问题:
接上官方的DVP接口的s5k4ecgx摄像头,上电开机,/dev/下找不到video设备。
这里要发下牢骚:官方什么时候可以出ubuntu/linux下直接支持rk3288 dvp接口摄像头的内核,也省得每个人都花时间做适配。
用的ubuntu镜像版本:FireFly-RK3288-Reload_Ubuntu14.04_201603111814
已进行操作如下:
1、
从https://bitbucket.org/T-Firefly/firenow-lollipop/commits/branch/Firefly-RK3288上下载 android5.1 sdk 最新的内核
git pull bitbucket Firefly-RK3288:Firefly-RK3288
make firefly-rk3288-reload-linux_defconfig
make menuconfig;加上cif选项
2、
从fireprime的内核中,把 ./drivers/media/video/s5k4ec.c,复制过来并修改修改Makefile
参照fireprime的内核,修改./include/media/v4l2-chip-ident.h,添加相关宏
参照fireprime的内核,修改./arch/arm/mach-rockchip/rk_camera.c
在./arch/arm/boot/dts下修改rk3288-cif-sensor.dts,添加
14 s5k4ec{
15 status = “okay”;
16 is_front = <0>;
17 //rockchip,power_pmu_name1 = “rk818_ldo4”;/*cif 2.8v /
18 //rockchip,power_pmu_voltage1 = <2800000>;
19 //rockchip,power_pmu_name2 = “rk818_ldo8”;/ cif 1.8v */
20 //rockchip,power_pmu_voltage2 = <1800000>;
21 rockchip,powerdown = <&gpio3 GPIO_B4 GPIO_ACTIVE_HIGH>;
22 pwdn_active = <0>;
23 tchip,rst = <&gpio2 GPIO_B7 GPIO_ACTIVE_LOW>;
24 //rockchip,power = <&gpio3 GPIO_D7 GPIO_ACTIVE_HIGH>;
25 //pwr_active = <PWR_ACTIVE_HIGH>;
26 #rockchip,reset = <>;
27 #rst_active = <>;
28 flash_attach = <1>;
29 rockchip,flash = <&gpio2 GPIO_C6 GPIO_ACTIVE_HIGH>; //不知道怎么修改
30 flash_active = <GPIO_ACTIVE_LOW>;
31 #rockchip,af = <>;
32 mir = <0>;
33 resolution = <0x500000>;
34 powerup_sequence = <s5k4ec_PWRSEQ_DEFAULT>;
35 orientation = <0>;
36 i2c_add = <s5k4ec_I2C_ADDR>;
37 i2c_rata = <20000>;
38 i2c_chl = <3>;
39 cif_chl = <0>;
40 mclk_rate = <24>;
41 };
修改 arch/arm/boot/dts/firefly-rk3288-reload-linux.dts@@ -1,6 +1,7 @@
/dts-v1/;
#include “rk3288.dtsi”
+#include “rk3288-cif-sensor.dtsi”
#include “lcd-box.dtsi”
#include <dt-bindings/input/input.h>
@@ -191,6 +192,10 @@
+&rk3288_cif_sensor {
status = "okay";
3、
make -j8 firefly-rk3288-reload-linux.img
从官方镜像的linux-boot.img提取initrd.img,并与新编译的kernel压缩
mkbootimg --kernel arch/arm/boot/zImage --ramdisk initrd.img -o kernel-boot.img
4、
kernel-boot.img下载到boot分区,resource.img下载到resource分区,
开机后进入系统,还是找不到video设备
内核打印信息:
[ 1.834056] Key type dns_resolver registered
[ 1.834179] rk_cam_cif(3053):rk312x-camera version: v0.2.0 Zoom by ipp
[ 1.834455] rockchip-pinctrl ff770000.pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff950000.cif
[ 1.834477] rockchip-pinctrl ff770000.pinctrl: pin-75 (ff950000.cif) status -22
[ 1.834490] rockchip-pinctrl ff770000.pinctrl: could not request pin 75 on device rockchip-pinctrl
[ 1.834504] rk_cif ff950000.cif: Error applying setting, reverse things back
[ 1.834517] rk_cif ff950000.cif: rk_camera_cif_iomux:could not set cif_pin_all pins
[ 1.834700] soc-camera-pdrv s5k4ec_back_3: Probing s5k4ec_back_3
[ 2.381463] udevd[150]: starting version 175
[ 2.423244] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 2.423273] s5k4ec_back_3(rk_cam_sensor:167): write reg(0xfcfc, val:0xd000) failed, try to write again!
[ 2.462595] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.620004] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 2.620027] s5k4ec_back_3(rk_cam_sensor:167): write reg(0xfcfc, val:0xd000) failed, try to write again!
[ 2.620052] s5k4ec_back_3(rk_cam_sensor:385): write array failed!
[ 2.620061] s5k4ec_back_3(rk_cam_sensor:669): soft reset failed
[ 2.620061]
[ 2.669237] mmc2:mmc host rescan start!
[ 2.728207] EXT4-fs (mmcblk0p5): 2 orphan inodes deleted
[ 2.728221] EXT4-fs (mmcblk0p5): recovery complete
[ 2.731094] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.836494] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 2.836519] s5k4ec_back_3(rk_cam_sensor:167): write reg(0x2c, val:0x7000) failed, try to write again!
[ 2.920336] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.921848] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.923356] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.926072] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.978600] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.980815] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.980840] mmc2: new high speed SDIO card at address 0001
[ 2.999732] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.999744] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 2.999754] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.005830] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.033284] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 3.033301] s5k4ec_back_3(rk_cam_sensor:167): write reg(0x2c, val:0x7000) failed, try to write again!
[ 3.083851] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.112000] [WLAN_RFKILL]: wifi shut off power.
[ 3.112011] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.112021] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.230086] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 3.230102] s5k4ec_back_3(rk_cam_sensor:167): write reg(0x2c, val:0x7000) failed, try to write again!
[ 3.426883] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 3.426898] s5k4ec_back_3(rk_cam_sensor:167): write reg(0x2e, val:0x1a4) failed, try to write again!
[ 3.446577] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.623685] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 3.623699] s5k4ec_back_3(rk_cam_sensor:167): write reg(0x2e, val:0x1a4) failed, try to write again!
[ 3.643567] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.643583] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.643595] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.643854] hub 3-1:1.0: USB hub found
[ 3.643904] hub 3-1:1.0: 4 ports detected
[ 3.820478] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 3.820493] s5k4ec_back_3(rk_cam_sensor:167): write reg(0x2e, val:0x1a4) failed, try to write again!
[ 4.017282] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 4.017296] s5k4ec_back_3(rk_cam_sensor:333): read reg(0xf12 val:0x0) failed, try to read again!
[ 4.017319] s5k4ec_back_3(rk_cam_sensor:716): error: mismatched pid = 0xffff
[ 4.017319]
ules/3.10.0/modules.dep: No such file or directory
请问还需要修改什么地方,
才能让FireFly-RK3288-Reload在ubuntu/linux可以支持DVP接口的s5k4ecgx摄像头?
