急救。。开发板无法启动
刚买的开发板,第一次启动的时候还可以进入Android系统界面,插拔了几次串口,按了几次reset键,不知道什么操作导致Android界面无法启动,串口打印信息如下:
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Jan 21 2015 - 17:07:53)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
light power led: bank-8 pin-1
pmic:act8846
#Boot ver: 2015-01-21#2.17
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
rkboot #
