机器会概率性卡死在kernel starting……,请大家帮忙看看
U-Boot 2014.10-RK3288-10-g791753e (Apr 20 2016 - 13:33:19)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 400
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2016-04-20#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00671e20)
ramdisk @ 0x05bf0000 (0x00156260)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561bca0 … OK
请问是怎么解决的?我也碰到了
上电时序时的电压问题
请问楼主问题怎么解决的,我也遇到了
请问楼主问题怎么解决的,我也遇到了
