下面是板子启动后串口打印出来的信息,一直卡在Starting kernel …就不动了
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Nov 13 2015 - 10:22:31)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
Enter power_led_init
#Boot ver: 2015-11-13#2.17
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
read logo_on switch from dts [1]
failed to find part:baseparamer
Hdmi Devices Not Exist.
pll_src = 0, dclk_hz = 148500000, dclk_div = 4
ERROR: yrgb scale exceed 8,srcW=0,srcH=0,dstW=1920,dstH=1080
scale_yrgb_x 75799680 scale_yrgb_y 2no fuel gauge found
yrgb:h_fac=17024,v_fac=30338,gt4=0,gt2=0
scale_yrgb_x 17024 scale_yrgb_y 30338got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x02000000 (0x006a32e8)
ramdisk @ 0x04bf0000 (0x002c6734)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480b000, end 04826cce … OK
