rk3288-reload如何制作linux根文件系统?
按照wiki上的教程,刷了个官方的Android固件,然后把miniroot和misc刷进recovery和misc分区,重启后串口不断打印信息如下:
DDR Version 1.00 20150318
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10-g65679f1 (Jul 20 2015 - 10:28:11)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
remotectl v0.1
storage init OK!
GetParam
check parameter success
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2015-07-20#2.19
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
checkKey
vbus = 0
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x0060b2a0)
ramdisk @ 0x05bf0000 (0x00199964)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561b5ad … OK
一直不断重复,根本无法进入miniroot,这个教程是不是针对rk3288的,不适用用reload板?
最简单的方法,先下载官方的Ubuntu软件,然后自己进行裁剪,在保存
Android5.1的内核+官方的Ubuntu core无法正常启动,我的是3288reload的板,按照wiki教程根本不能成功
