rk3288 每3分自动重启
[ 13.393531] stmmac_open
[ 13.393553] phy_power_on: enable = 1 0
[ 13.575106] wifi_driver_write: wifi driver already rmmod
[ 14.018504] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 14.018543] eth0: device MAC address 9a:e0:14:7d:34:4a
[ 14.022409] libphy: stmmac: probed
[ 14.022419] eth0: PHY ID 0007c0f1 at 0 IRQ POLL (stmmac-0:00) active
[ 14.022426] PHY driver name: SMSC LAN8710/LAN8720[ 14.155241] acc_open
[ 14.155272] acc_release
[ 14.515421] dwc_otg_hcd_resume, usb device mode
[ 14.515528] dwc_otg_hcd_suspend, usb device mode
[ 14.746874] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 14.764750] stat failed -2
[ 14.844501] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
[ 14.844538] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec
[ 14.844825] init: no such service ‘fuse_internal_sd’
[ 15.779414] init: sys_prop: permission denied uid:10007 name:sys.gmali.version
[ 15.811412] init: sys_prop: permission denied uid:10031 name:sys.gmali.version
[ 16.634659] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 16.703380] e31f0234,e31f0234,e31f0234
[ 16.732765] stat failed -2
[ 18.700719] stat failed -2
[ 20.669122] stat failed -2
[ 22.637032] stat failed -2
[ 24.605091] stat failed -2
[ 26.573002] stat failed -2
[ 28.541091] stat failed -2
[ 30.509032] stat failed reboot
[ 30.509215] REBOOT after 2 min
[ 33.996174] rk3288-hdmi ff980000.hdmi: Removed.
[ 33.996206] power control 0
[ 33.996223] rk3288-lcdc lcdc0: blank mode:4
[ 54.951607] rk3288_lcdc_early_resume
[ 54.951615] TMP=21300
[ 55.050046] rk3288-lcdc lcdc0: blank mode:0
[ 56.034192] power control 1
[ 56.141935] rk3288-hdmi ff980000.hdmi: Removed.
[ 63.319918] healthd: battery l=100 v=10 t=0.0 h=2 st=5 chg=
[ 70.371220] rk3288-hdmi ff980000.hdmi: Removed.
[ 70.371253] power control 0
[ 70.371271] rk3288-lcdc lcdc0: blank mode:4
[ 129.472921] healthd: battery l=100 v=10 t=0.0 h=2 st=5 chg=
[ 158.635765] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 158.644009] pgd = c0004000
[ 158.647191] [00000000] *pgd=00000000
[ 158.651135] Internal error: Oops: 805 [#1] PREEMPT SMP ARM
[ 158.656596] Modules linked in: mali_kbase drmboot(P)
[ 158.661652] CPU: 0 PID: 31 Comm: kworker/0:1 Tainted: P W 3.10.0 #774
[ 158.668982] Workqueue: events check_auth
[ 158.672915] task: dd9a1500 ti: dd9e0000 task.ti: dd9e0000
[ 158.678291] PC is at check_auth+0x2a8/0x2ec
[ 158.682510] LR is at try_to_del_timer_sync+0x4c/0x54
[ 158.687461] pc : [] lr : [] psr: 60070013
[ 158.687461] sp : dd9e1df8 ip : 00000000 fp : 00000009
[ 158.698818] r10: c265aad4 r9 : c265aac0 r8 : c15e99b0
[ 158.704013] r7 : 00000000 r6 : c265df00 r5 : c265aac0 r4 : 00000000
[ 158.710480] r3 : 00000000 r2 : a0070013 r1 : dd9e1d9c r0 : 00000000
[ 158.716973] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 158.724216] Control: 10c5387d Table: 1c73406a DAC: 00000015
[ 158.729921]
[ 158.729921] PC: 0xc0316288:
[ 158.734180] 6288 e3530009 c59f00a4 ca000010 e2833001 e3a00e7d e5843050 ebf490a1 e59f2090
[ 158.742454] 62a8 e5921000 e1a03000 e3a00004 e0842000 ebf4dd80 e28d1068 e59f004c ebf7d1c5
[ 158.750719] 62c8 e1a01000 e59f006c eb14b931 ea00000c eb14b92f e59f0060 eb14b92d e59f005c
[ 158.758982] 62e8 ebf4b0b2 e3a0400a e3a00f7d ebf4b0af e3a00f7d ebf4b0ad e2544001 1afffff9
[ 158.767248] 6308 e5844000 e28ddf41 e8bd8030 c0a91d07 c0a91d1b c0a91d29 c0a91d37 c0a91d42
[ 158.775508] 6328 c1429b38 c15e99ac c0a5a443 c0a91d4e c0a91d71 c13ee480 c0a91d5f c0a91d87
[ 158.783773] 6348 0001d4c0 e12fff1e e3a03000 ea00000b e791c003 e540c004 e791c003 e1a0c42c
[ 158.792035] 6368 e540c003 e791c003 e1a0c82c e540c002 e791c003 e2833004 e1a0cc2c e540c001
[ 158.800309]
[ 158.800309] LR: 0xc0041b5c:
[ 158.804571] 1b5c e3d76003 0a000009 e1a00006 eb207806 e5850000 e1a01000 e594300c e1a00006
[ 158.812837] 1b7c e1570003 1a000000 e8bd80f8 eb2078cd eafffff1 e92d4037 e28d1004 e1a05000
[ 158.821100] 1b9c ebffffea e5903004 e1a04000 e1530005 03e05000 0a000006 e3a03000 e1a00005
[ 158.829363] 1bbc e5853020 e1a01004 e3a02001 ebfffefb e1a05000 e1a00004 e59d1004 eb2078b9
[ 158.837627] 1bdc e1a00005 e8bd803e e92d4010 e1a0200d e3c23d7f e1a04000 e3c3303f e5932004
[ 158.845890] 1bfc e59f3038 e0023003 e3530000 0a000005 e590300c e3130002 1a000002 e59f0020
[ 158.854149] 1c1c e3001424 ebffc916 e1a00004 ebffffd8 e3500000 ba000000 e8bd8010 eafffff9
[ 158.862412] 1c3c 03ff0000 c0a5df5f e92d4037 e3a03000 e5803020 e1a05000 e5903000 e3530000
[ 158.870684]
[ 158.870684] SP: 0xdd9e1d78:
[ 158.874945] 1d78 dd9e1d9c a0070013 00000000 dd9e1d9c c159e000 c0041c2c c159e000 c085d4c8
[ 158.883207] 1d98 a0070013 c0316308 60070013 ffffffff dd9e1de4 c000d598 00000000 dd9e1d9c
[ 158.891467] 1db8 a0070013 00000000 00000000 c265aac0 c265df00 00000000 c15e99b0 c265aac0
[ 158.899726] 1dd8 c265aad4 00000009 00000000 dd9e1df8 c0041bdc c0316308 60070013 ffffffff
[ 158.907985] 1df8 c15e99b0 00000080 c265aad4 2c5a61b1 d3a5f779 00000039 c085ff24 00000000
[ 158.916245] 1e18 c04f3a84 00000000 dd9e0000 dd807b40 00000039 c15e99b0 00000000 dd9e0000
[ 158.924504] 1e38 dd807b40 c009b3c0 dd16f900 dd16f8f8 00000001 c0067d50 0000013c dd807b40
[ 158.932763] 1e58 dd807b98 c5a16c80 dd9e1ef4 c15e99b0 c265aac0 c265aad4 00000009 c009b42c
[ 158.941033]
[ 158.941033] R1: 0xdd9e1d1c:
[ 158.945295] 1d1c 00000000 c13ef484 c13e4f40 00000033 c000e3b0 00000039 fed91000 dd9e1d50
[ 158.953557] 1d3c c0008538 c0041a70 20070013 ffffffff c000d600 dd9e1d9c 00000000 00000000
[ 158.961818] 1d5c c159e000 dd9e1d9c c00425cc 00000000 ffffc9a5 c265aad4 c0041bcc dd9e1d9c
[ 158.970081] 1d7c a0070013 00000000 dd9e1d9c c159e000 c0041c2c c159e000 c085d4c8 a0070013
[ 158.978341] 1d9c c0316308 60070013 ffffffff dd9e1de4 c000d598 00000000 dd9e1d9c a0070013
[ 158.986600] 1dbc 00000000 00000000 c265aac0 c265df00 00000000 c15e99b0 c265aac0 c265aad4
[ 158.994859] 1ddc 00000009 00000000 dd9e1df8 c0041bdc c0316308 60070013 ffffffff c15e99b0
[ 159.003118] 1dfc 00000080 c265aad4 2c5a61b1 d3a5f779 00000039 c085ff24 00000000 c04f3a84
[ 159.011390]
[ 159.011390] R5: 0xc265aa40:
[ 159.015651] aa40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.023906] aa60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.032159] aa80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.040412] aaa0 00000000 00000000 00000000 c06fa0f8 c265aaa0 c265aab4 c265aab4 00000000
[ 159.048671] aac0 3ac03ac0 00000000 00000000 00000000 00000000 c265aad4 c265aad4 00000003
[ 159.056929] aae0 00000002 db035a00 dd84f280 00000000 00000000 00000000 c159e001 c004bbe4
[ 159.065188] ab00 c265aac0 ffffffff ffffffff 00000000 00000000 00000000 00000000 00000000
[ 159.073448] ab20 00000000 00200200 ffff96db c159e000 c004bd98 c265aac0 ffffffff ffffffff
[ 159.081715]
[ 159.081715] R6: 0xc265de80:
[ 159.085974] de80 00000001 00000000 00000000 00000000 c15d5540 00000000 00000000 00000000
[ 159.094231] dea0 00000000 00001fe8 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.102484] dec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.110739] dee0 00000000 00000000 00100100 00200200 c00cde24 00000000 00000000 00000000
[ 159.118999] df00 c265aac0 dd812d80 00000000 ffffffff 00000002 00000001 00000000 00000000
[ 159.127255] df20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.135507] df40 00000000 00000000 00000000 00000000 00000001 00000100 c265df58 c265df58
[ 159.143765] df60 dd812d80 c2666f60 c265df68 c265df68 ffffffe0 c265df74 c265df74 c004ed88
[ 159.152032]
[ 159.152032] R8: 0xc15e9930:
[ 159.156291] 9930 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.164549] 9950 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.172800] 9970 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.181058] 9990 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.189307] 99b0 00000000 c15e99b4 c15e99b4 c0316060 00000000 00200200 ffff96c8 c159e002
[ 159.197571] 99d0 c004cf78 c15e99b0 ffffffff ffffffff 00000000 00000000 00000000 00000000
[ 159.205833] 99f0 00000000 dd812d80 00000004 0000000a dd15d800 00000000 00000000 00000000
[ 159.214089] 9a10 00000000 c1429d0c 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.222349]
[ 159.222349] R9: 0xc265aa40:
[ 159.226609] aa40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.234859] aa60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.243110] aa80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.251364] aaa0 00000000 00000000 00000000 c06fa0f8 c265aaa0 c265aab4 c265aab4 00000000
[ 159.259623] aac0 3ac03ac0 00000000 00000000 00000000 00000000 c265aad4 c265aad4 00000003
[ 159.267882] aae0 00000002 db035a00 dd84f280 00000000 00000000 00000000 c159e001 c004bbe4
[ 159.276141] ab00 c265aac0 ffffffff ffffffff 00000000 00000000 00000000 00000000 00000000
[ 159.284399] ab20 00000000 00200200 ffff96db c159e000 c004bd98 c265aac0 ffffffff ffffffff
[ 159.292668]
[ 159.292668] R10: 0xc265aa54:
[ 159.297012] aa54 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.305265] aa74 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.313516] aa94 00000000 00000000 00000000 00000000 00000000 00000000 c06fa0f8 c265aaa0
[ 159.321771] aab4 c265aab4 c265aab4 00000000 3ac03ac0 00000000 00000000 00000000 00000000
[ 159.330028] aad4 c265aad4 c265aad4 00000003 00000002 db035a00 dd84f280 00000000 00000000
[ 159.338289] aaf4 00000000 c159e001 c004bbe4 c265aac0 ffffffff ffffffff 00000000 00000000
[ 159.346549] ab14 00000000 00000000 00000000 00000000 00200200 ffff96db c159e000 c004bd98
[ 159.354809] ab34 c265aac0 ffffffff ffffffff 00000000 00000000 00000000 00000000 00000000
[ 159.363086] Process kworker/0:1 (pid: 31, stack limit = 0xdd9e0238)
[ 159.369305] Stack: (0xdd9e1df8 to 0xdd9e2000)
[ 159.373649] 1de0: c15e99b0 00000080
[ 159.381768] 1e00: c265aad4 2c5a61b1 d3a5f779 00000039 c085ff24 00000000 c04f3a84 00000000
[ 159.389880] 1e20: dd9e0000 dd807b40 00000039 c15e99b0 00000000 dd9e0000 dd807b40 c009b3c0
[ 159.397992] 1e40: dd16f900 dd16f8f8 00000001 c0067d50 0000013c dd807b40 dd807b98 c5a16c80
[ 159.406105] 1e60: dd9e1ef4 c15e99b0 c265aac0 c265aad4 00000009 c009b42c c028c9fc dd807b40
[ 159.414214] 1e80: dd807b98 c009de74 00000039 00000000 c13ef484 dd9e1ef4 c15e99b0 c000e3b0
[ 159.422323] 1ea0: 00000039 fed91000 dd9e1ec0 c0008538 c085ff24 200f0013 ffffffff c000d600
[ 159.430434] 1ec0: c265aac0 00000000 c265aad4 0000345e dda1b080 c265aac0 c265df00 00000000
[ 159.438546] 1ee0: c15e99b0 c265aac0 c265aad4 00000009 c13e6044 dd9e1f08 c004de1c dda1b080
[ 159.446661] 1f00: c265aac0 c004deb4 dda1b080 e31bda88 fefdc600 00000000 fefdc600 dda1b080
[ 159.454770] 1f20: c265aac0 c14fb21c dd9e0000 dda1b098 c265aac0 c265aad4 00000009 c004e204
[ 159.462878] 1f40: 00000000 dd8a9ea0 00000000 dda1b080 c004e070 00000000 00000000 00000000
[ 159.470987] 1f60: 00000000 c0053730 ffffffff 00000000 ffffffff dda1b080 00000000 00000000
[ 159.479098] 1f80: dd9e1f80 dd9e1f80 00000000 00000000 dd9e1f90 dd9e1f90 dd9e1fac dd8a9ea0
[ 159.487204] 1fa0: c0053690 00000000 00000000 c000da98 00000000 00000000 00000000 00000000
[ 159.495308] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 159.503413] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff
[ 159.511632] [] (check_auth+0x2a8/0x2ec) from [] (process_one_work+0x29c/0x458)
[ 159.520563] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 159.529740] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 159.537999] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 159.546044] Code: e3a00f7d ebf4b0ad e2544001 1afffff9 (e5844000)
[ 159.553297] —[ end trace bde105742c8d1e41 ]—
[ 159.557937] Kernel panic - not syncing: Fatal exception
[ 159.563085] CPU2: stopping
[ 159.565765] CPU: 2 PID: 0 Comm: swapper/2 Tainted: P D W 3.10.0 #774
[ 159.572739] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 159.581135] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 159.589281] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x50/0x58)
[ 159.597766] [] (gic_handle_irq+0x50/0x58) from [] (__irq_svc+0x40/0x70)
[ 159.605982] Exception stack(0xdd8bff30 to 0xdd8bff78)
[ 159.610958] ff20: dd8bff78 000000a1 ab9b3d21 00000025
[ 159.619004] ff40: c266c320 00000000 ab700407 00000025 c13f9158 dd8be000 c13f9168 00000000
[ 159.627050] ff60: 1b226170 dd8bff78 c0076bd4 c05c75e4 600e0013 ffffffff
[ 159.633605] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 159.642264] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 159.651754] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 159.660677] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 159.669251] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x64)
[ 159.678246] CPU1: stopping
[ 159.680923] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P D W 3.10.0 #774
[ 159.687872] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 159.696267] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 159.704404] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x50/0x58)
[ 159.712881] [] (gic_handle_irq+0x50/0x58) from [] (__irq_svc+0x40/0x70)
[ 159.721094] Exception stack(0xdd8bdf30 to 0xdd8bdf78)
[ 159.726066] df20: dd8bdf78 000000a1 ab9b3d21 00000025
[ 159.734115] df40: c2663320 00000000 ab03bfb8 00000025 c13f9158 dd8bc000 c13f9168 00000000
[ 159.742157] df60: 1b226170 dd8bdf78 c0076bd4 c05c75e4 600f0013 ffffffff
[ 159.748672] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 159.757322] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 159.766826] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 159.775728] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 159.784290] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x64)
[ 159.793270] CPU3: stopping
[ 159.795946] CPU: 3 PID: 0 Comm: swapper/3 Tainted: P D W 3.10.0 #774
[ 159.802896] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 159.811291] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 159.819424] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x50/0x58)
[ 159.827898] [] (gic_handle_irq+0x50/0x58) from [] (__irq_svc+0x40/0x70)
[ 159.836108] Exception stack(0xdd8c1f30 to 0xdd8c1f78)
[ 159.841083] 1f20: dd8c1f78 000000a1 ab9b3d21 00000025
[ 159.849129] 1f40: c2675320 00000000 ab4b9c5d 00000025 c13f9158 dd8c0000 c13f9168 00000000
[ 159.857174] 1f60: 1b226170 dd8c1f78 c0076bd4 c05c75e4 600f0013 ffffffff
[ 159.863691] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 159.872338] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 159.881839] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 159.890743] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 159.899309] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x64)
[ 159.908290] CRU:
[ 159.910121] 00000000: 00000001 9fff0031 0fff0019 00000008
[ 159.915437] 00000010: 00000005 9fff0031 0fff0018 00000008
[ 159.920752] 00000020: 00000005 9fff0052 0fff0029 00000008
[ 159.926066] 00000030: 00000107 9fff00c5 0fff0063 00000008
[ 159.931377] 00000040: 00000b00 9fff0270 0fff0138 00000008
[ 159.936689] 00000050: 00005111 00000000 00000000 00000000
[ 159.942007] 00000060: 00004031 0000b100 00000003 00000200
[ 159.947319] 00000070: 00008100 00008200 00008585 0bb8ea60
[ 159.952630] 00000080: 03105091 0bb8ea60 0000a100 00002743
[ 159.957945] 00000090: 00004143 00008a00 00000200 00000200
[ 159.963250] 000000a0: 00000200 0bb8ea60 0bb8ea60 0bb8ea60
[ 159.968564] 000000b0: 0bb8ea60 00000910 00000900 001f05dc
[ 159.973878] 000000c0: 00001703 00000707 00000040 00000300
[ 159.979192] 000000d0: 00000486 00000742 00004040 00000100
[ 159.984509] 000000e0: 00004040 00000202 00008042 00008f8f
[ 159.989823] 000000f0: 00000000 00000631 00001ee1 00008307
[ 159.995137] 00000100: 00001200 0bb8ea60 00004040 00000000
[ 160.000448] 00000110: 00000000 00000000 00000000 00000000
[ 160.005762] 00000120: 00000000 00000000 00000000 00000000
[ 160.011076] 00000130: 00000000 00000000 00000000 00000000
[ 160.016389] 00000140: 00000000 00000000 00000000 00000000
[ 160.021699] 00000150: 00000000 00000000 00000000 00000000
[ 160.027013] 00000160: 00001000 0000ff00 00003f60 0000faf8
[ 160.032324] 00000170: 00004ff0 0000bed0 0000fbf0 0000812b
[ 160.037635] 00000180: 00000fa4 00000000 00000c0d 00000dcc
[ 160.042949] 00000190: 00000000 0000fe84 00000000 0000c19e
[ 160.048262] 000001a0: 0000037f 00000000 00000000 00000000
[ 160.053575] 000001b0: 00000000 00000000 00000000 00000000
[ 160.058885] 000001c0: 00000000 00000000 00000000 00000000
[ 160.064195] 000001d0: 00000000 00000000 00000000 00000000
[ 160.069511] 000001e0: 00000000 00000000 00000000 00640064
[ 160.074821] 000001f0: 00000004 00000000 00000002 00000000
[ 160.080134] 00000200: 00000002 00000000 00000002 00000000
[ 160.085444] 00000210: 00000002 00000000 00000004 00000000
[ 160.090758] Rebooting in 5 seconds..DDR Version 1.00 20141007
