(以太网)默认启用静态IP
1.frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java
private void loadSystemSettings(SQLiteDatabase db) { 下增加:
   / 增加默认静态IP 端口,子网掩码等设置
        loadBooleanSetting(stmt, Settings.System.ETHERNET_USE_STATIC_IP,
                R.bool.def_ethernet_use_static_ip);//默认启用静态IP
    loadStringSetting(stmt, Settings.System.ETHERNET_STATIC_IP,
                R.string.def_ethernet_static_ip);
    loadStringSetting(stmt, Settings.System.ETHERNET_STATIC_GATEWAY,
                R.string.def_ethernet_static_gateway);
    loadStringSetting(stmt, Settings.System.ETHERNET_STATIC_NETMASK,
                R.string.def_ethernet_static_netmask);
    loadStringSetting(stmt, Settings.System.ETHERNET_STATIC_DNS1,
                R.string.def_ethernet_static_dns1);2.    frameworks/base/packages/SettingsProvider/res/values/defaults.xml
<!--luyq add Default for static IP port,gateway dns-->
<bool name="def_ethernet_on">true</bool>
<bool name="def_ethernet_use_static_ip">true</bool>
<string name="def_ethernet_static_ip">192.168.1.102</string>
<string name="def_ethernet_static_gateway">192.168.1.101</string>
<string name="def_ethernet_static_netmask">255.255.255.0</string>
<string name="def_ethernet_static_dns1">192.168.1.101</string>
<string name="def_ethernet_static_dns2">8.8.8.8</string>
3.如果时5.1.1的话,由于sdk的问题,通过Settings.System.ETHERNET_USE_STATIC_IP默认启用静态ip无效,
目前Bug已修复,在修复后的sdk没推送出去前,如果想要默认启用静态ip的话,可以打上如下补丁
0001-Settings.System.ETHERNET_USE_STATIC_IP-ip 3128-5.1补丁
0001-Settings.System.ETHERNET_USE_STATIC_IP-ip.patch.tar.gz (1.89 KB)
3288-5.1_0001-Android-Eth-Settings.System.ETHERNET_USE_STATIC_IP-i.patch 3288-5.1补丁
3288-5.1_0001-Android-Eth-Settings.System.ETHERNET_USE_STATIC_IP-i.patch.tar.gz (2.18 KB)
不知道你在说什么
pqy 发表于 2016-5-24 17:35
不知道你在说什么
:L以太网设置静态ip
好东西,多谢版主分享。不过,DatabaseHelper.java里面少了DNS2.
5.1的还没试。4.4一次通过,没有问题。
very good
学习下
好想看一下程序
编译过程中报错:
ETHERNET_USE_STATIC_IP cannot be resolved or is not a field
ETHERNET_STATIC_IP cannot be resolved or is not a field
ETHERNET_STATIC_GATEWAY cannot be resolved or is not a field
ETHERNET_STATIC_NETMASK cannot be resolved or is not a field
ETHERNET_STATIC_DNS1 cannot be resolved or is not a field
wanglf1029 发表于 2019-4-2 10:09
编译过程中报错:
ETHERNET_STATIC_IP ca …
安卓8.1的源码
wanglf1029 发表于 2019-4-2 10:11
安卓8.1的源码
android8.1的话,我给个例子给你看一下吧
FToolBox.java.tar.gz (2.32 KB)
什么意思?是要我找到对应的这个文件中去手动赋值? 这个文件在哪
我要再apk里设置静态ip要怎么做
true
true
楼主 你的这两行在哪里用到?
make
