使用交叉编译工具编译开源sdl2,配置生成不了makefile的问题?
其中我使用的配置选项为:
./configure --prefix=/work/walkera_vr/opensrc-lib/vr_lib/sdl2.0.3 --target=arm-eabi --host=arm-eabi --enable-shared=yes --enable-audio=yes --enable-video=yes --enable-render=yes --enable-events=yes --disable-joystick --enable-threads --enable-timers --enable-file --enable-oss --enable-alsa --disable-alsatest --enable-pthreads=yes --enable-video-directfb=yes --enable-directfb-shared=yes --disable-video-dummy --enable-video-opengl --enable-video-opengles
配置信息输出:
checking build system type… x86_64-unknown-linux-gnu
checking host system type… arm-unknown-eabi
checking how to print strings… printf
checking for arm-eabi-gcc… no
checking for gcc… gcc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… no
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking for a sed that does not truncate output… /bin/sed
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for fgrep… /bin/grep -F
checking for ld used by gcc… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for BSD- or MS-compatible name lister (nm)… no
checking for arm-eabi-dumpbin… no
checking for arm-eabi-link… no
checking for dumpbin… no
checking for link… link -dump
checking the name lister (nm) interface… BSD nm
checking whether ln -s works… yes
checking the maximum length of command line arguments… 1572864
checking whether the shell understands some XSI constructs… yes
checking whether the shell understands “+=”… yes
checking how to convert x86_64-unknown-linux-gnu file names to arm-unknown-eabi format… func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format… func_convert_file_noop
checking for /usr/bin/ld option to reload object files… -r
checking for arm-eabi-objdump… no
checking for objdump… objdump
checking how to recognize dependent libraries… unknown
checking for arm-eabi-dlltool… no
checking for dlltool… no
checking how to associate runtime and link libraries… printf %s\n
checking for arm-eabi-ar… no
checking for ar… ar
checking for archiver @FILE support… @
checking for arm-eabi-strip… no
checking for strip… strip
checking for arm-eabi-ranlib… no
checking for ranlib… ranlib
checking for gawk… no
checking for mawk… mawk
checking command to parse nm output from gcc object… ok
checking for sysroot… no
checking for arm-eabi-mt… no
checking for mt… mt
checking if mt is a manifest tool… no
checking how to run the C preprocessor… gcc -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking for dlfcn.h… yes
checking for objdir… .libs
checking if gcc supports -fno-rtti -fno-exceptions… no
checking for gcc option to produce PIC… -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works… yes
checking if gcc static flag -static works… yes
checking if gcc supports -c -o file.o… yes
checking if gcc supports -c -o file.o… (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries… yes
checking whether -lc should be explicitly linked in… no
checking dynamic linker characteristics… no
checking how to hardcode library paths into programs… immediate
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… no
checking whether to build shared libraries… no
checking whether to build static libraries… yes
checking for arm-eabi-gcc… gcc
checking whether we are using the GNU C compiler… (cached) yes
checking whether gcc accepts -g… (cached) yes
checking for gcc option to accept ISO C89… (cached) none needed
checking for arm-eabi-g++… no
checking for arm-eabi-c++… no
checking for arm-eabi-gpp… no
checking for arm-eabi-aCC… no
checking for arm-eabi-CC… no
checking for arm-eabi-cxx… no
checking for arm-eabi-cc++… no
checking for arm-eabi-cl.exe… no
checking for arm-eabi-FCC… no
checking for arm-eabi-KCC… no
checking for arm-eabi-RCC… no
checking for arm-eabi-xlC_r… no
checking for arm-eabi-xlC… no
checking for g++… g++
checking whether we are using the GNU C++ compiler… yes
checking whether g++ accepts -g… yes
checking how to run the C++ preprocessor… g++ -E
checking for ld used by g++… /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries… no
checking for g++ option to produce PIC… -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works… yes
checking if g++ static flag -static works… yes
checking if g++ supports -c -o file.o… yes
checking if g++ supports -c -o file.o… (cached) yes
checking for a BSD-compatible install… /usr/bin/install -c
checking whether make sets $(MAKE)… yes
checking for arm-eabi-windres… no
checking for windres… no
checking for an ANSI C-conforming const… yes
checking for inline… inline
checking for working volatile… yes
checking for GCC -MMD -MT option… yes
checking for linker option --no-undefined… yes
checking for ANSI C header files… (cached) yes
checking for sys/types.h… (cached) yes
checking stdio.h usability… yes
checking stdio.h presence… yes
checking for stdio.h… yes
checking for stdlib.h… (cached) yes
checking stddef.h usability… yes
checking stddef.h presence… yes
checking for stddef.h… yes
checking stdarg.h usability… yes
checking stdarg.h presence… yes
checking for stdarg.h… yes
checking malloc.h usability… yes
checking malloc.h presence… yes
checking for malloc.h… yes
checking for memory.h… (cached) yes
checking for string.h… (cached) yes
checking for strings.h… (cached) yes
checking for inttypes.h… (cached) yes
checking for stdint.h… (cached) yes
checking ctype.h usability… yes
checking ctype.h presence… yes
checking for ctype.h… yes
checking math.h usability… yes
checking math.h presence… yes
checking for math.h… yes
checking iconv.h usability… yes
checking iconv.h presence… yes
checking for iconv.h… yes
checking signal.h usability… yes
checking signal.h presence… yes
checking for signal.h… yes
checking for size_t… yes
checking for M_PI in math.h… yes
checking for working alloca.h… yes
checking for alloca… yes
checking for working memcmp… yes
checking for working strtod… yes
checking for mprotect… yes
checking for malloc… yes
checking for calloc… yes
checking for realloc… yes
checking for free… yes
checking for getenv… yes
checking for setenv… yes
checking for putenv… yes
checking for unsetenv… yes
checking for qsort… yes
checking for abs… yes
checking for bcopy… yes
checking for memset… yes
checking for memcpy… yes
checking for memmove… yes
checking for strlen… yes
checking for strlcpy… no
checking for strlcat… no
checking for strdup… yes
checking for _strrev… no
checking for _strupr… no
checking for _strlwr… no
checking for strchr… yes
checking for strrchr… yes
checking for strstr… yes
checking for itoa… no
checking for _ltoa… no
checking for _uitoa… no
checking for _ultoa… no
checking for strtol… yes
checking for strtoul… yes
checking for _i64toa… no
checking for _ui64toa… no
checking for strtoll… yes
checking for strtoull… yes
checking for atoi… yes
checking for atof… yes
checking for strcmp… yes
checking for strncmp… yes
checking for _stricmp… no
checking for strcasecmp… yes
checking for _strnicmp… no
checking for strncasecmp… yes
checking for vsscanf… yes
checking for vsnprintf… yes
checking for fseeko… yes
checking for fseeko64… yes
checking for sigaction… yes
checking for setjmp… yes
checking for nanosleep… yes
checking for sysconf… yes
checking for sysctlbyname… no
checking for pow in -lm… yes
checking for atan… yes
checking for atan2… yes
checking for acos… yes
checking for asin… yes
checking for ceil… yes
checking for copysign… yes
checking for cos… yes
checking for cosf… yes
checking for fabs… yes
checking for floor… yes
checking for log… yes
checking for pow… yes
checking for scalbn… yes
checking for sin… yes
checking for sinf… yes
checking for sqrt… yes
checking for iconv_open in -liconv… no
checking for iconv… yes
checking for struct sigaction.sa_sigaction… yes
checking for GCC builtin atomic operations… yes
checking for GCC -mmmx option… yes
checking for GCC -m3dnow option… yes
checking for GCC -msse option… yes
checking for Altivec with GCC altivec.h and -maltivec option… no
checking for Altivec with GCC -maltivec option… no
checking for Altivec with GCC altivec.h and -faltivec option… no
checking for Altivec with GCC -faltivec option… no
configure: error:
*** Unsupported host: Please add to configure.in
对于这种问题,是我哪里用的不对,还是什么问题?有人能解答一下不?
之前使用hisi3531的配置交叉编译工具是没问题的,可以编译正常的
