新编的5.1镜像启不起来
新编的镜像 有时启不起来 有时有启的起来,奇怪啊 ,启动不起来的log 也不一样
log1 如下:
34.550541] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 234.550551] read channel() error: -110
[ 235.632944] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 235.632953] read channel() error: -110
[ 236.715337] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 236.715347] read channel() error: -110
[ 237.797742] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 237.797751] read channel() error: -110
[ 238.880140] saradc-reg[0x00-0x0c]: 0x000003fe 0x00000000 0x00000069 0x00000008
[ 238.880150] read channel() error: -110
[ 239.962537] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 239.962547] read channel() error: -110
[ 241.044937] saradc-reg[0x00-0x0c]: 0x000003fe 0x00000000 0x00000069 0x00000008
[ 241.044947] read channel() error: -110
[ 242.127340] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 242.127350] read channel() error: -110
[ 243.209737] saradc-reg[0x00-0x0c]: 0x000003fe 0x00000000 0x00000069 0x00000008
[ 243.209746] read channel() error: -110
[ 244.292142] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 244.292151] read channel() error: -110
[ 245.374540] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 245.374550] read channel() error: -110
[ 246.456939] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 246.456948] read channel() error: -110
[ 247.539342] saradc-reg[0x00-0x0c]: 0x000003fe 0x00000000 0x00000069 0x00000008
[ 247.539351] read channel() error: -110
[ 248.621742] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 248.621752] read channel() error: -110
[ 249.704135] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 249.704144] read channel() error: -110
[ 250.786541] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 250.786551] read channel() error: -110
[ 251.868941] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 251.868951] read channel() error: -110
[ 252.951335] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 252.951345] read channel() error: -110
[ 254.033741] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 254.033751] read channel() error: -110
另一种情况log2
27.988590] sending IPI to all other CPUs:
[ 44.283335] ------------[ cut here ]------------
[ 44.283347] WARNING: at kernel/watchdog.c:259 watchdog_check_hardlockup_other_cpu+0xd0/0xf8()
[ 44.283353] Watchdog detected hard LOCKUP on cpu 0
[ 44.283358] Modules linked in: mali_kbase
[ 44.283368] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 3.10.0 #1
[ 44.283378] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 44.283389] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 44.283398] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 44.283409] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (watchdog_check_hardlockup_other_cpu+0xd0/0xf8)
[ 44.283420] [] (watchdog_check_hardlockup_other_cpu+0xd0/0xf8) from [] (watchdog_timer_fn+0x38/0x168)
[ 44.283430] [] (watchdog_timer_fn+0x38/0x168) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 44.283439] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 44.283449] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 44.283460] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 44.283471] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 44.283481] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 44.283489] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 44.283498] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 44.283504] Exception stack(0xde8c1f30 to 0xde8c1f78)
[ 44.283511] 1f20: de8c1f78 0000002b 45c1c808 0000000a
[ 44.283519] 1f40: c2ed72e0 00000000 45298584 0000000a c0bfafd8 de8c0000 c0bfafe8 00000000
[ 44.283526] 1f60: 35bcdab8 de8c1f78 c0079820 c05ac7e4 600f0013 ffffffff
[ 44.283534] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 44.283543] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 44.283552] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 44.283561] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 44.283570] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
[ 44.283576] —[ end trace d912e5427bdb333a ]—
各位有没有遇到类似的问题,求指导
先使用官方5.1的固件升级试试,确定是软件还是硬件问题
试了 还是启不起来 ,停在Android 那个大的logo那边,我另外一个板子就可以,启不起来的板子,偶尔也能起来,但是大部分时间是启不起来,log如上所示
首先,要先确定的是升级工具是v2.35版本,升级前进行低格,或进行插除flash,再进行升级,如果还是不行,可能硬件就有问题
jpchen 发表于 2016-7-13 15:04
首先,要先确定的是升级工具是v2.35版本,升级前进行低格,或进行插除flash,再进行升级,如果还是不行,可 …
关键是 有时也是可以的… 大部分情况下是 不可以的,
