按照wiki上的制作了ubuntu TF卡但是黑屏
我们按照wiki说的做了一张ubuntu的启动盘,启动那个蓝色的led灯不亮,自带android可以启动,那个灯是亮的。是不是需要按什么按键,还是卡不行?我的TF卡 三星 C10 16G的
GetParam
check parameter success
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 0000-00-00#0.00
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
checkKey
vbus = 0
boot/recovery image sha mismatch!
Unable to boot:boot
try to start recovery
failed to find part:recovery
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
failed to find part:kernel
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
我也是不成功。独立的SD ubuntu镜像,烧到TF卡上,启动灯都不亮?这是什么原因?请专家帮忙。
我用的是hdmi转vga输出到显示屏。
