自己画的板子,hdmi不能显示,求救!!!
各位大神,
我们根据rk3288-reload板子的原理图,自己画了一块板子出来,只留了一个HDMI接口,现在这个HDMI接口不能显示画面,报的错误是EDID不能解析,但是我们的板子画的都是一样的,硬件都检查了,没有短路,断路情况,电压也正常,I2C5 是5V, HDP也是5V。
报错log如下:
下面是拔出时的log:
shell@firefly:/ $
shell@firefly:/ $
shell@firefly:/ $ [ 18.309976] android_usb gadget: high-speed config #1: android
[ 18.310853] android_work: sent uevent USB_STATE=CONFIGURED
[ 47.926217] [EDID] check header error
[ 47.926249] rockchip-hdmiv2 ff980000.hdmi: warning: no CEA video mode parsed from EDID !!!
[ 47.926483] hdmi output corlor mode is 1
[ 47.926502] hdmi connect to lcdc1
[ 47.926515] switch:en=1,lcdc_id=1,screen type=6,cur type=1
[ 48.123482] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 48.123794] pixel clk is 74250000 tmds clk is 74250000
[ 48.123829] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output DVI.
[ 51.934557] hdmi remove from lcdc1
下面是插入时的log
[ 51.934583] switch:en=0,lcdc_id=1,screen type=6,cur type=6
[ 52.131462] rk3288-lcdc lcdc1: no layer is used,go to standby!
[ 60.177022] [EDID] check header error
[ 60.177055] rockchip-hdmiv2 ff980000.hdmi: warning: no CEA video mode parsed from EDID !!!
[ 60.177165] hdmi output corlor mode is 1
[ 60.177181] hdmi connect to lcdc1
[ 60.177194] switch:en=1,lcdc_id=1,screen type=6,cur type=6
[ 60.374039] rk3288_load_screen,clk_on = 0
[ 60.374123] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 60.374139] rk3288-lcdc lcdc1: wakeup from standby!
[ 60.472986] pixel clk is 74250000 tmds clk is 74250000
[ 60.473029] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output DVI.
[ 60.483439] hdmi remove from lcdc1
[ 60.483455] switch:en=0,lcdc_id=1,screen type=6,cur type=6
[ 60.680368] rk3288-lcdc lcdc1: no layer is used,go to standby!
reload板子原理图
我们板子原理图:
请各位大神看看,帮忙给点提示!
问题解决了没,谢谢
akanjyy 发表于 2016-7-7 11:06
问题解决了没,谢谢
同问
问题解决了没,谢谢
还是硬件那边没焊好
bartfj 发表于 2016-7-7 16:04
同问
硬件问题
edid,是hdmi加密hdcp,需要在e2prom追加写入edid码就可以了,
