自己生产update.img后,运行报错,
DDR Version 1.00 20150318
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-09 (Sep 18 2016 - 10:15:19)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
Board: Rockchip platform Board 3288
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2016-09-18#2.19
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
boot/recovery image sha mismatch!
Unable to boot:recovery
try to start backup
bad image magic.
load boot image failed
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
少了一些image,检查一下package-file
顶顶顶顶
同问打包img文件的时候,如果修改filesystem文件夹的内容?
