DDR Version 1.00 20150318
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Apr 15 2016 - 15:17:22)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2016-04-15#2.19
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
can’t find power_ctr node for lcdc1
failed to find part:logo
no fuel gauge found
load fdt from resouce.
ERROR: [get_entry_ram]: Cannot
find logo_kernel.bmp!
Secure Boot state: 0
kernel @ 0x02000000 (0x00694938)
ramdisk @ 0x05bf0000 (0x00147bf4)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561b7fc … OK
