Microsoft Windows [版本 6.1.7601]
版权所有 (c) 2009 Microsoft Corporation。保留所有权利。
C:\Users\Administrator>adb shell
root@rk3288:/ # dmesg | grep cam
dmesg | grep cam
[ 0.825206] [3g_modem]: modem_platdata_parse_dt: get property: cam,power_gpio = 17, flags = 0.
[ 0.825267] success request cam_power gpio
[ 0.825282] pdata->cam_power_en=17
[ 1.279721] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.279801] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.279950] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe14c8000 size: 0x4000)
[ 1.280622] D1:camsys_platform_probe(1394): ff910000.isp memory:
[ 1.280639] D1:camsys_platform_probe(1404): Register memory (phy: 0xff910000 vir: 0xe14e0000 size: 0x10000)
[ 1.280656] D1:camsys_platform_probe(1399): I2c memory (phy: 0x1cec0000 vir: 0xdcec0000 size: 0x1000)
[ 1.280670] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.280683] D1:camsys_platform_probe(1419): Probe ff910000.isp device success
[ 3.801693] init: avc: denied { set } for property=sys_graphic.cam_hal.ver scontext=u:r:mediaserver:s0 tcontext=u:object_r:default_prop:s0 tclass
=property_service
[ 3.875719] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 3.875738] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 3.875747] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 3.875905] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 3.875920] _gpio_request: gpio-17 (camsys_gpio) status -16
[ 3.875926] E:camsys_extdev_register(239): Request RK30_PIN0_PC1(17) failed
[ 3.875934] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 3.876020] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 3.876049] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
[ 3.881382] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 3.881399] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 3.881505] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 3.881544] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 3.882625] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 3.883684] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 3.884768] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 3.888073] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 3.888212] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 3.888223] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 3.888237] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 3.889334] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 3.889385] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 3.891460] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 3.891478] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 3.891491] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 3.891497] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 3.891505] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 3.914705] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 3.914722] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 3.914731] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 3.914890] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 3.914907] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 3.914948] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 3.914995] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 3.915015] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 3.920353] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 3.920371] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 3.920476] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 3.920512] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 3.921605] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 3.922670] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 3.923744] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 3.927062] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 3.927790] E:camsys_ioctl(1028): iommu status not consistent,check the dts file ! isp:1,vpu:0
[ 3.928468] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 3.928481] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 3.928493] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 3.929588] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 3.929632] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 3.931701] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 3.931719] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 3.931732] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 3.931739] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 3.931747] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 3.939101] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 3.939119] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 3.939129] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 3.939285] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(70) gpio(active: 0) for dev_id 0x2000000 success!
[ 3.939297] _gpio_request: gpio-15 (camsys_gpio) status -16
[ 3.939303] E:camsys_extdev_register(239): Request RK30_PIN0_PB7(15) failed
[ 3.939311] D1:camsys_extdev_register(243): Get RK30_PIN0_PB7(15) gpio(active: 0) for dev_id 0x2000000 success!
[ 3.939326] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 3.939364] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 3.939413] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 3.939433] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 3.944791] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 3.944808] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 3.944913] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 3.944955] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 3.946053] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 3.947130] D1:camsys_sysctl_extdev(366): Sysctl 8 success, gpio(15) set 1
[ 3.948202] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(70) set 1
[ 3.952818] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 3.954119] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 3.954267] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(70) set 0
[ 3.954282] D1:camsys_sysctl_extdev(362): Sysctl 8 success, gpio(15) set 0
[ 3.954294] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 3.955569] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 3.955621] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 3.957962] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 3.957987] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 3.958004] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 3.958013] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 3.958023] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 3.961880] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 3.961897] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 3.961906] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 3.962039] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 3.962055] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 3.962090] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 3.962135] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 3.962155] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success
[ 3.967498] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 3.967517] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 3.967622] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 3.967663] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 3.968747] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 3.969813] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 3.970894] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 3.974193] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 3.975402] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 3.975532] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 3.975542] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 3.975555] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 3.976648] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 3.976695] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 3.978771] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 3.978790] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 3.978805] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 3.978813] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 3.978821] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.002083] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.002102] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.002111] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.002265] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(70) gpio(active: 1) for dev_id 0x1000000 success!
[ 4.002281] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success!
[ 4.002291] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_dvp10bit
[ 4.002403] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
[ 4.007736] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.007753] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.007859] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.007900] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.008985] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.010059] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.011125] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(70) set 0
[ 4.014451] E:camsys_i2c_write(78): i2c write dev(addr:0x60) failed!
[ 4.014583] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(70) set 1
[ 4.014596] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.014612] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.015704] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.015747] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.017811] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 4.017829] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.017842] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.017848] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.017856] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.029794] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.029812] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.029822] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.029929] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.029949] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 4.029992] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 4.030048] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 4.030090] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
[ 4.035430] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.035446] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.035552] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.035593] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.036691] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.037777] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.038908] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 4.042185] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.042317] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 4.042329] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.042341] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.043431] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.043479] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.045567] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 4.045588] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.045603] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.045610] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.045618] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.046810] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.046824] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.046836] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.046974] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.046993] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 4.047029] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 4.047075] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 4.047095] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 4.052421] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.052438] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.052544] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.052579] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.053666] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.054785] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.055882] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 4.059147] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.059809] E:camsys_ioctl(1028): iommu status not consistent,check the dts file ! isp:1,vpu:0
[ 4.060474] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 4.060488] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.060501] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.061594] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.061644] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.063734] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 4.063756] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.063773] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.063780] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.063789] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.064855] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.064869] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.064878] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.064995] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(70) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.065009] D1:camsys_extdev_register(243): Get RK30_PIN0_PB7(15) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.065020] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 4.065053] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 4.065101] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 4.065121] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 4.070567] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.070585] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.070692] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.070731] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.071814] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.072911] D1:camsys_sysctl_extdev(366): Sysctl 8 success, gpio(15) set 1
[ 4.073994] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(70) set 1
[ 4.077277] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 4.078476] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.078607] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(70) set 0
[ 4.078624] D1:camsys_sysctl_extdev(362): Sysctl 8 success, gpio(15) set 0
[ 4.078635] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.079727] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.079777] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.081867] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 4.081891] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.081908] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.081916] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.081925] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.082961] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.082974] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.082982] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.083099] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.083115] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 4.083151] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 4.083199] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 4.083219] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success
[ 4.088546] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.088563] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.088668] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.088710] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.089811] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.090876] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.091953] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 4.095215] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.096456] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.096585] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 4.096596] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.096608] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.097715] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.097763] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.099876] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 4.099912] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.099933] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.099942] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.099951] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.101297] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.101312] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.101322] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.101443] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(70) gpio(active: 1) for dev_id 0x1000000 success!
[ 4.101460] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success!
[ 4.101470] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_dvp10bit
[ 4.101579] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
[ 4.106911] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.106929] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.107035] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.107075] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.108164] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.109231] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.110293] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(70) set 0
[ 4.113596] E:camsys_i2c_write(78): i2c write dev(addr:0x60) failed!
[ 4.113730] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(70) set 1
[ 4.113741] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.113753] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.114845] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.114889] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.116980] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 4.117003] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.117017] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.117024] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.117032] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.127219] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.127236] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.127245] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.127353] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.127369] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 4.127405] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 4.127450] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 4.127483] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
[ 4.132817] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.132834] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.132939] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.132980] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.134063] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.135123] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.136205] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 4.139502] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.139654] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 4.139667] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.139682] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.140777] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.140823] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.142890] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 4.142907] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.142918] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.142925] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.142934] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.144028] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.144041] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.144049] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.144167] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.144185] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 4.144223] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 4.144269] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 4.144290] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 4.149618] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.149636] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.149741] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.149782] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.150867] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.151934] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.153006] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 4.156302] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.157002] E:camsys_ioctl(1028): iommu status not consistent,check the dts file ! isp:1,vpu:0
[ 4.157673] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 4.157686] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.157699] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.158781] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.158826] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.160894] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 4.160911] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.160923] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.160930] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.160938] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.162021] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.162035] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.162043] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.162158] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(70) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.162171] D1:camsys_extdev_register(243): Get RK30_PIN0_PB7(15) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.162183] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 4.162219] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 4.162267] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 4.162289] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 4.167631] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.167649] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.167754] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.167801] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.168873] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.169949] D1:camsys_sysctl_extdev(366): Sysctl 8 success, gpio(15) set 1
[ 4.171027] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(70) set 1
[ 4.174320] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 4.175547] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.175679] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(70) set 0
[ 4.175694] D1:camsys_sysctl_extdev(362): Sysctl 8 success, gpio(15) set 0
[ 4.175706] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.176791] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.176833] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.178941] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 4.178962] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.178976] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.178983] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.178992] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.180512] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.180533] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.180545] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.180675] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(71) gpio(active: 0) for dev_id 0x2000000 success!
[ 4.180689] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 4.180732] _gpio_request: gpio-229 (camsys_gpio) status -16
[ 4.180782] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_mipi_fl
[ 4.180803] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success
[ 4.186122] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.186138] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.186243] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.186283] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.187375] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.188474] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.189581] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(71) set 1
[ 4.192856] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.194048] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 4.194207] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(71) set 0
[ 4.194217] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.194229] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.195353] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.195428] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.197523] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 4.197545] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.197560] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.197567] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.197575] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
[ 4.198558] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.198572] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 4.198580] D1:camsys_open(739): camsys_marvin(dcee5410) is opened!
[ 4.198683] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(70) gpio(active: 1) for dev_id 0x1000000 success!
[ 4.198696] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success!
[ 4.198707] D1:camsys_mrv_iomux_cb(92): marvin pinctrl select: isp_dvp10bit
[ 4.198818] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
[ 4.204186] D1:camsys_mrv_clkin_cb(352): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 4.204201] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 4.204306] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 4.204349] D1:camsys_mrv_clkout_cb(394): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 4.205449] D1:camsys_sysctl_extdev(362): Sysctl 11 success, gpio(17) set 1
[ 4.206549] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.207640] D1:camsys_sysctl_extdev(366): Sysctl 7 success, gpio(70) set 0
[ 4.210922] E:camsys_i2c_write(78): i2c write dev(addr:0x60) failed!
[ 4.211045] D1:camsys_sysctl_extdev(362): Sysctl 7 success, gpio(70) set 1
[ 4.211055] E:camsys_sysctl_extdev(369): Sysctl 8 failed, because gpio is NULL!
[ 4.211067] D1:camsys_sysctl_extdev(366): Sysctl 11 success, gpio(17) set 0
[ 4.212166] D1:camsys_mrv_clkin_cb(376): camsys_marvin clock in turn off
[ 4.212219] D1:camsys_mrv_clkout_cb(406): camsys_marvin clock out turn off
[ 4.214616] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 4.214644] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 4.214660] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.214667] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 4.214677] D1:camsys_release(763): camsys_marvin(dcee5410) is closed
dmesg | grep cam
1|root@rk3288:/ # ^C
