板子起不来,nandflash按照文档加了个宏,不知道是哪里的问题了。
log如下:
DDR Version 1.00 20160217
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Boot1 Release Time: 2016-02-18, version: 2.30
ChipType = 8 237
No.1 FLASH ID:ad de 94 eb 74 44
ECC:60
SdmmcInit=0 400
StorageInit ok = 361762
powerOn 862975
SRX
ChipType = 8 238
ECC:60
SdmmcInit=0 400
StorageInit ok = 352156
theLoader 0 441342
U-Boot 2014.10-RK3288-10 (Jun 08 2016 - 12:07:04)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 400
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
battery: gl=0 dl=0 rl=0, v=4200, m=0
pmic:rk818
#Boot ver: 2016-06-08#2.30
empty serial no.
checkKey
vbus = 1
pll_src = 0, dclk_hz = 71000000, dclk_div = 5
got recovery cmd from misc.
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x007354a0)
ramdisk @ 0x05bf0000 (0x002c8588)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561e70e … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (williamxu@YX) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #11 SMP PREEMPT Fri Jun 3 10:48:11 CST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x01000000 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 55c00000 [ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1fc1000 s13440 r8192 d15232 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264 [ 0.000000] Kernel command line: vmalloc=496M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x0001a000@0x00026000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00200000@0x0039A000(userdata),0x00020000@0x0059A000(radical_update),-@0x005BA000(user) storagemedia=nand loader_charged uboot_logo=0x02000000@0x7dc00000:0x01000000 loader.timestamp=2016-06-08_12:07:04 [ 0.000000] battery charged in loader [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1352476k/1352476k available, 744676k reserved, 884736K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0cbd1ec (13013 kB) [ 0.000000] .init : 0xc0cbe000 - 0xc0d1a480 ( 370 kB) [ 0.000000] .data : 0xc0d1c000 - 0xc0e38a58 (1139 kB) [ 0.000000] .bss : 0xc0e38a58 - 0xc0f5eadc (1177 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 28 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 3 [ 0.000000] channel:0, lkg:10 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] channel:0, lkg:10 [ 0.000000] channel:1, lkg:9 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.343692] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.343707] pid_max: default: 32768 minimum: 301 [ 0.343820] Security Framework initialized [ 0.343837] SELinux: Initializing. [ 0.343910] Mount-cache hash table entries: 512 [ 0.344529] Initializing cgroup subsys debug [ 0.344542] Initializing cgroup subsys memory [ 0.344569] Initializing cgroup subsys freezer [ 0.344598] CPU: Testing write buffer coherency: ok [ 0.344902] /cpus/cpu@0 missing clock-frequency property [ 0.344914] /cpus/cpu@1 missing clock-frequency property [ 0.344923] /cpus/cpu@2 missing clock-frequency property [ 0.344932] /cpus/cpu@3 missing clock-frequency property [ 0.344995] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.345045] Setting up static identity map for 0xc0916800 - 0xc0916858 [ 0.347507] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17e6 (version 3.1) [ 0.421722] CPU1: Booted secondary processor [ 0.421756] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.441398] CPU2: Booted secondary processor [ 0.441422] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.461101] CPU3: Booted secondary processor [ 0.461124] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.461226] Brought up 4 CPUs [ 0.461254] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.461264] CPU: All CPU(s) started in SVC mode. [ 0.461987] devtmpfs: initialized [ 0.466428] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 0.467562] pinctrl core: initialized pinctrl subsystem [ 0.467804] regulator-dummy: no parameters [ 0.493596] NET: Registered protocol family 16 [ 0.495473] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.495882] ion_snapshot: 0x1eaa8000 map to 0xe0907000 and copy to 0xc0f3738c (version 0.1) [ 0.496112] Registered FIQ tty driver [ 0.497455] console [ttyFIQ0] enabled [ 0.497656] Registered fiq debugger ttyFIQ0 [ 0.498353] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.498378] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.498398] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.498418] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.498509] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.498576] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.498640] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.498705] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.498771] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.498834] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.498898] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.498963] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.499034] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.499103] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.499119] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.499133] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.499147] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.499784] rockchip_interrupts_register:bank_num=7 [ 0.501754] of_get_gpio_init_config:gpio[0] = 6, value = 0 [ 0.501803] rockchip_pinctrl_probe:init ok [ 0.508328] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.508420] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.508437] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.508615] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.508690] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.508706] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.508869] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.508943] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.508960] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.509136] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.509210] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.509225] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.509400] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.509476] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.509493] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.509668] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.509741] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.509756] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.509930] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.510013] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.510030] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.511921] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.511938] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.512578] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 0.512605] DDR DEBUG: version 1.00 20150126 [ 0.512635] DDR DEBUG: Channel a: [ 0.512646] DDR DEBUG: DDR3 Device [ 0.512660] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.512672] DDR DEBUG: Channel b: [ 0.512681] DDR DEBUG: DDR3 Device [ 0.512694] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.512706] DDR DEBUG: addr=0xe42000 [ 0.512717] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.512728] DDR DEBUG: socAddr[0]=0xe42000, socAddr[1]=0xe42100 [ 0.512740] DDR DEBUG: chAddr[0]=0xe42000, chAddr[1]=0xe42000 [ 0.512753] DDR DEBUG: dtar[0]=0x201c8000, dtar[1]=0x201c8000 [ 0.512812] DDR DEBUG: init success!!! freq=200MHz [ 0.512822] DDR DEBUG: Channel a: [ 0.512836] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512852] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512867] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512883] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512897] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.512909] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.512919] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.512929] DDR DEBUG: Channel b: [ 0.512942] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512957] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512972] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512988] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.513001] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.513013] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.513023] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.537793] bio: create slab at 0 [ 0.538323] Rockchip hdmi driver version 2.0 . [ 0.539478] SCSI subsystem initialized [ 0.539664] usbcore: registered new interface driver usbfs [ 0.539719] usbcore: registered new interface driver hub [ 0.539811] usbcore: registered new device driver usb [ 0.543649] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.545097] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.546130] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.546394] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.547040] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.547185] media: Linux media interface: v0.10 [ 0.547229] Linux video capture interface: v2.00 [ 0.547353] pps_core: LinuxPPS API ver. 1 registered [ 0.547367] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.547391] PTP clock support registered [ 0.547988] bq24296 0-006b: bq24296_battery_probe(): Failed in reading register0x0a [ 0.548012] bq24296: probe of 0-006b failed with error -11 [ 0.548060] i2c-core: driver [bq24296] using legacy suspend method [ 0.548072] i2c-core: driver [bq24296] using legacy resume method [ 0.548802] ion_drm_heap_create: 0@0 [ 0.548939] Rockchip ion module is successfully loaded (v1.1) [ 0.549112] Advanced Linux Sound Architecture Driver Initialized. [ 0.549508] Bluetooth: Core ver 2.16 [ 0.549548] NET: Registered protocol family 31 [ 0.549560] Bluetooth: HCI device and connection manager initialized [ 0.549579] Bluetooth: HCI socket layer initialized [ 0.549595] Bluetooth: L2CAP socket layer initialized [ 0.549624] Bluetooth: SCO socket layer initialized [ 0.549909] cfg80211: Calling CRDA to update world regulatory domain [ 0.550602] act8846_i2c_probe,line=880 [ 0.552055] act8846 set 0xf4 error! [ 0.552140] act8846: probe of 0-005a failed with error -11 [ 0.556798] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.557816] The device is not syr82x fffffff5 [ 0.557837] syr82x: probe of 0-0041 failed with error -11 [ 0.558332] rk808_i2c_probe,line=1355 [ 0.559673] The device is not rk808 -11 [ 0.559747] rk808: probe of 0-001b failed with error -11 [ 0.559849] i2c-core: driver [rk816] using legacy suspend method [ 0.559861] i2c-core: driver [rk816] using legacy resume method [ 0.559911] rk818_i2c_probe,line=1386 [ 0.560168] rk818_pre_init,line=1301 [ 0.566940] rk818_i2c_probe: rk818_pmic_sleep=0 [ 0.570495] vdd_logic: 712 <--> 1500 mV at 1100 mV [ 0.577511] rk818_dcdc2: 1200 mV [ 0.581113] rk818_dcdc3: 1200 mV [ 0.584903] vccio: 1800 <--> 3300 mV at 3300 mV [ 0.588501] rk818_ldo1: 3300 mV [ 0.592132] rk818_ldo2: 3300 mV [ 0.595716] rk818_ldo3: 1000 mV [ 0.599309] rk818_ldo4: 1800 mV [ 0.602919] rk818_ldo5: 3300 mV [ 0.606507] rk818_ldo6: 1000 mV [ 0.610108] rk818_ldo7: 1800 mV [ 0.613691] rk818_ldo8: 1800 mV [ 0.616189] vcc_sd: 1800 <--> 3300 mV at 3300 mV [ 0.617424] rk818_ldo10: at 3300 mV [ 0.618988] rk818_irq_init: rk818_pmic_irq=1 [ 0.634652] i2c-core: driver [rk818] using legacy suspend method [ 0.634666] i2c-core: driver [rk818] using legacy resume method [ 0.634736] ricoh619_i2c_probe,line=825 [ 0.636001] ricoh619 0-0032: failed reading at 0x36 -11 [ 0.636016] The device is not ricoh619 00000000 -11 [ 0.636035] ricoh619: probe of 0-0032 failed with error -11 [ 0.636516] rk818_rtc_probe,line=542 [ 0.640575] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.645997] rk818-rtc rk818-rtc: rtc core: registered rk818 as rtc0 [ 0.647995] rk818_rtc_probe:ok [ 0.649435] Switching to clocksource arch_sys_counter [ 0.674132] rga: Module initialized. [ 0.674856] rga2 ff920000.rga: rga ion client create success! [ 0.675018] rga: Driver loaded succesfully [ 0.675219] uboot-logo-on:1 [ 0.675252] rk-fb rockchip-fb: rk fb ion client create success! [ 0.675267] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.675609] rk-screen rk_screen.9: rockchip screen probe success [ 0.675879] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.676307] rk32-edp ff970000.edp: screen is not edp! [ 0.676330] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.677092] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.677415] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.677586] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.677755] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.677981] rk3288-lcdc lcdc0: lcdc0: dclk:71000000>>fps:62 [ 0.702604] rk3288-lcdc lcdc0: wakeup from standby! [ 0.719261] alloc_buffer:ion_phy_addr=0x55c00000 [ 0.725639] fb0:phy:55c00000>>vir:e0991000>>len:0xc00000 [ 0.731726] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.731918] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1 [ 0.731933] rk_fb_trsm_ops_get: unsupported transmitter: 0! [ 0.732168] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.732501] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.732676] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.732850] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.733096] unknow screen type: 0 [ 0.733160] rk3288-lcdc lcdc1: lcdc1: dclk:71000000>>fps:619 [ 0.757781] rk3288-lcdc lcdc1: wakeup from standby! [ 0.757798] fb4:phy:55c00000>>vir:e0991000>>len:0xc00000 [ 0.757813] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.758587] rockchip_set_mux:warning ignore bank num 15 [ 0.758722] rockchip_set_mux:warning ignore bank num 15 [ 0.758840] rockchip_set_mux:warning ignore bank num 15 [ 0.758964] rockchip_set_mux:warning ignore bank num 15 [ 0.759100] rockchip_set_mux:warning ignore bank num 15 [ 0.759222] rockchip_set_mux:warning ignore bank num 15 [ 0.759812] rockchip_set_mux:warning ignore bank num 15 [ 0.759973] rockchip_set_mux:warning ignore bank num 15 [ 0.760517] rockchip_set_mux:warning ignore bank num 15 [ 0.760665] rockchip_set_mux:warning ignore bank num 15 [ 0.761213] rockchip_set_mux:warning ignore bank num 15 [ 0.761362] rockchip_set_mux:warning ignore bank num 15 [ 0.761905] rockchip_set_mux:warning ignore bank num 15 [ 0.762057] rockchip_set_mux:warning ignore bank num 15 [ 0.762619] rockchip_set_mux:warning ignore bank num 15 [ 0.763789] cw201x:support DC charger [ 0.764787] cw_bat_probe cw_init error [ 0.764809] cw201x: probe of 0-0062 failed with error -11 [ 0.765301] NET: Registered protocol family 2 [ 0.765981] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.766061] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.766138] TCP: Hash tables configured (established 4096 bind 4096) [ 0.766199] TCP: reno registered [ 0.766217] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.766244] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.766440] NET: Registered protocol family 1 [ 0.766713] RPC: Registered named UNIX socket transport module. [ 0.766730] RPC: Registered udp transport module. [ 0.766741] RPC: Registered tcp transport module. [ 0.766751] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.767266] rk818-battery rk818-battery: Failed to request gpio 8 [ 0.768717] rk818-battery rk818-battery: invalid fcc(0x0), use design capacity [ 0.769446] rk818-battery rk818-battery: update fcc : 2100 [ 0.769695] rk818-battery rk818-battery: not battery, enter test power mode [ 0.788197] rk818-battery rk818-battery: v=4200, ov=4200, rv=0, c=0, pwroff_min=0 [ 0.792353] rk818-battery rk818-battery: loader charged [ 0.792371] rk818-battery rk818-battery: reg soc=0, init soc = 0, init cap=0 [ 0.817886] rk818-battery rk818-battery: battery driver version 4.0.0 [ 0.818349] Unpacking initramfs... [ 0.956308] Freeing initrd memory: 2848K (c5bf0000 - c5eb8000) [ 0.957112] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 0.959133] vcodec_service: No core reset resource define [ 0.959314] vcodec_service: ff9a0000.vpu_service: power on [ 0.959419] vcodec_service: probe device ff9a0000.vpu_service [ 0.959435] vcodec_service: checking hw id 4831 [ 0.959832] vcodec_service: ff9a0000.vpu_service: power off... [ 0.959869] vcodec_service: done [ 0.959880] vcodec_service: init success [ 0.960256] vcodec_service: ff9c0000.hevc_service: power on [ 0.960310] vcodec_service: probe device ff9c0000.hevc_service [ 0.960324] vcodec_service: checking hw id 6867 [ 0.960565] vcodec_service: ff9c0000.hevc_service: power off... [ 0.960603] vcodec_service: done [ 0.960613] vcodec_service: init success [ 0.960770] rknandbase v1.0 2014-03-31 [ 0.960890] rknand ff400000.nandc0: no irq resource? [ 0.961051] rknand_driver:ret = 0 [ 0.962357] audit: initializing netlink socket (disabled) [ 0.962411] type=2000 audit(0.620:1): initialized [ 0.963270] bounce pool size: 64 pages [ 0.967939] NFS: Registering the id_resolver key type [ 0.967996] Key type id_resolver registered [ 0.968009] Key type id_legacy registered [ 0.968393] fuse init (API version 7.22) [ 0.968774] msgmni has been set to 951 [ 0.969181] [ 0.969181] TEE Core Framework initialization (ver 1:0.1) [ 0.969212] TEE armv7 Driver initialization [ 0.969564] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ 0.969582] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ 0.969749] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=58) [ 0.971448] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.971468] io scheduler noop registered [ 0.971479] io scheduler deadline registered [ 0.971570] io scheduler cfq registered (default) [ 0.973041] hdmi phy_table not exist [ 0.973490] reset hdmi [ 0.973631] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess. [ 0.974444] iep ion client create success! [ 0.974459] IEP Driver loaded succesfully [ 0.974553] Module initialized. [ 0.975554] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.975574] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 0.976862] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.976883] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.977256] vdd_logic: 925 <--> 1400 mV at 1000 mV [ 0.977318] vdd_logic: Failed to create debugfs directory [ 0.977577] rk_serial.c v1.8 2014-03-04 [ 0.977809] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 0.978001] serial ff180000.serial: membase e259e000 [ 0.978258] arm_release_ver of this mali_ko is 'r6p0-02rel0', rk_ko_ver is '13', built at '12:00:37', on 'May 31 2016'. [ 0.978333] mali ffa30000.gpu: Continuing without Mali clock control [ 0.978372] mali pd enabled [ 0.978387] clk enabled [ 0.978399] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.978412] MALI_DVFS_STEP = 5, div_dvfs = 7 [ 0.978425] mali_dvfs_infotbl[0].clock=100000,min_threshold=0,max_threshold=70 [ 0.978439] mali_dvfs_infotbl[1].clock=200000,min_threshold=65,max_threshold=77 [ 0.978453] mali_dvfs_infotbl[2].clock=300000,min_threshold=75,max_threshold=84 [ 0.978466] mali_dvfs_infotbl[3].clock=420000,min_threshold=82,max_threshold=91 [ 0.978479] mali_dvfs_infotbl[4].clock=500000,min_threshold=93,max_threshold=100 [ 0.978609] turn on mali power [ 0.978626] kbase_platform_rk_init,register_reboot_notifier [ 0.978690] hrtimer: interrupt took 19250 ns [ 0.978698] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.978867] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1 [ 0.979600] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.979946] mali ffa30000.gpu: Probed as mali0 [ 0.980096] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 389; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-6ef3b6d', rk_ko_ver is '5', built at '10:47:54', on 'Jun 3 2016'. [ 0.980310] Mali: Mali device driver loaded [ 0.982978] loop: module loaded [ 0.983346] zram: Created 1 device(s) ... [ 0.983453] i2c-core: driver [mpu6050B1] using legacy suspend method [ 0.983466] i2c-core: driver [mpu6050B1] using legacy resume method [ 0.983487] mpu_init: Probe name mpu6050B1 [ 0.983660] ak8963_mod 1-000d: get compass-bus error [ 0.983673] parse ak8963 dts failed [ 0.983686] i2c i2c-1: ak8963_mod_probe: ak8963 [ 0.983696] yemk:ak8963_mod_probe [ 0.983711] i2c i2c-1: inv_mpu_register_slave: Null mpu_private_data [ 0.983723] invensense: in ak8963_mod_probe, result is -22 [ 0.983737] i2c i2c-1: Slave registration failed: ak8963, -22 [ 0.983750] i2c i2c-1: ak8963_mod_probe failed -22 [ 0.983769] ak8963_mod: probe of 1-000d failed with error -22 [ 0.983813] ak8963_mod_init: Probe name ak8963_mod [ 0.984671] SCSI Media Changer driver v0.25 [ 0.984920] dws->regs: e25be000 [ 0.985843] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok [ 0.985968] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000800,result=0xaa00 [ 0.985986] _rockchip_pinconf_set:GPIO7-13,group=spi1-cs0, function=gpio7_spi1, type=3 [ 0.986001] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10 [ 0.986015] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3 [ 0.986049] dws->regs: e25e2000 [ 0.986818] rockchip_spi_probe:num_cs=1,bus_num=1,irq=77,freq=45692308 ok [ 0.986981] dws->regs: e25e4000 [ 0.987673] rockchip_spi_probe:num_cs=2,bus_num=2,irq=78,freq=45692308 ok [ 0.987947] tun: Universal TUN/TAP device driver, 1.6 [ 0.987960] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 0.988105] vmac_init. [ 0.988468] PPP generic driver version 2.4.2 [ 0.988595] PPP BSD Compression module registered [ 0.988608] PPP Deflate Compression module registered [ 0.988640] PPP MPPE Compression module registered [ 0.988653] NET: Registered protocol family 24 [ 0.988693] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 0.988707] CSLIP: code copyright 1989 Regents of the University of California. [ 0.988720] Rockchip WiFi SYS interface (V1.00) ... [ 0.988761] esp_mem_init enter date May 31 2016 12:01:43 [ 0.988772] esp_mem_init VERSION [V2.5] [ 0.988816] esp_mem_init complete [ 0.988905] usbcore: registered new interface driver catc [ 0.988946] usbcore: registered new interface driver kaweth [ 0.988960] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 0.988999] usbcore: registered new interface driver pegasus [ 0.989038] usbcore: registered new interface driver rtl8150 [ 0.989076] usbcore: registered new interface driver r8152 [ 0.989089] hso: drivers/net/usb/hso.c: Option Wireless [ 0.989162] usbcore: registered new interface driver hso [ 0.989211] usbcore: registered new interface driver asix [ 0.989251] usbcore: registered new interface driver ax88179_178a [ 0.989290] usbcore: registered new interface driver cdc_ether [ 0.989327] usbcore: registered new interface driver cdc_eem [ 0.989365] usbcore: registered new interface driver dm9601 [ 0.989402] usbcore: registered new interface driver dm9620 [ 0.989454] usbcore: registered new interface driver smsc75xx [ 0.989501] usbcore: registered new interface driver smsc95xx [ 0.989541] usbcore: registered new interface driver gl620a [ 0.989580] usbcore: registered new interface driver net1080 [ 0.989619] usbcore: registered new interface driver plusb [ 0.989659] usbcore: registered new interface driver rndis_host [ 0.989698] usbcore: registered new interface driver cdc_subset [ 0.989742] usbcore: registered new interface driver zaurus [ 0.989784] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 0.989849] usbcore: registered new interface driver int51x1 [ 0.989890] usbcore: registered new interface driver kalmia [ 0.989929] usbcore: registered new interface driver ipheth [ 0.989970] usbcore: registered new interface driver sierra_net [ 0.990010] usbcore: registered new interface driver cx82310_eth [ 0.990063] usbcore: registered new interface driver cdc_ncm [ 0.990105] usbcore: registered new interface driver qmi_wwan [ 0.990145] usbcore: registered new interface driver cdc_mbim [ 0.990158] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.990170] ehci-platform: EHCI generic platform driver [ 0.992743] EHCI: ehci_rk_probe e2640000 e2640010 [ 0.992761] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 0.992793] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 0.993103] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 0.999280] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 1.003762] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 1.003861] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.003878] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.003893] usb usb1: Product: EHCI Host Controller [ 1.003906] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 1.003920] usb usb1: SerialNumber: ff500000.usb [ 1.004364] hub 1-0:1.0: USB hub found [ 1.004390] hub 1-0:1.0: 1 port detected [ 1.004560] EHCI: ehci_rk_probe ok [ 1.004665] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.004812] ohci-platform: OHCI generic platform driver [ 1.004983] usbcore: registered new interface driver cdc_acm [ 1.004995] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.005057] usbcore: registered new interface driver usblp [ 1.005103] usbcore: registered new interface driver cdc_wdm [ 1.005167] usbcore: registered new interface driver usb-storage [ 1.005206] usbcore: registered new interface driver ums-alauda [ 1.005245] usbcore: registered new interface driver ums-cypress [ 1.005284] usbcore: registered new interface driver ums-datafab [ 1.005321] usbcore: registered new interface driver ums_eneub6250 [ 1.005361] usbcore: registered new interface driver ums-freecom [ 1.005400] usbcore: registered new interface driver ums-isd200 [ 1.005445] usbcore: registered new interface driver ums-jumpshot [ 1.005485] usbcore: registered new interface driver ums-karma [ 1.005525] usbcore: registered new interface driver ums-onetouch [ 1.005564] usbcore: registered new interface driver ums-sddr09 [ 1.005603] usbcore: registered new interface driver ums-sddr55 [ 1.005645] usbcore: registered new interface driver ums-usbat [ 1.005737] usbcore: registered new interface driver usbserial [ 1.005780] usbcore: registered new interface driver usbserial_generic [ 1.005820] usbserial: USB Serial support registered for generic [ 1.005863] usbcore: registered new interface driver option [ 1.005894] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.005968] usbcore: registered new interface driver trancevibrator [ 1.005981] usb20_otg: version 3.10a 21-DEC-2012 [ 1.006419] e2680040 [ 1.006434] Core Release: 3.10a [ 1.006445] Setting default values for core params [ 1.006586] Using Buffer DMA mode [ 1.006598] Periodic Transfer Interrupt Enhancement - disabled [ 1.006609] Multiprocessor Interrupt Enhancement - disabled [ 1.006621] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.006631] ^^^^^^^^^^^^^^^^^Device Mode [ 1.006645] Dedicated Tx FIFOs mode [ 1.006665] pcd_init otg_dev = ddfbd840 [ 1.006834] usb20_otg ff580000.usb: DWC OTG Controller [ 1.006865] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 1.006902] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 1.006962] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.006978] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.006993] usb usb2: Product: DWC OTG Controller [ 1.007005] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.007018] usb usb2: SerialNumber: ff580000.usb [ 1.007434] hub 2-0:1.0: USB hub found [ 1.007458] hub 2-0:1.0: 1 port detected [ 1.007788] usb20_host: version 3.10a 21-DEC-2012 [ 1.010307] e2700040 [ 1.010320] Core Release: 3.10a [ 1.010332] Setting default values for core params [ 1.010456] Using Buffer DMA mode [ 1.010468] Periodic Transfer Interrupt Enhancement - disabled [ 1.010479] Multiprocessor Interrupt Enhancement - disabled [ 1.010490] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.010500] ^^^^^^^^^^^^^^^^^^Host Mode [ 1.010531] usb20_host ff540000.usb: DWC OTG Controller [ 1.010557] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 1.010587] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 1.010682] Init: Power Port (0) [ 1.010742] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.010758] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.010772] usb usb3: Product: DWC OTG Controller [ 1.010785] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.010797] usb usb3: SerialNumber: ff540000.usb [ 1.011196] hub 3-0:1.0: USB hub found [ 1.011225] hub 3-0:1.0: 1 port detected [ 1.011949] usbcore: registered new interface driver xpad [ 1.012012] usbcore: registered new interface driver usb_acecad [ 1.012061] usbcore: registered new interface driver aiptek [ 1.012108] usbcore: registered new interface driver gtco [ 1.012162] usbcore: registered new interface driver hanwang [ 1.012208] usbcore: registered new interface driver kbtab [ 1.012259] usbcore: registered new interface driver wacom [ 1.012548] ___vtl_ts_probe() end____ [ 1.012841] error tp_fw not node!!! [ 1.012858] vtl_ts 4-0001: VTL touch screen config Failed. [ 1.012864] Install touch driver. [ 1.012881] vtl_ts_Kthread exit,vtl_ts_handler(684) [ 1.012914] Goodix-TS 4-0055: power pin invalid [ 1.012958] sensor_register_slave:mma8452,id=17 [ 1.012973] sensor_register_slave:mma7660,id=18 [ 1.012984] sensor_register_slave:lsm303d,id=22 [ 1.012995] sensor_register_slave:gs_mc3230,id=23 [ 1.013004] gsensor_init [ 1.013015] sensor_register_slave:mpu6880_acc,id=24 [ 1.013025] sensor_register_slave:mpu6500_acc,id=25 [ 1.013037] sensor_register_slave:cm3217,id=48 [ 1.013048] sensor_register_slave:cm3218,id=49 [ 1.016332] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed [ 1.019060] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 1.020613] genirq: Flags mismatch irq 192. 00002002 (rtc_hym8563) vs. 00002002 (rk818) [ 1.020660] hym8563_probe:fail to request irq = 192, ret = 0xfffffff0 [ 1.023460] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 1.079021] goodix write cfg info err, retry 9 [ 1.102362] dwc_otg_hcd_suspend, usb device mode [ 1.112077] i2c /dev entries driver [ 1.112804] IR NEC protocol handler initialized [ 1.112818] IR RC5(x) protocol handler initialized [ 1.112828] IR RC6 protocol handler initialized [ 1.112838] IR JVC protocol handler initialized [ 1.112848] IR Sony protocol handler initialized [ 1.112857] IR RC5 (streamzap) protocol handler initialized [ 1.112868] IR SANYO protocol handler initialized [ 1.112878] IR MCE Keyboard/mouse protocol handler initialized [ 1.113046] usbcore: registered new interface driver uvcvideo [ 1.113059] USB Video Class driver (1.1.1) [ 1.113073] CamSys driver version: v0.33.0, CamSys head file version: v0.11.0 [ 1.114081] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288 [ 1.114081] [ 1.114160] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 1.114307] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe25f0000 size: 0x4000) [ 1.114934] D1:camsys_platform_probe(1394): ff910000.isp memory: [ 1.114953] D1:camsys_platform_probe(1404): Register memory (phy: 0xff910000 vir: 0xe2620000 size: 0x10000) [ 1.114969] D1:camsys_platform_probe(1399): I2c memory (phy: 0x1df5e000 vir: 0xddf5e000 size: 0x1000) [ 1.114984] D1:camsys_init_ext_fsh_module(20): init external flash module [ 1.114997] D1:camsys_platform_probe(1419): Probe ff910000.isp device success [ 1.115365] not find test_power_init dev node [ 1.116989] The device is not bq27320 -11 [ 1.117014] bq27320: probe of 0-0055 failed with error -11 [ 1.117068] i2c-core: driver [bq27320] using legacy suspend method [ 1.117081] i2c-core: driver [bq27320] using legacy resume method [ 1.117651] rockchip_temp_probe,line=375 [ 1.117980] tsadc ff280000.tsadc: Missing tsadc_low_temp in the DT. [ 1.171024] tsadc ff280000.tsadc: initialized [ 1.171416] device-mapper: uevent: version 1.0.3 [ 1.171668] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 1.171902] Bluetooth: HCI UART driver ver 2.2 [ 1.171918] Bluetooth: HCI H4 protocol initialized [ 1.171929] Bluetooth: HCILL protocol initialized [ 1.171941] rtk_btusb: Realtek Bluetooth USB driver module init, version 3.0 [ 1.171953] rtk_btusb: Register usb char device interface for BT driver [ 1.172138] usbcore: registered new interface driver rtk_btusb [ 1.172473] DVFS ERR: clk_enable_dvfs: vd(vd_gpu) can't get regulator(vdd_gpu)! [ 1.173083] cpufreq version 1.0, suspend freq 1200 MHz [ 1.173584] cpuidle: using governor ladder [ 1.173597] cpuidle: using governor menu [ 1.173635] Synopsys Designware Multimedia Card Interface Driver [ 1.173646] MHSC version = Ver 2.00 2015-06-10 [ 1.173982] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 1.174067] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc [ 1.174357] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 1.174536] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 1.174669] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_set_ios: no card. [mmc0] [ 1.190719] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_set_ios: no card. [mmc0] [ 1.210421] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 1.210450] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 1.210472] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 1.210825] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 1.210928] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc [ 1.211604] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 1.211774] dwmmc_rockchip ff0c0000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 1.211995] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 1.212073] dwmmc_rockchip ff0c0000.rksdmmc: dw_mci_set_ios: no card. [mmc1] [ 1.230067] dwmmc_rockchip ff0c0000.rksdmmc: dw_mci_set_ios: no card. [mmc1] [ 1.246746] goodix write cfg info err, retry 8 [ 1.249782] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 1.249795] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 1.250069] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 1.250127] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc [ 1.250277] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 1.250393] dwmmc_rockchip ff0d0000.rksdmmc: dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 1.250644] dwmmc_rockchip ff0d0000.rksdmmc: dw_mci_set_ios: no card. [mmc2] [ 1.269434] dwmmc_rockchip ff0d0000.rksdmmc: dw_mci_set_ios: no card. [mmc2] [ 1.289146] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 1.289158] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 1.289519] hidraw: raw HID events driver (C) Jiri Kosina [ 1.291014] usbcore: registered new interface driver usbhid [ 1.291024] usbhid: USB HID core driver [ 1.291133] ashmem: initialized [ 1.291255] logger: created 256K log 'log_main' [ 1.291355] logger: created 256K log 'log_events' [ 1.291454] logger: created 256K log 'log_radio' [ 1.291562] logger: created 256K log 'log_system' [ 1.292760] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input0 [ 1.294050] RT5631 Audio Codec 0.01 alsa 1.0.26 [ 1.413652] goodix write cfg info err, retry 7 [ 1.485912] rockchip_i2c ff660000.i2c: i2c is not in idle(state = 3) [ 1.485921] RT5631 probe error [ 1.485934] rt5631: probe of 2-001a failed with error -5 [ 1.580904] goodix write cfg info err, retry 6 [ 1.682715] rockchip_i2c ff660000.i2c: i2c is not in idle(state = 3) [ 1.682732] rt3261 && rt3224 probe error [ 1.682744] rt3261: probe of 2-001c failed with error -5 [ 1.683275] rockchip-spdif ff8b0000.rockchip-spdif: spdif ready. [ 1.683577] rockchip-rt5631 rockchip-rt5631.30: ASoC: CODEC (null) not registered [ 1.683609] rockchip_rt5631_audio_probe() register card failed:-517 [ 1.683623] platform rockchip-rt5631.30: Driver rockchip-rt5631 requests probe deferral [ 1.683837] rockchip-rt3261 rockchip-rt3224.31: ASoC: CODEC (null) not registered [ 1.683854] rockchip_rt3261_audio_probe() register card failed:-517 [ 1.683868] platform rockchip-rt3224.31: Driver rockchip-rt3261 requests probe deferral [ 1.686335] rockchip-hdmi-i2s rockchip-hdmi-i2s.28: rk-hdmi-i2s-hifi <-> ff890000.rockchip-i2s mapping ok [ 1.686807] u32 classifier [ 1.686814] Actions configured [ 1.686827] Netfilter messages via NETLINK v0.30. [ 1.686878] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 1.687165] ctnetlink v0.93: registering with nfnetlink. [ 1.687228] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 1.687235] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 1.687465] xt_time: kernel timezone is -0000 [ 1.687646] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.687762] arp_tables: (C) 2002 David S. Miller [ 1.687801] TCP: cubic registered [ 1.687808] Initializing XFRM netlink socket [ 1.687998] NET: Registered protocol family 10 [ 1.688425] mip6: Mobile IPv6 [ 1.688450] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.688562] sit: IPv6 over IPv4 tunneling driver [ 1.688873] NET: Registered protocol family 17 [ 1.688898] NET: Registered protocol family 15 [ 1.688947] Bridge firewalling registered [ 1.688959] Ebtables v2.0 registered [ 1.689111] Bluetooth: RFCOMM TTY layer initialized [ 1.689136] Bluetooth: RFCOMM socket layer initialized [ 1.689144] Bluetooth: RFCOMM ver 1.11 [ 1.689151] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 1.689157] Bluetooth: BNEP filters: protocol multicast [ 1.689168] Bluetooth: BNEP socket layer initialized [ 1.689175] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.689186] Bluetooth: HIDP socket layer initialized [ 1.689240] l2tp_core: L2TP core driver, V2.0 [ 1.689254] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 1.689261] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.689494] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 1.689506] [WLAN_RFKILL]: can't find rockchip,grf property [ 1.689514] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 1.689522] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 1.689531] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 1.689540] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 1.689561] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 148, flags = 0. [ 1.689582] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0. [ 1.689591] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 1.689612] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 1.689621] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.689668] [BT_RFKILL]: Enter rfkill_rk_init [ 1.689798] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139. [ 1.689815] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 147. [ 1.689829] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149. [ 1.689843] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146. [ 1.689856] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151. [ 1.689903] [BT_RFKILL]: Request irq for bt wakeup host [ 1.689998] [BT_RFKILL]: ** disable irq [ 1.690077] [BT_RFKILL]: ap6330 device registered. [ 1.690135] Key type dns_resolver registered [ 1.690920] rk3288_init_suspend [ 1.690932] rk3288_suspend_init enter [ 1.691167] rk3288_suspend_init: pm_ctrbits =200007 [ 1.691203] gpio_get_dts_info suspend:4 [ 1.691211] gpio_get_dts_info resume:4 [ 1.691217] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.691246] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.691386] clks_gating_suspend_init:clkgt info ok [ 1.691472] Registering SWP/SWPB emulation handler [ 1.691483] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000 [ 1.694334] ddrfreq: verion 1.2 20140526 [ 1.694350] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz [ 1.694358] ddrfreq: auto-freq=1 [ 1.694364] ddrfreq: auto-freq-table[0] 240MHz [ 1.694370] ddrfreq: auto-freq-table[1] 324MHz [ 1.694375] ddrfreq: auto-freq-table[2] 396MHz [ 1.694381] ddrfreq: auto-freq-table[3] 528MHz [ 1.701296] rk818_ldo2: disabling [ 1.701921] regulator-dummy: disabling [ 1.702283] rockchip-rt5631 rockchip-rt5631.30: ASoC: CODEC (null) not registered [ 1.702309] rockchip_rt5631_audio_probe() register card failed:-517 [ 1.702323] platform rockchip-rt5631.30: Driver rockchip-rt5631 requests probe deferral [ 1.702591] rockchip-rt3261 rockchip-rt3224.31: ASoC: CODEC (null) not registered [ 1.702609] rockchip_rt3261_audio_probe() register card failed:-517 [ 1.702622] platform rockchip-rt3224.31: Driver rockchip-rt3261 requests probe deferral [ 1.702646] ======================================================= [ 1.702653] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 1.702659] ======================================================= [ 1.702665] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init. [ 1.702728] dhd_module_init: in [ 1.702736] ======== bcm_wlan_set_plat_data ======== [ 1.702743] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 1.702766] host_oob_irq: 201 [ 1.702772] host_oob_irq_flags=4 [ 1.702777] dhd_wifi_platform_load: Enter [ 1.702790] pcd_pullup, is_on 0 [ 1.702795] Power-up adapter 'DHD generic adapter' [ 1.702813] wifi_platform_set_power = 1 [ 1.702819] ======== PULL WL_REG_ON HIGH! ======== [ 1.702826] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 1.702832] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1 [ 1.702835] file system registered [ 1.702844] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 1.703388] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 1.703398] android_usb gadget: Number of LUNs=2 [ 1.703406] lun0: LUN: removable file: (no medium) [ 1.703412] lun1: LUN: removable file: (no medium) [ 1.703573] android_usb gadget: android_usb ready [ 1.703683] i2c i2c-1: sensor_probe: gs_mma8452,de01d400 [ 1.703722] sensor_chip_init:gs_mma8452:devid=0x0,ops=0xc0dbbd48 [ 1.810616] [WLAN_RFKILL]: wifi turn on power. 148 [ 1.899189] rockchip_i2c ff140000.i2c: Addr[0x001d] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x0 [ 1.901169] rockchip_i2c ff140000.i2c: I2C_CON: start bit is set [ 2.017261] wifi_platform_bus_enumerate device present 1 [ 2.017269] ======== Card detection to detect SDIO card! ======== [ 2.017277] mmc2:mmc host rescan start! [ 2.086137] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 2.095987] rockchip_i2c ff140000.i2c: Addr[0x001d] wait event timeout, state: 3, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20 [ 2.098957] sensor_active:fail to active sensor [ 2.098963] sensor_init:line=188,error [ 2.098969] sensor_initial:fail to init sensor [ 2.098974] sensor_chip_init:fail to init sensor [ 2.098982] i2c i2c-1: sensor_probe failed -110 [ 2.098982] [ 2.098996] sensors: probe of 1-001d failed with error -110 [ 2.099035] i2c i2c-1: sensor_probe: gs_lis3dh,de01d600 [ 2.099064] sensor_chip_init:ops is null,sensor name is gs_lis3dh [ 2.099072] i2c i2c-1: sensor_probe failed -1 [ 2.099072] [ 2.099083] sensors: probe of 1-0019 failed with error -1 [ 2.099112] i2c i2c-1: sensor_probe: ak8963,de01d800 [ 2.099138] sensor_chip_init:ops is null,sensor name is ak8963 [ 2.099145] i2c i2c-1: sensor_probe failed -1 [ 2.099145] [ 2.099157] sensors: probe of 1-000d failed with error -1 [ 2.099186] i2c i2c-1: sensor_probe: l3g20d_gyro,de01da00 [ 2.099212] sensor_chip_init:ops is null,sensor name is l3g20d_gyro [ 2.099220] i2c i2c-1: sensor_probe failed -1 [ 2.099220] [ 2.099230] sensors: probe of 1-006b failed with error -1 [ 2.099283] sensor_init: Probe name sensors [ 2.099301] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 2.101489] rk818-rtc rk818-rtc: setting system clock to 2013-01-21 08:51:26 UTC (1358758286) [ 2.106756] rockchip_headset_probe() headset have hook adc mode [ 2.106885] input: rockchip_headset.33 as /devices/ff100000.adc/rockchip_headset.33/input/input1 [ 2.107460] rockchip-rt5631 rockchip-rt5631.30: ASoC: CODEC (null) not registered [ 2.107486] rockchip_rt5631_audio_probe() register card failed:-517 [ 2.107499] platform rockchip-rt5631.30: Driver rockchip-rt5631 requests probe deferral [ 2.107701] usbcore: registered new interface driver snd-usb-audio [ 2.107710] ALSA device list: [ 2.107717] #0: RK-HDMI-I2S [ 2.107744] rockchip-rt3261 rockchip-rt3224.31: ASoC: CODEC (null) not registered [ 2.107762] rockchip_rt3261_audio_probe() register card failed:-517 [ 2.107791] platform rockchip-rt3224.31: Driver rockchip-rt3261 requests probe deferral [ 2.282941] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 2.479742] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 2.479751] goodix write cfg info err, retry 5 [ 2.784786] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 2.981583] EHCI: rk_ehci_hcd_enable, disable host controller [ 2.981590] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 3.178386] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 3.375186] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 3.571982] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 3.670368] dwmmc_rockchip ff0f0000.rksdmmc: slot->flags = 1 [ 3.670380] CPU: 0 PID: 6 Comm: kworker/u8:0 Not tainted 3.10.0 #11 [ 3.670396] Workqueue: kmmcd mmc_rescan [ 3.670418] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 3.670433] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0xa4/0x264) [ 3.670446] [] (dw_mci_set_ios+0xa4/0x264) from [] (mmc_set_chip_select+0x18/0x1c) [ 3.670460] [] (mmc_set_chip_select+0x18/0x1c) from [] (mmc_go_idle+0x94/0xc4) [ 3.670472] [] (mmc_go_idle+0x94/0xc4) from [] (mmc_rescan_try_freq+0x54/0xd0) [ 3.670484] [] (mmc_rescan_try_freq+0x54/0xd0) from [] (mmc_rescan+0x204/0x298) [ 3.670498] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458) [ 3.670510] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4) [ 3.670523] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac) [ 3.670536] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x34) [ 3.670548] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_set_ios: wait for unbusy timeout.. STATUS = 0x206 [mmc0] [ 3.768787] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 3.965586] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 3.985263] failed to power up DHD generic adapter, 0 retry left [ 4.001044] wifi_platform_set_power = 0 [ 4.001051] ======== PULL WL_REG_ON LOW! ======== [ 4.001058] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 4.103341] [WLAN_RFKILL]: wifi shut off power. [ 4.103349] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0 [ 4.103355] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 4.103363] wifi_platform_bus_enumerate device present 0 [ 4.103369] ======== Card detection to remove SDIO card! ======== [ 4.103376] mmc2:mmc host rescan start! [ 4.103387] failed to power up DHD generic adapter, max retry reached** [ 4.103406] unregister wifi platform drivers [ 4.103412] wifi_platform_bus_enumerate device present 0 [ 4.103418] ======== Card detection to remove SDIO card! ======== [ 4.103424] mmc2:mmc host rescan start! [ 4.103431] dhd_module_init: Failed to load the driver, try cnt 0 [ 4.103452] dhd_module_init: Failed to load driver max retry reached** [ 4.103459] dhd_module_init: Exit err=-19 [ 4.162382] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 4.359188] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 4.565815] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 4.565824] goodix write cfg info err, retry 4 [ 4.870870] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 5.067661] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 5.264466] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 5.461262] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 5.658062] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 5.745222] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0 [ 5.854862] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 6.051663] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 6.130367] dwmmc_rockchip ff0f0000.rksdmmc: slot->flags = 1 [ 6.130387] CPU: 0 PID: 6 Comm: kworker/u8:0 Not tainted 3.10.0 #11 [ 6.130398] Workqueue: kmmcd mmc_rescan [ 6.130413] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 6.130425] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0xa4/0x264) [ 6.130437] [] (dw_mci_set_ios+0xa4/0x264) from [] (mmc_set_bus_mode+0x18/0x1c) [ 6.130449] [] (mmc_set_bus_mode+0x18/0x1c) from [] (mmc_attach_mmc+0x48/0x178) [ 6.130460] [] (mmc_attach_mmc+0x48/0x178) from [] (mmc_rescan_try_freq+0xb8/0xd0) [ 6.130472] [] (mmc_rescan_try_freq+0xb8/0xd0) from [] (mmc_rescan+0x204/0x298) [ 6.130484] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458) [ 6.130496] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4) [ 6.130507] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac) [ 6.130518] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x34) [ 6.130528] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_set_ios: wait for unbusy timeout.. STATUS = 0x206 [mmc0] [ 6.248461] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 6.445261] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 6.642061] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 6.642073] goodix write cfg info err, retry 3 [ 6.729220] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0 [ 6.729873] rk818-battery rk818-battery: set charge to digital termination mode [ 6.947102] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 7.143902] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 7.340700] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 7.537501] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 7.734303] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 7.931102] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 8.127901] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 8.324700] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 8.521501] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 8.718305] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 8.718318] goodix write cfg info err, retry 2 [ 8.875744] [otg id chg] last id -1 current id 1 [ 8.875760] PortPower off [ 8.875768] rk_battery_charger_detect_cb , battery_charger_detect 6 [ 8.975190] Using Buffer DMA mode [ 8.975201] Periodic Transfer Interrupt Enhancement - disabled [ 8.975207] Multiprocessor Interrupt Enhancement - disabled [ 8.975215] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 8.975222] ^^^^^^^^^^^^^^^^^Device Mode [ 8.975234] dwc_otg_hcd_resume, usb device mode [ 9.023341] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 9.082418] dwc_otg_hcd_suspend, usb device mode [ 9.220152] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 9.416943] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 9.466136] ***************vbus detect***************** [ 9.468318] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 9.613742] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 9.810545] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 10.007341] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 10.204151] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 10.400945] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 10.597744] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 10.794544] rockchip_i2c ff160000.i2c: i2c is not in idle(state = 3) [ 10.794556] goodix write cfg info err, retry 1 [ 10.902783] goodix write cfg info err [ 10.902793] goodix panel init fail [ 10.902799] rk ts init fail [ 10.902818] Goodix-TS: probe of 4-0055 failed with error -1 [ 10.903037] Freeing unused kernel memory: 368K (c0cbe000 - c0d1a000) [ 10.955324] type=1403 audit(1358758295.490:2): policy loaded auid=4294967295 ses=4294967295 [ 10.980685] init: could not import file '/init.recovery.rk30board.rc' from '/init.rc' [ 10.982317] init: invalid gid 'trace' [ 10.982384] bat_cap: oldcap path is /sys/devices/ff100000.adc [ 10.982425] bat_cap: oldcap_path no exist [ 10.983544] healthd: BatteryTemperaturePath not found [ 10.983558] healthd: BatteryTechnologyPath not found [ 10.984069] healthd: battery l=66 v=3800 t=0.0 h=2 st=2 c=1000 chg=a [ 10.984526] healthd: battery l=66 v=3800 t=0.0 h=2 st=2 c=1000 chg=a [ 10.984976] healthd: battery l=66 v=3800 t=0.0 h=2 st=2 c=1000 chg=a [ 11.009063] healthd: battery l=66 v=3800 t=0.0 h=2 st=2 c=1000 chg=a [ 11.009560] healthd: battery l=66 v=3800 t=0.0 h=2 st=2 c=1000 chg=a [ 11.010036] healthd: battery l=66 v=3800 t=0.0 h=2 st=2 c=1000 chg=a [ 11.050393] dwmmc_rockchip ff0f0000.rksdmmc: slot->flags = 1 [ 11.050413] CPU: 0 PID: 6 Comm: kworker/u8:0 Not tainted 3.10.0 #11 [ 11.050430] Workqueue: kmmcd mmc_rescan [ 11.050450] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 11.050464] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0xa4/0x264) [ 11.050477] [] (dw_mci_set_ios+0xa4/0x264) from [] (mmc_power_off+0x5c/0x7c) [ 11.050490] [] (mmc_power_off+0x5c/0x7c) from [] (mmc_rescan_try_freq+0xc8/0xd0) [ 11.050502] [] (mmc_rescan_try_freq+0xc8/0xd0) from [] (mmc_rescan+0x204/0x298) [ 11.050516] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458) [ 11.050528] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4) [ 11.050540] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac) [ 11.050553] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x34) [ 11.050564] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_set_ios: wait for unbusy timeout.. STATUS = 0x206 [mmc0] [ 11.070680] init: /dev/hw_random not found [ 11.071679] init: /dev/hw_random not found [ 11.072528] android_usb: already disabled [ ata.07en01]oki3gxfornd_T!: mobine h: ensnin' wonts harnefulad tossok ng{ror lrialto}'! [job11.nt3ol _Disoniing en_k deba: ingldne tfinernny taiata [ en1loo74ng9] r pandxrnies! [ Sta1.0ng 6e]oveny nitd 1il o[ Mo11Jan407 08init_na20_blk_ead:redl=neffffdli [vma11.1=496M] onso: UttyFeQ0 oproiperot.telt px=pertissirecandr /dboo/prardrtre=rkno:oar art 1k29xx791d:0nit: u000g x00rec000dusynt), fo000pec0@0x000pr000rtysc)o.prod08t.m@0xfac060er',esoe $e),me}000stead0x0 e00159er8elinix00usi000dex0001ted0(bnta),0or 01a000@ing002op00(y cku.pr0x0ct400del0x 005 ${0(me}he)ste0d0 [ 0011.00087900inpan u),0g d300ec0ted00ynt000forstee)ifx00g p000ert0039o.00(ialada, u,0x$0nam000ins003d 00(use.1598),0 i0it:00r@0x00y '000seadilno' pdasn't-@xis05BA00e eserndsto '$em.diaialnd [der11.15ged6]booit:ogonnxt e000n0@0'$rc00er0a0x0' w000e woadin. toestsys=20ass06-08oid:07b/an r bootmSer = ' now v=ce===nso=e===ed= a===Lin domamntdefterd;l_le se t /! ck/rknand_system 0stpullut4 isev/ 1 al_164vfat reev/strck/s 3 /cache ext4 /dev/block/rknand_cache 0 4 /metadata ext4 /dev/block/rknand_metadata 0 5 /data ext4 /dev/block/rknand_userdata 0 6 /cust ext4 /dev/block/rknand_cust 0 7 /custom ext4 /dev/block/rknand_custom 0 8 /radical_update ext4 /dev/block/rknand_radical_update 0 9 /misc mtd misc 0 10 /uboot mtd uboot 0 11 /charge mtd charge 0 12 /resource mtd resource 0 13 /parameter mtd parameter 0 14 /boot mtd boot 0 15 /recovery mtd recovery 0 16 /backup mtd backup 0 17 /tmp ramdisk ramdisk 0I/ [File] : bootable/recovery/recovery.cpp; [Line] : 1408; [Func] : SetSdcardRootPath; InternalSD_ROOT: /mnt/internal_sd
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 1410; [Func] : SetSdcardRootPath; ExternalSD_ROOT: /mnt/external_sd
failed to create /cache dir,err=File exists!
E:failed to mount /cache /dev/block/rknand_cache (No such file or directory)
E/ [File] : bootable/recovery/roots.cpp; [Line] : 138; [Func] : ensure_path_mounted; failed to mount /cache /dev/block/rknand_cache (No such file or directory)
delay 1sec
[ 11.434137] soft reconnect
[ 11.613378] Using Buffer DMA mode
[ 11.613391] Periodic Transfer Interrupt Enhancement - disabled
[ 11.613398] Multiprocessor Interrupt Enhancement - disabled
[ 11.613405] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 11.613412] ^^^^^^^^^^^^^^^^^Device Mode
[ 11.613451] soft connect!!!
[ 11.722301] USB RESET
[ 11.759798] android_work: sent uevent USB_STATE=CONNECTED
[ 11.763404] USB RESET
[ 11.833270] android_usb gadget: high-speed config #1: android
[ 11.833337] android_work: sent uevent USB_STATE=CONFIGURED
delay 1sec
D/ [File] : bootable/recovery/recovery.cpp; [Line] : 2265; [Func] : main; to dump args befor get_args() :
1 argument(s) :
/sbin/recovery
E:Can’t find misc
E/ [File] : bootable/recovery/bootloader.cpp; [Line] : 90; [Func] : get_bootloader_message_mtd; Can’t find misc
D/ [File] : bootable/recovery/recovery.cpp; [Line] : 604; [Func] : get_args; to dump ‘boot’ :
command :
status :
recovery :
stage :
E:Can’t mount /cache/recovery/command
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 298; [Func] : fopen_path; Can’t mount /cache/recovery/command
E:Can’t find misc
E/ [File] : bootable/recovery/bootloader.cpp; [Line] : 116; [Func] : set_bootloader_message_mtd; Can’t find misc
D/ [File] : bootable/recovery/recovery.cpp; [Line] : 2282; [Func] : main; to dump args after get_args() :
1 argument(s) :
/sbin/recovery
E:Can’t mount /cache/recovery/last_locale
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 298; [Func] : fopen_path; Can’t mount /cache/recovery/last_locale
locale is [(null)]
stage is
reason is [(null)]
can’t open /dev/tty0: No such file or directory
fb0 reports (possibly inaccurate):
vi.bits_per_pixel = 16
vi.red.offset = 11 .length = 5
vi.green.offset = 5 .length = 6
vi.blue.offset = 0 .length = 5
fi.line_length = 2560
[ 13.510382] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc0]
set config done failed: Bad address
framebuffer: 0 (1280 x 800) double_buffer 1
load png icon_installing, width 280 height 2975 channels 3
found frames = 7
[ 13.522889] rk3288-lcdc lcdc0: blank mode:0
[ 13.559586] mmc_host mmc0: Timeolo sepngng onmmrro (cwid0x 22000eirgt 20 schaus ls83202000)
[ 13.560614] dwmmc_rockchd ff prog0.rs_emmty,dw_dth_se2 hos:htno chad. [smc1]
oa 1ng 616gre dwfil_rowidhip2520deig0.r7 cmmcnelw_3c
_letd ps: sta ecerpty[mmidt
50 height 50 channels 1
load png stage_fill, width 50 height 50 channels 1
Recovery system v5.0
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 2379; [Func] : main; Recovery system v5.0, built at ‘09:48:00’, on ‘May 31 2016’.
failed to create /mnt/external_sd dir,err=File exists!
W/ [File] : bootable/recovery/roots.cpp; [Line] : 145; [Func] : ensure_path_mounted; trying mount /dev/block/mmcblk0p1 to ntfs
W/ [File] : bootable/recovery/roots.cpp; [Line] : 161; [Func] : ensure_path_mounted; trying mount /dev/block/mmcblk0 to ntfs
E:failed to mount /mnt/external_sd (No such device)
E/ [File] : bootable/recovery/roots.cpp; [Line] : 167; [Func] : ensure_path_mounted; failed to mount /mnt/external_sd (Bad address)
delay 2sec
delay 2sec
read cmdline
Not enter sdboot!
E/ [File] : bootable/recovery/roots.cpp; [Line] : 138; [Func] : ensure_path_mounted; failed to mount /cache /dev/block/rknand_cache (Bad address)
mount cache fail,so formate…
[ Ne7.6siz07]f fpees400 mu
block" dev=“tmpfet inofig66oneonteled: Bad codrey:vc4 fdeneed n /wri/bl} f/rknaid_c78 e wm=” 1(ove ad nass)
EtcoFilxt=: objtat_e/rlocverevioots0 pp;assiner p 3mis [Fe=1] : rma699olu] t fo=14t_ alumt(1mak758xt2 fa40:d o avdev denck/ {andd_nche } thr Bad=17drcom)
rfcoledy" cre=“e /and_e dhe"errontle =uistrecovefais0 tontexn=u:cacect/deblblo_d/rkce:d_ctcle (Blir demise re=ui
7.699493] typeset00 nfiit(one87583ed: 4ad ): res:
denieile{ c bote }le/r ove=17rootmm=pp;covine” n 1e=; [Fand] :chesuscopatxt=oun:re; verles0 o mntet /u:ohe cdev/block_rknice_cachclaBad ileresrmi
fave=d t[ rea.69/5eta tya d140errudile135ist8302.340il): toc: unen/me {ataiteev/enock/rr /rknand_cache" set “tmfis” one=fai7 sconte adu:rsse
pat moun995; ] tled=14 moaud /m135dat830d.v40:ock avnan deetad ta gead tr resor:rootk_dppiceLin tc: 1s=f [e pc] issnsu=1
pidnt 8 tadm=" faoveso pamat"/d.
bleed/rkze d_cfile"ystv="tEpfsrmano=ol67 : onte e=u: faeced rn s0 v/bntek/ru:obd_mt_rdatockith icead tcress=file permissive=1et config done failed: Bad address
E/ [File] : bootable/recovery/roots.cpp; [Line] : 316; [Func] : format_volume; format_volume: make ext4 failed on /dev/block/rknand_metadata with 1(Bad address)
failed to create /metadata dir,err=File exists!
E:failed to mount /metadata /dev/block/rknand_metadata (Block device required)
E/ [File] : bootable/recovery/roots.cpp; [Line] : 138; [Func] : ensure_path_mounted; failed to mount /metadata /dev/block/rknand_metadata (Bad address)
bootmode = unknown
Command: “/sbin/recovery”
ro.rk.cpu=rk3288v2
ro.rk.soc=rk3288
ro.rk.bt_enable=true
ro.rk.systembar.tabletUI=false
ro.rk.systembar.voiceicon=true
ro.rk.MassStorage=false
ro.rk.cpu_min_freq=126000
ro.rk.homepage_base=http://www.google.com/webhp?client={CID}&source=android-home
ro.rk.def_brightness=200
ro.rk.screenoff_time=60000
ro.rk.screenshot_enable=true
ro.rk.LowBatteryBrightness=false
ro.rk.install_non_market_apps=false
ro.sf.hwrotation=0
ro.sf.lcd_density=320
ro.sf.fakerotation=false
ro.adb.secure=0
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.ril.ecclist=112,911
ro.boot.console=ttyFIQ0
ro.boot.selinux=permissive
ro.boot.hardware=rk30board
ro.wifi.channels=
ro.allow.mock.location=1
ro.audio.monitorOrientation=true
ro.board.platform=rk3288
ro.build.id=LMY49F
ro.build.date=2016骞05鏈31鏃鏄熸湡浜09:20:07 CST
ro.build.date.utc=1464657607
ro.build.host=YX
ro.build.tags=test-keys
ro.build.type=eng
ro.build.user=williamxu
ro.build.flavor=rk3288-eng
ro.build.display.id=rk3288-eng 5.1.1 LMY49F eng.williamxu.20160531.091803 test-keys
ro.build.product=rk3288
ro.build.version.sdk=22
ro.build.version.base_os=
ro.build.version.release=5.1.1
ro.build.version.codename=REL
ro.build.version.incremental=eng.williamxu.20160531.091803
ro.build.version.all_codenames=REL
ro.build.version.security_patch=2016-03-01
ro.build.description=rk3288-eng 5.1.1 LMY49F eng.williamxu.20160531.091803 test-keys
ro.build.fingerprint=Android/rk3288/rk3288:5.1.1/LMY49F/williamxu05310919:eng/test-keys
ro.build.characteristics=tablet
ro.rksdk.version=RK30_ANDROID5.1.1-SDK-v1.00.00
ro.config.enable.remotecontrol=false
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.config.notification_sound=pixiedust.ogg
ro.dalvik.vm.native.bridge=0
ro.kernel.android.checkjni=0
ro.secure=0
ro.target.product=tablet
ro.tether.denied=false
ro.zygote=zygote32
ro.carrier=unknown
ro.default.size=100
ro.factory.tool=0
ro.factory.hasGPS=false
ro.factory.hasUMS=true
ro.factory.without_battery=false
ro.factory.storage_suppntfs=true
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.cpu.abilist=armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=
ro.product.ota.host:2300=www.rockchip.com
ro.product.name=rk3288
ro.product.board=rk30sdk
ro.product.brand=Android
ro.product.model=rk3288
ro.product.device=rk3288
ro.product.locale.region=US
ro.product.locale.language=en
ro.product.version=1.0.0
ro.product.usbfactory=rockchip_usb
ro.product.manufacturer=rockchip
ro.baseband=unknown
ro.bootmode=unknown
ro.hardware=rk30board
ro.opengles.version=196609
ro.revision=0
ro.bootloader=unknown
ro.debuggable=1
ro.factorytest=0
ro.enable_boot_charger_mode=0
sf.power.control=2073600
net.bt.name=Android
net.change=net.bt.name
ril.function.dataonly=1
sys.hwc.compose_policy=6
sys.rkadb.root=0
sys.wallpaper.rgb565=0
sys.resolution.changed=false
init.svc.adbd=running
init.svc.console=running
init.svc.healthd=running
init.svc.ueventd=running
init.svc.recovery=running
rild.libargs=-d /dev/ttyACM0
rild.libpath=/system/lib/libril-rk29-dataonly.so
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
debug.nfc.se=false
debug.nfc.fw_download=false
dalvik.vm.isa.arm.features=div
dalvik.vm.jniopts=warnonly
dalvik.vm.heapsize=512m
dalvik.vm.dex2oat-Xms=64m
dalvik.vm.dex2oat-Xmx=512m
dalvik.vm.heapmaxfree=8m
dalvik.vm.heapminfree=512k
dalvik.vm.dexopt-flags=m=y
dalvik.vm.heapstartsize=16m
dalvik.vm.dex2oat-filter=interpret-only
dalvik.vm.heapgrowthlimit=192m
dalvik.vm.stack-trace-file=/data/anr/traces.txt
dalvik.vm.image-dex2oat-Xms=64m
dalvik.vm.image-dex2oat-Xmx=64m
dalvik.vm.image-dex2oat-filter=verify-none
dalvik.vm.heaptargetutilization=0.75
camera2.portability.force_api=1
persist.sys.usb.config=mass_storage,adb
persist.sys.dalvik.vm.lib.2=libart.so
persist.sys.timezone=
persist.sys.strictmode.visual=false
persist.tegra.nvmmlite=1
testing.mediascanner.skiplist=/mnt/internal_sd/Android/
keyguard.no_require_sim=true
ExternalSD_ROOT=/mnt/external_sd
InternalSD_ROOT=/mnt/internal_sd
UserVolumeLabel=RockChip
D/ [File] : bootable/recovery/recovery.cpp; [Line] : 2623; [Func] : main; to mount ru_partition.failed to create /radical_update dir,err=File exists!
E:failed to mount /radical_update /dev/block/rknand_radical_update (No such file or directory)
E/ [File] : bootable/recovery/roots.cpp; [Line] : 138; [Func] : ensure_path_mounted; failed to mount /radical_update /dev/block/rknand_radical_update (Bad address)
E:To set ‘status’ to 1(‘INSTALL_ERROR’) : fail to mount ru_partition.
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 2626; [Func] : main; To set ‘status’ to 1(‘INSTALL_ERROR’) : fail to mount ru_partition.
E:failed to mount /cache /dev/block/rknand_cache (Block device required)
E:Can’t mount /cache/recovery/log
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 298; [Func] : fopen_path; Can’t mount /cache/recovery/log
E:Can’t open /cache/recovery/log
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 749; [Func] : copy_log_file; Can’t open /cache/recovery/log
E:Can’t mount /cache/recovery/last_log
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 298; [Func] : fopen_path; Can’t mount /cache/recovery/last_log
E:Can’t open /cache/recovery/last_log
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 749; [Func] : copy_log_file; Can’t open /cache/recovery/last_log
E:Can’t mount /cache/recovery/last_install
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 298; [Func] : fopen_path; Can’t mount /cache/recovery/last_install
E:Can’t open /cache/recovery/last_install
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 749; [Func] : copy_log_file; Can’t open /cache/recovery/last_install
E:Can’t mount /cache/recovery/last_kmsg
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 298; [Func] : fopen_path; Can’t mount /cache/recovery/last_kmsg
E:Can’t open /cache/recovery/last_kmsg
E/ [File] : bootable/recovery/recovery.cpp; [Line] : 733; [Func] : save_kernel_log; Can’t open /cache/recovery/last_kmsg
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 2707; [Func] : main; install failed, ‘status’ : 1; to prompt user and wait.
E:Can’t find misc
W/ [File] : bootable/recovery/recovery.cpp; [Line] : 855; [Func] : finish_recovery; Can’t unlink /cache/recovery/command
D/ [File] : bootable/recovery/recovery.cpp; [Line] : 1288; [Func] : prompt_and_wait; ‘status’ : 1.
V/ [File] : bootable/recovery/recovery.cpp; [Line] : 1303; [Func] : prompt_and_wait; to get menu selection.
