144] init: ttyS2 main process ended, respawning
[14236.425308] init: ttyS2 main process (4193) terminated with status 1
[14236.425719] init: ttyS2 main process ended, respawning
[14246.314763] init: ttyS2 main process (4195) terminated with status 1
[14246.315161] init: ttyS2 main process ended, respawning
[14256.211485] init: ttyS2 main process (4197) terminated with status 1
[14256.211921] init: ttyS2 main process ended, respawning
[14266.097866] init: ttyS2 main process (4199) terminated with status 1
[14266.099003] init: ttyS2 main process ended, respawning
[14275.988973] init: ttyS2 main process (4201) terminated with status 1
[14275.989393] init: ttyS2 main process ended, respawning
[14285.876824] init: ttyS2 main process (4203) terminated with status 1
[14285.877256] init: ttyS2 main process ended, respawning
[14295.783400] init: ttyS2 main process (4205) terminated with status 1
[14295.783924] init: ttyS2 main process ended, respawning
[14305.683830] init: ttyS2 main process (4207) terminated with status 1
[14305.684240] init: ttyS2 main process ended, respawning
[14315.570145] init: ttyS2 main process (4209) terminated with status 1
[14315.570551] init: ttyS2 main process ended, respawning
[14325.460627] init: ttyS2 main process (4211) terminated with status 1
[14325.461079] init: ttyS2 main process ended, respawning
[14335.348002] init: ttyS2 main process (4213) terminated with status 1
[14335.348415] init: ttyS2 main process ended, respawning
[14345.236314] init: ttyS2 main process (4215) terminated with status 1
[14345.236750] init: ttyS2 main process ended, respawning
[14355.127797] init: ttyS2 main process (4217) terminated with status 1
[14355.128189] init: ttyS2 main process ended, respawning
[14365.017737] init: ttyS2 main process (4219) terminated with status 1
[14365.018150] init: ttyS2 main process ended, respawning
[14374.906715] init: ttyS2 main process (4221) terminated with status 1
[14374.907147] init: ttyS2 main process ended, respawning
[14384.798319] init: ttyS2 main process (4223) terminated with status 1
[14384.798720] init: ttyS2 main process ended, respawning
[14394.685626] init: ttyS2 main process (4225) terminated with status 1
[14394.686063] init: ttyS2 main process ended, respawning
[14404.574125] init: ttyS2 main process (4227) terminated with status 1
[14404.574516] init: ttyS2 main process ended, respawning
[14414.461412] init: ttyS2 main process (4229) terminated with status 1
[14414.461844] init: ttyS2 main process ended, respawning
[14424.354397] init: ttyS2 main process (4231) terminated with status 1
[14424.355845] init: ttyS2 main process ended, respawning
[14434.256767] init: ttyS2 main process (4233) terminated with status 1
[14434.257204] init: ttyS2 main process ended, respawning
想問這有事嗎 @@?
繼續 @@"
衝了許久的浪, 上岸一會, 小歇片刻
============{以上廢話}============
echo 1 > /sys/bus/platform/drivers/usb20_otg/dwc_otg_conn_en
之後,
M$ 系統提示有新的 USB 硬體接入, 但是 {音效,視訊及遊戲控制器} 驅動裝置[ Source/Sink ] 顯示為 (!)驚嘆號
應該是對應到 ./drivers/usb/gadget/f_uac2.c: [STR_ASSOC].s = “Source/Sink”,
dmesg 顯示:
在 afunc_set_alt 裡面 印出了 snd_uac2 snd_uac2.0: free_ep:946 Error!
懇請大神 釋疑
既然接 Windows 系統驅動顯示是(!)驚嘆號, 就改接 Linux 系統試看看:
dmesg顯示
[432450.249412] usb 2-1.6: USB disconnect, device number 5
[432461.964368] usb 2-1.6: new high-speed USB device number 6 using ehci-pci
[432462.058621] usb 2-1.6: New USB device found, idVendor=1d6b, idProduct=0101
[432462.058626] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[432462.058629] usb 2-1.6: Product: Linux USB Audio Gadget
[432462.058631] usb 2-1.6: Manufacturer: Linux 3.10.0 with dwc_otg_pcd
[432462.130287] retire_capture_urb: 4548 callbacks suppressed
root@atuser123:~# cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf7130000 irq 47
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xf7080000 irq 17
2 [Gadget ]: USB-Audio - Linux USB Audio Gadget
Linux 3.10.0 with dwc_otg_pcd Linux USB Audio Gadget at usb-0000:00:1d.0-1.6, h
在 rk3288 上面執行:
arecord -D plughw:2,0 /root/test.wav -v
然後, 在 Linux 上面執行:
aplay -D plughw:2,0 /root/Media-Convert_test3_PCM_Stereo_VBR_16SS_11025Hz.wav -v
把檔案放到windows上來播放聽看看, 好像有點東西了~~
有大神知道這個嗎??
retire_capture_urb: 4931 callbacks suppressed
昨天搞了一天沒弄出甚麼東西, 真是讓人沮喪 Orz
請大神指點迷津, 目前狀態:
RK3288 ↔ Ubuntu Result
arecord aplay OK
aplay arecord Fail
RK3288 ↔ Win7 (!)Source/Sink
改成 insmod 方式作驗證
dmesg 訊息如下
[ 146.166042] WARN::dwc_otg_pcd_ep_stop_transfer:1762: dwc_otg_pcd_ep_stop_transfer: timeout diepctl.snak
[ 146.166042]
[ 146.818142] init: ttyS2 main process (1323) terminated with status 1
[ 146.818424] init: ttyS2 main process ended, respawning
[ 147.082139] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 147.084193] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 147.279043] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 147.281085] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 147.282099] ###################WARNING:set voltage is error!voltage set is 950000 mv -110
[ 147.282125] DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
[ 147.475932] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 147.477978] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 147.478992] DVFS ERR: dvfs_regulator_set_voltage_readback: set ERROR AND NOT effected, volt=937500
[ 147.479078] DVFS ERR: dvfs_scale_volt_direct: vd_arm set voltage up err ret = -110, Vnew = 950000(was 900000)mV
[ 147.672821] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 147.674863] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 147.675879] DVFS WARNING: dvfs_reset_volt:vd(vd_arm) try to reload volt = 937500
[ 147.873313] WARN::dwc_otg_pcd_ep_stop_transfer:1786: dwc_otg_pcd_ep_stop_transfer: timeout diepctl.epdis
[ 147.873313]
[ 156.706129] init: ttyS2 main process (1327) terminated with status 1
[ 156.706421] init: ttyS2 main process ended, respawning
[ 166.581110] init: ttyS2 main process (1330) terminated with status 1
[ 166.581498] init: ttyS2 main process ended, respawning
[ 176.469193] init: ttyS2 main process (1334) terminated with status 1
[ 176.469487] init: ttyS2 main process ended, respawning
[ 186.335126] init: ttyS2 main process (1336) terminated with status 1
[ 186.335413] init: ttyS2 main process ended, respawning
懇請大神度化有緣人~~
老感覺挫折像海浪般襲來, 這浪也太大了唄!
更新一下進度:
insmod後, rmmod 就會出現在 dmesg裏
[ 67.803881] ------------[ cut here ]------------
[ 67.803999] WARNING: at drivers/base/core.c:228 device_release+0x7c/0x90()
[ 67.804499] Device ‘snd_uac2.0’ does not have a release() function, it is broken and must be fixed.
[ 67.815224] Modules linked in: g_audio(-) mali_kbase libcomposite
[ 67.815336] CPU: 2 PID: 1201 Comm: rmmod Not tainted 3.10.0 #38
[ 67.815443] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 67.815520] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 67.815590] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 67.815659] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (device_release+0x7c/0x90)
[ 67.815728] [] (device_release+0x7c/0x90) from [] (kobject_release+0x68/0x7c)
[ 67.815808] [] (kobject_release+0x68/0x7c) from [] (afunc_unbind+0x44/0xa4 [g_audio])
[ 67.815917] [] (afunc_unbind+0x44/0xa4 [g_audio]) from [] (remove_config+0x6c/0xe4 [libcomposite])
[ 67.816032] [] (remove_config+0x6c/0xe4 [libcomposite]) from [] (__composite_unbind+0x40/0xa0 [libcomposite])
[ 67.816132] [] (__composite_unbind+0x40/0xa0 [libcomposite]) from [] (usb_gadget_remove_driver+0x68/0x9c)
[ 67.817035] [] (usb_gadget_remove_driver+0x68/0x9c) from [] (usb_gadget_unregister_driver+0x3c/0x78)
[ 67.817117] [] (usb_gadget_unregister_driver+0x3c/0x78) from [] (SyS_delete_module+0x18c/0x1fc)
[ 67.817191] [] (SyS_delete_module+0x18c/0x1fc) from [] (ret_fast_syscall+0x0/0x30)
[ 67.817233] —[ end trace 7e1c631e2a90cd3b ]—
更新下進度:
  1. RK3288下 arecord 可以錄到 從 OTG port 進來的聲音
  2. RK3288下 aplay 會有下列訊息:
    root@firefly:/home/firefly/Downloads# aplay -D plughw:2,0 -f S16_LE -r192000 64K_S16_LE_Mono.wav
    Playing WAVE ‘64K_S16_LE_Mono.wav’ : Signed 16 bit Little Endian, Rate 64000 Hz, Mono
    underrun!!! (at least 1051.375 ms long)
    underrun!!! (at least 4.734 ms long)
根據網路上查到的資料
來源引用: http://blog.csdn.net/azloong/article/details/6277457
overrun(录制时,数据都满了,还没被alsa驱动读走)和underrun(需要数据来播放,alsa驱动却不写入数据)
到底問題在哪呢 @@?
root@firefly:/home/firefly/Downloads# reboot
Broadcast message from root@firefly
(/dev/ttyFIQ0) at 5:50 …
The system is going down for reboot NOW!
root@firefly:/home/firefly/Downloads# wait-for-state stop/waiting
  • Stopping rsync daemon rsync [ OK ]
    [ 1669.435045] Unable to handle kernel paging request at virtual address 32460410
    [ 1669.442509] pgd = ecb34000
    [ 1669.445314] [32460410] *pgd=00000000
    [ 1669.449044] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
    [ 1669.454500] Modules linked in: g_audio mali_kbase libcomposite
    [ 1669.460636] CPU: 1 PID: 1205 Comm: console-kit-dae Not tainted 3.10.0 #38
    [ 1669.467602] task: ec9ce400 ti: ecae8000 task.ti: ecae8000
    [ 1669.473172] PC is at migrate_task_rq_fair+0x60/0x148
    [ 1669.478292] LR is at set_task_cpu+0x11c/0x1f4
    [ 1669.482783] pc : [] lr : [] psr: 200e0093
    [ 1669.482783] sp : ecae9da8 ip : 00000000 fp : ecae9e4c
    [ 1669.494536] r10: 600e0093 r9 : ecb6d440 r8 : 00000000
    [ 1669.499904] r7 : ece41848 r6 : 00000001 r5 : c1ed7f88 r4 : ece41400
    [ 1669.506599] r3 : 1c5e1c5e r2 : c0ccdf40 r1 : c0cd9298 r0 : ece41400
    [ 1669.513299] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
    [ 1669.520706] Control: 10c5387d Table: 2cb3406a DAC: 00000015
    [ 1669.526600]
    [ 1669.526600] PC: 0xc005bdf0:
    [ 1669.530998] bdf0 e3500001 e2d1c000 b1a06002 b1a07003 e1c463f0 e8bd80d0 c0cd84ac c0cf6a90
    [ 1669.539667] be10 e92d43f8 e3a03f5e e18320d0 e1a04000 e590515c e1921003 08bd83f8 e5908054
    [ 1669.548329] be30 e3580000 1a00001a e5903004 e59f2104 e5933014 e3530000 e283101f a1a01003
    [ 1669.556991] be50 e1a012c1 e7921101 e203201f e1a02231 e3120001 0a00000e e59f10dc e59f20dc
    [ 1669.565651] be70 e7916103 e0826006 e1a00006 eb1cd6b1 e1a07000 e1a00006 ebffe86e e1a00005
    [ 1669.574313] be90 e1a01008 ebfffebe e1a00006 e1a01007 eb1cd777 e594315c e2832058 e1b28f9f
    [ 1669.582974] beb0 e3a03f5e e18320d4 e0588002 e0c99003 e1983009 0a000010 e3590000 03580e7e
    [ 1669.591636] bed0 e5940180 83a02000 8a00000a e358001f e3a01000 e1a06008 9a000002 e1a022a8
    [ 1669.600300]
    [ 1669.600300] LR: 0xc0057264:
    [ 1669.604698] 7264 e5963000 e1a01004 e5960004 e1a02005 e2866008 e12fff33 e0673006 e0833008
    [ 1669.613362] 7284 e5133008 e3530000 1afffff4 e1a0200d e3c23d7f e3c3303f e5932004 e2422001
    [ 1669.622023] 72a4 e5832004 e5933000 e3130002 0a000000 eb1ce6bd e5943004 e5933014 e1530005
    [ 1669.630686] 72c4 0a000025 e5943030 e5933024 e3530000 0a000002 e1a00004 e1a01005 e12fff33
    [ 1669.639349] 72e4 e1c427d8 e3a06001 e3a07000 e0922006 e0a33007 e1c427f8 e59f30b0 e5933010
    [ 1669.648012] 7304 e3530000 0a00000b e24b8064 e3a01048 e1a00008 eb082c38 e3a02000 e3a03000
    [ 1669.656674] 7324 e3a00004 e1cd20f8 e1a02006 e1a03007 e58d8000 eb018c50 e5943004 e3a01000
    [ 1669.665336] 7344 e59f006c e24b2070 e50b4070 e5933014 e50b5068 e50b306c ebffdf27 e59431b4
    [ 1669.674002]
    [ 1669.674002] SP: 0xecae9d28:
    [ 1669.678398] 9d28 ece40538 00000000 ece40538 c005f9d4 00200200 edbfd944 0000016b 00000000
    [ 1669.687060] 9d48 0017309c c005be70 200e0093 ffffffff ecae9d94 c000d598 ece41400 c0cd9298
    [ 1669.695720] 9d68 c0ccdf40 1c5e1c5e ece41400 c1ed7f88 00000001 ece41848 00000000 ecb6d440
    [ 1669.704381] 9d88 600e0093 ecae9e4c 00000000 ecae9da8 c00572e4 c005be70 200e0093 ffffffff
    [ 1669.713041] 9da8 c005be10 ece41400 00000000 00000001 ece41848 00000000 ecb6d440 c00572e4
    [ 1669.721699] 9dc8 00000001 00000000 c1ecf3d8 c1ecef40 ec9ce400 c005d550 ec9ce438 ece40538
    [ 1669.730359] 9de8 c1ecef40 c07972a0 ece40500 c0cd9298 01201000 c0056c8c c1ecef40 00000001
    [ 1669.739018] 9e08 ecae9e2c c0056cf8 00000000 c005d26c 00000001 ece40500 00000010 00000000
    [ 1669.747680]
    [ 1669.747680] FP: 0xecae9dcc:
    [ 1669.752075] 9dcc 00000000 c1ecf3d8 c1ecef40 ec9ce400 c005d550 ec9ce438 ece40538 c1ecef40
    [ 1669.760739] 9dec c07972a0 ece40500 c0cd9298 01201000 c0056c8c c1ecef40 00000001 ecae9e2c
    [ 1669.769400] 9e0c c0056cf8 00000000 c005d26c 00000001 ece40500 00000010 00000000 ecb90000
    [ 1669.778060] 9e2c ece41400 00000000 ece41400 00000004 00000001 ece41848 00000000 ecae9e74
    [ 1669.786719] 9e4c c005941c 00000001 ece41400 00000000 ecae8000 00060013 ecae9efc ecb6d440
    [ 1669.795378] 9e6c b6d27fc2 ed7035ec c003a6c8 00000021 ecb6d440 ece41400 c003b500 00000013
    [ 1669.804039] 9e8c ece416ac 003c0000 ecae8000 00000013 ed703984 ed703984 c003c85c 00000000
    [ 1669.812701] 9eac ed703480 00000012 ed7035e8 ecae9ee8 00000005 00000000 ecae9fb0 ffffffff
    [ 1669.821366]
    [ 1669.821366] R0: 0xece41380:
    [ 1669.825762] 1380 ece4137c 00000000 ece41388 ece41388 00000000 00000000 00000000 00000001
    [ 1669.834422] 13a0 00000000 ece413a4 ece413a4 00000000 00000000 ece413b4 ece413b4 edba16c0
    [ 1669.843081] 13c0 c002ed4c 00000000 00000000 00000000 00000000 00000020 00000000 0000c350
    [ 1669.851740] 13e0 0000c350 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1669.860396] 1400 00000100 ecb90000 00000002 00404140 00000000 00000000 00000000 00000000
    [ 1669.869054] 1420 00000078 00000078 00000078 00000000 c07972a0 00000000 00000400 00400000
    [ 1669.877712] 1440 00000001 00000000 00000000 ece4144c ece4144c 00000000 a84af99f 00000011
    [ 1669.886371] 1460 00042c67 00000000 3a5235b5 fffffffe 0002d43a 00000000 00000002 00000000
    [ 1669.895032]
    [ 1669.895032] R1: 0xc0cd9218:
    [ 1669.924250] 9218 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1669.945390] 9238 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1669.966406] 9258 00000064 c1ee70c0 00009000 0000000f c1ee7100 00000004 00000009 c1ee7080
    [ 1669.987376] 9278 0000002c c1ec3000 c1ee7000 c1ee7040 00000001 00001000 00000000 00000003
    [ 1670.008298] 9298 011f8000 01201000 0120a000 01213000 00050800 00000001 0002e7f1 0007ffff
    [ 1670.029209] 92b8 0000f730 00002000 00000000 00000032 0000fffa 00000001 ee001e00 ee308f10
    [ 1670.050122] 92d8 00000001 00000001 ee001900 ee001480 00000011 0001ffff c1eeb200 ee001b80
    [ 1670.071082] 92f8 00000064 00000010 0000ffff c1f6b200 ee001400 00100000 ee04c000 ee04b000
    [ 1670.092030]
    [ 1670.092030] R2: 0xc0ccdec0:
    [ 1670.121089] dec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.142136] dee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.163094] df00 0000a1ff 00000008 54b4c3e7 53e887cd 534eea5b 00000000 00010000 00000000
    [ 1670.183985] df20 00000000 00000001 6e75722f 6d68732f 00000000 00000000 00000000 00000000
    [ 1670.204794] df40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.225526] df60 00000000 bbc80c91 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.246258] df80 0000001c 120ff47c 00000000 cf478004 53e887cd 120ff47c 00000000 00000000
    [ 1670.266886] dfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.287441]
    [ 1670.287441] R4: 0xece41380:
    [ 1670.315528] 1380 ece4137c 00000000 ece41388 ece41388 00000000 00000000 00000000 00000001
    [ 1670.336151] 13a0 00000000 ece413a4 ece413a4 00000000 00000000 ece413b4 ece413b4 edba16c0
    [ 1670.356781] 13c0 c002ed4c 00000000 00000000 00000000 00000000 00000020 00000000 0000c350
    [ 1670.377374] 13e0 0000c350 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.397820] 1400 00000100 ecb90000 00000002 00404140 00000000 00000000 00000000 00000000
    [ 1670.418098] 1420 00000078 00000078 00000078 00000000 c07972a0 00000000 00000400 00400000
    [ 1670.438443] 1440 00000001 00000000 00000000 ece4144c ece4144c 00000000 a84af99f 00000011
    [ 1670.458687] 1460 00042c67 00000000 3a5235b5 fffffffe 0002d43a 00000000 00000002 00000000
    [ 1670.478762]
    [ 1670.478762] R5: 0xc1ed7f08:
    [ 1670.505999] 7f08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.526050] 7f28 00000000 00000000 00000000 00000000 00000000 00000000 6ccd6ccd 0000000b
    [ 1670.545971] 7f48 00000400 00000200 00000100 00000088 0000008a 00022152 00000000 00000000
    [ 1670.565834] 7f68 00000000 00000000 00002c00 00000000 00001f3a 00000000 0000d657 00000000
    [ 1670.585602] 7f88 00002c00 00000000 0000000b 0000000b 24c268a8 00000007 71bfc3c6 00000005
    [ 1670.605233] 7fa8 71bfc3c6 00000005 edb46e40 ec9c8540 ec884138 00000000 00000000 00000000
    [ 1670.624995] 7fc8 000001bd 00000000 000003cc 00000000 0000001f 00000000 00184b22 00000000
    [ 1670.644666] 7fe8 00000000 00000000 00184b21 00000000 000000e9 000000e9 000003ce 00000000
    [ 1670.664198]
    [ 1670.664198] R7: 0xece417c8:
    [ 1670.690217] 17c8 00000000 00000000 00000000 00000000 00000000 ec8a12c0 ecb7ed00 c0cf5b00
    [ 1670.709659] 17e8 ecb6d440 ed703480 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.729032] 1808 ece41808 ece41808 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1670.748269] 1828 00000000 00000000 00000000 ffffffff ffffffff 00000004 00000006 00010001
    [ 1670.767467] 1848 00040003 ece4184c ece4184c 00000000 00000000 00000000 00000000 00000000
    [ 1670.786586] 1868 00000000 00000000 00000000 00000000 c0e218c4 ece4097c ee19d47c b627f460
    [ 1670.805842] 1888 ece41888 ece41888 00000000 00000000 00000000 00000001 00000000 ece418a4
    [ 1670.825038] 18a8 ece418a4 00000000 00000000 ece418b4 ece418b4 00000000 00000000 00000000
    [ 1670.844171]
    [ 1670.844171] R9: 0xecb6d3c0:
    [ 1670.869537] d3c0 ffffffff ffffffff ffffffff ffffffff 00003e6c 00003e6c 000c8000 000c8000
    [ 1670.888720] d3e0 00000000 00000000 00000000 00000000 ffffffff ffffffff 00000000 00000000
    [ 1670.907893] d400 00000000 00000000 00160016 ecb6d40c ecb6d40c 00000000 00000000 00000001
    [ 1670.927007] d420 00000000 ecb6d424 ecb6d424 00000000 00000000 00000000 00000000 00000000
    [ 1670.946036] d440 00000041 00000041 00000041 00080008 ecb6d450 ecb6d450 ec9ce400 ecb6d45c
    [ 1670.965016] d460 ecb6d45c 00000000 00000000 00000013 00000000 00000000 00000021 00000000
    [ 1670.984117] d480 00000000 00000000 ecb6d488 ecb6d488 ecb6d490 00000000 00000000 00000000
    [ 1671.003129] d4a0 00000000 00000000 00000000 00000000 c00306c0 c1ec3740 00000000 ffffffff
    [ 1671.022121] Process console-kit-dae (pid: 1205, stack limit = 0xecae8238)
    [ 1671.039466] Stack: (0xecae9da8 to 0xecaea000)
    [ 1671.054480] 9da0: c005be10 ece41400 00000000 00000001 ece41848 00000000
    [ 1671.073553] 9dc0: ecb6d440 c00572e4 00000001 00000000 c1ecf3d8 c1ecef40 ec9ce400 c005d550
    [ 1671.092733] 9de0: ec9ce438 ece40538 c1ecef40 c07972a0 ece40500 c0cd9298 01201000 c0056c8c
    [ 1671.111964] 9e00: c1ecef40 00000001 ecae9e2c c0056cf8 00000000 c005d26c 00000001 ece40500
    [ 1671.131259] 9e20: 00000010 00000000 ecb90000 ece41400 00000000 ece41400 00000004 00000001
    [ 1671.150461] 9e40: ece41848 00000000 ecae9e74 c005941c 00000001 ece41400 00000000 ecae8000
    [ 1671.169746] 9e60: 00060013 ecae9efc ecb6d440 b6d27fc2 ed7035ec c003a6c8 00000021 ecb6d440
    [ 1671.188992] 9e80: ece41400 c003b500 00000013 ece416ac 003c0000 ecae8000 00000013 ed703984
    [ 1671.208418] 9ea0: ed703984 c003c85c 00000000 ed703480 00000012 ed7035e8 ecae9ee8 00000005
    [ 1671.227913] 9ec0: 00000000 ecae9fb0 ffffffff fffffdfc ecae8000 b6d27fc0 ecae8000 b6d27fc2
    [ 1671.247476] 9ee0: 00000000 c0010c00 00000000 00000000 00000001 00020000 ed7cc308 00000013
    [ 1671.267059] 9f00: 00000000 00000000 00000700 00000000 be8ad000 be88b000 bf000000 c01327bc
    [ 1671.286627] 9f20: ed7cc300 00000000 ec9ce400 00000000 00000000 00000000 be82ebb4 00000008
    [ 1671.306180] 9f40: ed7cc308 00000001 ede00580 00000000 00000000 00000000 00000000 c00f6c78
    [ 1671.325674] 9f60: 00000000 ffffffff 00000004 0004bc28 000000a8 c000db84 ecae8000 00000000
    [ 1671.345114] 9f80: 00000000 ecae9fb0 ecae8000 c000db84 000000a8 c000db84 00000000 c0010fa4
    [ 1671.364640] 9fa0: 0002dd48 00000004 0004bc28 c000da40 0004bc28 00000004 ffffffff ffffffff
    [ 1671.384111] 9fc0: 0002dd48 00000004 0004bc28 000000a8 b6dd82a5 00000001 00000001 00000000
    [ 1671.403686] 9fe0: 00000000 be82ec08 b6d27fbb b6d27fc0 80010030 0004bc28 00000000 00000000
    [ 1671.423337] [] (migrate_task_rq_fair+0x60/0x148) from [] (set_task_cpu+0x11c/0x1f4)
    [ 1671.444374] [] (set_task_cpu+0x11c/0x1f4) from [] (try_to_wake_up+0x1bc/0x1fc)
    [ 1671.465137] [] (try_to_wake_up+0x1bc/0x1fc) from [] (signal_wake_up_state+0x24/0x38)
    [ 1671.486628] [] (signal_wake_up_state+0x24/0x38) from [] (do_signal_stop+0xd4/0x258)
    [ 1671.508142] [] (do_signal_stop+0xd4/0x258) from [] (get_signal_to_deliver+0x310/0x3fc)
    [ 1671.530057] [] (get_signal_to_deliver+0x310/0x3fc) from [] (do_signal+0xa0/0x14c)
    [ 1671.551546] [] (do_signal+0xa0/0x14c) from [] (do_work_pending+0x4c/0x94)
    [ 1671.572538] [] (do_work_pending+0x4c/0x94) from [] (work_pending+0xc/0x20)
    [ 1671.593587] Code: e3120001 0a00000e e59f10dc e59f20dc (e7916103)
    [ 1671.612126] —[ end trace 6e0a6a4f09a2f7e0 ]—
…這該怎麼弄呢
在 windows 上用 usbview dump 出來的資訊:
呼喚大神! 懇請開示, 感恩^^
訊息如下
[Port3] : USB Composite Device
Device Power State: PowerDeviceD0
   ---===>Device Information<===---
English product name: “Linux USB Audio Gadget”
ConnectionStatus:
Current Config Value: 0x01 → Device Bus Speed: High
Device Address: 0x02
Open Pipes: 0
*!*ERROR: No open pipes!
      ===>Device Descriptor<===
bLength: 0x12
bDescriptorType: 0x01
bcdUSB: 0x0200
bDeviceClass: 0x00 → This is an Interface Class Defined Device
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x40 = (64) Bytes
idVendor: 0x1D6B = The Linux Foundation
idProduct: 0x0101
bcdDevice: 0x0310
iManufacturer: 0x01
English (United States) “Linux 3.10.0 with dwc_otg_pcd”
iProduct: 0x02
English (United States) “Linux USB Audio Gadget”
iSerialNumber: 0x00
bNumConfigurations: 0x01
   ---===>Full Configuration Descriptor<===---
      ===>Configuration Descriptor<===
bLength: 0x09
bDescriptorType: 0x02
wTotalLength: 0x006E → Validated
bNumInterfaces: 0x02
bConfigurationValue: 0x01
iConfiguration: 0x00
bmAttributes: 0xC0 → Self Powered
MaxPower: 0xFA = 500 mA
      ===>Interface Descriptor<===
bLength: 0x09
bDescriptorType: 0x04
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x00
bInterfaceClass: 0x01 → Audio Interface Class
bInterfaceSubClass: 0x01 → Audio Control Interface SubClass
bInterfaceProtocol: 0x00
iInterface: 0x00
      ===>Audio Control Interface Header Descriptor<===
bLength: 0x0A
bDescriptorType: 0x24
bDescriptorSubtype: 0x01
bcdADC: 0x0100
wTotalLength: 0x0028
bInCollection: 0x02
baInterfaceNr[1]: 0x00
baInterfaceNr[2]: 0x01
      ===>Audio Control Input Terminal Descriptor<===
bLength: 0x0C
bDescriptorSubtype: 0x02
bTerminalID: 0x01
wTerminalType: 0x0101 (USB streaming)
bAssocTerminal: 0x00
bNrChannels: 0x02
wChannelConfig: 0x0003
iChannelNames: 0x00
iTerminal: 0x00
      ===>Audio Control Output Terminal Descriptor<===
bLength: 0x09
bDescriptorSubtype: 0x03
bTerminalID: 0x03
wTerminalType: 0x0301 (Speaker)
bAssocTerminal: 0x02
bSourceID: 0x02
iTerminal: 0x00
      ===>Audio Control Feature Unit Descriptor<===
bLength: 0x09
bDescriptorSubtype: 0x06
bUnitID: 0x02
bSourceID: 0x01
bControlSize: 0x02
bmaControls[0]: 03 00
iFeature: 0x00
bLength: 0x09
bInterfaceNumber: 0x01
bNumEndpoints: 0x00
bInterfaceSubClass: 0x02 → Audio Streaming Interface SubClass
iInterface: 0x00
bLength: 0x09
bAlternateSetting: 0x01
bNumEndpoints: 0x01
iInterface: 0x00
      ===>Audio Streaming Class Specific Interface Descriptor<===
bLength: 0x07
bTerminalLink: 0x01
bDelay: 0x01
wFormatTag: 0x0001 (PCM)
      ===>Audio Streaming Format Type Descriptor<===
bLength: 0x0B
bFormatType: 0x01
bNrChannels: 0x02
bSubframeSize: 0x02
bBitResolution: 0x10
bSamFreqType: 0x01
tSamFreq[1]: 0x00BB80 (48000 Hz)
      ===>Endpoint Descriptor<===
bLength: 0x09
bDescriptorType: 0x05
bEndpointAddress: 0x02 → Direction: OUT - EndpointID: 2
bmAttributes: 0x09 → Isochronous Transfer Type, Synchronization Type = Adaptive, Usage Type = Data Endpoint
wMaxPacketSize: 0x00C8 = 1 transactions per microframe, 0xC8 max bytes
wInterval: 0x0004
bSyncAddress: 0x00
      ===>Audio Streaming Class Specific Audio Data Endpoint Descriptor<===
bLength: 0x07
bDescriptorType: 0x25
bmAttributes: 0x01
bLockDelayUnits: 0x01
wLockDelay: 0x0001
您好,您的问题解决了么?
我这边也调适这块。遇到类似问题。
呼喚大神! 懇請開示, 感恩^^
在吗
windows怎么识别呢
woody.lee 发表于 2016-5-20 14:39
另外, dmesg 常可見
[14196. …
楼主现在还在吗,这个问题解决了吗?????
