flyprimeS+的andrioid SDK编译问题
按照http://wiki.t-firefly.com/index.php/FirePrime/Build_android#.E4.B8.8B.E8.BD.BD_Android_SDK的流程,最后make的时候编译了一天,结果报了这个错误,谁知道怎么解决呢?
including ./system/media/audio_utils/Android.mk …
including ./system/media/camera/src/Android.mk …
including ./system/media/camera/tests/Android.mk …
including ./system/netd/client/Android.mk …
including ./system/netd/server/Android.mk …
including ./system/security/keystore-engine/Android.mk …
including ./system/security/keystore/Android.mk …
including ./system/security/softkeymaster/Android.mk …
including ./system/vold/Android.mk …
including ./tools/external/fat32lib/Android.mk …
including ./vendor/rockchip/common/apps/AllApp/Android.mk …
including ./vendor/rockchip/common/apps/DeviceTest/Android.mk …
including ./vendor/rockchip/common/apps/GoogleEmail/Android.mk …
including ./vendor/rockchip/common/apps/MediaFloat/Android.mk …
including ./vendor/rockchip/common/apps/RFTest/Android.mk …
including ./vendor/rockchip/common/apps/RKGameControlSettingV1.0.1/Android.mk …
including ./vendor/rockchip/common/apps/RKUpdateService/Android.mk …
including ./vendor/rockchip/common/apps/Rk3grExplorer/Android.mk …
including ./vendor/rockchip/common/apps/Rk3grVideoPlayer/Android.mk …
including ./vendor/rockchip/common/apps/Rk4kVideoPlayer/Android.mk …
including ./vendor/rockchip/common/apps/RkAlarmHelper/Android.mk …
including ./vendor/rockchip/common/apps/RkApkinstaller/Android.mk …
including ./vendor/rockchip/common/apps/RkBoxVideoPlayer/Android.mk …
including ./vendor/rockchip/common/apps/RkEbookReader/Android.mk …
including ./vendor/rockchip/common/apps/RkExpe/Android.mk …
including ./vendor/rockchip/common/apps/RkExplorer/Android.mk …
including ./vendor/rockchip/common/apps/RkMusic/Android.mk …
including ./vendor/rockchip/common/apps/RkUserExperienceService/Android.mk …
including ./vendor/rockchip/common/apps/RkVideoPlayer/Android.mk …
including ./vendor/rockchip/common/apps/Settings2/Android.mk …
including ./vendor/rockchip/common/apps/SimpleLauncher/Android.mk …
including ./vendor/rockchip/common/apps/StressTest/Android.mk …
including ./vendor/rockchip/common/apps/WinStartService/Android.mk …
including ./vendor/rockchip/common/apps/eHomeMediaCenter_box/Android.mk …
including ./vendor/rockchip/common/apps/ituxd/Android.mk …
including ./vendor/rockchip/common/apps/itvlauncher/Android.mk …
including ./vendor/rockchip/common/bin/Android.mk …
including ./vendor/rockchip/common/copybit/Android.mk …
including ./vendor/rockchip/common/gpu/Mali400/Android.mk …
including ./vendor/rockchip/common/gpu/Mali450/Android.mk …
including ./vendor/rockchip/common/gpu/MaliT760/Android.mk …
including ./vendor/rockchip/common/hdcp2/Android.mk …
including ./vendor/rockchip/common/pluginsvc/Android.mk …
including ./vendor/rockchip/common/vpu/Android.mk …
including ./vendor/widevine/Android.mk …
PRODUCT_COPY_FILES device/rockchip/common/init.rk30board.bootmode.emmc.rc:root/init.rk30board.bootmode.emmc.rc ignored.
PRODUCT_COPY_FILES device/rockchip/common/init.rk30board.bootmode.unknown.rc:root/init.rk30board.bootmode.unknown.rc ignored.
PRODUCT_COPY_FILES device/rockchip/common/fstab.rk30board.bootmode.unknown:root/fstab.rk30board.bootmode.unknown ignored.
PRODUCT_COPY_FILES device/rockchip/common/fstab.rk30board.bootmode.emmc:root/fstab.rk30board.bootmode.emmc ignored.
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk312x/obj/lib/libGLES_mali.so' build/core/prebuilt_internal.mk:282: warning: ignoring old commands for target out/target/product/rk312x/obj/lib/libGLES_mali.so’
rm -f art/compiler/sha_version.h
target Generated: libart-compiler_32 <=
e9abf31bacf5435c909a3f1ba3b9803b19e296f49c2a980da1b5725dff2a0627aa893ae0a0d06f4d0bfa03537b54a0cd0e58dc745758c3bf51b4e96c6760b6a5
Copy: out/host/linux-x86/obj32/SHARED_LIBRARIES/libart-compiler_intermediates/sha_version.h
Copy: out/host/linux-x86/obj/SHARED_LIBRARIES/libart-compiler_intermediates/sha_version.h
target SharedLib: libwebviewchromium (out/target/product/rk312x/obj/SHARED_LIBRARIES/libwebviewchromium_intermediates/LINKED/libwebviewchromium.so)
collect2: error: ld terminated with signal 9 [Killed]
/work/flyprime/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.8/bin/../lib/gcc/arm-linux-androideabi/4.8/../../../../arm-linux-androideabi/bin/ld.gold: warning: hidden symbol ‘SkBitmap::lockPixels() const’ in out/target/product/rk312x/obj/STATIC_LIBRARIES/skia_skia_library_gyp_intermediates/skia_skia_library_gyp.a(SkBitmap.o) is referenced by DSO out/target/product/rk312x/obj/lib/libjnigraphics.so
/work/flyprime/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.8/bin/../lib/gcc/arm-linux-androideabi/4.8/../../../../arm-linux-androideabi/bin/ld.gold: warning: hidden symbol ‘SkBitmap::unlockPixels() const’ in out/target/product/rk312x/obj/STATIC_LIBRARIES/skia_skia_library_gyp_intermediates/skia_skia_library_gyp.a(SkBitmap.o) is referenced by DSO out/target/product/rk312x/obj/lib/libjnigraphics.so
/work/flyprime/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.8/bin/../lib/gcc/arm-linux-androideabi/4.8/../../../../arm-linux-androideabi/bin/ld.gold: warning: hidden symbol ‘SkBitmap::notifyPixelsChanged() const’ in out/target/product/rk312x/obj/STATIC_LIBRARIES/skia_skia_library_gyp_intermediates/skia_skia_library_gyp.a(SkBitmap.o) is referenced by DSO out/target/product/rk312x/obj/lib/libjnigraphics.so
make: *** [out/target/product/rk312x/obj/SHARED_LIBRARIES/libwebviewchromium_intermediates/LINKED/libwebviewchromium.so] Error 1
#### make failed to build some targets (17:41 (mm:ss)) ####
内存不足
http://bbs.csdn.net/topics/380266160
