大家好,我用Firefly-RK3288_SDBoot_Ubuntu14.04_201503021436.7z 解压出来的img 烧写 32G 的SD 卡, 无法顺利启动。 32G class10 的SD卡, 以下是log:
U-Boot 2014.10-RK3288-10-g65679f1 (Jul 20 2015 - 10:28:11)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
remotectl v0.1
SDCard Boot.
storage init OK!
GetParam
check parameter success
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 0000-00-00#0.00
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
checkKey
vbus = 0
got recovery cmd from misc.
boot/recovery image sha mismatch!
Unable to boot:recovery
try to start backup
bad image magic.
load boot image failed
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
