nandflah识别问题
现在板子出现无法找到/dev/block/mtd/by-name/linuxroot问题,仔细看log发现无法识别出nandflash的分区,目前现在板子启动系统的方式是通过将根文件系统放在u盘上,通过修改parameter文件的root路径来启动系统,查看/dev目录下的文件发现没有相应的rknand_分区。请问出现这种问题的原因是什么?
启动log如下
DDR Version 2.01 201401008
1A1A1B1B   3
DDR3
1A1B1B1B   F
Bus Width=32 Col=10 Bank=8 Row=14 CS=1 Die Bus-Width=16 Size=512MB
mach:1
2.18 1
ChipType = 9
No.1 FLASH ID:ad de 94 eb 74 44
U-Boot 2014.10-RK3128-10 (Dec 28 2015 - 14:53:17)
CPU: rk3128
CPU's clock information:
    arm pll = 300000000HZ
    periph pll = 594000000HZ
    ddr pll = 600000000HZ
    codec pll = 400000000HZ
Board:  Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks:1
Adding bank:0000000060000000(0000000020000000)
128 MiB
rk dmainit OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk312x!
Unknow param: MACHINE_ID:007!
power key: bank-3 pin-23
can't find dts node for ricoh619
can't find dts node for act8846
can't find dts node for rk808
pmic rk818 i2c probe failed
device rt5025 is disabled
device rt5036 is disabled
No pmic detect.
can't find dts node for ADC
Enter power_led_init
#Boot ver: 2014-10-31#2.19
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
read logo_on switch from dts [1]
can't find power_ctr node for lcdc0
no fuel gauge found
failed to find part:logo
Hit any key to stop autoboot:  0
load fdt from resouce.
Secure Boot state: 0
kernel   @ 0x62000000 (0x0069ab50)
ramdisk  @ 0x65bf0000 (0x0029a22c)
bootrk: do_bootm_linux...
   Loading Device Tree to 65600000, end 65616640 ... OK
Add bank:0000000060000000, 0000000020000000
Starting kernel ...
<hit enter to activate fiq debugger>
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.0+ (rk3128@rk3128-ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #2 SMP PREEMPT Fri May 27 17:40:26 CST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128
[    0.000000] rockchip_uboot_logo_setup: mem: 2000000@7dc00000, offset:0
[    0.000000] rockchip_uboot_mem_reserve: reserve 2000000@7dc00000 for uboot logo
[    0.000000] rockchip_ion_reserve
[    0.000000] ion heap(cma): base(0) size(800000) align(0)
[    0.000000] ion heap(vmalloc): base(0) size(0) align(0)
[    0.000000] cma: CMA: reserved 8 MiB at 7d400000
[    0.000000] ion_reserve: cma reserved base 7d400000 size 8388608
[    0.000000] cma: CMA: reserved 16 MiB at 7c400000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] PERCPU: Embedded 9 pages/cpu @c1256000 s14016 r8192 d14656 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0,115200 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/init  mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00010000@0x0000E000(boot),0x00020000@0x0001E000(backup),-@0x0003E000(linuxroot) storagemedia=nand uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2015-12-28_14:53:17
[    0.000000] rockchip jtag enabled
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 443792k/443792k available, 80496k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0b96164   (11833 kB)
[    0.000000]       .init : 0xc0b97000 - 0xc0bf16c0   ( 362 kB)
[    0.000000]       .data : 0xc0bf2000 - 0xc0d0ceb8   (1132 kB)
[    0.000000]        .bss : 0xc0d0ceb8 - 0xc0e2e47c   (1158 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[    0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[    0.000000] rkclk_init_clks: cnt_parent = 25
[    0.000000] rkclk_init_clks: cnt_rate = 17
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
[    0.000000] process version: 0
[    0.000000] channel:0, lkg:39
[    0.000000] target-temp:85
[    0.000000] FirePrime hardware version: V01
[    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[    0.000000] Console: colour dummy device 80x30
[    0.090859] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.090885] pid_max: default: 32768 minimum: 301
[    0.091082] Security Framework initialized
[    0.091110] SELinux:  Initializing.
[    0.091244] Mount-cache hash table entries: 512
[    0.092456] Initializing cgroup subsys debug
[    0.092484] Initializing cgroup subsys memory
[    0.092536] Initializing cgroup subsys freezer
[    0.092597] CPU: Testing write buffer coherency: ok
[    0.093119] /cpus/cpu@0 missing clock-frequency property
[    0.093147] /cpus/cpu@1 missing clock-frequency property
[    0.093167] /cpus/cpu@2 missing clock-frequency property
[    0.093186] /cpus/cpu@3 missing clock-frequency property
[    0.093257] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.093327] Setting up static identity map for 0xc0847a30 - 0xc0847a88
[    0.095108] last_log: 0x7c100000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x15de (version 3.0)
[    0.168641] CPU1: Booted secondary processor
[    0.168696] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.188361] CPU2: Booted secondary processor
[    0.188405] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.208101] CPU3: Booted secondary processor
[    0.208146] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.208333] Brought up 4 CPUs
[    0.208385] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.208400] CPU: All CPU(s) started in SVC mode.
[    0.209803] devtmpfs: initialized
[    0.219329] pinctrl core: initialized pinctrl subsystem
[    0.219828] regulator-dummy: no parameters
[    0.221337] NET: Registered protocol family 16
[    0.224403] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.225163] ion_snapshot: 0x7c218000 map to 0xe0907000 and copy to 0xc0e09a04 (version 0.1)
[    0.225388] Registered FIQ tty driver
[    0.227686] console [ttyFIQ0] enabled
[    0.228066] Registered fiq debugger ttyFIQ0
[    0.229515] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff
[    0.229651] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff
[    0.229733] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff
[    0.229809] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff
[    0.229897] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff
[    0.229969] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5
[    0.230000] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7
[    0.230028] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3
[    0.230056] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137
[    0.230084] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103
[    0.232779] rockchip_pinctrl_probe:init ok
[    0.240510] rk_iommu 1010e300.vop_mmu: (vop) Enter
[    0.240567] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq
[    0.240659] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.240687] rk_iommu 1010e300.vop_mmu: (vop) Initialized
[    0.240960] rk_iommu 10104440.hevc_mmu: (hevc) Enter
[    0.241106] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.241140] rk_iommu 10104440.hevc_mmu: (hevc) Initialized
[    0.241413] rk_iommu 10106800.vpu_mmu: (vpu) Enter
[    0.241541] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.241572] rk_iommu 10106800.vpu_mmu: (vpu) Initialized
[    0.241822] rk_iommu 10108800.iep_mmu: (iep) Enter
[    0.241949] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.241981] rk_iommu 10108800.iep_mmu: (iep) Initialized
[    0.243572] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.243601] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.243885] DDR DEBUG: version 1.02 20140828
[    0.243907] DDR DEBUG: DRAM Type:DDR3
[    0.243932] DDR DEBUG: 1 CS, ROW=14, Bank=8, COL=10, Total Capability=512MB
[    0.243978] DDR DEBUG: init success!!! freq=300MHz
[    0.297854] bio: create slab <bio-0> at 0
[    0.298854] Rockchip hdmi driver version 2.0
[    0.300646] SCSI subsystem initialized
[    0.301017] usbcore: registered new interface driver usbfs
[    0.301125] usbcore: registered new interface driver hub
[    0.301330] usbcore: registered new device driver usb
[    0.303532] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter
[    0.305655] media: Linux media interface: v0.10
[    0.305748] Linux video capture interface: v2.00
[    0.305975] pps_core: LinuxPPS API ver. 1 registered
[    0.306001] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.306115] PTP clock support registered
[    0.306221] i2c-core: driver [bq24296] using legacy suspend method
[    0.306243] i2c-core: driver [bq24296] using legacy resume method
[    0.307711] Rockchip ion module is successfully loaded (v1.1)
[    0.307981] Advancedver Initialized.
[    0.308732] Bluetooth: Core ver 2.16
[    0.308813] NET: Registered protocol family 31
[    0.308837] Bluetooth: HCI device and connection manager initialized
[    0.308881] Bluetooth: HCI socket layer initialized
[    0.308912] Bluetooth: L2CAP socket layer initialized
[    0.308969] Bluetooth: SCO socket layer initialized
[    0.309419] cfg80211: Calling CRDA to update world regulatory domain
[    0.311043] act8931_i2c_probe,line=715
[    0.311851] The device is not act8931
[    0.313808] Switching to clocksource arch_sys_counter
[    0.350373] fb disp policy is box
[    0.350478] rk-fb rockchip-fb: rk fb ion client create success!
[    0.350507] rk-fb rockchip-fb: rockchip framebuffer driver probe
[    0.351002] rk-screen rk_screen.9: rockchip screen probe success
[    0.351565] rk31xx-lvds 20038000.lvds: screen is not lvds/rgb!
[    0.351613] rk31xx-lvds: probe of 20038000.lvds failed with error -22
[    0.352656] rk312x-lcdc lcdc0: can't find power_ctr node for lcdc0
[    0.352685] rk_fb_trsm_ops_get:un supported transmitter:6!
[    0.353204] graphics fb0: rockchip framebuffer registerd:fb0
[    0.353975] graphics fb1: rockchip framebuffer registerd:fb1
[    0.354362] graphics fb2: rockchip framebuffer registerd:fb2
[    0.354987] rk312x-lcdc lcdc0: set lcdc0 dclk failed
[    0.355021] rk312x-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[    0.355047] rk312x-lcdc lcdc0: wakeup from standby!
[    0.367006] alloc_buffer:ion_phy_addr=0x10000000
[    0.374148] fb0:phy:10000000>>vir:e0930000>>len:0xb00000
[    0.390287] rk312x-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[    0.406683] NET: Registered protocol family 2
[    0.407572] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.407705] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.407819] TCP: Hash tables configured (established 4096 bind 4096)
[    0.407903] TCP: reno registered
[    0.407933] UoPdias, tlblseewaiie..
                                       56 (order: 1, 8192 bytes)
[    0.407980] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.408360] NET: Registered protocol family 1
[    0.409260] Unpacking initramfs...
[    0.685802] Freeing initrd memory: 2664K (c5bf0000 - c5e8a000)
[    0.687058] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available
s[ k3 0x68n78k] koo3de0_s+rv Ne:sNohrfsee rr ourcetdeyine
[    0.687878] vcodec_service: No reset resource define
[    0.687902] vcodec_service: No reset resource define
[    0.688024] vcodec vpu_combo.10: failed on clk_get clk_cabac
[    0.688132] vcodec_service: vpu_combo.10: power on
[    0.688274] vcodec_service: probe device 10106000.vpu_service
[    0.688332] vcodec_service: checking hw id 4831
[    0.689657] vcodec_service: probe device 10104000.hevc_service
[    0.689719] vcodec_service: checking hw id 6867
[    0.690723] vcodec_service: vpu_combo.10: power off...
[    0.690794] vcodec_service: done
[    0.690814] vcodec_service: init success
[    0.690970] rknandbase v1.0 2014-03-31
[    0.691222] rknand_probe clk rate = 148500000
[    0.691401] rknand_driver:ret = 0
[    0.692174] rk_dts_sensor_probe:Get s5k4ec rockchip,power failed!
[    0.692215] s5k4ec_io==1
[    0.692266] the gpiorst1 is 107
[    0.692296] the gpiorst2 is 107
[    0.692351] rk_dts_sensor_probe:Get ov2659 rockchip,power failed!
[    0.692382] s5k4ec_io==2
[    0.692435] rk_dts_sensor_probe:Get gc0329 rockchip,power failed!
[    0.692467] s5k4ec_io==2
[    0.692503] rk_dts_sensor_probe:Get gc2035 rockchip,powerdown failed!
[    0.692533] s5k4ec_io==2
[    0.692576] s5k4ec_io==2
[    0.694157] audit: initializing netlink socket (disabled)
[    0.694231] type=2000 audit(0.600:1): initialized
[    0.705893] fuse init (API version 7.22)
[    0.706707] msgmni has been set to 919
[    0.709960] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.709999] io scheduler noop registered
[    0.710019] io scheduler deadline registered
[    0.710218] io scheduler cfq registered (default)
[    0.715597] rga 1010c000.rga: rga ion client create success!
[    0.715915] rga: Driver loaded succesfully
[    0.716038] rga: Module initialized.
[    0.796504] rk_battery_charger_detect_cb , battery_charger_detect 2
[    0.825889] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode 0 --> 1
[    0.825924] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode LOWER_PWR
[    0.826027] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode 1 --> 0
[    0.826060] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode NORMAL
[    0.826103] rk-hdmi 20034000.hdmi: EDID DATA (Segment = 0 Block = 0 Offset = 0):
[    0.838266] rk-hdmi 20034000.hdmi: [rockchip_hdmiv1_read_edid] edid read sucess
[    0.838353] rk-hdmi 20034000.hdmi: EDID DATA (Segment = 0 Block = 1 Offset = 128):
[    0.850554] rk-hdmi 20034000.hdmi: [rockchip_hdmiv1_read_edid] edid read sucess
[    0.850633] ******** Show Sink Info ********
[    0.850654] Max tmds clk is 0
[    0.850670] Support video mode:
[    0.850686]  1920x1080p@60Hz
[    0.850702]  1920x1080p@50Hz
[    0.850717]  1920x1080p@24Hz
[    0.850733]  1920x1080i@60Hz
[    0.850748]  1920x1080i@50Hz
[    0.850764]  1280x720p@60Hz
[    0.850779]  1280x720p@50Hz
[    0.850794]  720x576p@50Hz
[    0.850810]  720x576i@50Hz
[    0.850825]  720x480p@60Hz
[    0.850840]  720x480i@60Hz
[    0.850856] Support video color mode:
[    0.850871]  RGB
[    0.850885]  YCbCr422
[    0.850900]  YCbCr444
[    0.850915] Support video color depth:
[    0.850930]  24bit
[    0.850945] Support audio type:
[    0.850961]  LPCM
[    0.850976] Support max audio channel is 2
[    0.850993] Support audio sample rate:
[    0.851009]  32000
[    0.851023]  44100
[    0.851037]  48000
[    0.851052] Support audio word lenght:
[    0.851067]  16bit
[    0.851081]  20bit
[    0.851095]  24bit
[    0.851109]
[    0.851123] ******** Show Sink Info ********
[    0.851164] hdmi output corlor mode is 3
[    0.851190] hdmi connect to lcdc0
[    0.851220] rk-hdmi 20034000.hdmi: [rockchip_hdmiv1_video_csc] input_color=3,output_color=3
[    0.851254] rk-hdmi 20034000.hdmi: [rockchip_hdmiv1_config_video] sucess output HDMI.
[    0.851739] rk-hdmi 20034000.hdmi: hdmi probe success.
[    0.852701] IEP Power ON
[    0.852780] iep ion client create success!
[    0.853237] IEP Power OFF
[    0.853272] IEP Driver loaded succesfully
[    0.853414] Module initialized.
[    0.853868] rk3036-tve 1010e200.tve: rockchip,rk312x-tve tv encoder probe ok
[    0.856786] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-2364208
[    0.856827] dma-pl330 20078000.pdma:         DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16
[    0.857696] rk_serial.c v1.8 2014-03-04
[    0.858043] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 52) is a rk29_serial.0
[    0.858508] serial 20060000.serial: membase e3452000
[    0.864718] loop: module loaded
[    0.864850] i2c-core: driver [mpu6050B1] using legacy suspend method
[    0.864875] i2c-core: driver [mpu6050B1] using legacy resume method
[    0.864901] mpu_init: Probe name mpu6050B1
[    0.865261] ak8963_mod_init: Probe name ak8963_mod
[    0.866490] SCSI Media Changer driver v0.25
[    0.867104] tun: Universal TUN/TAP device driver, 1.6
[    0.867132] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.867447] vmac_init.
[    0.868557] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[    0.868588] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[    0.868612] stmmac_probe_config_dt: clock input or output? (input).
[    0.868635] stmmac_probe_config_dt: TX delay(0x30).
[    0.868657] stmmac_probe_config_dt: RX delay(0x10).
[    0.868756] stmmac_probe_config_dt: is rockchip,rk312x-gmac
[    0.868775] stmmc_pltfr_init:
[    0.868794] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[    0.868888] stmmc_pltfr_init: init for RGMII
[    0.868912] tx delay=0x30
[    0.868912] rx delay=0x10
[    0.869144] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    0.869165]  Normal descriptors
[    0.869182]  Ring mode enabled
[    0.869199]  DMA HW capability register supported
[    0.869219]  RX Checksum Offload Engine supported (type 2)
[    0.869238]  TX Checksum insertion supported
[    0.869255]  Wake-Up On Lan supported
[    0.869333]  Enable RX Mitigation via HW Watchdog Timer
[    0.870216] PPP generic driver version 2.4.2
[    0.870588] PPP BSD Compression module registered
[    0.870615] PPP Deflate Compression module registered
[    0.870650] PPP MPPE Compression module registered
[    0.870673] NET: Registered protocol family 24
[    0.870728] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    0.870753] CSLIP: code copyright 1989 Regents of the University of California.
[    0.870776] Rockchip WiFi SYS interface (V1.00) ...
[    0.870849] esp_mem_init enter date May 27 2016 15:23:45
[    0.870870] esp_mem_init VERSION [V2.5]
[    0.870949] esp_mem_init complete
[    0.871077] usbcore: registered new interface driver catc
[    0.871164] usbcore: registered new interface driver kaweth
[    0.871191] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    0.871274] usbcore: registered new interface driver pegasus
[    0.871359] usbcore: registered new interface driver rtl8150
[    0.871441] usbcore: registered new interface driver r8152
[    0.871464] hso: drivers/net/usb/hso.c: Option Wireless
[    0.871637] usbcore: registered new interface driver hso
[    0.871740] usbcore: registered new interface driver asix
[    0.871827] usbcore: registered new interface driver ax88179_178a
[    0.871912] usbcore: registered new interface driver cdc_ether
[    0.871997] usbcore: registered new interface driver cdc_eem
[    0.872080] usbcore: registered new interface driver dm9601
[    0.872175] usbcore: registered new interface driver dm9620
[    0.872281] usbcore: registered new interface driver smsc75xx
[    0.872387] usbcore: registered new interface driver smsc95xx
[    0.872473] usbcore: registered new interface driver gl620a
[    0.872557] usbcore: registered new interface driver net1080
[    0.872641] usbcore: registered new interface driver plusb
[    0.872736] usbcore: registered new interface driver rndis_host
[    0.872824] usbcore: registered new interface driver cdc_subset
[    0.872906] usbcore: registered new interface driver zaurus
[    0.872994] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    0.873133] usbcore: registered new interface driver int51x1
[    0.873219] usbcore: registered new interface driver kalmia
[    0.873304] usbcore: registered new interface driver ipheth
[    0.873408] usbcore: registered new interface driver sierra_net
[    0.873498] usbcore: registered new interface driver cx82310_eth
[    0.873607] usbcore: registered new interface driver cdc_ncm
[    0.873693] usbcore: registered new interface driver qmi_wwan
[    0.873779] usbcore: registered new interface driver cdc_mbim
[    0.873801] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.875744] EHCI: ehci_rk_probe e3480000 e3480010
[    0.875783] rockchip_ehci_host 101c0000.usb: EHCI Host Controller
[    0.875854] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1
[    0.876478] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000
[    0.894511] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00
[    0.894665] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.894696] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.894723] usb usb1: Product: EHCI Host Controller
[    0.894747] usb usb1: Manufacturer: Linux 3.10.0+ ehci_hcd
[    0.894771] usb usb1: SerialNumber: 101c0000.usb
[    0.895692] hub 1-0:1.0: USB hub found
[    0.895744] hub 1-0:1.0: 1 port detected
[    0.896138] EHCI: ehci_rk_probe ok
[    0.896312] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.896532] ohci-rockchip 101e0000.usb: RK OHCI Host Controller
[    0.896589] ohci-rockchip 101e0000.usb: new USB bus registered, assigned bus number 2
[    0.896668] ohci-rockchip 101e0000.usb: irq 64, io mem 0x101e0000
[    0.957601] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    0.957635] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.957663] usb usb2: Product: RK OHCI Host Controller
[    0.957687] usb usb2: Manufacturer: Linux 3.10.0+ ohci_hcd
[    0.957711] usb usb2: SerialNumber: 101e0000.usb
[    0.958569] hub 2-0:1.0: USB hub found
[    0.958618] hub 2-0:1.0: 1 port detected
[    0.959271] usbcore: registered new interface driver cdc_acm
[    0.959298] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.959424] usbcore: registered new interface driver usblp
[    0.959525] usbcore: registered new interface driver cdc_wdm
[    0.959693] usbcore: registered new interface driver usb-storage
[    0.959782] usbcore: registered new interface driver ums-alauda
[    0.959865] usbcore: registered new interface driver ums-cypress
[    0.959949] usbcore: registered new interface driver ums-datafab
[    0.960031] usbcore: registered new interface driver ums_eneub6250
[    0.960114] usbcore: registered new interface driver ums-freecom
[    0.960198] usbcore: registered new interface driver ums-isd200
[    0.960280] usbcore: registered new interface driver ums-jumpshot
[    0.960363] usbcore: registered new interface driver ums-karma
[    0.960457] usbcore: registered new interface driver ums-onetouch
[    0.960543] usbcore: registered new interface driver ums-sddr09
[    0.960629] usbcore: registered new interface driver ums-sddr55
[    0.960713] usbcore: registered new interface driver ums-usbat
[    0.960906] usbcore: registered new interface driver usbserial
[    0.961002] usbcore: registered new interface driver usbserial_generic
[    0.961078] usbserial: USB Serial support registered for generic
[    0.961167] usbcore: registered new interface driver option
[    0.961248] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.961473] usbcore: registered new interface driver trancevibrator
[    0.961499] usb20_otg: version 3.10a 21-DEC-2012
[    0.962148] e3500040
[    0.962177] Core Release: 2.91a
[    0.962197] Setting default values for core params
[    0.962445] Using Buffer DMA mode
[    0.962471] Periodic Transfer Interrupt Enhancement - disabled
[    0.962491] Multiprocessor Interrupt Enhancement - disabled
[    0.962511] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.962529] ^^^^^^^^^^^^^^^^^Device Mode
[    0.962554] Dedicated Tx FIFOs mode
[    0.962589] pcd_init otg_dev = c5b34500
[    0.962877] usb20_otg 10180000.usb: DWC OTG Controller
[    0.962931] usb20_otg 10180000.usb: new USB bus registered, assigned bus number 3
[    0.963005] usb20_otg 10180000.usb: irq 42, io mem 0x00000000
[    0.963128] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    0.963160] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.963186] usb usb3: Product: DWC OTG Controller
[    0.963210] usb usb3: Manufacturer: Linux 3.10.0+ dwc_otg_hcd
[    0.963235] usb usb3: SerialNumber: 10180000.usb
[    0.964058] hub 3-0:1.0: USB hub found
[    0.964107] hub 3-0:1.0: 1 port detected
[    0.964716] usb20_host: version 3.10a 21-DEC-2012
[    0.965657] usbcore: registered new interface driver xpad
[    0.965773] usbcore: registered new interface driver usb_acecad
[    0.965870] usbcore: registered new interface driver aiptek
[    0.965963] usbcore: registered new interface driver gtco
[    0.966055] usbcore: registered new interface driver hanwang
[    0.966146] usbcore: registered new interface driver kbtab
[    0.966253] usbcore: registered new interface driver wacom
[    0.967045] sensor_register_slave:mma8452,id=17
[    0.967072] sensor_register_slave:gs_mc3230,id=23
[    0.967091] gsensor_init
[    0.967109] sensor_register_slave:mpu6880_acc,id=24
[    0.967129] sensor_register_slave:cm3217,id=47
[    0.967149] sensor_register_slave:cm3218,id=48
[    0.967532] .. rk pwm remotectl v1.1 init
[    0.967907] input: 20050030.pwm as /devices/20050030.pwm/input/input0
[    0.972019] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[    0.983770] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[    0.983856] i2c /dev entries driver
[    0.984474] IR NEC protocol handler initialized
[    0.984500] IR RC5(x) protocol handler initialized
[    0.984519] IR RC6 protocol handler initialized
[    0.984537] IR JVC protocol handler initialized
[    0.984554] IR Sony protocol handler initialized
[    0.984572] IR RC5 (streamzap) protocol handler initialized
[    0.984591] IR SANYO protocol handler initialized
[    0.984609] IR MCE Keyboard/mouse protocol handler initialized
[    0.985094] usbcore: registered new interface driver uvcvideo
[    0.985120] USB Video Class driver (1.1.1)
[    0.985144] CamSys driver version: v0.27.1,  CamSys head file version: v0.10.0
[    0.985169] E:camsys_soc_init(87): camsys isn't support soc: 0x31260001!
[    0.987231] i2c-core: driver [bq27320] using legacy suspend method
[    0.987262] i2c-core: driver [bq27320] using legacy resume method
[    0.988038] device-mapper: uevent: version 1.0.3
[    0.988582] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    0.989283] Bluetooth: HCI UART driver ver 2.2
[    0.989312] Bluetooth: HCI H4 protocol initialized
[    0.989331] Bluetooth: HCILL protocol initialized
[    0.989352] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.19
[    0.989373] rtk_btusb: Register usb char device interface for BT driver
[    0.989794] usbcore: registered new interface driver rtk_btusb
[    0.989901] DVFS ERR:        clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)!
[    0.989931] DVFS ERR:        clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)!
[    0.989959] DVFS ERR:        clk_enable_dvfs: vd(vd_arm) can't get regulator(vdd_arm)!
[    0.989982] cpufreq version 1.0, suspend freq 1008 MHz
[    0.990350] cpuidle: using governor ladder
[    0.990376] cpuidle: using governor menu
[    0.990447] Synopsys Designware Multimedia Card Interface Driver
[    0.990470] MHSC version = Ver 2.00 2015-06-10
[    0.990894] dw cru_regsbase addr 0x124.
[    0.990919] dw cru_reset_offset val 3.
[    0.990948] dwmmc_rockchip 1021c000.rksdmmc: Version ID is 270a
[    0.991009] dwmmc_rockchip 1021c000.rksdmmc: failed to get hpclk_mmc
[    0.991459] dwmmc_rockchip 1021c000.rksdmmc: Using external DMA controller.
[    0.991880] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc0]
[    0.992190] 1358..dw_mci_set_ios:  no card. [mmc0]
[    1.002752] 1358..dw_mci_set_ios:  no card. [mmc0]
[    1.022522] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[    1.022563] dwmmc_rockchip 1021c000.rksdmmc: DW MMC controller at irq 48, 32 bit host data width, 256 deep fifo
[    1.022597] dwmmc_rockchip 1021c000.rksdmmc: 1 slots initialized
[    1.023135] dw cru_regsbase addr 0x124.
[    1.023160] dw cru_reset_offset val 1.
[    1.023187] dwmmc_rockchip 10214000.rksdmmc: Version ID is 270a
[    1.023246] dwmmc_rockchip 10214000.rksdmmc: failed to get hpclk_mmc
[    1.023835] dwmmc_rockchip 10214000.rksdmmc: Using external DMA controller.
[    1.024248] dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1]
[    1.024363] mmc1: no vmmc regulator found
[    1.024694] 1358..dw_mci_set_ios:  no card. [mmc1]
[    1.042144] 1358..dw_mci_set_ios:  no card. [mmc1]
[    1.061827] 1358..dw_mci_set_ios:  no card. [mmc1]
[    1.061887] dwc_otg_hcd_suspend, usb device mode
[    1.062906] dwmmc_rockchip 10214000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo
[    1.062941] dwmmc_rockchip 10214000.rksdmmc: 1 slots initialized
[    1.063439] dw cru_regsbase addr 0x124.
[    1.063465] dw cru_reset_offset val 2.
[    1.063491] dwmmc_rockchip 10218000.rksdmmc: Version ID is 270a
[    1.063552] dwmmc_rockchip 10218000.rksdmmc: failed to get hpclk_mmc
[    1.063935] dwmmc_rockchip 10218000.rksdmmc: Using external DMA controller.
[    1.064341] dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc2]
[    1.064685] 1358..dw_mci_set_ios:  no card. [mmc2]
[    1.081493] 1358..dw_mci_set_ios:  no card. [mmc2]
[    1.101204] 1358..dw_mci_set_ios:  no card. [mmc2]
[    1.101281] dwmmc_rockchip 10218000.rksdmmc: DW MMC controller at irq 47, 32 bit host data width, 256 deep fifo
[    1.101316] dwmmc_rockchip 10218000.rksdmmc: 1 slots initialized
[    1.101736] leds-gpio leds.18: pins are not configured from the driver
[    1.102447] hidraw: raw HID events driver (C) Jiri Kosina
[    1.106935] usbcore: registered new interface driver usbhid
[    1.106965] usbhid: USB HID core driver
[    1.107847] zram: Created 1 device(s) ...
[    1.108774] ashmem: initialized
[    1.109102] logger: created 256K log 'log_main'
[    1.109425] logger: created 256K log 'log_events'
[    1.109732] logger: created 256K log 'log_radio'
[    1.110028] logger: created 256K log 'log_system'
[    1.112537] input: rk29-keypad as /devices/2006c000.adc/key.21/input/input1
[    1.114755] ------------[ cut here ]------------
[    1.114793] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[    1.114815] autorequest GPIO-27
[    1.114832] Modules linked in:
[    1.114861] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.0+ #2
[    1.114911] [<c0013e44>] (unwind_backtrace+0x0/0xe0) from [<c001175c>] (show_stack+0x10/0x14)
[    1.114953] [<c001175c>] (show_stack+0x10/0x14) from [<c0036278>] (warn_slowpath_common+0x4c/0x68)
[    1.114993] [<c0036278>] (warn_slowpath_common+0x4c/0x68) from [<c0036314>] (warn_slowpath_fmt+0x2c/0x3c)
[    1.115033] [<c0036314>] (warn_slowpath_fmt+0x2c/0x3c) from [<c02993ec>] (gpio_ensure_requested+0x4c/0xb4)
[    1.115073] [<c02993ec>] (gpio_ensure_requested+0x4c/0xb4) from [<c029a44c>] (gpiod_direction_input+0x58/0x1f0)
[    1.115117] [<c029a44c>] (gpiod_direction_input+0x58/0x1f0) from [<c06564b8>] (rk312x_platform_probe+0x46c/0x5a4)
[    1.115163] [<c06564b8>] (rk312x_platform_probe+0x46c/0x5a4) from [<c030c784>] (platform_drv_probe+0x14/0x18)
[    1.115205] [<c030c784>] (platform_drv_probe+0x14/0x18) from [<c030b54c>] (really_probe+0xa8/0x20c)
[    1.115244] [<c030b54c>] (really_probe+0xa8/0x20c) from [<c030b7a8>] (driver_probe_device+0x30/0x48)
[    1.115282] [<c030b7a8>] (driver_probe_device+0x30/0x48) from [<c030b820>] (__driver_attach+0x60/0x84)
[    1.115320] [<c030b820>] (__driver_attach+0x60/0x84) from [<c0309ffc>] (bus_for_each_dev+0x50/0x90)
[    1.115358] [<c0309ffc>] (bus_for_each_dev+0x50/0x90) from [<c030adac>] (bus_add_driver+0xac/0x20c)
[    1.115396] [<c030adac>] (bus_add_driver+0xac/0x20c) from [<c030bcfc>] (driver_register+0x9c/0x138)
[    1.115435] [<c030bcfc>] (driver_register+0x9c/0x138) from [<c00086a4>] (do_one_initcall+0x34/0xc8)
[    1.115478] [<c00086a4>] (do_one_initcall+0x34/0xc8) from [<c0b97b28>] (do_initcalls+0x70/0xa0)
[    1.115520] [<c0b97b28>] (do_initcalls+0x70/0xa0) from [<c0b97be8>] (kernel_init_freeable+0x90/0x130)
[    1.115563] [<c0b97be8>] (kernel_init_freeable+0x90/0x130) from [<c0825dc0>] (kernel_init+0x8/0xe4)
[    1.115603] [<c0825dc0>] (kernel_init+0x8/0xe4) from [<c000da98>] (ret_from_fork+0x14/0x3c)
[    1.115666] ---[ end trace 8a3943ebeb3b65da ]---
[    1.116068] This platfrom have not i2s_mclk,no need to set i2s_mclk.
[    1.116775] rockchip-spdif 10204000.spdif: spdif ready.
[    1.119799] audio-rk312x audio-rk312x.14:  rk312x-hifi <-> rockchip-i2s.1 mapping ok
[    1.121110] audio-rk312x audio-rk312x.14:  rk312x-voice <-> rockchip-i2s.1 mapping ok
[    1.121182] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
[    1.121212] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Jack -> direct -> Mic Bias
[    1.121242] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
[    1.121269] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias -> direct -> MICP
[    1.121298] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
[    1.121325] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias -> direct -> MICN
[    1.121354] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
[    1.121381] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Headset Jack -> direct -> Mic Bias
[    1.121410] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
[    1.121437] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR -> direct -> Ext Spk
[    1.121465] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
[    1.121492] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL -> direct -> Ext Spk
[    1.121521] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
[    1.121548] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR -> direct -> Headphone Jack
[    1.121577] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
[    1.121604] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL -> direct -> Headphone Jack
[    1.125116] rockchip-hdmi-spdif rockchip-hdmi-spdif.13:  rk-hdmi-spdif-hifi <-> 10204000.spdif mapping ok
[    1.126479] u32 classifier
[    1.126504]     Actions configured
[    1.126529] Netfilter messages via NETLINK v0.30.
[    1.126647] nf_conntrack version 0.5.0 (7359 buckets, 29436 max)
[    1.127454] ctnetlink v0.93: registering with nfnetlink.
[    1.127575] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    1.127599] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    1.128398] xt_time: kernel timezone is -0000
[    1.128933] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.129299] arp_tables: (C) 2002 David S. Miller
[    1.129401] TCP: cubic registered
[    1.129421] Initializing XFRM netlink socket
[    1.130174] NET: Registered protocol family 10
[    1.131692] mip6: Mobile IPv6
[    1.131768] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.132092] sit: IPv6 over IPv4 tunneling driver
[    1.133074] NET: Registered protocol family 17
[    1.133140] NET: Registered protocol family 15
[    1.133287] Bridge firewalling registered
[    1.133320] Ebtables v2.0 registered
[    1.133659] Bluetooth: RFCOMM TTY layer initialized
[    1.133729] Bluetooth: RFCOMM socket layer initialized
[    1.133753] Bluetooth: RFCOMM ver 1.11
[    1.133775] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.133795] Bluetooth: BNEP filters: protocol multicast
[    1.133828] Bluetooth: BNEP socket layer initialized
[    1.133851] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.133881] Bluetooth: HIDP socket layer initialized
[    1.133952] l2tp_core: L2TP core driver, V2.0
[    1.133991] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    1.134012] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    1.134300] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    1.134331] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[    1.134356] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    1.134379] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[    1.134403] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    1.134480] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 43, flags = 0.
[    1.134549] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 2, flags = 0.
[    1.134573] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    1.134624] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    1.134723] [BT_RFKILL]: Enter rfkill_rk_init
[    1.135065] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 17.
[    1.135135] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 35.
[    1.135181] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 42.
[    1.135227] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 41.
[    1.135330] [BT_RFKILL]: Request irq for bt wakeup host
[    1.135506] [BT_RFKILL]: ** disable irq
[    1.135740] [BT_RFKILL]: ap6212 device registered.
[    1.136172] rk_cam_cif(3083):rk312x-camera version: v0.1.14  Zoom by ipp
[    1.136337] rk_cif 1010a000.cif: rk_camera_cif_iomux:could not get cif_pin_all pinstate
[    1.136978] soc-camera-pdrv s5k4ec_back_3: Probing s5k4ec_back_3
[    1.137956] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    1.138006] rk312x_init_suspend
[    1.138025] rk312x_suspend_init
[    1.138416] Registering SWP/SWPB emulation handler
[    1.138448] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 2000000@7dc00000
[    1.148563] DVFS ERR:        clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)!
[    1.149559] ddrfreq: verion 1.2 20140526
[    1.149601] ddrfreq: normal 492MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 198MHz reboot 492MHz
[    1.149627] ddrfreq: auto-freq=0
[    1.149645] ddrfreq: auto-freq-table[0] 240MHz
[    1.149663] ddrfreq: auto-freq-table[1] 324MHz
[    1.149682] ddrfreq: auto-freq-table[2] 396MHz
[    1.149701] ddrfreq: auto-freq-table[3] 528MHz
[    1.151059] regulator-dummy: disabling
[    1.151343] =======================================================
[    1.151371] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[    1.151391] =======================================================
[    1.151413]  WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[    1.151559] dhd_module_init: in
[    1.151586] ======== bcm_wlan_set_plat_data ========
[    1.151607] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    1.151682] host_oob_irq: 164
[    1.151701] host_oob_irq_flags=4
[    1.151718] dhd_wifi_platform_load: Enter
[    1.151795] pcd_pullup, is_on 0
[    1.151807] Power-up adapter 'DHD generic adapter'
[    1.151886] wifi_platform_set_power = 1
[    1.151909] ======== PULL WL_REG_ON HIGH! ========
[    1.151931] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    1.151953] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[    1.151962] file system registered
[    1.151993] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[    1.154014] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.154046] android_usb gadget: Number of LUNs=2
[    1.154069]  lun0: LUN: removable file: (no medium)
[    1.154091]  lun1: LUN: removable file: (no medium)
[    1.154575] android_usb gadget: android_usb ready
[    1.154762] sensor_init: Probe name sensors
[    1.154806] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[    1.156463] rtc_hym8563 0-0051: hctosys: invalid date/time
[    1.167402] usbcore: registered new interface driver snd-usb-audio
[    1.167436] ALSA device list:
[    1.167455]   #0: RK_RK312X
[    1.167472]   #1: RK-HDMI-SPDIF
[    1.168382] Freeing unused kernel memory: 360K (c0b97000 - c0bf1000)
[    1.238959] Cam_Powerdowm
[    1.239028] Unable to handle kernel paging request at virtual address fffffe2b
[    1.258647] [WLAN_RFKILL]: wifi turn on power. 43
[    1.261970] udevd[131]: starting version 175
[    1.465298] wifi_platform_bus_enumerate device present 1
[    1.465314] ======== Card detection to detect SDIO card! ========
[    1.465326] mmc2:mmc host rescan start!
[    1.681799] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[    1.730974] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 300000Hz, actual 297619HZ div = 63)
[    1.731004] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc2]
[    1.780127] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 200000Hz, actual 199468HZ div = 94)
[    1.780157] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
[    2.872343] EHCI: rk_ehci_hcd_enable, disable host controller
[    3.433224] failed to power up DHD generic adapter, 0 retry left
[    3.449163] wifi_platform_set_power = 0
[    3.449194] ======== PULL WL_REG_ON LOW! ========
[    3.449207] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    3.551298] [WLAN_RFKILL]: wifi shut off power.
[    3.551319] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[    3.551330] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[    3.551342] wifi_platform_bus_enumerate device present 0
[    3.551351] ======== Card detection to remove SDIO card! ========
[    3.551361] mmc2:mmc host rescan start!
[    3.551389] failed to power up DHD generic adapter, max retry reached**
[    3.551433] unregister wifi platform drivers
[    3.551445] wifi_platform_bus_enumerate device present 0
[    3.551453] ======== Card detection to remove SDIO card! ========
[    3.551463] mmc2:mmc host rescan start!
[    3.551477] dhd_module_init: Failed to load the driver, try cnt 0
[    3.551528] dhd_module_init: Failed to load driver max retry reached**
[    3.551538] dhd_module_init: Exit err=-19
[    3.904931] pgd = c0004000
Begin: Loading essential drivers ... [    3.911076] [fffffe2b] *pgd=7fff2821, *pte=00000000, *ppte=00000000
[    3.917440] Internal error: Oops: 17 [#1] PREEMPFASMP ACould not load /lib/modules/3.10.0+/modules.dep: No such file or directory
[    3.928901] Modules linked in:
[    3.931970] CPU: 1 PID: 95 Comm: rk_camera_init Tainted: G     F TWL:  oul0.0o #2
[    3.945069] task: da9d4980 ti: da546000 task.ti: da546000
[    3.950426] PC is at regulator_set_voltage+0x8/0xe0
FATAL: Could not load /lib/modules/3.10.0+/modules.dep: No such file or directory
[    3.962335] LR is at sensor_power_default_cb+0x90/0x270
[    3.967505] pc : [<c02e2690>]    lr : [ATA0328fuld notpsoad /li0013
les/33.96750module: da547do sucp : 000or dir fp :
2ab980
done.
[    3.979418] r10: fffffdfb  r9 : 001b77B0 in: Run56111fscripts/init-premount ... [    3.986548] r7 : 00000001  r6 : ffffffff  r5 : c5611218  r4 : fffffdfb
done.
g /scripts/local-top ... done.   4.002360] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  SeBmgin: Runel
[    4.012233] Control: 10c5387d  Table: 7a5b806a  DAC: 00000015
[    4.017909]
[    4.017909] PC: 0xc02e2610:
[    4.022125] 2610  e3530000 1a000002 e5962018 e3520000 0a000013 e58d3000 e1a00004 e5963018
[    4.030275] 2630  e1a0100d e28d2004 e58d3004 ebfffa43 e2506000 ba00000b e1a00004 e1a0100d
[    4.038422] 2650  e28d2004 ebffffb9 e2506000 ba000005 e1a00004 e89d0006 ebfffc14 e1a06000
[    4.046569] 2670  ea000000 e3e06015 e1a00005 eb158b31 e1a00006 e8bd807c e92d45f7 e1a04000
[    4.054716] 2690  e5905030 e58d2000 e2856038 e58d1004 e1a00006 eb158bbe e5942014 e59d3004
[    4.062863] 26b0  e1520003 1a000004 e5942018 e59d3000 e1520003 03a0a000 0a000022 e5953000
[    4.071009] 26d0  e5933014[    4.072839] rk312x_delay_workq
 e5932004 e3520000 1a000003 e593300c e3530000 03e0a015 0a000019
[    4.082155] 26f0  e1a00005 e28d1004 e1a0200d ebfffa13 e250a000 ba000013 e59d3004 e1a00005
[    4.090304]
[    4.090304] LR: 0xc0032870:
[    4.094513] 2870  e1a07001 e5906004 e590b054 e58d3008 e5903018 e5909058 e5908048 e58d300c
[    4.102661] 2890  e59f3210 e590504c e5933000 e3530002 da000007 e59f3200 e30021aa e59f01fc
[    4.110808] 28b0  e59f11fc e58d3004 e59f31f8 e58d2000 eb1fe618 e3550000 0a000018 e3a00000
[    4.118956] 28d0  e1a01005 eb0abdac e3570000 e1a0a000 0a00000b e1a01009 e1a02009 eb0abf65
[    4.127103] 28f0  e1a0000a eb0ac060 e1a05000 e1a0000a eb0ab63d e3a0000a eb0047af ea000007
[    4.135251] 2910  eb0ac043 e1a0000a eb0ac1a1 e3500000 e1a0000a cafffff9 eb0ab633 e3a05000
[    4.143399] 2930  e3a0a033 e59f9180 ea000002 e5993004 e59f0178 e12fff33 e25aa001 1afffffa
[    4.151547] 2950  e3580000 0a000017 e1a01008 e1a0000a eb0abd89 e3570000 e1a08000 0a00000b
[    4.159697]
[    4.159697] SP: 0xda547c90:
[    4.163905] 7c90  c0d2cfc8 c0037acc 0000001d c0d3a870 00000000 0000001d c0d3a870 c0037f38
[    4.172052] 7cb0  00000400 c02e2690 20000013 ffffffff da547cfc c000d598 fffffdfb 001b7740
[    4.180199] 7cd0  001b7740 00000000 fffffdfb c5611218 ffffffff 00000001 c56111f0 001b7740
[    4.188345] 7cf0  fffffdfb 002ab980[    4.190981] rockchip_line_in enable
[    4.190997]  [on]
 00000000 da547d10 c00328f0 c02e2690 20000013 ffffffff
[    4.201891] 7d10  fffffdfb 001b7740 001b7740 dc297a28 c5611218 ffffffff 00000001 c56111f0
[    4.210038] 7d30  fffffdfb c00328f0 c0d2cac0 c00327e8 00000008 00000004 00000000 00000001
[    4.218183] 7d50  c0032860 dc297a28 dc297800 00000000 00000467 00000000 016e3600 c00314d4
[    4.226330] 7d70  00000005 c029a2a0 db884a28 00000000 0000007f 00000001 00000008 dc297880
[    4.234476]
[    4.234476] R0: 0xfffffd7b:
[    4.238685] fd78  ******** ******** ******** ******** ******** ******** ******** ********
[    4.246834] fd98  ******** ******** ******** ******** ******** ******** ******** ********
[    4.254977] fdb8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.263121] fdd8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.271264] fdf8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.279407] fe18  ******** ******** ******** ******** ******** ******** ******** ********
[    4.287551] fe38  ******** ******** ******** ******** ******** ******** ******** ********
[    4.295695] fe58  ******** ******** ******** ******** ******** ******** ******** ********
[    4.303838] fe78  ******** ******** ******** ******** ******** ******** ******** ********
[    4.311984]
[    4.311984] R4: 0xfffffd7b:
[    4.316193] fd78  ******** ******** ******** ******** ******** ******** ******** ********
[    4.324336] fd98  ******** ******** ******** ******** ******** ******** ******** ********
[    4.332480] fdb8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.340623] fdd8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.348766] fdf8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.356914] fe18  ******** ******** ******** ******** ******** ******** ******** ********
[    4.365061] fe38  ******** ******** ******** ******** ******** ******** ******** ********
[    4.373209] fe58  ******** ******** ******** ******** ******** ******** ******** ********
[    4.381356] fe78  ******** ******** ******** ******** ******** ******** ******** ********
[    4.389505]
[    4.389505] R5: 0xc5611198:
[    4.393714] 1198  04000000 e00f0000 00000000 03000000 04000000 fe0f0000 00000000 01000000
[    4.401865] 11b8  346b3573 00006365 03000000 05000000 f0020000 79616b6f 00000000 03000000
[    4.410016] 11d8  04000000 19100000 00000000 03000000 0b000000 22100000 31386b72 646c5f38
[    4.418166] 11f8  0000346f 03000000 04000000 3b100000 80b92a00 03000000 0b000000 57100000
[    4.426318] 1218  31386b72 646c5f38 0000386f 03000000 04000000 70100000 40771b00 03000000
[    4.434468] 1238  0c000000 8c100000 76000000 1f000000 00000000 03000000 04000000 9f100000
[    4.442619] 1258  00000000 03000000 0c000000 ab100000 76000000 0b000000 01000000 03000000
[    4.450769] 1278  00000000 b5100000 03000000 00000000 c5100000 03000000 04000000 d1100000
[    4.458921]
[    4.458921] R8: 0xc5611170:
[    4.463130] 1170  01000000 03000000 04000000 a00f0000 00000000 03000000 04000000 be0f0000
[    4.471281] 1190  00000000 03000000 04000000 e00f0000 00000000 03000000 04000000 fe0f0000
[    4.479432] 11b0  00000000 01000000 346b3573 00006365 03000000 05000000 f0020000 79616b6f
[    4.487582] 11d0  00000000 03000000 04000000 19100000 00000000 03000000 0b000000 22100000
[    4.495733] 11f0  31386b72 646c5f38 0000346f 03000000 04000000 3b100000 80b92a00 03000000
[    4.503883] 1210  0b000000 57100000 31386b72 646c5f38 0000386f 03000000 04000000 70100000
[    4.512034] 1230  40771b00 03000000 0c000000 8c100000 76000000 1f000000 00000000 03000000
[    4.520185] 1250  04000000 9f100000 00000000 03000000 0c000000 ab100000 76000000 0b000000
[    4.528337]
[    4.528337] R10: 0xfffffd7b:
[    4.532632] fd78  ******** ******** ******** ******** ******** ******** ******** ********
[    4.540779] fd98  ******** ******** ******** ******** ******** ******** ******** ********
[    4.548927] fdb8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.557074] fdd8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.565220] fdf8  ******** ******** ******** ******** ******** ******** ******** ********
[    4.573367] fe18  ******** ******** ******** ******** ******** ******** ******** ********
[    4.581514] fe38  ******** ******** ******** ******** ******** ******** ******** ********
[    4.589661] fe58  ******** ******** ******** ******** ******** ******** ******** ********
[    4.597808] fe78  ******** ******** ******** ******** ******** ******** ******** ********
[    4.605960] Process rk_camera_init (pid: 95, stack limit = 0xda546238)
[    4.612383] Stack: (0xda547d10 to 0xda548000)
[    4.616680] 7d00:                                     fffffdfb 001b7740 001b7740 dc297a28
[    4.624734] 7d20: c5611218 ffffffff 00000001 c56111f0 fffffdfb c00328f0 c0d2cac0 c00327e8
[    4.632785] 7d40: 00000008 00000004 00000000 00000001 c0032860 dc297a28 dc297800 00000000
[    4.640838] 7d60: 00000467 00000000 016e3600 c00314d4 00000005 c029a2a0 db884a28 00000000
[    4.648890] 7d80: 0000007f 00000001 00000008 dc297880 c0d2cac0 c00317e4 dc297880 00000467
[    4.656942] 7da0: 00000001 00000467 dc297880 016e3600 c0d2cac0 dc297800 00000001 00000001
[    4.664995] 7dc0: 000004a5 c0031b74 dc297880 00000001 00000000 dc297828 dc297880 00000000
[    4.673049] 7de0: 00000000 c0de7de4 db806c00 00000000 dc3b7c64 c053b900 dc3b7c10 dc297828
[    4.681102] 7e00: dc3b7c10 c053b9a4 c0bfb2a8 0067a000 ff0a0004 ffffffff 00000001 db806c00
[    4.689155] 7e20: c0c15e38 00000000 00000000 c0de7de4 c0c15e38 c0a46fab 00000000 c0280a54
[    4.697209] 7e40: db806c14 da547e54 c0a6f45c db806c00 c0c962f0 dc3b7c10 00000000 c0de7de4
[    4.705262] 7e60: c0c15e38 c0a46fab 00000000 c053bf0c 00000000 db806c00 c0c15e28 c0d2cae0
[    4.713314] 7e80: 00000000 c055012c 00000000 db806c00 0000000e c0ac1fbb 00000000 c0c15e38
[    4.721367] 7ea0: 00000000 c0c98144 00000000 00000000 00000000 c030c784 c030c770 c030b54c
[    4.729419] 7ec0: c0c15e38 c0c98144 c0c98144 00000000 00000000 c030b7a8 00000000 c0c15e38
[    4.737473] 7ee0: c0c15e6c c030b820 c0c98144 da547ef8 c030b7c0 c0309ffc dc1cd65c dc334734
[    4.745527] 7f00: c0c98144 c0c98144 c5b40580 c0c37a30 00000000 c030adac c0a46fab c0a46fad
[    4.753579] 7f20: c0c98144 00000000 00000000 c054d484 00000000 c030bcfc 00000000 dc067f00
[    4.761631] 7f40: 00000000 00000000 c054d484 00000000 00000000 c054d4c0 00000000 da547f6c
[    4.769682] 7f60: da547f50 c0055984 bfbfabfa 00000000 dfffdfdf 00000000 00000000 00000000
[    4.777736] 7f80: da547f80 da547f80 00000000 00000000 da547f90 da547f90 da547fac dc067f00
[    4.785787] 7fa0: c00558e4 00000000 00000000 c000da98 00000000 00000000 00000000 00000000
[    4.793837] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.801888] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 fdcd7fbe ff77bff8
[    4.809957] [<c02e2690>] (regulator_set_voltage+0x8/0xe0) from [<c00328f0>] (sensor_power_default_cb+0x90/0x270)
[    4.819978] [<c00328f0>] (sensor_power_default_cb+0x90/0x270) from [<c00314d4>] (rk_sensor_ioctrl+0xdc/0x2e4)
[    4.829739] [<c00314d4>] (rk_sensor_ioctrl+0xdc/0x2e4) from [<c00317e4>] (rk_sensor_pwrseq+0xa0/0x230)
[    4.838904] [<c00317e4>] (rk_sensor_pwrseq+0xa0/0x230) from [<c0031b74>] (rk_sensor_power+0x200/0x2dc)
[    4.848070] [<c0031b74>] (rk_sensor_power+0x200/0x2dc) from [<c053b900>] (soc_camera_power_on+0x48/0x78)
[    4.857407] [<c053b900>] (soc_camera_power_on+0x48/0x78) from [<c053b9a4>] (soc_camera_probe+0x74/0x41c)
[    4.866743] [<c053b9a4>] (soc_camera_probe+0x74/0x41c) from [<c053bf0c>] (soc_camera_host_register+0x1c0/0x220)
[    4.876677] [<c053bf0c>] (soc_camera_host_register+0x1c0/0x220) from [<c055012c>] (rk_camera_probe+0x3e8/0x598)
[    4.886614] [<c055012c>] (rk_camera_probe+0x3e8/0x598) from [<c030c784>] (platform_drv_probe+0x14/0x18)
[    4.895868] [<c030c784>] (platform_drv_probe+0x14/0x18) from [<c030b54c>] (really_probe+0xa8/0x20c)
[    4.904779] [<c030b54c>] (really_probe+0xa8/0x20c) from [<c030b7a8>] (driver_probe_device+0x30/0x48)
[    4.913774] [<c030b7a8>] (driver_probe_device+0x30/0x48) from [<c030b820>] (__driver_attach+0x60/0x84)
[    4.922938] [<c030b820>] (__driver_attach+0x60/0x84) from [<c0309ffc>] (bus_for_each_dev+0x50/0x90)
[    4.931847] [<c0309ffc>] (bus_for_each_dev+0x50/0x90) from [<c030adac>] (bus_add_driver+0xac/0x20c)
[    4.940756] [<c030adac>] (bus_add_driver+0xac/0x20c) from [<c030bcfc>] (driver_register+0x9c/0x138)
[    4.949667] [<c030bcfc>] (driver_register+0x9c/0x138) from [<c054d4c0>] (rk_camera_init_async+0x3c/0x5c)
[    4.959007] [<c054d4c0>] (rk_camera_init_async+0x3c/0x5c) from [<c0055984>] (kthread+0xa0/0xac)
[    4.967579] [<c0055984>] (kthread+0xa0/0xac) from [<c000da98>] (ret_from_fork+0x14/0x3c)
[    4.975546] Code: e1a00006 e8bd807c e92d45f7 e1a04000 (e5905030)
[    4.981732] ---[ end trace 8a3943ebeb3b65dc ]---
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 2...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 3...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 4...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 5...
[    8.835428] [otg id chg] last id -1 current id 256
[    8.840166] PortPower off
[    8.942170] Using Buffer DMA mode
[    8.945464] Periodic Transfer Interrupt Enhancement - disabled
[    8.951203] Multiprocessor Interrupt Enhancement - disabled
[    8.956729] OTG VER PARAM: 0, OTG VER FLAG: 0
[    8.961019] ^^^^^^^^^^^^^^^^^Device Mode
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 6...
[    9.455319] ***************vbus detect*****************
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 7...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 8...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 9...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 10...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 11...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 12...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 13...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 14...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 15...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 16...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 17...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 18...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 19...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 20...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 21...
RK818和DDR都识别错了,板子有问题吧
的确这块板子并不是firefly的板子,而是换了块开博尔电视盒子那种公版板子,刚好闲置了就拿来折腾一下。
回到正题,照道理主控的flash控制器也就一组,所以接口应该不存在问题,flash也是现代的,只不过型号是2BTR,而firefly的是2ETR,两个类型都在rk的支持范围内,ddr也能识别,只要这样系统应该就能跑起来才对,顶多其他外设的驱动有问题。但是为什么会出现这种识别不了nandflash情况呢,想不明白,求解决思路
Begin: Loading essential drivers … [ 3.911076] [fffffe2b] *pgd=7fff2821, *pte=00000000, *ppte=00000000
Initramfs 包進去的 ko 位置在這嗎??
