求助!板能升级固件,但不了机?。。。。
用的是lubuntu,想下载gnome,下载配置完后,reboot重启。。然后就什么也不显示了。。。固件倒是能刷。。。。刷了几次都是这样,鼠标键盘也亮。。。:L:(
鼠标键盘不亮。。!
没有人吗?难道这的要用MaskRom模式吗?由于用平板匆忙问问题。。出现漏字的情况。。。
顺便刷一下回帖数。。。:lol还是真心求大神帮忙。。。
你要把刷哪个固件,具体操作的步骤和log发出来,人家才有办法给你分析
我刚用fireprime,我不是很懂,不知道是不是这个
Jun  4 12:49:03 VAIO kernel: [ 8148.681240] usb 1-2: USB disconnect, device number 78
Jun  4 12:49:06 VAIO kernel: [ 8151.163444] usb 1-2: new high-speed USB device number 79 using xhci_hcd
Jun  4 12:49:06 VAIO kernel: [ 8151.292170] usb 1-2: New USB device found, idVendor=2207, idProduct=310c
Jun  4 12:49:06 VAIO kernel: [ 8151.292179] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun  4 12:49:06 VAIO mtp-probe: checking bus 1, device 79: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2"
Jun  4 12:49:06 VAIO mtp-probe: bus: 1, device: 79 was not an MTP device
Jun  4 12:49:27 VAIO kernel: [ 8172.129749] usb 1-2: usbfs: process 5333 (upgrade_tool) did not claim interface 0 before use
Jun  4 12:49:50 VAIO kernel: [ 8195.092330] usb 1-2: usbfs: process 5346 (upgrade_tool) did not claim interface 0 before use
Jun  4 12:49:53 VAIO kernel: [ 8197.925084] usb 1-2: USB disconnect, device number 79
Jun  4 12:49:54 VAIO kernel: [ 8199.494239] usb 1-2: new high-speed USB device number 80 using xhci_hcd
Jun  4 12:49:54 VAIO kernel: [ 8199.622745] usb 1-2: New USB device found, idVendor=2207, idProduct=310c
Jun  4 12:49:54 VAIO kernel: [ 8199.622754] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun  4 12:49:54 VAIO mtp-probe: checking bus 1, device 80: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2"
Jun  4 12:49:54 VAIO mtp-probe: bus: 1, device: 80 was not an MTP device
Jun  4 12:49:55 VAIO kernel: [ 8200.255695] usb 1-2: usbfs: process 5346 (upgrade_tool) did not claim interface 0 before use
Jun  4 12:50:04 VAIO systemd-timesyncd[398]: Timed out waiting for reply from 91.189.94.4:123 (ntp.ubuntu.com).
Jun  4 12:52:04 VAIO smartd[626]: Device: /dev/sda [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 35 to 46
Jun  4 12:54:29 VAIO kernel: [ 8474.652812] usb 1-2: USB disconnect, device number 80
Jun  4 12:54:36 VAIO systemd-timesyncd[398]: Timed out waiting for reply from 91.189.94.4:123 (ntp.ubuntu.com).
Jun  4 12:54:46 VAIO systemd-timesyncd[398]: Timed out waiting for reply from 91.189.89.199:123 (ntp.ubuntu.com).
shell:
$ sudo upgrade_tool lf
   Lower Format Device,total(2120),current(2120)
   Lower Format Device OK.
$ sudo upgrade_tool uf FirePrime_Ubuntu15.04_201506260948.img
   Loading firmware...
   Support Type:RK312A	FW Ver:5.1.00	FW Time:2015-06-26 09:48:56
   Loader ver:2.25	Loader Time:2015-06-12 09:11:29
   Upgrade firmware ok.
