<已解决>RK3288点14寸EDP屏,背光点不亮,求解
按照维基里点MIPI的方法点EDP,背光控制接的是PWM0,背光使能接的是GPIO7_A2,置高电平背光还是没反应。我把开机logo贴出来:
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (zdd@zdd-machine) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Aug 12 14:18:30 CST 2016
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<6>[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x01000000
<6>[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(drm): base(0) size(0) align(0)
<6>[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 640 MiB at 55c00000
<6>[ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<4>[ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0d6fcc0, node_mem_map c0e99000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ef2000 s13376 r8192 d15296 u36864
<7>[ 0.000000] pcpu-alloc: s13376 r8192 d15296 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000:0x01000000 loader.timestamp=2016-07-26_12:47:19
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 1354992k/1354992k available, 742160k reserved, 884736K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0b8c32c (11793 kB)
<5>[ 0.000000] .init : 0xc0b8d000 - 0xc0be5440 ( 354 kB)
<5>[ 0.000000] .data : 0xc0be6000 - 0xc0d77300 (1605 kB)
<5>[ 0.000000] .bss : 0xc0d77300 - 0xc0e986fc (1157 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000]
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start!
<3>[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
<3>[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 28
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 2
<6>[ 0.000000] channel:0, lkg:15
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:13
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.342384] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.342400] pid_max: default: 32768 minimum: 301
<6>[ 0.342514] Security Framework initialized
<6>[ 0.342529] SELinux: Initializing.
<7>[ 0.342564] SELinux: Starting in permissive mode
<6>[ 0.342601] Mount-cache hash table entries: 512
<6>[ 0.343241] Initializing cgroup subsys debug
<6>[ 0.343256] Initializing cgroup subsys memory
<6>[ 0.343282] Initializing cgroup subsys freezer
<6>[ 0.343311] CPU: Testing write buffer coherency: ok
<3>[ 0.343625] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.343639] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.343648] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.343657] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.343711] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.343762] Setting up static identity map for 0xc084e078 - 0xc084e0d0
<6>[ 0.346198] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1830 (version 3.1)
<4>[ 0.420538] CPU1: Booted secondary processor
<6>[ 0.420570] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.440213] CPU2: Booted secondary processor
<6>[ 0.440237] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.459922] CPU3: Booted secondary processor
<6>[ 0.459945] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.460046] Brought up 4 CPUs
<6>[ 0.460074] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.460084] CPU: All CPU(s) started in SVC mode.
<6>[ 0.460812] devtmpfs: initialized
<6>[ 0.464989] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<6>[ 0.466077] pinctrl core: initialized pinctrl subsystem
<6>[ 0.466330] regulator-dummy: no parameters
<6>[ 0.490443] NET: Registered protocol family 16
<6>[ 0.492259] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.492611] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e73a0c (version 0.1)
<6>[ 0.492841] Registered FIQ tty driver
<3>[ 0.493241] fiq-debugger is disabled in device tree
<4>[ 0.493886] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.493907] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.493924] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.493941] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.494032] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.494097] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.494158] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.494220] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.494281] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.494342] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.494403] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.494464] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.494530] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.494594] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.494606] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.494618] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.494629] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.494707] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.494763] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.494817] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.494877] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.494930] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.494983] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.495042] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.495096] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.495149] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.495209] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.495235] rockchip_interrupts_register:bank_num=7
<7>[ 0.497118] of_get_named_gpio_flags exited with status 256
<4>[ 0.497130] of_get_gpio_init_config:gpio[0] = 256, value = 0
<7>[ 0.497142] of_get_named_gpio_flags exited with status 233
<4>[ 0.497151] of_get_gpio_init_config:gpio[1] = 233, value = 0
<7>[ 0.497163] of_get_named_gpio_flags exited with status 136
<4>[ 0.497173] of_get_gpio_init_config:gpio[2] = 136, value = 0
<4>[ 0.497234] rockchip_pinctrl_probe:init ok
<6>[ 0.503418] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.503508] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.503522] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.503690] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.503758] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.503770] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.503942] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.504012] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504025] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.504196] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.504267] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504279] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.504458] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.504534] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504546] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.504727] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.504797] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504809] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.504989] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.505065] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.505078] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.506849] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.506862] hw-breakpoint: maximum watchpoint size is 4 bytes.
<3>[ 0.507438] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
<4>[ 0.507460] DDR DEBUG: version 1.00 20150126
<4>[ 0.507488] DDR DEBUG: Channel a:
<4>[ 0.507496] DDR DEBUG: DDR3 Device
<4>[ 0.507510] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.507518] DDR DEBUG: Channel b:
<4>[ 0.507525] DDR DEBUG: DDR3 Device
<4>[ 0.507538] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.507547] DDR DEBUG: addr=0xd81000
<4>[ 0.507556] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.507564] DDR DEBUG: socAddr[0]=0xd81000, socAddr[1]=0xd81100
<4>[ 0.507574] DDR DEBUG: chAddr[0]=0xd81000, chAddr[1]=0xd81000
<4>[ 0.507585] DDR DEBUG: dtar[0]=0x101b0000, dtar[1]=0x101b0000
<4>[ 0.507640] DDR DEBUG: init success!!! freq=200MHz
<4>[ 0.507648] DDR DEBUG: Channel a:
<4>[ 0.507661] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.507673] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.507686] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.507699] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.507711] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.507720] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.507729] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.507736] DDR DEBUG: Channel b:
<4>[ 0.507748] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.507760] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.507772] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.507784] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.507795] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.507804] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.507812] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.532057] bio: create slab at 0
<6>[ 0.532506] Rockchip hdmi driver version 2.0
<6>[ 0.532506] .
<5>[ 0.533612] SCSI subsystem initialized
<6>[ 0.533759] usbcore: registered new interface driver usbfs
<6>[ 0.533809] usbcore: registered new interface driver hub
<6>[ 0.533896] usbcore: registered new device driver usb
<7>[ 0.534145] of_get_named_gpio_flags exited with status 14
<7>[ 0.534177] of_get_named_gpio_flags exited with status 12
<7>[ 0.535206] of_get_named_gpio_flags exited with status 15
<7>[ 0.535226] of_get_named_gpio_flags exited with status 16
<6>[ 0.536532] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.536643] of_get_named_gpio_flags exited with status 260
<7>[ 0.536662] of_get_named_gpio_flags exited with status 261
<6>[ 0.536996] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.537101] of_get_named_gpio_flags exited with status 201
<7>[ 0.537120] of_get_named_gpio_flags exited with status 202
<6>[ 0.537445] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.537549] of_get_named_gpio_flags exited with status 81
<7>[ 0.537566] of_get_named_gpio_flags exited with status 80
<6>[ 0.537700] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.537801] of_get_named_gpio_flags exited with status 241
<7>[ 0.537819] of_get_named_gpio_flags exited with status 242
<6>[ 0.538715] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.538838] media: Linux media interface: v0.10
<6>[ 0.538877] Linux video capture interface: v2.00
<6>[ 0.538939] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.538949] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.538968] PTP clock support registered
<4>[ 0.539025] i2c-core: driver [bq24296] using legacy suspend method
<4>[ 0.539034] i2c-core: driver [bq24296] using legacy resume method
<4>[ 0.539740] ion_drm_heap_create: 0@0
<6>[ 0.539875] Rockchip ion module is successfully loaded (v1.1)
<6>[ 0.540034] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.540429] Bluetooth: Core ver 2.16
<6>[ 0.540466] NET: Registered protocol family 31
<6>[ 0.540476] Bluetooth: HCI device and connection manager initialized
<6>[ 0.540491] Bluetooth: HCI socket layer initialized
<6>[ 0.540504] Bluetooth: L2CAP socket layer initialized
<6>[ 0.540529] Bluetooth: SCO socket layer initialized
<6>[ 0.540759] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.541457] act8846_i2c_probe,line=898
<4>[ 0.542432] act8846_parse_dt,line=746
<7>[ 0.542855] of_get_named_gpio_flags exited with status 238
<7>[ 0.542869] of_get_named_gpio_flags exited with status 1
<7>[ 0.542880] of_get_named_gpio_flags exited with status 234
<7>[ 0.542892] of_get_named_gpio_flags exited with status 259
<4>[ 0.542913] act8846_i2c_probe: act8846_pmic_hold=1
<4>[ 0.542935] act8846_i2c_probe: act8846_pmic_sleep=1
<4>[ 0.542950] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
<4>[ 0.542965] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
<6>[ 0.545033] act_dcdc1: 1200 mV
<6>[ 0.548028] vccio: 3300 mV
<6>[ 0.549900] vdd_logic: 700 ↔ 1500 mV at 1125 mV
<6>[ 0.552863] act_dcdc4: 2000 mV
<6>[ 0.554094] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.556422] act_ldo2: 1050 mV
<6>[ 0.558754] act_ldo3: 2800 mV
<6>[ 0.561098] act_ldo4: 3300 mV
<6>[ 0.563432] act_ldo5: 3300 mV
<6>[ 0.565750] act_ldo6: 1100 mV
<6>[ 0.568060] vcc_18: 1800 mV
<6>[ 0.570370] act_ldo8: 1850 mV
<6>[ 0.575165] vdd_arm: 712 ↔ 1500 mV at 1100 mV
<6>[ 0.579879] vdd_gpu: 712 ↔ 1500 mV at 900 mV
<4>[ 0.580620] rk808_i2c_probe,line=1355
<4>[ 0.581935] The device is not rk808 -11
<4>[ 0.582023] rk808: probe of 0-001b failed with error -11
<4>[ 0.582098] i2c-core: driver [rk818] using legacy suspend method
<4>[ 0.582109] i2c-core: driver [rk818] using legacy resume method
<6>[ 0.583812] Switching to clocksource arch_sys_counter
<6>[ 0.607791] rga: Module initialized.
<6>[ 0.608478] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.608646] rga: Driver loaded succesfully
<6>[ 0.608866] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.608880] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.609162] rk-screen rk_screen.8: rockchip screen probe success
<3>[ 0.609312] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
<4>[ 0.609333] rk32-lvds: probe of ff96c000.lvds failed with error -22
<3>[ 0.609815] rk32-edp rk32-edp: failed to get reset
<3>[ 0.609830] rk32-edp rk32-edp: failed to get reset
<6>[ 0.610548] rk32-edp rk32-edp: rk32 edp driver probe success
<7>[ 0.611037] of_get_named_gpio_flags exited with status 227
<6>[ 0.611270] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.611572] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.611742] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.611905] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.622879] rk3288-lcdc lcdc0: lcdc0: dclk:30000000>>fps:13
<6>[ 0.623089] rk32-edp rk32-edp: edp pll locked
<4>[ 0.635414] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.664101] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:2
<6>[ 0.667082] rk32-edp rk32-edp: link training success.
<3>[ 0.765703] rk32-edp rk32-edp: Timeout of video streamclk ok
<3>[ 0.765715] rk32-edp rk32-edp: unable to config video
<6>[ 0.765727] rk3288-lcdc lcdc0: wakeup from standby!
<6>[ 0.790887] alloc_buffer:ion_phy_addr=0x55c00000
<6>[ 0.803454] fb0:phy:55c00000>>vir:e0991000>>len:0x1800000
<6>[ 0.803472] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
<4>[ 0.804325] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.804471] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.804590] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.804714] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.804828] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.804940] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.805528] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.805694] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.806240] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.806385] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.806923] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.807075] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.807660] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.807816] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.809329] NET: Registered protocol family 2
<6>[ 0.809990] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.810065] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.810138] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.810236] TCP: reno registered
<6>[ 0.810252] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.810277] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.810465] NET: Registered protocol family 1
<6>[ 0.811058] Unpacking initramfs…
<6>[ 0.873124] Freeing initrd memory: 1172K (c5bf0000 - c5d15000)
<6>[ 0.873847] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.874362] vcodec_service: probe device ff9a0000.vpu_service
<4>[ 0.874564] vcodec_service: No reset resource define
<6>[ 0.874739] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 0.874825] vcodec_service: probe device ff9a0000.vpu_service
<6>[ 0.874840] vcodec_service: checking hw id 4831
<6>[ 0.875870] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 0.875914] vcodec_service: done
<6>[ 0.875922] vcodec_service: init success
<6>[ 0.875988] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.876318] vcodec_service: ff9c0000.hevc_service: power on
<6>[ 0.876380] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.876394] vcodec_service: checking hw id 6867
<6>[ 0.876643] vcodec_service: ff9c0000.hevc_service: power off…
<6>[ 0.876682] vcodec_service: done
<6>[ 0.876690] vcodec_service: init success
<4>[ 0.876825] rknandbase v1.0 2014-03-31
<4>[ 0.876958] rknand: probe of ff400000.nandc failed with error -1
<4>[ 0.877069] rknand_driver:ret = 0
<6>[ 0.878208] audit: initializing netlink socket (disabled)
<5>[ 0.878252] type=2000 audit(0.530:1): initialized
<4>[ 0.879175] bounce pool size: 64 pages
<6>[ 0.883745] fuse init (API version 7.22)
<6>[ 0.884102] msgmni has been set to 952
<7>[ 0.884152] SELinux: Registering netfilter hooks
<6>[ 0.885935] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 0.885951] io scheduler noop registered
<6>[ 0.885960] io scheduler deadline registered
<6>[ 0.886046] io scheduler cfq registered (default)
<7>[ 0.886477] of_get_named_gpio_flags exited with status 226
<3>[ 0.886638] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 0.886651] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 0.886679] platform backlight.20: Driver pwm-backlight requests probe deferral
<6>[ 0.887445] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
<4>[ 0.888123] IEP Driver loaded succesfully
<4>[ 0.888210] Module initialized.
<6>[ 0.889033] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.889051] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.890380] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.890397] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<3>[ 0.890621] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
<3>[ 0.890635] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
<4>[ 0.890644] pwm_regulator_probe:error
<6>[ 0.890662] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
<4>[ 0.890856] rk_serial.c v1.8 2014-03-04
<6>[ 0.891076] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.891264] serial ff180000.serial: membase e097e000
<6>[ 0.891404] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<6>[ 0.893005] console [ttyS2] enabled
<6>[ 0.893232] serial ff690000.serial: membase fed60000
<6>[ 0.895960] loop: module loaded
<6>[ 0.896307] zram: Created 1 device(s) …
<4>[ 0.896392] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 0.896405] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 0.896423] mpu_init: Probe name mpu6050B1
<6>[ 0.896566] ak8963_mod_init: Probe name ak8963_mod
<6>[ 0.897232] SCSI Media Changer driver v0.25
<6>[ 0.897542] tun: Universal TUN/TAP device driver, 1.6
<6>[ 0.897555] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 0.897674] vmac_init.
<3>[ 0.898234] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<6>[ 0.898252] stmmac_probe_config_dt: clock input/output? (input).
<6>[ 0.898264] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 0.898275] stmmac_probe_config_dt: RX delay(0x20).
<7>[ 0.898289] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 0.898304] of_get_named_gpio_flags exited with status 136
<7>[ 0.898313] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 0.898324] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 0.898335] stmmc_pltfr_init:
<3>[ 0.898344] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<7>[ 0.898357] _gpio_request: gpio-136 (gmac_phy_reset) status -16
<3>[ 0.898367] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
<6>[ 0.898378] stmmc_pltfr_init: init for RGMII
<6>[ 0.898389] tx delay=0x30
<6>[ 0.898389] rx delay=0x20
<6>[ 0.898405] tx delay=0x30
<6>[ 0.898405] rx delay=0x20
<6>[ 0.898910] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 0.898923] Normal descriptors
<6>[ 0.898932] Ring mode enabled
<6>[ 0.898942] DMA HW capability register supported
<6>[ 0.898954] RX Checksum Offload Engine supported (type 2)
<6>[ 0.898965] TX Checksum insertion supported
<6>[ 0.898974] Wake-Up On Lan supported
<6>[ 0.899012] Enable RX Mitigation via HW Watchdog Timer
<6>[ 0.899472] PPP generic driver version 2.4.2
<6>[ 0.899642] PPP BSD Compression module registered
<6>[ 0.899655] PPP Deflate Compression module registered
<6>[ 0.899679] PPP MPPE Compression module registered
<6>[ 0.899691] NET: Registered protocol family 24
<6>[ 0.899727] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 0.899740] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 0.899755] Rockchip WiFi SYS interface (V1.00) …
<4>[ 0.899790] esp_mem_init enter date Aug 12 2016 14:13:22
<4>[ 0.899802] esp_mem_init VERSION [V2.5]
<4>[ 0.899845] esp_mem_init complete
<6>[ 0.899932] usbcore: registered new interface driver catc
<6>[ 0.899974] usbcore: registered new interface driver kaweth
<6>[ 0.899987] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 0.900027] usbcore: registered new interface driver pegasus
<6>[ 0.900074] usbcore: registered new interface driver rtl8150
<6>[ 0.900116] usbcore: registered new interface driver r8152
<6>[ 0.900127] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 0.900196] usbcore: registered new interface driver hso
<6>[ 0.900241] usbcore: registered new interface driver asix
<6>[ 0.900281] usbcore: registered new interface driver ax88179_178a
<6>[ 0.900321] usbcore: registered new interface driver cdc_ether
<6>[ 0.900364] usbcore: registered new interface driver cdc_eem
<6>[ 0.900404] usbcore: registered new interface driver dm9601
<6>[ 0.900448] usbcore: registered new interface driver dm9620
<6>[ 0.900497] usbcore: registered new interface driver smsc75xx
<6>[ 0.900545] usbcore: registered new interface driver smsc95xx
<6>[ 0.900585] usbcore: registered new interface driver gl620a
<6>[ 0.900630] usbcore: registered new interface driver net1080
<6>[ 0.900671] usbcore: registered new interface driver plusb
<6>[ 0.900713] usbcore: registered new interface driver rndis_host
<6>[ 0.900753] usbcore: registered new interface driver cdc_subset
<6>[ 0.900792] usbcore: registered new interface driver zaurus
<6>[ 0.900834] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 0.900899] usbcore: registered new interface driver int51x1
<6>[ 0.900941] usbcore: registered new interface driver kalmia
<6>[ 0.900988] usbcore: registered new interface driver ipheth
<6>[ 0.901033] usbcore: registered new interface driver sierra_net
<6>[ 0.901076] usbcore: registered new interface driver cx82310_eth
<6>[ 0.901126] usbcore: registered new interface driver cdc_ncm
<6>[ 0.901168] usbcore: registered new interface driver qmi_wwan
<6>[ 0.901209] usbcore: registered new interface driver cdc_mbim
<6>[ 0.901222] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<6>[ 0.903669] EHCI: ehci_rk_probe e2240000 e2240010
<6>[ 0.903689] rockchip_ehci_host ff500000.usb: EHCI Host Controller
<6>[ 0.903720] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 0.904079] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 0.918452] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
<6>[ 0.918534] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.918552] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.918567] usb usb1: Product: EHCI Host Controller
<6>[ 0.918580] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 0.918593] usb usb1: SerialNumber: ff500000.usb
<6>[ 0.919069] hub 1-0:1.0: USB hub found
<6>[ 0.919095] hub 1-0:1.0: 1 port detected
<6>[ 0.919274] EHCI: ehci_rk_probe ok
<6>[ 0.919377] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<6>[ 0.919586] usbcore: registered new interface driver cdc_acm
<6>[ 0.919599] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 0.919651] usbcore: registered new interface driver usblp
<6>[ 0.919694] usbcore: registered new interface driver cdc_wdm
<6>[ 0.919753] usbcore: registered new interface driver usb-storage
<6>[ 0.919792] usbcore: registered new interface driver ums-alauda
<6>[ 0.919830] usbcore: registered new interface driver ums-cypress
<6>[ 0.919873] usbcore: registered new interface driver ums-datafab
<6>[ 0.919911] usbcore: registered new interface driver ums_eneub6250
<6>[ 0.919950] usbcore: registered new interface driver ums-freecom
<6>[ 0.919988] usbcore: registered new interface driver ums-isd200
<6>[ 0.920026] usbcore: registered new interface driver ums-jumpshot
<6>[ 0.920064] usbcore: registered new interface driver ums-karma
<6>[ 0.920103] usbcore: registered new interface driver ums-onetouch
<6>[ 0.920141] usbcore: registered new interface driver ums-sddr09
<6>[ 0.920180] usbcore: registered new interface driver ums-sddr55
<6>[ 0.920219] usbcore: registered new interface driver ums-usbat
<6>[ 0.920311] usbcore: registered new interface driver usbserial
<6>[ 0.920353] usbcore: registered new interface driver usbserial_generic
<6>[ 0.920386] usbserial: USB Serial support registered for generic
<6>[ 0.920430] usbcore: registered new interface driver option
<6>[ 0.920460] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 0.920533] usbcore: registered new interface driver trancevibrator
<6>[ 0.920545] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 0.920965] e2280040
<4>[ 0.920979] Core Release: 3.10a
<4>[ 0.920991] Setting default values for core params
<4>[ 0.921112] Using Buffer DMA mode
<4>[ 0.921124] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.921135] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.921147] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.921170] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 0.921185] Dedicated Tx FIFOs mode
<3>[ 0.921197] [EDID] check header error
<4>[ 0.921205] pcd_init otg_dev = dde5fd80
<3>[ 0.921228] rockchip-hdmiv2 ff980000.hdmi: [HDMI] parse edid base block error
<3>[ 1.009588] [EDID] check header error
<3>[ 1.009607] rockchip-hdmiv2 ff980000.hdmi: [HDMI] parse edid base block error
<4>[ 1.019761] Using Buffer DMA mode
<4>[ 1.019774] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.019785] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.019797] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.019808] ^^^^^^^^^^^^^^^^^Device Mode
<6>[ 1.019838] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 1.019866] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 1.019900] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 1.019956] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.019973] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.019987] usb usb2: Product: DWC OTG Controller
<6>[ 1.020000] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.020012] usb usb2: SerialNumber: ff580000.usb
<6>[ 1.020434] hub 2-0:1.0: USB hub found
<6>[ 1.020460] hub 2-0:1.0: 1 port detected
<6>[ 1.020760] usb20_host: version 3.10a 21-DEC-2012
<4>[ 1.023289] e2300040
<4>[ 1.023303] Core Release: 3.10a
<4>[ 1.023314] Setting default values for core params
<4>[ 1.023423] Using Buffer DMA mode
<4>[ 1.023434] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.023445] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.023456] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.023467] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 1.023492] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 1.023517] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 1.023546] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 1.023638] Init: Power Port (0)
<6>[ 1.023696] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.023712] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.023727] usb usb3: Product: DWC OTG Controller
<6>[ 1.023740] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.023753] usb usb3: SerialNumber: ff540000.usb
<6>[ 1.024135] hub 3-0:1.0: USB hub found
<6>[ 1.024158] hub 3-0:1.0: 1 port detected
<6>[ 1.024852] usbcore: registered new interface driver xpad
<6>[ 1.024912] usbcore: registered new interface driver usb_acecad
<6>[ 1.024959] usbcore: registered new interface driver aiptek
<6>[ 1.025003] usbcore: registered new interface driver gtco
<6>[ 1.025048] usbcore: registered new interface driver hanwang
<6>[ 1.025092] usbcore: registered new interface driver kbtab
<6>[ 1.025144] usbcore: registered new interface driver wacom
<4>[ 1.025403] sensor_register_slave:mma8452,id=17
<4>[ 1.025418] sensor_register_slave:gs_mc3230,id=23
<4>[ 1.025428] gsensor_init
<4>[ 1.025438] sensor_register_slave:mpu6880_acc,id=24
<4>[ 1.025448] sensor_register_slave:mpu6500_acc,id=25
<4>[ 1.025459] sensor_register_slave:cm3217,id=48
<4>[ 1.025470] sensor_register_slave:cm3218,id=49
<3>[ 1.025672] .. rk pwm remotectl v1.1 init
<6>[ 1.025911] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
<7>[ 1.028938] of_get_named_gpio_flags exited with status 228
<6>[ 1.030917] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 1.030974] i2c /dev entries driver
<6>[ 1.031663] IR NEC protocol handler initialized
<6>[ 1.031676] IR RC5(x) protocol handler initialized
<6>[ 1.031687] IR RC6 protocol handler initialized
<6>[ 1.031697] IR JVC protocol handler initialized
<6>[ 1.031706] IR Sony protocol handler initialized
<6>[ 1.031717] IR RC5 (streamzap) protocol handler initialized
<6>[ 1.031727] IR SANYO protocol handler initialized
<6>[ 1.031737] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 1.031897] usbcore: registered new interface driver uvcvideo
<6>[ 1.031909] USB Video Class driver (1.1.1)
<4>[ 1.031922] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
<7>[ 1.033363] of_get_named_gpio_flags exited with status 236
<4>[ 1.033376] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
<7>[ 1.033391] of_get_named_gpio_flags exited with status 236
<4>[ 1.033400] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
<4>[ 1.033421] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
<4>[ 1.033443] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
<4>[ 1.033486] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
<4>[ 1.033486]
<4>[ 1.033558] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 1.033709] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe21b8000 size: 0x4000)
<4>[ 1.034355] D1:camsys_platform_probe(1447): ff910000.isp memory:
<4>[ 1.034375] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe2220000 size: 0x10000)
<4>[ 1.034391] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1dec7000 vir: 0xddec7000 size: 0x1000)
<4>[ 1.034406] D1:camsys_init_ext_fsh_module(20): init external flash module
<4>[ 1.034418] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
<6>[ 1.034876] not find test_power_init dev node
<4>[ 1.034933] i2c-core: driver [bq27320] using legacy suspend method
<4>[ 1.034945] i2c-core: driver [bq27320] using legacy resume method
<4>[ 1.035286] rockchip_temp_probe,line=362
<6>[ 1.085724] tsadc ff280000.tsadc: initialized
<6>[ 1.086150] device-mapper: uevent: version 1.0.3
<6>[ 1.086402] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 1.086699] Bluetooth: HCI UART driver ver 2.2
<6>[ 1.086716] Bluetooth: HCI H4 protocol initialized
<6>[ 1.086728] Bluetooth: HCILL protocol initialized
<6>[ 1.086739] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
<6>[ 1.086751] rtk_btusb: Register usb char device interface for BT driver
<6>[ 1.086958] usbcore: registered new interface driver rtk_btusb
<4>[ 1.087626] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(600000), use default, just enable dvfs
<4>[ 1.091771] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 1.091964] cpuidle: using governor ladder
<6>[ 1.091978] cpuidle: using governor menu
<6>[ 1.092015] Synopsys Designware Multimedia Card Interface Driver
<6>[ 1.092027] MHSC version = Ver 2.00 2015-06-10
<4>[ 1.092317] dw cru_regsbase addr 0x1d8.
<4>[ 1.092330] dw cru_reset_offset val 3.
<6>[ 1.092345] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<3>[ 1.092392] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.092718] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 1.092892] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<7>[ 1.092921] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.093031] 1358..dw_mci_set_ios: no card. [mmc0]
<3>[ 1.098132] [EDID] check header error
<3>[ 1.098151] rockchip-hdmiv2 ff980000.hdmi: [HDMI] parse edid base block error
<3>[ 1.098167] rockchip-hdmiv2 ff980000.hdmi: warning: EDID error, assume sink as HDMI !!!
<6>[ 1.098182] rockchip-hdmiv2 ff980000.hdmi: warning: no CEA video mode parsed from EDID !!!
<6>[ 1.098225] hdmi output corlor mode is 2
<4>[ 1.098241] hdmi connect to lcdc0
<6>[ 1.098252] switch:en=1,lcdc_id=0,screen type=6,cur type=9
<4>[ 1.105417] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.115317] dwc_otg_hcd_suspend, usb device mode
<6>[ 1.125201] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<4>[ 1.125211] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 1.125235] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<4>[ 1.125556] dw cru_regsbase addr 0x1d8.
<4>[ 1.125575] dw cru_reset_offset val 0.
<6>[ 1.125597] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<3>[ 1.125643] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.126355] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 1.126506] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
<7>[ 1.126533] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.127019] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 1.127084] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 1.144772] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.164477] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 1.164489] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<4>[ 1.164774] dw cru_regsbase addr 0x1d8.
<4>[ 1.164784] dw cru_reset_offset val 1.
<6>[ 1.164794] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<3>[ 1.164821] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.164986] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 1.165104] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<7>[ 1.165123] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.165354] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.184128] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.196749] mmc0: BKOPS_EN bit is not set
<4>[ 1.198600] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
<4>[ 1.200862] mmc0: switch to highspeed failed
<6>[ 1.200877] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 25000000Hz, actual 25000000HZ div = 2)
<4>[ 1.200900] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<4>[ 1.200909] rk_sdmmc: ERROR dw_mci_setup_bus: div SHOULD NOT LARGER THAN ONE! [mmc0]
<4>[ 1.200918] rk_sdmmc: BOOT dw_mci_setup_bus: workaround div = 1, host->bus_hz = 50000000 [mmc0]
<6>[ 1.201059] mmc0: new MMC card at address 0001
<6>[ 1.201324] mmcblk0: mmc0:0001 016GE2 14.6 GiB
<6>[ 1.201663] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 1.201674] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 1.201683] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 1.201693] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 1.201702] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 1.201710] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 1.201719] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 1.201728] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 1.201737] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 1.201746] system: 0x012400000 – 0x072400000 (1536 MB)
<6>[ 1.201755] metadata: 0x072400000 – 0x073400000 (16 MB)
<6>[ 1.201763] baseparamer: 0x073400000 – 0x073800000 (4 MB)
<6>[ 1.201772] userdata: 0x073800000 – 0x0b3800000 (1024 MB)
<6>[ 1.201780] radical_update: 0x0b3800000 – 0x0b7800000 (64 MB)
<6>[ 1.201789] user: 0x0b7800000 – 0x3ab000000 (12088 MB)
<6>[ 1.201815] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
<6>[ 1.203855] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 1.203870] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<6>[ 1.204051] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 1.205512] usbcore: registered new interface driver usbhid
<6>[ 1.205522] usbhid: USB HID core driver
<6>[ 1.205640] ashmem: initialized
<6>[ 1.205746] logger: created 256K log ‘log_main’
<6>[ 1.205836] logger: created 256K log ‘log_events’
<6>[ 1.205957] logger: created 256K log ‘log_radio’
<6>[ 1.206050] logger: created 256K log ‘log_system’
<7>[ 1.206970] of_get_named_gpio_flags exited with status 5
<7>[ 1.206981] of_get_named_gpio_flags exited with status 5
<6>[ 1.207212] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input1
<3>[ 1.208017] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
<3>[ 1.208035] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
<3>[ 1.208047] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
<3>[ 1.208058] ES8323 2-0010: Error applying setting, reverse things back
<7>[ 1.208083] of_get_named_gpio_flags exited with status 10
<7>[ 1.208093] of_get_named_gpio_flags exited with status 239
<4>[ 1.208760] es8323 probe error
<4>[ 1.208778] ES8323: probe of 2-0010 failed with error -11
<6>[ 1.209506] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
<4>[ 1.210013] ASOC:binding ES8323 at idx 0
<4>[ 1.210023] ---------------------start--------------------
<4>[ 1.210031] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 1.210043] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.210074] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.210089] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<3>[ 1.210122] Error: Driver ‘rockchip-es8323’ is already registered, aborting…
<6>[ 1.210272] u32 classifier
<6>[ 1.210280] Actions configured
<6>[ 1.210294] Netfilter messages via NETLINK v0.30.
<6>[ 1.210355] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 1.210717] ctnetlink v0.93: registering with nfnetlink.
<6>[ 1.210791] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 1.210800] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 1.211086] xt_time: kernel timezone is -0000
<6>[ 1.211297] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.211433] arp_tables: (C) 2002 David S. Miller
<6>[ 1.211474] TCP: cubic registered
<6>[ 1.211481] Initializing XFRM netlink socket
<6>[ 1.211710] NET: Registered protocol family 10
<6>[ 1.212275] mip6: Mobile IPv6
<6>[ 1.212306] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.212430] sit: IPv6 over IPv4 tunneling driver
<6>[ 1.212772] NET: Registered protocol family 17
<6>[ 1.212800] NET: Registered protocol family 15
<5>[ 1.212854] Bridge firewalling registered
<6>[ 1.212867] Ebtables v2.0 registered
<6>[ 1.213021] Bluetooth: RFCOMM TTY layer initialized
<6>[ 1.213048] Bluetooth: RFCOMM socket layer initialized
<6>[ 1.213057] Bluetooth: RFCOMM ver 1.11
<6>[ 1.213065] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 1.213073] Bluetooth: BNEP filters: protocol multicast
<6>[ 1.213085] Bluetooth: BNEP socket layer initialized
<6>[ 1.213094] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 1.213107] Bluetooth: HIDP socket layer initialized
<6>[ 1.213136] l2tp_core: L2TP core driver, V2.0
<6>[ 1.213151] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 1.213160] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 1.213351] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 1.213364] [WLAN_RFKILL]: can’t find rockchip,grf property
<6>[ 1.213373] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 1.213384] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 1.213393] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 1.213402] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 1.213418] of_get_named_gpio_flags exited with status 156
<6>[ 1.213425] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 1.213434] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.213442] of_get_named_gpio_flags exited with status 158
<6>[ 1.213448] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 1.213458] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 1.213488] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 1.213497] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 1.213543] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 1.213715] of_get_named_gpio_flags exited with status 147
<6>[ 1.213724] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 1.213737] of_get_named_gpio_flags exited with status 155
<6>[ 1.213745] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
<7>[ 1.213754] of_get_named_gpio_flags exited with status 157
<6>[ 1.213760] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 1.213769] of_get_named_gpio_flags exited with status 154
<6>[ 1.213775] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 1.213785] of_get_named_gpio_flags exited with status 159
<6>[ 1.213791] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 1.213840] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 1.213936] [BT_RFKILL]: ** disable irq
<6>[ 1.214027] [BT_RFKILL]: ap6335 device registered.
<4>[ 1.214836] rk3288_init_suspend
<4>[ 1.214849] rk3288_suspend_init enter
<4>[ 1.215053] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 1.215093] gpio_get_dts_info suspend:4
<4>[ 1.215102] gpio_get_dts_info resume:4
<4>[ 1.215109] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.215141] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.215299] clks_gating_suspend_init:clkgt info ok
<5>[ 1.215395] Registering SWP/SWPB emulation handler
<6>[ 1.215409] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
<6>[ 1.218748] ddrfreq: verion 1.2 20140526
<6>[ 1.218766] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
<6>[ 1.218776] ddrfreq: auto-freq=0
<6>[ 1.218783] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 1.218789] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 1.218797] ddrfreq: auto-freq-table[2] 456MHz
<6>[ 1.218803] ddrfreq: auto-freq-table[3] 528MHz
<3>[ 1.223411] act_ldo3: operation not allowed
<6>[ 1.223421] vga_edid_probe: turn on ldo3 done.
<6>[ 1.223503] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
<4>[ 1.223526] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc1]
<3>[ 1.225049] act_ldo4: operation not allowed
<6>[ 1.225056] vga_edid_probe: turn on ldo done.
<3>[ 1.225307] act_ldo2: operation not allowed
<6>[ 1.225314] vga_edid_probe: turn on ldo2 done.
<3>[ 1.225560] act_ldo8: operation not allowed
<6>[ 1.225566] vga_edid_probe: turn on ldo done.
<7>[ 1.225577] of_get_named_gpio_flags exited with status 17
<4>[ 1.230923] unable to read EDID block.
<4>[ 1.252926] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.265772] unable to read EDID block.
<4>[ 1.300624] unable to read EDID block.
<4>[ 1.300633] vga-ddc: read and parse edid failed errno:-5.
<4>[ 1.300638] vga_edid_probe: success. 10
<4>[ 1.300747] firefly_vga_get_enable 180, 0
<4>[ 1.300753] firefly_vga_get_status 186
<4>[ 1.300758] firefly_vga_set_enable 159 enable:0
<6>[ 1.300801] regulator-dummy: disabling
<7>[ 1.300973] of_get_named_gpio_flags exited with status 226
<3>[ 1.301035] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.301043] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 1.301057] platform backlight.20: Driver pwm-backlight requests probe deferral
<4>[ 1.301307] ASOC:binding ES8323 at idx 0
<4>[ 1.301313] ---------------------start--------------------
<4>[ 1.301318] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 1.301327] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.301345] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.301355] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<4>[ 1.301381] =======================================================
<4>[ 1.301388] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 1.301392] =======================================================
<4>[ 1.301398] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
<4>[ 1.301446] dhd_module_init: in
<4>[ 1.301453] ======== bcm_wlan_set_plat_data ========
<6>[ 1.301458] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
<4>[ 1.301477] host_oob_irq: 195
<4>[ 1.301481] host_oob_irq_flags=4
<4>[ 1.301485] dhd_wifi_platform_load: Enter
<4>[ 1.301500] Power-up adapter ‘DHD generic adapter’
<4>[ 1.301503] pcd_pullup, is_on 0
<4>[ 1.301524] wifi_platform_set_power = 1
<4>[ 1.301528] ======== PULL WL_REG_ON HIGH! ========
<6>[ 1.301533] file system registered
<6>[ 1.301536] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 1.301539] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 1.301543] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 1.302041] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 1.302049] android_usb gadget: Number of LUNs=2
<6>[ 1.302055] lun0: LUN: removable file: (no medium)
<6>[ 1.302060] lun1: LUN: removable file: (no medium)
<6>[ 1.302202] android_usb gadget: android_usb ready
<6>[ 1.302274] sensor_init: Probe name sensors
<4>[ 1.302290] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 1.302812] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:35:01 UTC (1293885301)
<4>[ 1.307099] ASOC:binding SPDIF at idx 0
<4>[ 1.307108] ---------------------start--------------------
<4>[ 1.307114] firfly : cpu_dai name:::ff880000.rockchip-spdif
<4>[ 1.307120] rtd->platform start…
<4>[ 1.307124] rtd->platform end…
<6>[ 1.308413] rockchip-spdif-card rockchip-spdif-card.26: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
<7>[ 1.308857] of_get_named_gpio_flags exited with status 226
<3>[ 1.308929] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.308938] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 1.308952] platform backlight.20: Driver pwm-backlight requests probe deferral
<6>[ 1.309098] usbcore: registered new interface driver snd-usb-audio
<6>[ 1.309106] ALSA device list:
<6>[ 1.309111] #0: RK-SPDIF-CARD
<4>[ 1.309150] ASOC:binding ES8323 at idx 0
<4>[ 1.309169] ---------------------start--------------------
<4>[ 1.309174] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 1.309179] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.309195] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.309207] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<6>[ 1.309463] Freeing unused kernel memory: 352K (c0b8d000 - c0be5000)
<6>[ 1.351394] rk_fb_switch_screen: wait update_regs_wait timeout
<6>[ 1.351587] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
<6>[ 1.351616] pixel clk is 74250000 tmds clk is 74250000
<6>[ 1.351662] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
<6>[ 1.400608] [WLAN_RFKILL]: wifi turn on power. 156
<7>[ 1.420205] SELinux: 2048 avtab hash slots, 5342 rules.
<7>[ 1.421731] SELinux: 2048 avtab hash slots, 5342 rules.
<7>[ 1.421748] SELinux: 1 users, 2 roles, 439 types, 0 bools, 1 sens, 1024 cats
<7>[ 1.421755] SELinux: 86 classes, 5342 rules
<7>[ 1.422575] SELinux: Completing initialization.
<7>[ 1.422580] SELinux: Setting up existing superblocks.
<7>[ 1.422595] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 1.422610] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 1.422651] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 1.422661] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 1.422674] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.422687] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 1.422838] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 1.432228] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 1.432242] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 1.432252] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 1.432261] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 1.432279] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 1.432325] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 1.432334] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.432353] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<4>[ 1.508845] vbus detect**
<5>[ 1.565929] type=1403 audit(1293885301.750:2): policy loaded auid=4294967295 ses=4294967295
<11>[ 1.592914] init: invalid gid ‘trace’
<4>[ 1.607249] wifi_platform_bus_enumerate device present 1
<4>[ 1.607266] ======== Card detection to detect SDIO card! ========
<6>[ 1.607280] mmc2:mmc host rescan start!
<11>[ 1.681608] init: /dev/hw_random not found
<6>[ 1.681673] keychord: using input dev ff680000.pwm for fevent
<6>[ 1.681688] keychord: using input dev rk29-keypad for fevent
<7>[ 1.682179] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 1.682443] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.682716] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 1.683967] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.684124] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.685339] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 1.686607] init: /dev/hw_random not found
<14>[ 1.687540] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 1.688358] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
<4>[ 1.693477] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
<6>[ 1.702197] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.702227] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 1.702296] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
<14>[ 1.703290] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 1.711558] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.711604] e2fsck: system: clean, 1839/81984 files, 111640/393216 blocks
<6>[ 1.719322] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 1.719347] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 1.719393] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 1.727661] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 1.727690] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 1.727734] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<4>[ 1.728133] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
<6>[ 1.735983] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.736005] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 1.736043] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
<14>[ 1.736943] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
<14>[ 1.744103] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.744140] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
<6>[ 1.752277] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 1.752301] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 1.752345] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<14>[ 1.752389] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 1.753351] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
<14>[ 1.753391] fsck.f2fs: fsck.f2fs terminated by exit(255)
<14>[ 1.753642] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 1.754023] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
<6>[ 1.761887] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.761917] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 1.761961] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 1.762905] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 1.770544] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.770580] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 11/65536 files, 8536/262144 blocks
<6>[ 1.778815] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 1.778840] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 1.778877] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 1.778899] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
<7>[ 1.779549] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<6>[ 1.816223] arm_release_ver of this mali_ko is ‘r5p0-06rel0’, rk_ko_ver is ‘12’, built at ‘12:02:29’, on ‘Jul 6 2015’.
<6>[ 1.816317] mali ffa30000.gpu: Continuing without Mali clock control
<4>[ 1.816404] mali pd enabled
<4>[ 1.816420] clk enabled
<4>[ 1.816433] MALI_DVFS_STEP=4,div_dvfs=10
<6>[ 1.816443] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
<6>[ 1.816453] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
<6>[ 1.816462] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
<6>[ 1.816472] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
<3>[ 1.816572] turn on mali power
<6>[ 1.816586] kbase_platform_rk_init,register_reboot_notifier
<6>[ 1.816607] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<6>[ 1.817016] mali ffa30000.gpu: Probed as mali0
<7>[ 1.817318] of_get_named_gpio_flags exited with status 226
<3>[ 1.817431] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.817453] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 1.817480] platform backlight.20: Driver pwm-backlight requests probe deferral
<4>[ 1.817766] ASOC:binding ES8323 at idx 0
<4>[ 1.817780] ---------------------start--------------------
<4>[ 1.817789] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 1.817800] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.817826] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.817842] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<3>[ 1.818690] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 1.819891] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 1.821063] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 1.821822] zram0: detected capacity change from 0 to 533413888
<4>[ 1.823744] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<4>[ 1.858418] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 1.859921] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 1.861415] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 1.864147] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<6>[ 1.877331] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 1.877359] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 1.877428] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
<6>[ 1.878518] mmc2: new high speed SDIO card at address 0001
<7>[ 1.878901] of_get_named_gpio_flags exited with status 226
<3>[ 1.879006] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.879024] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 1.879049] platform backlight.20: Driver pwm-backlight requests probe deferral
<4>[ 1.879300] ASOC:binding ES8323 at idx 0
<4>[ 1.879315] ---------------------start--------------------
<4>[ 1.879327] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 1.879339] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.879363] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.879379] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<7>[ 1.879468] of_get_named_gpio_flags exited with status 226
<3>[ 1.879502] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.879517] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 1.879533] platform backlight.20: Driver pwm-backlight requests probe deferral
<4>[ 1.894690] bcmsdh_register: register client driver
<4>[ 1.894788] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 1.894865] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 1.894876] bus num (host idx)=2, slot num (rca)=1
<4>[ 1.894887] found adapter info ‘DHD generic adapter’
<4>[ 1.895042] ASOC:binding ES8323 at idx 0
<4>[ 1.895054] ---------------------start--------------------
<4>[ 1.895064] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 1.895075] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 1.895098] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.895114] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<4>[ 1.895121] F1 signature read @0x18000000=0x1591a962
<7>[ 1.895211] of_get_named_gpio_flags exited with status 226
<3>[ 1.895255] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 1.895268] pwm-backlight backlight.20: unable to request legacy PWM
<4>[ 1.895283] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
<6>[ 1.895287] platform backlight.20: Driver pwm-backlight requests probe deferral
<4>[ 1.896686] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
<4>[ 1.897238] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
<4>[ 1.897684] wifi_platform_get_mac_addr
<4>[ 1.897696] ======== bcm_wlan_get_mac_address ========
<6>[ 1.897706] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 1.897718] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 1.897727] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 1.897741] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
<4>[ 1.897787] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<4>[ 1.898104] wl_create_event_handler(): thread:wl_event_handler:96 started
<4>[ 1.898110] tsk Enter, tsk = 0xdd42149c
<4>[ 1.898238] dhd_attach(): thread:dhd_watchdog_thread:97 started
<4>[ 1.898284] dhd_attach(): thread:dhd_dpc:98 started
<4>[ 1.898297] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
<4>[ 1.898358] dhd_attach(): thread:dhd_rxf:99 started
<4>[ 1.898374] dhd_deferred_work_init: work queue initialized
<4>[ 1.898451] dhdsdio_probe_init: set use_rxchain 0 from config.txt
<4>[ 1.903672] Dongle Host Driver, version 1.201.59.4 (r506368)
<4>[ 1.903672] Compiled in drivers/net/wireless/bcmdhd on Aug 12 2016 at 14:13:32
<4>[ 1.904014] Register interface [wlan0] MAC: 44:2c:05:05:dd:69
<4>[ 1.904014]
<4>[ 1.904034] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 1.904077] bcmsdh_oob_intr_unregister: Enter
<4>[ 1.904088] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 1.904099] dhd_txglom_enable: enable 0
<4>[ 1.904108] dhd_bus_devreset: WLAN OFF DONE
<4>[ 1.904144] wifi_platform_set_power = 0
<4>[ 1.904155] ======== PULL WL_REG_ON LOW! ========
<6>[ 1.904163] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 1.929871] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<6>[ 2.010674] [WLAN_RFKILL]: wifi shut off power.
<6>[ 2.010693] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 2.010704] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 2.010761] dhd_module_init: Exit err=0
<4>[ 2.011056] ASOC:binding ES8323 at idx 0
<4>[ 2.011073] ---------------------start--------------------
<4>[ 2.011087] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 2.011101] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 2.011126] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 2.011143] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<7>[ 2.011261] of_get_named_gpio_flags exited with status 226
<3>[ 2.011310] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 2.011326] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 2.011343] platform backlight.20: Driver pwm-backlight requests probe deferral
<3>[ 2.093347] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
<14>[ 2.099444] bat_cap: oldcap path is /sys/devices/ff100000.adc
<11>[ 2.099499] bat_cap: oldcap_path no exist
<6>[ 2.099688] binder: 155:155 transaction failed 29189, size 0-0
<11>[ 2.100200] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<11>[ 2.104054] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 2.104088] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 2.104298] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 2.104857] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.104876] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.104891] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.104902] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.104923] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.104934] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.104949] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.104958] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<11>[ 2.108322] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 2.109965] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 2.110418] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 2.110616] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<11>[ 2.110868] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
<7>[ 2.111887] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<3>[ 2.112443] android_usb: already disabled
<6>[ 2.114579] read descriptors
<6>[ 2.114593] read strings
<4>[ 2.114622] pcd_pullup, is_on 1
<4>[ 2.396770] firefly_vga_get_enable 180, 0
<4>[ 2.396846] firefly_vga_get_status 186
<4>[ 2.397766] firefly_vga_set_mode 203
<4>[ 2.397822] firefly_vga_set_enable 159 enable:0
<4>[ 2.416669] dhd_open: Enter c5ac0800
<4>[ 2.416682]
<4>[ 2.416682] Dongle Host Driver, version 1.201.59.4 (r506368)
<4>[ 2.416682] Compiled in drivers/net/wireless/bcmdhd on Aug 12 2016 at 14:13:32
<4>[ 2.416693] wl_android_wifi_on in 1
<4>[ 2.416698] wl_android_wifi_on in 2: g_wifi_on=0
<4>[ 2.416703] wifi_platform_set_power = 1
<4>[ 2.416708] ======== PULL WL_REG_ON HIGH! ========
<6>[ 2.416713] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 2.416719] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 2.416724] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 2.492843] soft reconnect
<6>[ 2.522364] [WLAN_RFKILL]: wifi turn on power. 156
<38>[ 2.572273] logd.auditd: start
<4>[ 2.672124] Using Buffer DMA mode
<4>[ 2.672137] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 2.672143] Multiprocessor Interrupt Enhancement - disabled
<4>[ 2.672149] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 2.672155] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 2.672194] soft connect!!!
<4>[ 2.729057] sdio_reset_comm():
<6>[ 2.732064] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
<4>[ 2.732075] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
<4>[ 2.750606] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 2.753593] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 2.756579] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 2.761934] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<6>[ 2.788105] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 2.788141] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 2.788442]
<4>[ 2.788442]
<4>[ 2.788442] dhd_bus_devreset: == WLAN ON ==
<4>[ 2.788512] F1 signature read @0x18000000=0x1591a962
<4>[ 2.788698] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
<4>[ 2.790252] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
<4>[ 2.790418] USB RESET
<4>[ 2.790844] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
<4>[ 2.791393] dhdsdio_probe_init: set use_rxchain 0 from config.txt
<4>[ 2.799315] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
<4>[ 2.799334] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_RK901a2.bin,nv_path=/system/etc/firmware/nvram_AP6210.txt
<4>[ 2.799342] Final fw_path=/system/etc/firmware/fw_RK901a2.bin
<4>[ 2.799348] Final nv_path=/system/etc/firmware/nvram_AP6210.txt
<4>[ 2.799354] Final conf_path=/system/etc/firmware/config.txt
<6>[ 2.840646] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 2.844237] USB RESET
<4>[ 2.864461] NVRAM version: AP6210_NVRAM_V1.2_03192013
<4>[ 2.864875] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
<4>[ 2.865338] dhd_bus_init: delay 100ms for BCM43362
<6>[ 2.896282] EHCI: rk_ehci_hcd_enable, disable host controller
<6>[ 2.922563] android_usb gadget: high-speed config #1: android
<6>[ 2.922818] android_work: sent uevent USB_STATE=CONFIGURED
<4>[ 2.994674] dwc_otg_hcd_enable, enable host controller
<11>[ 3.084356] healthd: No charger supplies found
<12>[ 3.084369] healthd: No battery devices found
<4>[ 3.091944] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
<4>[ 3.092030] bcmsdh_oob_intr_register: Enter
<4>[ 3.092036] bcmsdh_oob_intr_register: HW_OOB enabled
<4>[ 3.092041] bcmsdh_oob_intr_register OOB irq=195 flags=4
<4>[ 3.092094] bcmsdh_oob_intr_register: enable_irq_wake
<4>[ 3.092691] dhd_conf_set_band: Set band 0
<4>[ 3.092830] wifi_platform_get_mac_addr
<4>[ 3.092837] ======== bcm_wlan_get_mac_address ========
<6>[ 3.092842] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 3.092850] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 3.092855] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 3.094326] Firmware up: op_mode=0x0005, MAC=44:2c:05:05:dd:69
<4>[ 3.094335] dhd_conf_set_country: Set country ALL, revision 0
<4>[ 3.098120] Using Buffer DMA mode
<4>[ 3.098130] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.098135] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.098140] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.098145] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 3.142376] Init: Power Port (0)
<4>[ 3.142425] ff540000.usb resume, HPRT0:0x21401
<4>[ 3.168632] Country code: ALL (ALL/0)
<4>[ 3.168863] dhd_conf_set_roam: Set roam_off 1
<4>[ 3.170372] dhd_preinit_ioctls buf_key_b4_m4 set failed -23
<4>[ 3.175695] Firmware version = wl0: Jul 5 2013 17:55:22 version 5.90.195.89.10 FWID 01-f4d31c13
<4>[ 3.175709] Driver: 1.201.59.4 (r506368)
<4>[ 3.175709] Firmware: wl0: Jul 5 2013 17:55:22 version 5.90.195.89.10 FWID 01-f4d31c13
<4>[ 3.175909] dhd_txglom_enable: enable 0
<4>[ 3.175917] dhd_conf_set_disable_proptx: set disable_proptx 1
<4>[ 3.178609] dhd_preinit_ioctls wl ampdu_hostreorder failed -23
<4>[ 3.178968] wl_android_wifi_on: Success
<4>[ 3.259506] dhd_set_scb_probe: GET max_scb_probe failed
<4>[ 3.259854] dhd_set_scb_probe: max_scb_probe setting failed
<4>[ 3.259863] dhd_open: Exit ret=0
<4>[ 3.280091] Indeed it is in host mode hprt0 = 00021501
<4>[ 3.358948] dhd_stop: Enter c5ac0800
<4>[ 3.362330] wl_android_wifi_off in 1
<4>[ 3.362337] wl_android_wifi_off in 2: g_wifi_on=1
<4>[ 3.362564] bcmsdh_oob_intr_unregister: Enter
<4>[ 3.362580] dhd_txglom_enable: enable 0
<4>[ 3.362586] dhd_bus_devreset: WLAN OFF DONE
<4>[ 3.362616] wifi_platform_set_power = 0
<4>[ 3.362622] ======== PULL WL_REG_ON LOW! ========
<6>[ 3.362627] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 3.467011] [WLAN_RFKILL]: wifi shut off power.
<6>[ 3.467022] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 3.467028] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 3.467035] wl_android_wifi_off out
<4>[ 3.467040] dhd_stop: Exit
<6>[ 3.476862] usb 3-1: new high-speed USB device number 2 using usb20_host
<4>[ 3.477070] Indeed it is in host mode hprt0 = 00001101
<6>[ 3.674760] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608
<6>[ 3.674773] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 3.674779] usb 3-1: Product: USB2.0 Hub
<6>[ 3.675382] hub 3-1:1.0: USB hub found
<6>[ 3.675641] hub 3-1:1.0: 4 ports detected
<4>[ 3.677290] ASOC:binding ES8323 at idx 0
<4>[ 3.677299] ---------------------start--------------------
<4>[ 3.677305] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 3.677314] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 3.677334] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 3.677347] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<7>[ 3.677451] of_get_named_gpio_flags exited with status 226
<3>[ 3.677496] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 3.677505] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 3.677518] platform backlight.20: Driver pwm-backlight requests probe deferral
<6>[ 3.932389] rk3288-lcdc lcdc0: blank mode:0
<6>[ 3.949491] usb 3-1.1: new high-speed USB device number 3 using usb20_host
<4>[ 3.975339] check config var fail 1:
<4>[ 3.975339] xpos=0,xsize=1920,xres=1280
<4>[ 3.975339] ypos=0,ysize=1080,yres=720
<3>[ 3.975354] error config ,ignore
<6>[ 4.048944] usb 3-1.1: New USB device found, idVendor=05e3, idProduct=0608
<6>[ 4.048958] usb 3-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 4.048964] usb 3-1.1: Product: USB2.0 Hub
<6>[ 4.049880] hub 3-1.1:1.0: USB hub found
<6>[ 4.050162] hub 3-1.1:1.0: 4 ports detected
<4>[ 4.052147] ASOC:binding ES8323 at idx 0
<4>[ 4.052157] ---------------------start--------------------
<4>[ 4.052164] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 4.052173] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 4.052196] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 4.052211] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<7>[ 4.052321] of_get_named_gpio_flags exited with status 226
<3>[ 4.052368] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 4.052376] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 4.052389] platform backlight.20: Driver pwm-backlight requests probe deferral
<4>[ 4.185360] ff540000.usb suspend, HPRT0:0x1485
<4>[ 4.188070] check config var fail 1:
<4>[ 4.188070] xpos=0,xsize=1920,xres=1280
<4>[ 4.188070] ypos=0,ysize=1080,yres=720
<3>[ 4.188088] error config ,ignore
<4>[ 4.204637] check config var fail 1:
<4>[ 4.204637] xpos=0,xsize=1920,xres=1280
<4>[ 4.204637] ypos=0,ysize=1080,yres=720
<3>[ 4.204653] error config ,ignore
<4>[ 8.377806] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.377828] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.377835] D1:camsys_open(739): camsys_marvin(ddeb7710) is opened!
<4>[ 8.385547] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 8.385564] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 8.385574] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 8.385590] of_get_named_gpio_flags exited with status 237
<7>[ 8.385595] of_get_named_gpio_flags exited with status 237
<4>[ 8.385600] rockchip_gpio_request:GPIO7-13
<4>[ 8.385610] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 8.385615] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 8.385623] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 8.385631] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x760c,result=0x760c
<4>[ 8.385638] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 8.385660] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 8.390711] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.390722] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 8.390827] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 8.390861] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 8.391932] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 8.392993] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 8.394055] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 8.583867] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 8.583885] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 8.780614] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 8.780635] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 8.780725] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 8.780738] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 8.780750] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 8.781852] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 8.781888] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 8.783953] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 8.783969] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 8.783980] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.783986] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.783992] D1:camsys_release(763): camsys_marvin(ddeb7710) is closed
<38>[ 8.795787] type=1400 audit(1293885309.100:3): avc: denied { execute } for pid=540 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=307 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.796187] type=1400 audit(1293885309.100:4): avc: denied { read open } for pid=540 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=307 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.796323] type=1400 audit(1293885309.100:5): avc: denied { execute_no_trans } for pid=540 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=307 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.800369] type=1400 audit(1293885309.100:6): avc: denied { getattr } for pid=540 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=320 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.800488] type=1400 audit(1293885309.100:7): avc: denied { execute } for pid=540 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=320 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.800555] type=1400 audit(1293885309.100:8): avc: denied { read open } for pid=540 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=320 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.800618] type=1400 audit(1293885309.100:9): avc: denied { execute_no_trans } for pid=540 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=320 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<6>[ 8.810146] [otg id chg] last id -1 current id 1
<6>[ 29.379921] warning: `main’ uses 32-bit capabilities (legacy support in use)
<12>[ 47.281442] healthd: battery none chg=
<6>[ 47.549566] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 47.549591] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 47.549599] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 47.549605] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 47.549612] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 47.549618] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 47.549625] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 81.565117] acc_open
<6>[ 81.565144] acc_release
<4>[ 81.734886] phy_power_on: enable = 1
<4>[ 81.774294] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 81.774332] eth0: device MAC address 72:ee:67:2c:26:57
<6>[ 81.778477] libphy: stmmac: probed
<6>[ 81.778489] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
<6>[ 81.778497] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
<4>[ 81.778915] ASOC:binding ES8323 at idx 0
<4>[ 81.778924] ---------------------start--------------------
<4>[ 81.778931] firfly : cpu_dai name:::ff890000.rockchip-i2s
<3>[ 81.778944] rockchip-es8323 rockchip-es8323.28: ASoC: CODEC (null) not registered
<4>[ 81.778967] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 81.778984] platform rockchip-es8323.28: Driver rockchip-es8323 requests probe deferral
<7>[ 81.779106] of_get_named_gpio_flags exited with status 226
<3>[ 81.779160] pwm-backlight backlight.20: unable to request PWM, trying legacy API
<3>[ 81.779169] pwm-backlight backlight.20: unable to request legacy PWM
<6>[ 81.779183] platform backlight.20: Driver pwm-backlight requests probe deferral
<4>[ 83.778772] dwc_otg_hcd_resume, usb device mode
<4>[ 83.781268] dwc_otg_hcd_suspend, usb device mode
<4>[ 83.781362] ff540000.usb resume, HPRT0:0x1485
<4>[ 83.919012] ff540000.usb suspend, HPRT0:0x1485
<7>[ 84.954571] SELinux: initialized (dev mmcblk0p15, type vfat), uses genfs_contexts
<6>[ 84.995079] pm policy 0 → 1
<11>[ 85.232764] init: no such service ‘fuse_internal_sd’
<4>[ 85.421937] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 85.421962] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 85.421972] D1:camsys_open(739): camsys_marvin(ddeb7710) is opened!
<4>[ 85.422057] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 85.422071] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 85.422084] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 85.422103] of_get_named_gpio_flags exited with status 237
<7>[ 85.422109] of_get_named_gpio_flags exited with status 237
<7>[ 85.422115] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 85.422123] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 85.422130] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 85.422143] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 85.422153] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x760c,result=0x760c
<4>[ 85.422162] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 85.422178] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 85.427236] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 85.427248] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 85.427354] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 85.427385] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 85.428454] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 85.429515] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 85.430577] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 85.621174] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 85.621194] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 85.817981] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 85.818007] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 85.818106] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 85.818119] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 85.818133] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 85.819243] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 85.819284] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 85.821363] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 85.821685] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 85.821699] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 85.821707] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 85.821714] D1:camsys_release(763): camsys_marvin(ddeb7710) is closed
<4>[ 85.827088] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 85.827105] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 85.827115] D1:camsys_open(739): camsys_marvin(ddeb7710) is opened!
<6>[ 86.133027] binder: release 166:166 transaction 11140 in, still active
<6>[ 86.133049] binder: send failed reply for transaction 11140 to 1417:1417
<4>[ 86.133061] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 86.133378] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 86.133388] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 86.133396] D1:camsys_release(763): camsys_marvin(ddeb7710) is closed
<4>[ 86.387432] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 86.387462] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 86.387471] D1:camsys_open(739): camsys_marvin(ddeb7710) is opened!
<4>[ 86.387548] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 86.387562] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 86.387572] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 86.387587] of_get_named_gpio_flags exited with status 237
<7>[ 86.387592] of_get_named_gpio_flags exited with status 237
<7>[ 86.387598] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 86.387605] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 86.387611] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 86.387620] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 86.387628] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x760c,result=0x760c
<4>[ 86.387635] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 86.387650] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 86.392871] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 86.392884] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 86.392992] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 86.393024] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 86.394171] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 86.395439] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 86.396614] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 86.595331] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 86.595349] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 86.792128] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
<3>[ 86.792148] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 86.792241] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 86.792254] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 86.792266] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 86.793359] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 86.793392] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 86.795444] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 86.795459] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 86.795468] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 86.795475] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 86.795481] D1:camsys_release(763): camsys_marvin(ddeb7710) is closed
<38>[ 86.797184] type=1400 audit(1293885388.370:10): avc: denied { execute } for pid=1887 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=307 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 86.797409] type=1400 audit(1293885388.370:11): avc: denied { read open } for pid=1887 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=307 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 86.797527] type=1400 audit(1293885388.370:12): avc: denied { execute_no_trans } for pid=1887 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=307 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 86.799403] type=1400 audit(1293885388.370:13): avc: denied { getattr } for pid=1887 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=320 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 86.799510] type=1400 audit(1293885388.370:14): avc: denied { execute } for pid=1887 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=320 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 86.799611] type=1400 audit(1293885388.370:15): avc: denied { read open } for pid=1887 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=320 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 86.799691] type=1400 audit(1293885388.370:16): avc: denied { execute_no_trans } for pid=1887 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=320 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 89.112523] type=1400 audit(1293885390.720:17): avc: denied { write } for pid=1973 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12253 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
<4>[ 89.113752] force_usb_mode_store 2->1
<4>[ 89.212327] Using Buffer DMA mode
<4>[ 89.212357] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 89.212369] Multiprocessor Interrupt Enhancement - disabled
<4>[ 89.212383] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 89.212394] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 89.214008] android_work: sent uevent USB_STATE=DISCONNECTED
<4>[ 89.252190] Init: Power Port (0)
<4>[ 89.252211] rk_battery_charger_detect_cb , battery_charger_detect 5
<4>[ 89.252252] ff580000.usb resume, HPRT0:0x1000
<4>[ 89.252341] ff580000.usb suspend, HPRT0:0x1000
<4>[ 89.447984] Current WiFi chip is AP6210.
<4>[ 90.104182] Current WiFi chip is AP6210.
<4>[ 90.110759] Current WiFi chip is AP6210.
<6>[ 90.137752] [BT_RFKILL]: bt shut off power
<6>[ 90.747955] [BT_RFKILL]: ENABLE UART_RTS
<6>[ 90.856081] [BT_RFKILL]: DISABLE UART_RTS
<6>[ 90.856146] [BT_RFKILL]: bt turn on power
<4>[ 91.588029] Current WiFi chip is AP6210.
<38>[ 91.764949] type=1400 audit(1293885393.420:18): avc: denied { write } for pid=1973 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12253 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
<4>[ 91.766344] force_usb_mode_store 1->2
<4>[ 91.766366] PortPower off
<4>[ 91.766376] rk_battery_charger_detect_cb , battery_charger_detect 6
<4>[ 91.964238] Using Buffer DMA mode
<4>[ 91.964283] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 91.964301] Multiprocessor Interrupt Enhancement - disabled
<4>[ 91.964317] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 91.964331] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 92.029029] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 92.029064] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 92.029079] D1:camsys_open(739): camsys_marvin(ddeb7710) is opened!
<3>[ 92.029190] E:camsys_extdev_register(197): register ext flash InternalE failed!
<4>[ 92.029220] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 92.029231] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 92.029243] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 92.029251] D1:camsys_release(763): camsys_marvin(ddeb7710) is closed
<4>[ 92.253342] vbus detect**
<4>[ 92.255539] rk_battery_charger_detect_cb , battery_charger_detect 1
<4>[ 92.432634] Using Buffer DMA mode
<4>[ 92.432665] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 92.432674] Multiprocessor Interrupt Enhancement - disabled
<4>[ 92.432688] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 92.432696] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 92.432744] soft connect!!!
<6>[ 92.538699] [BT_RFKILL]: bt shut off power
<4>[ 92.550482] USB RESET
<6>[ 92.600908] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 92.605440] USB RESET
<6>[ 92.683638] android_usb gadget: high-speed config #1: android
<6>[ 92.686415] android_work: sent uevent USB_STATE=CONFIGURED
<4>[ 162.565239] USB RESET
<4>[ 162.621507] USB RESET
<4>[ 162.886599] USB RESET
<4>[ 162.939050] USB RESET
<4>[ 163.131101] USB RESET
<4>[ 163.183062] USB RESET
<6>[ 163.405437] android_usb gadget: high-speed config #1: android
<6>[ 163.406683] android_work: sent uevent USB_STATE=CONFIGURED
其中:我主要发现了两点:
  1. pwm-backlight unable to request PWM, trying legacy API这个错误,然后去改dts还是这个错误
    2.edp probe成功,但是接下来就会出错
    rk32-edp rk32-edp: failed to get reset
    <3>[ 0.609830] rk32-edp rk32-edp: failed to get reset
    <6>[ 0.610548] rk32-edp rk32-edp: rk32 edp driver probe success
    <7>[ 0.611037] of_get_named_gpio_flags exited with status 227
    <6>[ 0.611270] graphics fb0: rockchip framebuffer registerd:fb0
    <6>[ 0.611572] graphics fb1: rockchip framebuffer registerd:fb1
    <6>[ 0.611742] graphics fb2: rockchip framebuffer registerd:fb2
    <6>[ 0.611905] graphics fb3: rockchip framebuffer registerd:fb3
    <6>[ 0.622879] rk3288-lcdc lcdc0: lcdc0: dclk:30000000>>fps:13
    <6>[ 0.623089] rk32-edp rk32-edp: edp pll locked
    <4>[ 0.635414] rk_battery_charger_detect_cb , battery_charger_detect 1
    <6>[ 0.664101] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:2
    <6>[ 0.667082] rk32-edp rk32-edp: link training success.
    <3>[ 0.765703] rk32-edp rk32-edp: Timeout of video streamclk ok
    <3>[ 0.765715] rk32-edp rk32-edp: unable to config video
    <6>[ 0.765727] rk3288-lcdc lcdc0: wakeup from standby!
    <6>[ 0.790887] alloc_buffer:ion_phy_addr=0x55c00000
    <6>[ 0.803454] fb0:phy:55c00000>>vir:e0991000>>len:0x1800000
    <6>[ 0.803472] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
我想点EDP,但是现在背光都没法点亮,求班主大神解惑,感激不尽!!!!!
HelloBirthday 发表于 2016-8-12 14:52
按照维基里点MIPI的方法点EDP,背光控制接的是PWM0,背光使能接的是GPIO7_A2,置高电平背光还是没反应。我 …
我觉得你参考的应该是lcd-LP097Qx1.dtsi,而不是mipi
都是类似的,现在是背光都没亮
HelloBirthday 发表于 2016-8-12 15:05
都是类似的,现在是背光都没亮
背光不亮不就是硬件io没拉起来,看软件。
这是我的配置,,参考下,另外,,,量一下gpio 的值
示波器测了,是高电平。输出电压也符合EDP屏的电压,但背光就是不亮
和你的基本上都一样啊。
但是rockchip-pwm-regulator.c文件中注册rockchip_pwm_regulator的时候,会出现这个错误unable to request PWM, trying legacy API。 不知道这个是用来干嘛的
HelloBirthday 发表于 2016-8-12 15:46
和你的基本上都一样啊。
但是rockchip-pwm-regulator.c文件中注册rockchip_pwm_regulator的时候,会出现 …
跟踪代码吧,,,可能pwm 有问题
发现了,我在重烧后。IO是低电平,也就是我贴出的那个pwm-backlight注册失败,但是我写个驱动直接将GPIO7_A2拉高,可以输出正常电压,但是背光不亮。还是跟rockchip-pwm-regulator.c代码有关,为啥注册pwm-backlight会失败,我一直找不到原因。我的dts和楼下loading的一样,是pwm0的
和你的基本上都一样啊。
这个本来就没用到的,如果你要用pwm0, remote那个pwm是不是应该先去掉。
还可以查一下你的pwm有没有注册成功。/sys/kernel/debug/pwm
loading 发表于 2016-8-12 16:00
跟踪代码吧,,,可能pwm 有问题
请教下。pwm-backlight注册是在哪里调用的?
还可以查一下你的pwm有没有注 …
/sys/kernel/debug/pwm 是存在的。。 remote那个pwm ???额,不太懂?麻烦能解释下么,谢谢
红外用了一个pwm, debug pwm是用来看的。 cat /sys/kernel/debug/pwm
cat /sys/kernel/debug/pwm没反应
不是没反应,是pwm全部都没打开
leung先森 发表于 2016-8-12 16:38
不是没反应,是pwm全部都没打开
额 我dts里只有pwm0 okay,其他disable。。 我找到注册pwm-backlight的文件了,pwm_bl.c,是在这注册pwm-backlight时失败的,我好好看看这段代码 是怎么失败的。。
之前5.1没更新,pwm0节点会有两个compatile,后面那个remotectl-pwm会覆盖rk-pwm,因此最终dtb中的pwm0不是rk-pwm,所以pwm_bl.c中注册pwm时失败了,我的方法是将remotectl-pwm节点删掉(有点暴力:lol),最终dtb中pwm0就是rk-pwm,背光设备注册成功。
更新代码后,rk3288.dtsi中pwm0部分节点已经更改了,背光节点部分只需要添加backlight,使能即可。
HelloBirthday 发表于 2016-8-25 14:20
之前5.1没更新,pwm0节点会有两个compatile,后面那个remotectl-pwm会覆盖rk-pwm,因此最终dtb中的pwm0不是 …
请问背光节点,blacklight是在哪个文件夹中修改
