/dts-v1/;
#include “rk3128.dtsi”
#include “rk3128-cif-sensor.dtsi”
#include “rk312x-sdk.dtsi”
#include “lcd-box.dtsi”
#include <dt-bindings/input/input.h>
compatible = “rockchip,rk3128”;
backlight: backlight {
compatible = “pwm-backlight”;
pwms = <&pwm0 0 25000>;
brightness-levels = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255>;
default-brightness-level = <128>;
enable-gpios = <&gpio0 GPIO_D3 GPIO_ACTIVE_HIGH>;
wireless-wlan {
compatible = “wlan-platdata”;
/* wifi_chip_type - wifi chip define
* bcmwifi ==> like ap6xxx, rk90, ...x;
* rtkwifi ==> like rtl8188xx, rtl8723xx, ...;
* esp8089 ==> esp8089;
* other ==> for other wifi;
wifi_chip_type = "bcmwifi";
sdio_vref = <3300>; //1800mv or 3300mv
//keep_wifi_power_on;
//power_ctrl_by_pmu;
power_pmu_regulator = "vccio";
power_pmu_enable_level = <1>; //1->HIGH, 0->LOW
//vref_ctrl_enable;
//vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
//vref_pmu_regulator = "act_ldo3";
//vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW
WIFI,poweren_gpio = <&gpio1 GPIO_B3 GPIO_ACTIVE_HIGH>;
WIFI,host_wake_irq = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
//WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>;
status = "okay";
wireless-bluetooth {
compatible = "bluetooth-platdata";
//wifi-bt-power-toggle;
uart_rts_gpios = <&gpio0 GPIO_C1 GPIO_ACTIVE_LOW>;
pinctrl-names = "default","rts_gpio";
pinctrl-0 = <&uart0_rts>;
pinctrl-1 = <&uart0_rts_gpio>;
//BT,power_gpio = <&gpio1 GPIO_B3 GPIO_ACTIVE_HIGH>;
BT,reset_gpio = <&gpio1 GPIO_A3 GPIO_ACTIVE_HIGH>;
BT,wake_gpio = <&gpio1 GPIO_B2 GPIO_ACTIVE_HIGH>;
BT,wake_host_irq = <&gpio1 GPIO_B1 GPIO_ACTIVE_LOW>;
status = "disabled";
leds {
compatible = "gpio-leds";
power {
label = "firefly:blue:power";
linux,default-trigger = "ir-power-click";
default-state = "on";
gpios = <&gpio1 GPIO_C7 GPIO_ACTIVE_LOW>;
user {
label = "firefly:yellow:user";
linux,default-trigger = "ir-user-click";
default-state = "off";
gpios = <&gpio1 GPIO_C6 GPIO_ACTIVE_LOW>;
gpios-v01 = <&gpio2 GPIO_A3 GPIO_ACTIVE_LOW>;
rockchip-spdif-card {
compatible = "rockchip-spdif-card";
dais {
dai0 {
audio-codec = <&codec_hdmi_spdif>;
audio-controller = <&spdif>;
usb_control {
compatible = "rockchip,rk3126-usb-control";
host_drv_gpio = <&gpio3 GPIO_C4 GPIO_ACTIVE_LOW>;
otg_drv_gpio = <&gpio0 GPIO_D6 GPIO_ACTIVE_LOW>;
rockchip,remote_wakeup;
rockchip,usb_irq_wakeup;
rockchip_suspend {
rockchip,ctrbits = <
(0
|RKPM_CTR_PWR_DMNS
|RKPM_CTR_GTCLKS
|RKPM_CTR_PLLS
//|RKPM_CTR_ARMOFF_LPMD
|RKPM_CTR_DDR
|RKPM_CTR_IDLESRAM_MD
|RKPM_CTR_DDR
//|RKPM_CTR_BUS_IDLE
//|RKPM_CTR_VOLTS
//|RKPM_CTR_VOL_PWM1
//|RKPM_CTR_VOL_PWM2
rockchip,pmic-suspend_gpios = <GPIO3_C1>;
test-power {
status = “okay”;
&i2c0 {
status = “okay”;
rtc@51 {
compatible = “rtc,hym8563”;
reg = <0x51>;
irq_gpio = <&gpio0 GPIO_D4 IRQ_TYPE_EDGE_FALLING>;
ts@41 {
compatible = “tchip,gsl3680”;
reg = <0x41>;
touch-gpio = <&gpio1 GPIO_B4 IRQ_TYPE_EDGE_RISING>;
//reset-gpio = <&gpio8 GPIO_A6 GPIO_ACTIVE_LOW>;
max-x = <1280>;
max-y = <800>;
&fb {
rockchip,disp-mode = <NO_DUAL>;
rockchip,disp-policy = <DISPLAY_POLICY_BOX>;
rockchip,uboot-logo-on = <1>;
&disp_timings {
native-mode = <&timing0>;
&rk_screen {
display-timings = <&disp_timings>;
&lvds {
status = “okay”;
pinctrl-names = "lcdc";
pinctrl-0 = <&lcdc0_lcdc_d>;
&lcdc {
status = “okay”;
rockchip,fb-win-map = <FB0_WIN0_FB1_WIN1_FB2_WIN2>;
&hdmi {
status = “okay”;
rockchip,hdmi_audio_source = <1>;
&tve {
status = “okay”;
test_mode = <0>;
&uart0 {
status = “okay”;
dma-names = “!tx”, “!rx”;
pinctrl-0 = <&uart0_xfer &uart0_cts>;
&spi0 {
status = “disabled”;
&uart0 {
status = “okay”;
pinctrl-0 = <&uart1_xfer &uart1_cts>;
&sdmmc {
status = “okay”;
cd-gpios = <&gpio1 GPIO_C1 GPIO_ACTIVE_HIGH>;/CD GPIO/
&key {
power-key {
gpios = <&gpio3 GPIO_C7 GPIO_ACTIVE_LOW>;
linux,code = <116>;
label = “power”;
gpio-key,wakeup;
recovery-key {
linux,code = <113>;
label = “recovery”;
rockchip,adc_value = <4>;
&dwc_control_usb {
usb_uart {
&codec {
spk_ctl_io = <&gpio3 GPIO_C5 GPIO_ACTIVE_HIGH>;
aux_det_io = <&gpio0 GPIO_D3 GPIO_ACTIVE_HIGH>;
spk-mute-delay = <200>;
hp-mute-delay = <100>;
rk312x_for_mid = <0>;
is_rk3128 = <0>;
spk_volume = <25>;
hp_volume = <25>;
capture_volume = <26>;
gpio_debug = <1>;
codec_hp_det = <0>;
&rk3128_cif_sensor{
status = “okay”;
&i2c2 {
&gmac_clkin {
clock-frequency = <125000000>;
&gmac {
//pmu_regulator = “act_ldo5”;
//pmu_enable_level = <1>; //1->HIGH, 0->LOW
//power-gpio = <&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
reset-gpio = <&gpio2 GPIO_D0 GPIO_ACTIVE_LOW>;
phyirq-gpio = <&gpio0 GPIO_D0 GPIO_ACTIVE_LOW>;
phy-mode = “rgmii”;
clock_in_out = “input”;
tx_delay = <0x30>;
rx_delay = <0x10>;
&pwm1 {
status = “okay”;
&clk_core_dvfs_table {
operating-points = <
/* KHz uV /
216000 925000
408000 925000
600000 950000
696000 975000
816000 1050000
1008000 1175000
1200000 1300000
1296000 1350000
1320000 1375000
virt-temp-limit-1-cpu-busy = <
/ target-temp limit-freq /
75 1008000
85 1200000
95 1200000
100 1200000
virt-temp-limit-2-cpu-busy = <
75 912000
85 1008000
95 1104000
100 1200000
virt-temp-limit-3-cpu-busy = <
75 816000
85 912000
95 100800
100 110400
virt-temp-limit-4-cpu-busy = <
/ target-temp limit-freq */
75 816000
85 912000
95 100800
100 110400
temp-limit-enable = <1>;
target-temp = <85>;
status=“okay”;
&clk_gpu_dvfs_table {
/* KHz uV */
200000 950000
300000 975000
400000 1075000
//480000 1175000
status=“okay”;
&clk_ddr_dvfs_table {
/* KHz uV */
200000 1250000
300000 1250000
400000 1250000
operating-points-v01 = <
/* KHz uV */
200000 950000
300000 950000
400000 1200000
533000 1250000
freq-table = <
/*status freq(KHz)*/
SYS_STATUS_NORMAL 500000
SYS_STATUS_SUSPEND 200000
SYS_STATUS_VIDEO_1080P 240000
SYS_STATUS_VIDEO_4K 400000
SYS_STATUS_PERFORMANCE 528000
SYS_STATUS_DUALVIEW 400000
SYS_STATUS_BOOST 324000
SYS_STATUS_ISP 533000
auto-freq-table = <
240000
324000
396000
528000
auto-freq=<0>;
status="okay";
&remotectl {
handle_cpu_id = <2>;
ir_key1{
rockchip,usercode = <0xff00>;
rockchip,key_table =
<0xeb KEY_POWER>,
<0xa3 250>,
<0xec KEY_MENU>,
<0xfc KEY_UP>,
<0xfd KEY_DOWN>,
<0xf1 KEY_LEFT>,
<0xe5 KEY_RIGHT>,
<0xf8 KEY_REPLY>,
<0xb7 KEY_HOME>,
<0xfe KEY_BACK>,
<0xa7 KEY_VOLUMEDOWN>,
<0xf4 KEY_VOLUMEUP>;
