[求助]android5.1烧入之后,启动卡在kernel中。日志如下。
DDR Version 1.00 20160217
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=8 Size=1024MB
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Aug 08 2016 - 16:57:14)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
remotectl v0.1
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2016-08-08#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
can’t find dts node for deviceinfo
rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
tve baseparamer 0x0@0-0
Hdmi Devices Not Exist.
pll_src = 0, dclk_hz = 27000000, dclk_div = 22
-----1813—1—
rk1000_write_reg: failed to write register 0x0
rk1000_write_reg: failed to write register 0x3
no fuel gauge found
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a3ae8)
ramdisk @ 0x05bf0000 (0x002c6788)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561bc62 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (zmint@zmint-Vostro-470) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #2 SMP PREEMPT Thu Sep 8 17:05:04 CST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000 [ 0.000000] hdmi init vic is 93671260 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 55c00000 [ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f16000 s13376 r8192 d15296 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264 [ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x000020001 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1353180k/1353180k available, 743972k reserved, 884736K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0bad7ac (11926 kB) [ 0.000000] .init : 0xc0bae000 - 0xc0c07440 ( 358 kB) [ 0.000000] .data : 0xc0c08000 - 0xc0d9ab00 (1611 kB) [ 0.000000] .bss : 0xc0d9ab00 - 0xc0ebbafc (1156 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 28 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process
就卡到这里。谁能看出问题出在哪里?
