各位大侠:
帮忙看一下。我遇到的问题
先在开发板烧写下载的FirePrime_Android5.1_201603030926.img升级可以正常启动,再单独烧写源码编译的kernel也能正常启动,最后单独烧写源码编译的system.img启动后停在fireflylogo界面。
[ 2.953585] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/1021c000.rksdmmc/by-name/system
[ 2.956463] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: /sbin/resize2fs: Bad magic number in super-block while trying to open /dev/block/platform/1021c000.rksdmmc/by-name/systemresize2fs: Couldn’t find valid filesystem superblock.resize2fs: resize2fs terminated by exit(1)
[ 2.959437] EXT4-fs (mmcblk0p12): VFS: Can’t find ext4 filesystem
[ 2.959625] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/system,target=/system,type=ext4)=-1
[ 2.960364] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/platform/1021c000.rksdmmc/by-name/system at /system options: noauto_da_alloc error: Invalid argument
[ 2.968740] EXT4-fs (mmcblk0p8): recovery complete
[ 2.969176] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.969340] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.974515] EXT4-fs (mmcblk0p10): recovery complete
[ 2.974548] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.974698] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 3.031369] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[ 3.031407] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 3.031580] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2]
[ 3.032489] Cam_Powerdowm
[ 3.033224] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
[ 3.034682] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 3.035962] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 3.036540] mmc2: new high speed SDIO card at address 0001
[ 3.037288] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 3.037323] ov2659_front_4(rk_cam_sensor:387): write array failed!
[ 3.037339] ov2659_front_4(rk_cam_sensor:671): soft reset failed
[ 3.037339]
[ 3.037519] EXT4-fs (mmcblk0p9): 2 orphan inodes deleted
[ 3.037540] EXT4-fs (mmcblk0p9): recovery complete
[ 3.050567] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.050731] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 3.050816] init: fs_mgr_mount_all returned an error
[ 3.051191] init: fs_mgr_mount_all returned unexpected error 255
[ 3.053822] Unable to find swap-space signature
[ 3.053912] ov2659_front_4(rk_cam_sensor:335): read reg(0x300a val:0x0) failed, try to read again!
[ 3.053935] fs_mgr: swapon failed for /dev/block/zram0
[ 3.053945] ov2659_front_4(rk_cam_sensor:699): read chip id failed
[ 3.053976] bcmsdh_register: register client driver
[ 3.054215] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.054382] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.054404] bus num (host idx)=2, slot num (rca)=1
[ 3.054418] found adapter info ‘DHD generic adapter’
[ 3.055012] F1 signature read @0x18000000=0x1540a9a6
[ 3.058699] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x0 pkg:0x4
[ 3.059896] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 3.060080] wifi_platform_get_mac_addr
[ 3.060097] ======== bcm_wlan_get_mac_address ========
[ 3.060112] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.060133] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.060149] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.060170] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=0
[ 3.060252] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.061381] wl_create_event_handler(): thread:wl_event_handler:79 started
[ 3.061394] tsk Enter, tsk = 0xdde6149c
[ 3.062100] dhd_attach(): thread:dhd_watchdog_thread:7a started
[ 3.062240] dhd_attach(): thread:dhd_dpc:7b started
[ 3.062263] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 3.062364] dhd_attach(): thread:dhd_rxf:7c started
[ 3.062392] dhd_deferred_work_init: work queue initialized
[ 3.062662] dhdsdio_probe_init: set use_rxchain 0 from config.txt
[ 3.063262] Cannot change disksize for initialized device
[ 3.064847] Unable to find swap-space signature
[ 3.064946] fs_mgr: swapon failed for /dev/block/zram0
[ 3.076877] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 3.076877] Compiled in drivers/net/wireless/bcmdhd on Oct 25 2016 at 14:55:37
[ 3.077699] Register interface [wlan0] MAC: 94:a1:a2:a3:ff:e8
[ 3.077699]
[ 3.077730] dhd_prot_ioctl : bus is down. we have nothing to do
[ 3.077815] bcmsdh_oob_intr_unregister: Enter
[ 3.077832] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.077852] dhd_txglom_enable: enable 0
[ 3.077865] dhd_bus_devreset: WLAN OFF DONE
[ 3.077958] wifi_platform_set_power = 0
[ 3.077974] ======== PULL WL_REG_ON LOW! ========
[ 3.077988] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.107529] EXT4-fs (mmcblk0p9): Unrecognized mount option “background_gc=on” or missing value
[ 3.117831] init: cannot find ‘/system/bin/logd’, disabling ‘logd’
[ 3.118530] init: cannot find ‘/system/bin/lmkd’, disabling ‘lmkd’
[ 3.118597] init: cannot find ‘/system/bin/servicemanager’, disabling ‘servicemanager’
[ 3.118656] init: cannot find ‘/system/bin/vold’, disabling ‘vold’
[ 3.118705] init: cannot find ‘/system/bin/surfaceflinger’, disabling ‘surfaceflinger’
[ 3.121802] bat_cap: oldcap path is /sys/devices/2006c000.adc
[ 3.121903] bat_cap: oldcap_path no exist
[ 3.122241] binder: 126:126 transaction failed 29189, size 0-0
[ 3.125596] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.125636] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 3.125936] init: property ‘ro.product.manufacturer’ doesn’t exist while expanding ‘${ro.product.manufacturer}’
[ 3.125972] init: cannot expand ‘${ro.product.manufacturer}’ while writing to ‘/sys/class/android_usb/android0/iManufacturer’
[ 3.126009] init: property ‘ro.product.model’ doesn’t exist while expanding ‘${ro.product.model}’
[ 3.126037] init: cannot expand ‘${ro.product.model}’ while writing to ‘/sys/class/android_usb/android0/iProduct’
[ 3.126072] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 3.126102] init: property ‘ro.product.usbfactory’ doesn’t exist while expanding ‘$ro.product.usbfactory’
[ 3.126131] init: cannot expand ‘$ro.product.usbfactory’ while writing to ‘/sys/class/android_usb/android0/f_mass_storage/inquiry_string’
[ 3.127129] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.127150] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.127183] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.127198] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.127237] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.127253] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.127282] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.127296] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.133601] init: cannot find ‘/system/bin/sh’, disabling ‘console’
[ 3.133775] init: cannot find ‘/system/bin/rild’, disabling ‘ril-daemon’
[ 3.133912] android_usb: already disabled
[ 3.139663] read descriptors
[ 3.139693] read strings
[ 3.139747] pcd_pullup, is_on 1
[ 3.160425] Cam_Powerdowm
[ 3.180110] [WLAN_RFKILL]: wifi shut off power.
[ 3.180133] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.180148] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.180262] dhd_module_init: Exit err=0
[ 3.229302] ret: 0
[ 3.258862] soc-camera-pdrv gc0329_front_5: Probing gc0329_front_5
[ 3.327717] ret: 0
[ 3.475290] Cam_Powerdowm
[ 3.475838] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
[ 3.495951] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 3.496921] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 3.497884] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 3.525738] gc0329_front_5(rk_cam_sensor:335): read reg(0x0 val:0x0) failed, try to read again!
[ 3.525763] gc0329(917): gc0329 read chip id high byte failed
[ 3.525763]
[ 3.525780] gc0329(924): error: gc0329 mismatched pid = 0x0
[ 3.525780]
[ 3.525797] gc0329_front_5(rk_cam_sensor:718): error: mismatched pid = 0x0
[ 3.525797]
[ 3.632707] Cam_Powerdowm
[ 3.701606] ret: 0
[ 3.731175] soc-camera-pdrv gc2035_back_6: Probing gc2035_back_6
[ 3.819696] ret: 0
[ 3.967293] Cam_Powerdowm
[ 3.967313] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
[ 3.967387] soc-camera-pdrv gc2035_back_6: Cannot get I2C adapter #2. No driver?
[ 4.075526] Cam_Powerdowm
[ 4.075543] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
[ 4.075555] rk_cam_io(1117):SENSOR_PWRSEQ_HWRST failed
[ 4.105030] EHCI: rk_ehci_hcd_enable, disable host controller
[ 4.106373] binder: 126:126 transaction failed 29189, size 0-0
[ 4.144400] ret: 0
[ 4.173958] soc-camera-pdrv gc0308_front_7: Probing gc0308_front_7
[ 4.262490] ret: 0
[ 4.410093] Cam_Powerdowm
[ 4.410161] soc-camera-pdrv gc0308_front_7: Cannot get I2C adapter #2. No driver?
[ 4.518308] Cam_Powerdowm
[ 4.587216] ret: 0
[ 5.090499] binder: 126:126 transaction failed 29189, size 0-0
[ 5.295690] rk312x_delay_workq
[ 5.413792] [off]
[ 6.074627] binder: 126:126 transaction failed 29189, size 0-0
[ 6.721541] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
[ 7.058757] binder: 126:126 transaction failed 29189, size 0-0
[ 7.705514] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
[ 7.706288] rk818-battery rk818-battery: set charge to digital termination mode
[ 8.042893] binder: 126:126 transaction failed 29189, size 0-0
[ 9.027029] binder: 126:126 transaction failed 29189, size 0-0
[ 10.011167] binder: 126:126 transaction failed 29189, size 0-0
楼主你问题解决了吗 ?我也遇到这个问题
我也遇到过楼主类似的打印,最终找到原因了:是system分区大小过小导致的,楼主可以看一下你的parameter中的system分区大小,是否比system.img小(注意parameter中的分区size是以block为单位的,一个block是512个字节)。将parameter中的system分区大小改大一点就好了(注意烧录之前要低格nand)。希望对大家有帮助!
DDR Version 2.08 20180427
1A1A1C1C 3
DDR3
1B1C1C1C F
mach:2
Boot1 Release Time: Jul 25 2018 09:49:51, version: 2.52
ChipType = 0xa, 2272
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456M?&???,32
SdmmcInit=0 1
StorageInit ok = 113296
GPT 0x632c7e08 signature is wrong
tag:LOADER error,addr:0x2000
hdr 632c77e0 + 0x0:0x4d524150,0x00000188,0x4d524946,0x45524157,
LOADER Check OK! 0x60000000, 142397
tag:TOS error,addr:0x4000
hdr 632c77e0 + 0x0:0x44414f4c,0x20205245,0x00000000,0x00000000,
TOS Check OK! 0x68400000, 172321
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-372-g9a9308d-dev #2 Thu Dec 6 07:03:01 UTC 2018 arm)
INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 1.2
INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x60000000
U-Boot 2017.09-02729-gc4902d3fde (Mar 14 2019 - 10:10:43 +0800)
Model: Rockchip RK3128 Evaluation board
DRAM: 1010 MiB
Relocation Offset is: 00000000
Sysmem: init
dwmmc@1021c000: 0
MMC Device 1 not found
no mmc device at slot 1
switch to partitions #0, OK
Bootdev: mmc 0
PartType: RKPARM
get part misc fail -1
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK8180 (on=0x00, off=0x00)
vdd_arm 1100000 uV
vdd_logic 1100000 uV
In: serial2@20068000
Out: serial2@20068000
Err: serial2@20068000
Model: Rockchip RK3128 Fireprime board
CLK: (uboot. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
apll 600000 KHz
dpll 600000 KHz
cpll 400000 KHz
gpll 594000 KHz
armclk 600000 KHz
aclk_cpu 148500 KHz
hclk_cpu 74250 KHz
pclk_cpu 74250 KHz
aclk_peri 148500 KHz
hclk_peri 74250 KHz
pclk_peri 74250 KHz
Net: Net Initialization Skipped
No ethernet found.
Could not find misc partition
Kernel image @ 0x93f6b140 [ 0x000000 - 0x7bc9a8 ]
Fdt Ramdisk skip relocation
FDT load addr 0x10f00000 size 173 KiB
Booting kernel at 0x62008000 with fdt at 0x68300000…
## Booting Android Image at 0x6373ccf8 …
Kernel load addr 0x6373d4f8 size 7923 KiB
## Flattened Device Tree blob at 68300000
Booting using the fdt blob at 0x68300000
XIP Kernel Image … OK
CACHE: Misaligned operation at range [6373d4f8, 63ef9eb8]
Using Device Tree in place at 68300000, end 6830e6fa
Adding bank: 0x60000000 - 0x68400000 (size: 0x08400000)
Adding bank: 0x69200000 - 0xa0000000 (size: 0x36e00000)
Total: 2432.362 ms
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.4.154 (huangzx@tchip14) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #108 SMP Thu Apr 18 17:22:16 CST 2019
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] Machine model: Rockchip RK3128 Fireprime board
[ 0.000000] earlycon: Early serial console at MMIO32 0x20068000 (options ‘’)
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] PERCPU: Embedded 14 pages/cpu @ef798000 s24728 r8192 d24424 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257024
[ 0.000000] Kernel command line: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00010000@0 x0000a000(boot),0x00010000@0x0002a000(backup),-@0x0005a000(rootfs:grow) storagemedia=emmc androidboot.mode=emmc androidboot.slo t_suffix= androidboot.serialno=c3d9b8674f4b94f6 earlyprintk rw rootwait earlycon=uart8250,mmio32,0x20068000 console=ttyFIQ0 ro ot=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.000000] Memory: 988408K/1034240K available (12288K kernel code, 1000K rwdata, 3444K rodata, 1024K init, 651K bss, 29448K reserved, 16384K cma-reserved, 245760K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0d00000 (13280 kB)
[ 0.000000] .init : 0xc1200000 - 0xc1300000 (1024 kB)
[ 0.000000] .data : 0xc1300000 - 0xc13fa334 (1001 kB)
[ 0.000000] .bss : 0xc13fc000 - 0xc149ef30 ( 652 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008803] Switching to timer-based delay loop, resolution 41ns
[ 0.017847] Console: colour dummy device 80x30
[ 0.022768] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.034173] pid_max: default: 32768 minimum: 301
[ 0.039378] Security Framework initialized
[ 0.043902] Yama: becoming mindful.
[ 0.047818] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.055114] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.064103] Initializing cgroup subsys devices
[ 0.069061] Initializing cgroup subsys freezer
[ 0.073980] CPU: Testing write buffer coherency: ok
[ 0.079414] ftrace: allocating 44211 entries in 130 pages
[ 0.197301] /cpus/cpu@f00 missing clock-frequency property
[ 0.203274] /cpus/cpu@f01 missing clock-frequency property
[ 0.209312] /cpus/cpu@f02 missing clock-frequency property
[ 0.215271] /cpus/cpu@f03 missing clock-frequency property
[ 0.221252] CPU0: update cpu_capacity 430
[ 0.225612] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.232006] Setting up static identity map for 0x60100000 - 0x60100058
[ 0.242909] CPU1: update cpu_capacity 430
[ 0.242921] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.244240] CPU2: update cpu_capacity 430
[ 0.244250] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.245582] CPU3: update cpu_capacity 430
[ 0.245592] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.245760] Brought up 4 CPUs
[ 0.280807] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.287625] CPU: All CPU(s) started in SVC mode.
[ 0.294504] devtmpfs: initialized
[ 0.324622] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.333667] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.344402] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.352970] pinctrl core: initialized pinctrl subsystem
[ 0.360808] NET: Registered protocol family 16
[ 0.368824] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.398883] cpuidle: using governor ladder
[ 0.428922] cpuidle: using governor menu
[ 0.433228] Registered FIQ tty driver
[ 0.465215] genirq: Setting trigger mode 8 for irq 177 failed (gic_set_type+0x0/0x60)
[ 0.477921] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.486668] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.494127] console [ttyFIQ0] enabled
[ 0.501829] bootconsole [uart0] disabled
[ 0.510528] Registered fiq debugger ttyFIQ0
[ 0.612344] iommu: Adding device 1010e000.vop to group 0
[ 0.620191] SCSI subsystem initialized
[ 0.624477] usbcore: registered new interface driver usbfs
[ 0.630152] usbcore: registered new interface driver hub
[ 0.635680] usbcore: registered new device driver usb
[ 0.641025] media: Linux media interface: v0.10
[ 0.645672] Linux video capture interface: v2.00
[ 0.650365] pps_core: LinuxPPS API ver. 1 registered
[ 0.655372] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.664552] PTP clock support registered
[ 0.670921] Advanced Linux Sound Architecture Driver Initialized.
[ 0.678392] Bluetooth: Core ver 2.21
[ 0.682105] NET: Registered protocol family 31
[ 0.686560] Bluetooth: HCI device and connection manager initialized
[ 0.692965] Bluetooth: HCI socket layer initialized
[ 0.697860] Bluetooth: L2CAP socket layer initialized
[ 0.703008] Bluetooth: SCO socket layer initialized
[ 0.709744] rockchip-cpuinfo cpuinfo: Serial : 0e89e15f09284efa
[ 0.717541] clocksource: Switched to clocksource arch_sys_counter
[ 0.825500] NET: Registered protocol family 2
[ 0.831119] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.838405] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 0.845403] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.851925] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 0.857967] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 0.864768] NET: Registered protocol family 1
[ 0.869838] RPC: Registered named UNIX socket transport module.
[ 0.875763] RPC: Registered udp transport module.
[ 0.880533] RPC: Registered tcp transport module.
[ 0.885240] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.893924] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.905872] Initialise system trusted keyring
[ 0.931190] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.941099] NFS: Registering the id_resolver key type
[ 0.946218] Key type id_resolver registered
[ 0.950481] Key type id_legacy registered
[ 0.954527] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.962331] fuse init (API version 7.23)
[ 0.975746] NET: Registered protocol family 38
[ 0.980326] Key type asymmetric registered
[ 0.984451] Asymmetric key parser ‘x509’ registered
[ 0.989532] bounce: pool size: 64 pages
[ 0.993771] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.001221] io scheduler noop registered
[ 1.005162] io scheduler deadline registered
[ 1.009528] io scheduler cfq registered (default)
[ 1.024974] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-241330
[ 1.031751] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16
[ 1.042180] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.052774] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.064019] [drm] Initialized drm 1.1.0 20060810
[ 1.073013] [drm] Rockchip DRM driver version: v1.0.1
[ 1.078471] rockchip-drm display-subsystem: devfreq is not set
[ 1.084995] rockchip-vop 1010e000.vop: invalid resource
[ 1.090287] rockchip-vop 1010e000.vop: failed to get vop cabc lut registers
[ 1.097259] rockchip-vop 1010e000.vop: missing rockchip,grf property
[ 1.104066] [drm] no mcu-timing node found in /vop@1010e000
[ 1.109706] rockchip-drm display-subsystem: bound 1010e000.vop (ops 0xc0d64a48)
[ 1.117770] i2c i2c-4: of_i2c: modalias failure on /hdmi@20034000/port
[ 1.124319] innohdmi-rockchip 20034000.hdmi: registered Inno HDMI I2C bus driver
[ 1.132483] rockchip-drm display-subsystem: bound 20034000.hdmi (ops 0xc0d5d374)
[ 1.139952] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.146567] [drm] No driver support for vblank timestamp query.
[ 1.152674] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.192344] rockchip-vop 1010e000.vop: [drm:vop_crtc_enable] Update mode to 1280x720p60, type: 11
[ 1.255696] Console: switching to colour frame buffer device 160x45
[ 1.304166] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.340393] usbcore: registered new interface driver udl
[ 1.351090] brd: module loaded
[ 1.368439] loop: module loaded
[ 1.373118] zram: Added device: zram0
[ 1.376883] lkdtm: No crash points registered, enable through debugfs
[ 1.384802] register spi return v = :0
[ 1.388842] tun: Universal TUN/TAP device driver, 1.6
[ 1.393928] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.402704] rk_gmac-dwmac 2008c000.eth: clock input or output? (input).
[ 1.409431] rk_gmac-dwmac 2008c000.eth: TX delay(0x30).
[ 1.414671] rk_gmac-dwmac 2008c000.eth: RX delay(0x16).
[ 1.419957] rk_gmac-dwmac 2008c000.eth: integrated PHY? (no).
[ 1.425937] rk_gmac-dwmac 2008c000.eth: cannot get clock clk_mac_speed
[ 1.432501] rk_gmac-dwmac 2008c000.eth: clock input from PHY
[ 1.443209] rk_gmac-dwmac 2008c000.eth: init for RGMII
[ 1.448548] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.453601] Ring mode enabled
[ 1.456660] DMA HW capability register supported
[ 1.461245] Normal descriptors
[ 1.464584] RX Checksum Offload Engine supported (type 2)
[ 1.470087] TX Checksum insertion supported
[ 1.474358] Wake-Up On Lan supported
[ 1.478154] Enable RX Mitigation via HW Watchdog Timer
[ 1.561563] libphy: stmmac: probed
[ 1.564990] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.571489] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.579228] PPP generic driver version 2.4.2
[ 1.584132] usbcore: registered new interface driver rndis_wlan
[ 1.590661] usbcore: registered new interface driver rt2800usb
[ 1.596671] Rockchip WiFi SYS interface (V1.00) …
[ 1.601783] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.609350] usbcore: registered new interface driver pegasus
[ 1.615125] usbcore: registered new interface driver rtl8150
[ 1.620995] usbcore: registered new interface driver r8152
[ 1.626640] usbcore: registered new interface driver asix
[ 1.632199] usbcore: registered new interface driver ax88179_178a
[ 1.638468] usbcore: registered new interface driver cdc_ether
[ 1.644424] usbcore: registered new interface driver dm9601
[ 1.650181] usbcore: registered new interface driver smsc75xx
[ 1.656057] usbcore: registered new interface driver smsc95xx
[ 1.661972] usbcore: registered new interface driver net1080
[ 1.667789] usbcore: registered new interface driver rndis_host
[ 1.673808] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.681476] usbcore: registered new interface driver cdc_ncm
[ 1.687248] usbcore: registered new interface driver qmi_wwan
[ 1.693187] usbcore: registered new interface driver cdc_mbim
[ 1.699504] 10180000.usb supply vusb_d not found, using dummy regulator
[ 1.706270] 10180000.usb supply vusb_a not found, using dummy regulator
[ 1.917651] dwc2 10180000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 1.926188] dwc2 10180000.usb: DWC OTG Controller
[ 1.931030] dwc2 10180000.usb: new USB bus registered, assigned bus number 1
[ 1.938169] dwc2 10180000.usb: irq 30, io mem 0x10180000
[ 1.943882] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.950730] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.957988] usb usb1: Product: DWC OTG Controller
[ 1.962718] usb usb1: Manufacturer: Linux 4.4.154 dwc2_hsotg
[ 1.968417] usb usb1: SerialNumber: 10180000.usb
[ 1.974412] hub 1-0:1.0: USB hub found
[ 1.978326] hub 1-0:1.0: 1 port detected
[ 1.984693] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.991380] ehci-platform: EHCI generic platform driver
[ 2.000608] ehci-platform 101c0000.usb: EHCI Host Controller
[ 2.006756] ehci-platform 101c0000.usb: new USB bus registered, assigned bus number 2
[ 2.015014] ehci-platform 101c0000.usb: irq 31, io mem 0x101c0000
[ 2.037607] ehci-platform 101c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.044226] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.051084] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.058344] usb usb2: Product: EHCI Host Controller
[ 2.063254] usb usb2: Manufacturer: Linux 4.4.154 ehci_hcd
[ 2.068774] usb usb2: SerialNumber: 101c0000.usb
[ 2.074725] hub 2-0:1.0: USB hub found
[ 2.078863] hub 2-0:1.0: 1 port detected
[ 2.083972] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.090261] ohci-platform: OHCI generic platform driver
[ 2.095990] ohci-platform 101e0000.usb: Generic Platform OHCI controller
[ 2.103234] ohci-platform 101e0000.usb: new USB bus registered, assigned bus number 3
[ 2.111446] ohci-platform 101e0000.usb: irq 32, io mem 0x101e0000
[ 2.182342] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.189240] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.196499] usb usb3: Product: Generic Platform OHCI controller
[ 2.202464] usb usb3: Manufacturer: Linux 4.4.154 ohci_hcd
[ 2.207988] usb usb3: SerialNumber: 101e0000.usb
[ 2.214015] hub 3-0:1.0: USB hub found
[ 2.217901] hub 3-0:1.0: 1 port detected
[ 2.223048] usbcore: registered new interface driver cdc_acm
[ 2.228799] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.236944] usbcore: registered new interface driver cdc_wdm
[ 2.242938] usbcore: registered new interface driver usb-storage
[ 2.249218] usbcore: registered new interface driver usbserial
[ 2.255137] usbcore: registered new interface driver usbserial_generic
[ 2.261810] usbserial: USB Serial support registered for generic
[ 2.267975] usbcore: registered new interface driver ch341
[ 2.273525] usbserial: USB Serial support registered for ch341-uart
[ 2.280234] usbcore: registered new interface driver cp210x
[ 2.285885] usbserial: USB Serial support registered for cp210x
[ 2.292040] usbcore: registered new interface driver ftdi_sio
[ 2.297927] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.305600] usbcore: registered new interface driver keyspan
[ 2.311409] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.319609] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.327011] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.334436] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.342307] usbcore: registered new interface driver option
[ 2.348002] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.355419] usbcore: registered new interface driver oti6858
[ 2.361228] usbserial: USB Serial support registered for oti6858
[ 2.367354] usbcore: registered new interface driver pl2303
[ 2.373046] usbserial: USB Serial support registered for pl2303
[ 2.379159] usbcore: registered new interface driver qcserial
[ 2.384978] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.392245] usbcore: registered new interface driver sierra
[ 2.397907] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.405030] usbserial: USB Serial support registered for Sierra USB modem
[ 2.413788] usbcore: registered new interface driver iforce
[ 2.419636] usbcore: registered new interface driver xpad
[ 2.425902] usbcore: registered new interface driver usbtouchscreen
[ 2.432728] .. rk pwm remotectl v1.1 init
[ 2.437352] input: 20050030.pwm as /devices/platform/20050030.pwm/input/input0
[ 2.445664] sensor_register_slave:mma8452,id=17
[ 2.450272] sensor_register_slave:lis3dh,id=7
[ 2.454642] sensor_register_slave:mma7660,id=18
[ 2.459232] sensor_register_slave:lsm303d,id=22
[ 2.463780] sensor_register_slave:gs_mc3230,id=23
[ 2.468524] [Gsensor] gsensor_init
[ 2.472422] sensor_register_slave:mpu6880_acc,id=24
[ 2.477345] sensor_register_slave:mpu6500_acc,id=25
[ 2.482286] sensor_register_slave:lsm330_acc,id=26
[ 2.487090] sensor_register_slave:akm8975,id=30
[ 2.491664] sensor_register_slave:akm8963,id=31
[ 2.496230] sensor_register_slave:l3g4200d,id=45
[ 2.500896] sensor_register_slave:l3g20d,id=46
[ 2.505360] sensor_register_slave:ewtsa,id=47
[ 2.509781] sensor_register_slave:lsm330_gyro,id=51
[ 2.514678] sensor_register_slave:cm3217,id=53
[ 2.519172] sensor_register_slave:cm3218,id=54
[ 2.524835] i2c /dev entries driver
[ 2.531685] rk808 0-001c: Pmic Chip id: 0x8180
[ 2.536638] rk808 0-001c: source: on=0x40, off=0x00
[ 2.545241] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.551611] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.558176] DCDC_REG1: supplied by vcc_sys
[ 2.562870] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.569681] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.576871] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 2.582794] DCDC_REG2: supplied by vcc_sys
[ 2.583040] hub 2-1:1.0: USB hub found
[ 2.583248] hub 2-1:1.0: 4 ports detected
[ 2.596283] DCDC_REG3: supplied by vcc_sys
[ 2.601724] DCDC_REG4: supplied by vcc_sys
[ 2.608402] LDO_REG1: supplied by vcc_sys
[ 2.614452] LDO_REG2: supplied by vcc_sys
[ 2.620582] LDO_REG3: supplied by vcc_sys
[ 2.626640] LDO_REG4: supplied by vcc_sys
[ 2.632760] LDO_REG5: supplied by vcc_sys
[ 2.638801] LDO_REG6: supplied by vcc_sys
[ 2.644818] LDO_REG7: supplied by vcc_sys
[ 2.650974] LDO_REG8: supplied by vcc_sys
[ 2.657167] LDO_REG9: supplied by vcc_io
[ 2.663159] SWITCH_REG: supplied by vcc_io
[ 2.674872] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.682667] rk3x-i2c 20072000.i2c: Initialized RK3xxx I2C bus at f0c62000
[ 2.692587] usbcore: registered new interface driver uvcvideo
[ 2.698440] USB Video Class driver (1.1.1)
[ 2.706543] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.715479] Bluetooth: Virtual HCI driver ver 1.5
[ 2.720600] Bluetooth: HCI UART driver ver 2.3
[ 2.725061] Bluetooth: HCI UART protocol H4 registered
[ 2.730238] Bluetooth: HCI UART protocol LL registered
[ 2.735377] Bluetooth: HCI UART protocol ATH3K registered
[ 2.740997] usbcore: registered new interface driver bfusb
[ 2.746630] usbcore: registered new interface driver btusb
[ 2.752687] cpu cpu0: leakage=24
[ 2.755946] cpu cpu0: leakage-volt-sel=2
[ 2.759927] cpu cpu0: leakage-scale=0
[ 2.763952] cpu cpu0: Failed to get pvtm
[ 2.771821] sdhci: Secure Digital Host Controller Interface driver
[ 2.778110] sdhci: Copyright(c) Pierre Ossman
[ 2.782486] Synopsys Designware Multimedia Card Interface Driver
[ 2.789615] dwmmc_rockchip 10218000.dwmmc: Using external DMA controller.
[ 2.796442] dwmmc_rockchip 10218000.dwmmc: Version ID is 270a
[ 2.802279] dwmmc_rockchip 10218000.dwmmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[ 2.812106] dwmmc_rockchip 10218000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.820283] dwmmc_rockchip 10218000.dwmmc: No vmmc regulator found
[ 2.826457] dwmmc_rockchip 10218000.dwmmc: No vqmmc regulator found
[ 2.833030] dwmmc_rockchip 10218000.dwmmc: allocated mmc-pwrseq
[ 2.857636] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.877749] dwmmc_rockchip 10218000.dwmmc: 1 slots initialized
[ 2.884422] dwmmc_rockchip 1021c000.dwmmc: Using external DMA controller.
[ 2.887656] usb 2-1.1: new low-speed USB device number 3 using ehci-platform
[ 2.898526] dwmmc_rockchip 1021c000.dwmmc: Version ID is 270a
[ 2.905419] dwmmc_rockchip 1021c000.dwmmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[ 2.915260] dwmmc_rockchip 1021c000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.923472] dwmmc_rockchip 1021c000.dwmmc: No vmmc regulator found
[ 2.927769] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.929344] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.930912] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.933722] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.937162] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.957109] dwmmc_rockchip 1021c000.dwmmc: No vqmmc regulator found
[ 2.977618] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.998648] dwmmc_rockchip 1021c000.dwmmc: 1 slots initialized
[ 3.006692] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.016561] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.021092] usb 2-1.1: New USB device found, idVendor=0603, idProduct=2801
[ 3.021099] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.022039] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.024904] mmc0: new high speed SDIO card at address 0001
[ 3.057133] input: HID 0603:2801 as /devices/platform/101c0000.usb/usb2/2-1/2-1.1/2-1.1:1.0/0003:0603:2801.0001/input/input1
[ 3.068483] mmc1: MAN_BKOPS_EN bit is not set
[ 3.073896] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.084175] mmc1: new high speed MMC card at address 0001
[ 3.090328] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 3.095250] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[ 3.101566] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[ 3.107884] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB
[ 3.114254] uboot: 0x000800000 – 0x000c00000 (4 MB)
[ 3.119710] trust: 0x000c00000 – 0x001000000 (4 MB)
[ 3.125111] boot: 0x001400000 – 0x003400000 (32 MB)
[ 3.128521] hid-generic 0003:0603:2801.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 0603:2801] on usb-101c0000.usb-1.1/input0
[ 3.135295] input: HID 0603:2801 as /devices/platform/101c0000.usb/usb2/2-1/2-1.1/2-1.1:1.1/0003:0603:2801.0002/input/input2
[ 3.153546] backup: 0x005400000 – 0x007400000 (32 MB)
[ 3.159066] rootfs:grow: 0x00b400000 – 0x1d1c00000 (7272 MB)
[ 3.164846] mmcblk1: p1 p2 p3 p4 p5
[ 3.188046] hid-generic 0003:0603:2801.0002: input,hidraw1: USB HID v1.10 Mouse [HID 0603:2801] on usb-101c0000.usb-1.1/input1
[ 3.199831] usbcore: registered new interface driver usbhid
[ 3.205396] usbhid: USB HID core driver
[ 3.209739] ashmem: initialized
[ 3.213326] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 3.221071] 2006c000.saradc supply vref not found, using dummy regulator
[ 3.228547] rknandbase v1.2 2018-05-08
[ 3.233299] usbcore: registered new interface driver snd-usb-audio
[ 3.245865] rk-multicodecs codec-hdmi-sound: multicodec ↔ 10200000.i2s-8ch mapping ok
[ 3.255145] input: rockchip,codec-hdmi Headphones as /devices/platform/codec-hdmi-sound/sound/card0/input3
[ 3.265717] u32 classifier
[ 3.268495] Netfilter messages via NETLINK v0.30.
[ 3.273284] nf_conntrack version 0.5.0 (15699 buckets, 62796 max)
[ 3.279998] ctnetlink v0.93: registering with nfnetlink.
[ 3.285481] ip_set: protocol 6
[ 3.288593] IPVS: Registered protocols ()
[ 3.292634] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 3.300121] IPVS: Creating netns size=1104 id=0
[ 3.304708] IPVS: ipvs loaded.
[ 3.308186] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.313791] Initializing XFRM netlink socket
[ 3.319104] NET: Registered protocol family 10
[ 3.324962] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.330712] sit: IPv6 over IPv4 tunneling driver
[ 3.336081] NET: Registered protocol family 17
[ 3.340635] NET: Registered protocol family 15
[ 3.345141] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.357802] Bridge firewalling registered
[ 3.362025] Bluetooth: RFCOMM socket layer initialized
[ 3.367194] Bluetooth: RFCOMM ver 1.11
[ 3.371002] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.376929] Bluetooth: HIDP socket layer initialized
[ 3.382007] 8021q: 802.1Q VLAN Support v1.8
[ 3.386219] lib80211: common routines for IEEE802.11 drivers
[ 3.391964] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.396899] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.401746] -----had defined CONFIG_MFD_SYSCON-----
[ 3.406650] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 3.413552] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.420710] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.428180] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 2, flags = 0.
[ 3.437218] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 3.444537] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.449774] -----No power_ctrl_by pmu-----
[ 3.453876] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.458705] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.463365] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 17.
[ 3.471525] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 35.
[ 3.479577] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 42.
[ 3.487521] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 41.
[ 3.495785] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 3.502578] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.507879] [BT_RFKILL]: ** disable irq
[ 3.511896] -----BT Turn off reset → 0-----
[ 3.516200] [BT_RFKILL]: bt_default device registered.
[ 3.521512] Key type dns_resolver registered
[ 3.525983] sensor_register_slave:mpu6880_gyro,id=50
[ 3.531012] Error: Driver ‘ov13850’ is already registered, aborting…
[ 3.532678] vendor storage:20160801 ret = 0
[ 3.542859] ThumbEE CPU extension supported.
[ 3.547154] Registering SWP/SWPB emulation handler
[ 3.552988] Loading compiled-in X.509 certificates
[ 3.557996] pvtm list NULL
[ 3.561382] rockchip-dmc dmc: Cannot get the regulator “center”
[ 3.568887] asoc-simple-card spdif-sound: dit-hifi ↔ 10204000.spdif mapping ok
[ 3.577662] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 3.577664]
[ 3.577675] =======================================================
[ 3.577676] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 3.577678] =======================================================
[ 3.577681] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 3.577685] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.577689] [WLAN_RFKILL]: wifi turn on power. -1
[ 3.577691] RTW: module init start
[ 3.577694] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 3.577697] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.577883] usbcore: registered new interface driver rtl8188eu
[ 3.577886] RTW: module init ret=0
[ 3.578695] input: gpio-keys as /devices/platform/gpio-keys/input/input4
[ 3.579142] ==gsl_ts_init==
[ 3.579204] ret=0
[ 3.631830] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:07 UTC (1358499007)
[ 3.641893] vcc_otg_vbus: disabling
[ 3.641901] vcc_sdmmc: disabling
[ 3.642050] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘15:55:39’, on ‘Apr 4 2019’.
[ 3.642396] Mali: Mali device driver loaded
[ 3.646855] ALSA device list:
[ 3.646860] #0: rockchip,codec-hdmi
[ 3.646862] #1: ROCKCHIP,SPDIF
[ 3.707739] ======== dhd_wlan_init_plat_data ========
[ 3.708037] Waiting for root device PARTUUID=614e0000-0000…
[ 3.718554] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 3.723520] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 3.728767] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.734335] dhd_wlan_init_gpio: host_oob_irq: 50
[ 3.738970] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 3.744275] dhd_wifi_platform_load: Enter
[ 3.748356] Power-up adapter ‘DHD generic adapter’
[ 3.753496] wifi_platform_set_power = 1
[ 3.757340] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.762503] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.767202] [WLAN_RFKILL]: wifi turn on power. -1
[ 4.077730] wifi_platform_bus_enumerate device present 1
[ 4.083077] ======== Card detection to detect SDIO card! ========
[ 4.089307] mmc0:mmc host rescan start!
[ 4.109518] bcmsdh_register: register client driver
[ 4.114990] bcmsdh_sdmmc_probe: Enter num=1
[ 4.119844] bcmsdh_sdmmc_probe: Enter num=2
[ 4.124072] bus num (host idx)=0, slot num (rca)=1
[ 4.128974] found adapter info ‘DHD generic adapter’
[ 4.134299] sdioh_attach: set sd_f2_blocksize 256
[ 4.139490] sdioh_attach: sd clock rate = 0
[ 4.144242] F1 signature read @0x18000000=0x1541a9a6
[ 4.152865] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 4.160541] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 4.167162] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[ 4.172767] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 4.180029] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 4.186531] wl_escan_attach: Enter
[ 4.190035] wl_escan_init: Enter
[ 4.193398] wl_create_event_handler(): thread:wl_escan_handler:76 started
[ 4.193408] tsk Enter, tsk = 0xee090170
[ 4.204366] dhd_attach(): thread:dhd_watchdog_thread:77 started
[ 4.210424] dhd_attach(): thread:dhd_dpc:78 started
[ 4.215396] dhd_attach(): thread:dhd_rxf:79 started
[ 4.220313] dhd_deferred_work_init: work queue initialized
[ 4.225842] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 4.232065] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 4.249021] Dongle Host Driver, version 1.579.77.41.2 (r)
[ 4.255210] Register interface [wlan0] MAC: 10:d0:7a:56:d2:3a
[ 4.255210]
[ 4.262645] dhd_wl_ioctl: returning as busstate=0
[ 4.267346] dhd_dbg_detach_pkt_monitor, 2204
[ 4.271645] dhd_bus_devreset: == Power OFF ==
[ 4.276319] bcmsdh_oob_intr_unregister: Enter
[ 4.280720] bcmsdh_oob_intr_unregister: irq is not registered
[ 4.286467] dhd_txglom_enable: enable 0
[ 4.290344] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 4.298285] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[ 4.305935] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[ 4.312649] sdioh_set_mode: set txglom_mode to copy
[ 4.317540] dhd_bus_devreset: WLAN OFF DONE
[ 4.321923] wifi_platform_set_power = 0
[ 4.325764] ======== PULL WL_REG_ON(-1) LOW! ========
[ 4.330837] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 4.335553] [WLAN_RFKILL]: wifi shut off power.
[ 4.340199] dhd_module_init: Exit err=0
[ 6.247682] rk312x_delay_workq
1A1A1C1C 3
DDR3
1B1C1C1C F
mach:2
ChipType = 0xa, 2278
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MBL???,32
SdmmcInit=0 1
StorageInit ok = 113546
LOADER Check OK! 0x60000000, 142649
TOS Check OK! 0x68400000, 172575
Enter Trust OS
DRAM: 1010 MiB
Sysmem: init
dwmmc@1021c000: 0
Bootdev: mmc 0
PartType: RKPARM
boot mode: None
DTB: rk-kernel.dtb
I2c speed: 400000Hz
vdd_arm 1100000 uV
apll 600000 KHz
dpll 600000 KHz
cpll 400000 KHz
gpll 594000 KHz
armclk 600000 KHz
aclk_cpu 148500 KHz
hclk_cpu 74250 KHz
pclk_cpu 74250 KHz
hclk_peri 74250 KHz
pclk_peri 74250 KHz
No ethernet found.
Total: 2433.914 ms
[ 0.000000] Kernel command line: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00010000@0x0000a000(boot),0x00010000@0x0002a000(backup),-@0x0005a000(rootfs:grow) storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 earlyprintk rw rootwait earlycon=uart8250,mmio32,0x20068000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.017843] Console: colour dummy device 80x30
[ 0.022766] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.034169] pid_max: default: 32768 minimum: 301
[ 0.039375] Security Framework initialized
[ 0.043899] Yama: becoming mindful.
[ 0.055112] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.064100] Initializing cgroup subsys devices
[ 0.197303] /cpus/cpu@f00 missing clock-frequency property
[ 0.203266] /cpus/cpu@f01 missing clock-frequency property
[ 0.209303] /cpus/cpu@f02 missing clock-frequency property
[ 0.215280] /cpus/cpu@f03 missing clock-frequency property
[ 0.225603] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.231999] Setting up static identity map for 0x60100000 - 0x60100058
[ 0.242903] CPU1: update cpu_capacity 430
[ 0.242914] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.244237] CPU2: update cpu_capacity 430
[ 0.244248] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.245580] CPU3: update cpu_capacity 430
[ 0.245591] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.245764] Brought up 4 CPUs
[ 0.280743] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.287569] CPU: All CPU(s) started in SVC mode.
[ 0.294446] devtmpfs: initialized
[ 0.324625] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.333679] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.344416] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.353007] pinctrl core: initialized pinctrl subsystem
[ 0.360861] NET: Registered protocol family 16
[ 0.368837] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.398939] cpuidle: using governor ladder
[ 0.428978] cpuidle: using governor menu
[ 0.433293] Registered FIQ tty driver
[ 0.465313] genirq: Setting trigger mode 8 for irq 177 failed (gic_set_type+0x0/0x60)
[ 0.478021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.486732] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.494192] console [ttyFIQ0] enabled
[ 0.501902] bootconsole [uart0] disabled
[ 0.510602] Registered fiq debugger ttyFIQ0
[ 0.612436] iommu: Adding device 1010e000.vop to group 0
[ 0.620283] SCSI subsystem initialized
[ 0.624568] usbcore: registered new interface driver usbfs
[ 0.630239] usbcore: registered new interface driver hub
[ 0.635771] usbcore: registered new device driver usb
[ 0.641112] media: Linux media interface: v0.10
[ 0.645757] Linux video capture interface: v2.00
[ 0.650451] pps_core: LinuxPPS API ver. 1 registered
[ 0.655457] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.664634] PTP clock support registered
[ 0.670999] Advanced Linux Sound Architecture Driver Initialized.
[ 0.678480] Bluetooth: Core ver 2.21
[ 0.682196] NET: Registered protocol family 31
[ 0.686652] Bluetooth: HCI device and connection manager initialized
[ 0.693059] Bluetooth: HCI socket layer initialized
[ 0.697956] Bluetooth: L2CAP socket layer initialized
[ 0.703105] Bluetooth: SCO socket layer initialized
[ 0.709837] rockchip-cpuinfo cpuinfo: Serial : 0e89e15f09284efa
[ 0.717698] clocksource: Switched to clocksource arch_sys_counter
[ 0.825707] NET: Registered protocol family 2
[ 0.831336] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.838611] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 0.845610] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.852139] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 0.858183] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 0.864992] NET: Registered protocol family 1
[ 0.870123] RPC: Registered named UNIX socket transport module.
[ 0.876050] RPC: Registered udp transport module.
[ 0.880828] RPC: Registered tcp transport module.
[ 0.885534] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.894214] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.906172] Initialise system trusted keyring
[ 0.931483] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.941398] NFS: Registering the id_resolver key type
[ 0.946538] Key type id_resolver registered
[ 0.950801] Key type id_legacy registered
[ 0.954847] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.962651] fuse init (API version 7.23)
[ 0.976025] NET: Registered protocol family 38
[ 0.980604] Key type asymmetric registered
[ 0.984726] Asymmetric key parser ‘x509’ registered
[ 0.989809] bounce: pool size: 64 pages
[ 0.994046] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.001495] io scheduler noop registered
[ 1.005437] io scheduler deadline registered
[ 1.009802] io scheduler cfq registered (default)
[ 1.025246] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-241330
[ 1.032028] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16
[ 1.042413] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.052996] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.064291] [drm] Initialized drm 1.1.0 20060810
[ 1.073258] [drm] Rockchip DRM driver version: v1.0.1
[ 1.078718] rockchip-drm display-subsystem: devfreq is not set
[ 1.085240] rockchip-vop 1010e000.vop: invalid resource
[ 1.090534] rockchip-vop 1010e000.vop: failed to get vop cabc lut registers
[ 1.097506] rockchip-vop 1010e000.vop: missing rockchip,grf property
[ 1.104315] [drm] no mcu-timing node found in /vop@1010e000
[ 1.109958] rockchip-drm display-subsystem: bound 1010e000.vop (ops 0xc0d64a48)
[ 1.118017] i2c i2c-4: of_i2c: modalias failure on /hdmi@20034000/port
[ 1.124568] innohdmi-rockchip 20034000.hdmi: registered Inno HDMI I2C bus driver
[ 1.132727] rockchip-drm display-subsystem: bound 20034000.hdmi (ops 0xc0d5d374)
[ 1.140195] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.146810] [drm] No driver support for vblank timestamp query.
[ 1.152916] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.192589] rockchip-vop 1010e000.vop: [drm:vop_crtc_enable] Update mode to 1280x720p60, type: 11
[ 1.254103] Console: switching to colour frame buffer device 160x45
[ 1.302583] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.340614] usbcore: registered new interface driver udl
[ 1.351296] brd: module loaded
[ 1.368581] loop: module loaded
[ 1.373249] zram: Added device: zram0
[ 1.377012] lkdtm: No crash points registered, enable through debugfs
[ 1.384918] register spi return v = :0
[ 1.388955] tun: Universal TUN/TAP device driver, 1.6
[ 1.394042] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.402832] rk_gmac-dwmac 2008c000.eth: clock input or output? (input).
[ 1.409569] rk_gmac-dwmac 2008c000.eth: TX delay(0x30).
[ 1.414811] rk_gmac-dwmac 2008c000.eth: RX delay(0x16).
[ 1.420107] rk_gmac-dwmac 2008c000.eth: integrated PHY? (no).
[ 1.426092] rk_gmac-dwmac 2008c000.eth: cannot get clock clk_mac_speed
[ 1.432665] rk_gmac-dwmac 2008c000.eth: clock input from PHY
[ 1.443382] rk_gmac-dwmac 2008c000.eth: init for RGMII
[ 1.448717] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.453771] Ring mode enabled
[ 1.456831] DMA HW capability register supported
[ 1.461423] Normal descriptors
[ 1.464762] RX Checksum Offload Engine supported (type 2)
[ 1.470272] TX Checksum insertion supported
[ 1.474557] Wake-Up On Lan supported
[ 1.478357] Enable RX Mitigation via HW Watchdog Timer
[ 1.561687] libphy: stmmac: probed
[ 1.565112] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.571611] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.579357] PPP generic driver version 2.4.2
[ 1.584255] usbcore: registered new interface driver rndis_wlan
[ 1.590807] usbcore: registered new interface driver rt2800usb
[ 1.596778] Rockchip WiFi SYS interface (V1.00) …
[ 1.601889] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.609464] usbcore: registered new interface driver pegasus
[ 1.615238] usbcore: registered new interface driver rtl8150
[ 1.621108] usbcore: registered new interface driver r8152
[ 1.626749] usbcore: registered new interface driver asix
[ 1.632310] usbcore: registered new interface driver ax88179_178a
[ 1.638575] usbcore: registered new interface driver cdc_ether
[ 1.644530] usbcore: registered new interface driver dm9601
[ 1.650290] usbcore: registered new interface driver smsc75xx
[ 1.656167] usbcore: registered new interface driver smsc95xx
[ 1.662081] usbcore: registered new interface driver net1080
[ 1.667902] usbcore: registered new interface driver rndis_host
[ 1.673944] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.681591] usbcore: registered new interface driver cdc_ncm
[ 1.687361] usbcore: registered new interface driver qmi_wwan
[ 1.693283] usbcore: registered new interface driver cdc_mbim
[ 1.699600] 10180000.usb supply vusb_d not found, using dummy regulator
[ 1.706367] 10180000.usb supply vusb_a not found, using dummy regulator
[ 1.917807] dwc2 10180000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 1.926346] dwc2 10180000.usb: DWC OTG Controller
[ 1.931196] dwc2 10180000.usb: new USB bus registered, assigned bus number 1
[ 1.938340] dwc2 10180000.usb: irq 30, io mem 0x10180000
[ 1.944057] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.950909] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.958188] usb usb1: Product: DWC OTG Controller
[ 1.962899] usb usb1: Manufacturer: Linux 4.4.154 dwc2_hsotg
[ 1.968598] usb usb1: SerialNumber: 10180000.usb
[ 1.974595] hub 1-0:1.0: USB hub found
[ 1.978484] hub 1-0:1.0: 1 port detected
[ 1.984830] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.991552] ehci-platform: EHCI generic platform driver
[ 2.000748] ehci-platform 101c0000.usb: EHCI Host Controller
[ 2.006894] ehci-platform 101c0000.usb: new USB bus registered, assigned bus number 2
[ 2.015150] ehci-platform 101c0000.usb: irq 31, io mem 0x101c0000
[ 2.037768] ehci-platform 101c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.044373] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.051229] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.058511] usb usb2: Product: EHCI Host Controller
[ 2.063401] usb usb2: Manufacturer: Linux 4.4.154 ehci_hcd
[ 2.068920] usb usb2: SerialNumber: 101c0000.usb
[ 2.074892] hub 2-0:1.0: USB hub found
[ 2.078999] hub 2-0:1.0: 1 port detected
[ 2.084103] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.090385] ohci-platform: OHCI generic platform driver
[ 2.096110] ohci-platform 101e0000.usb: Generic Platform OHCI controller
[ 2.103351] ohci-platform 101e0000.usb: new USB bus registered, assigned bus number 3
[ 2.111566] ohci-platform 101e0000.usb: irq 32, io mem 0x101e0000
[ 2.182498] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.189394] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.196651] usb usb3: Product: Generic Platform OHCI controller
[ 2.202614] usb usb3: Manufacturer: Linux 4.4.154 ohci_hcd
[ 2.208153] usb usb3: SerialNumber: 101e0000.usb
[ 2.214171] hub 3-0:1.0: USB hub found
[ 2.218054] hub 3-0:1.0: 1 port detected
[ 2.223193] usbcore: registered new interface driver cdc_acm
[ 2.228946] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.237092] usbcore: registered new interface driver cdc_wdm
[ 2.243084] usbcore: registered new interface driver usb-storage
[ 2.249368] usbcore: registered new interface driver usbserial
[ 2.255287] usbcore: registered new interface driver usbserial_generic
[ 2.261958] usbserial: USB Serial support registered for generic
[ 2.268127] usbcore: registered new interface driver ch341
[ 2.273680] usbserial: USB Serial support registered for ch341-uart
[ 2.280391] usbcore: registered new interface driver cp210x
[ 2.286029] usbserial: USB Serial support registered for cp210x
[ 2.292209] usbcore: registered new interface driver ftdi_sio
[ 2.298078] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.305747] usbcore: registered new interface driver keyspan
[ 2.311551] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.319748] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.327148] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.334574] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.342421] usbcore: registered new interface driver option
[ 2.348122] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.355544] usbcore: registered new interface driver oti6858
[ 2.361349] usbserial: USB Serial support registered for oti6858
[ 2.367475] usbcore: registered new interface driver pl2303
[ 2.373167] usbserial: USB Serial support registered for pl2303
[ 2.379278] usbcore: registered new interface driver qcserial
[ 2.385096] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.392359] usbcore: registered new interface driver sierra
[ 2.398025] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.405152] usbserial: USB Serial support registered for Sierra USB modem
[ 2.413938] usbcore: registered new interface driver iforce
[ 2.419780] usbcore: registered new interface driver xpad
[ 2.426093] usbcore: registered new interface driver usbtouchscreen
[ 2.432908] .. rk pwm remotectl v1.1 init
[ 2.437526] input: 20050030.pwm as /devices/platform/20050030.pwm/input/input0
[ 2.445837] sensor_register_slave:mma8452,id=17
[ 2.450445] sensor_register_slave:lis3dh,id=7
[ 2.454816] sensor_register_slave:mma7660,id=18
[ 2.459416] sensor_register_slave:lsm303d,id=22
[ 2.463963] sensor_register_slave:gs_mc3230,id=23
[ 2.468708] [Gsensor] gsensor_init
[ 2.472683] sensor_register_slave:mpu6880_acc,id=24
[ 2.477605] sensor_register_slave:mpu6500_acc,id=25
[ 2.482544] sensor_register_slave:lsm330_acc,id=26
[ 2.487357] sensor_register_slave:akm8975,id=30
[ 2.491949] sensor_register_slave:akm8963,id=31
[ 2.496498] sensor_register_slave:l3g4200d,id=45
[ 2.501164] sensor_register_slave:l3g20d,id=46
[ 2.505628] sensor_register_slave:ewtsa,id=47
[ 2.510048] sensor_register_slave:lsm330_gyro,id=51
[ 2.514944] sensor_register_slave:cm3217,id=53
[ 2.519439] sensor_register_slave:cm3218,id=54
[ 2.525111] i2c /dev entries driver
[ 2.531955] rk808 0-001c: Pmic Chip id: 0x8180
[ 2.536895] rk808 0-001c: source: on=0x50, off=0x00
[ 2.545521] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.551893] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.558547] DCDC_REG1: supplied by vcc_sys
[ 2.563121] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.569925] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.577107] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 2.583245] hub 2-1:1.0: USB hub found
[ 2.583251] DCDC_REG2: supplied by vcc_sys
[ 2.591528] hub 2-1:1.0: 4 ports detected
[ 2.596609] DCDC_REG3: supplied by vcc_sys
[ 2.602102] DCDC_REG4: supplied by vcc_sys
[ 2.608808] LDO_REG1: supplied by vcc_sys
[ 2.614855] LDO_REG2: supplied by vcc_sys
[ 2.620982] LDO_REG3: supplied by vcc_sys
[ 2.627062] LDO_REG4: supplied by vcc_sys
[ 2.633203] LDO_REG5: supplied by vcc_sys
[ 2.639267] LDO_REG6: supplied by vcc_sys
[ 2.645298] LDO_REG7: supplied by vcc_sys
[ 2.651450] LDO_REG8: supplied by vcc_sys
[ 2.657636] LDO_REG9: supplied by vcc_io
[ 2.663647] SWITCH_REG: supplied by vcc_io
[ 2.675383] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.683200] rk3x-i2c 20072000.i2c: Initialized RK3xxx I2C bus at f0c62000
[ 2.693027] usbcore: registered new interface driver uvcvideo
[ 2.698824] USB Video Class driver (1.1.1)
[ 2.706975] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.715904] Bluetooth: Virtual HCI driver ver 1.5
[ 2.721028] Bluetooth: HCI UART driver ver 2.3
[ 2.725490] Bluetooth: HCI UART protocol H4 registered
[ 2.730666] Bluetooth: HCI UART protocol LL registered
[ 2.735805] Bluetooth: HCI UART protocol ATH3K registered
[ 2.741429] usbcore: registered new interface driver bfusb
[ 2.747075] usbcore: registered new interface driver btusb
[ 2.753130] cpu cpu0: leakage=24
[ 2.756389] cpu cpu0: leakage-volt-sel=2
[ 2.760382] cpu cpu0: leakage-scale=0
[ 2.764418] cpu cpu0: Failed to get pvtm
[ 2.772285] sdhci: Secure Digital Host Controller Interface driver
[ 2.778582] sdhci: Copyright(c) Pierre Ossman
[ 2.782958] Synopsys Designware Multimedia Card Interface Driver
[ 2.790059] dwmmc_rockchip 10218000.dwmmc: Using external DMA controller.
[ 2.796868] dwmmc_rockchip 10218000.dwmmc: Version ID is 270a
[ 2.802719] dwmmc_rockchip 10218000.dwmmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[ 2.812537] dwmmc_rockchip 10218000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.820698] dwmmc_rockchip 10218000.dwmmc: No vmmc regulator found
[ 2.826875] dwmmc_rockchip 10218000.dwmmc: No vqmmc regulator found
[ 2.833460] dwmmc_rockchip 10218000.dwmmc: allocated mmc-pwrseq
[ 2.857766] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.877821] dwmmc_rockchip 10218000.dwmmc: 1 slots initialized
[ 2.884165] dwmmc_rockchip 1021c000.dwmmc: Using external DMA controller.
[ 2.891132] dwmmc_rockchip 1021c000.dwmmc: Version ID is 270a
[ 2.897819] dwmmc_rockchip 1021c000.dwmmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[ 2.907586] dwmmc_rockchip 1021c000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.907745] usb 2-1.1: new low-speed USB device number 3 using ehci-platform
[ 2.910665] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.912234] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.913799] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.916615] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.920064] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.950347] dwmmc_rockchip 1021c000.dwmmc: No vmmc regulator found
[ 2.956545] dwmmc_rockchip 1021c000.dwmmc: No vqmmc regulator found
[ 2.977770] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.998799] dwmmc_rockchip 1021c000.dwmmc: 1 slots initialized
[ 3.004909] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.006838] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.008808] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.010280] usbcore: registered new interface driver usbhid
[ 3.010283] usbhid: USB HID core driver
[ 3.010703] ashmem: initialized
[ 3.011123] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 3.012204] 2006c000.saradc supply vref not found, using dummy regulator
[ 3.012971] rknandbase v1.2 2018-05-08
[ 3.013905] usbcore: registered new interface driver snd-usb-audio
[ 3.020789] rk-multicodecs codec-hdmi-sound: multicodec ↔ 10200000.i2s-8ch mapping ok
[ 3.022103] input: rockchip,codec-hdmi Headphones as /devices/platform/codec-hdmi-sound/sound/card0/input1
[ 3.023001] u32 classifier
[ 3.023014] Netfilter messages via NETLINK v0.30.
[ 3.023114] nf_conntrack version 0.5.0 (15699 buckets, 62796 max)
[ 3.023747] ctnetlink v0.93: registering with nfnetlink.
[ 3.023983] ip_set: protocol 6
[ 3.024001] IPVS: Registered protocols ()
[ 3.024055] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 3.024215] IPVS: Creating netns size=1104 id=0
[ 3.024268] IPVS: ipvs loaded.
[ 3.024734] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.025063] Initializing XFRM netlink socket
[ 3.026313] NET: Registered protocol family 10
[ 3.028024] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.028314] sit: IPv6 over IPv4 tunneling driver
[ 3.029219] NET: Registered protocol family 17
[ 3.029253] NET: Registered protocol family 15
[ 3.029329] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.029367] Bridge firewalling registered
[ 3.029636] Bluetooth: RFCOMM socket layer initialized
[ 3.029675] Bluetooth: RFCOMM ver 1.11
[ 3.029730] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.029748] Bluetooth: HIDP socket layer initialized
[ 3.029825] 8021q: 802.1Q VLAN Support v1.8
[ 3.029864] lib80211: common routines for IEEE802.11 drivers
[ 3.029924] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.030178] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.030183] -----had defined CONFIG_MFD_SYSCON-----
[ 3.030211] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 3.030215] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.030219] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.030274] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 2, flags = 0.
[ 3.030284] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 3.030288] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.030290] -----No power_ctrl_by pmu-----
[ 3.030298] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.030412] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.030714] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 17.
[ 3.030743] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 35.
[ 3.030761] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 42.
[ 3.030779] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 41.
[ 3.030787] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 3.030869] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.030950] [BT_RFKILL]: ** disable irq
[ 3.031158] -----BT Turn off reset → 0-----
[ 3.031179] [BT_RFKILL]: bt_default device registered.
[ 3.031326] Key type dns_resolver registered
[ 3.031538] sensor_register_slave:mpu6880_gyro,id=50
[ 3.031556] Error: Driver ‘ov13850’ is already registered, aborting…
[ 3.032755] ThumbEE CPU extension supported.
[ 3.032779] Registering SWP/SWPB emulation handler
[ 3.033829] Loading compiled-in X.509 certificates
[ 3.033997] pvtm list NULL
[ 3.034751] rockchip-dmc dmc: Cannot get the regulator “center”
[ 3.036350] asoc-simple-card spdif-sound: dit-hifi ↔ 10204000.spdif mapping ok
[ 3.037803] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 3.037805]
[ 3.037808] =======================================================
[ 3.037811] ======== dhd_wlan_init_plat_data ========
[ 3.037813] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 3.037817] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 3.037819] =======================================================
[ 3.037822] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 3.037825] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 3.037829] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.037832] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.037836] dhd_wlan_init_gpio: host_oob_irq: 50
[ 3.037838] [WLAN_RFKILL]: wifi turn on power. -1
[ 3.037841] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 3.037842] RTW: module init start
[ 3.037844] dhd_wifi_platform_load: Enter
[ 3.037847] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 3.037850] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.037877] Power-up adapter ‘DHD generic adapter’
[ 3.037975] wifi_platform_set_power = 1
[ 3.037979] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.037983] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.037987] [WLAN_RFKILL]: wifi turn on power. -1
[ 3.038038] usbcore: registered new interface driver rtl8188eu
[ 3.038041] RTW: module init ret=0
[ 3.039071] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 3.039564] ==gsl_ts_init==
[ 3.039664] ret=0
[ 3.045105] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:52:39 UTC (1358499159)
[ 3.050778] mmc1: MAN_BKOPS_EN bit is not set
[ 3.051550] usb 2-1.1: New USB device found, idVendor=0603, idProduct=2801
[ 3.051558] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.052542] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.053601] mmc1: new high speed MMC card at address 0001
[ 3.057604] input: HID 0603:2801 as /devices/platform/101c0000.usb/usb2/2-1/2-1.1/2-1.1:1.0/0003:0603:2801.0001/input/input3
[ 3.057905] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 3.058471] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[ 3.058939] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[ 3.059433] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB
[ 3.060153] uboot: 0x000800000 – 0x000c00000 (4 MB)
[ 3.060159] trust: 0x000c00000 – 0x001000000 (4 MB)
[ 3.060164] boot: 0x001400000 – 0x003400000 (32 MB)
[ 3.060168] backup: 0x005400000 – 0x007400000 (32 MB)
[ 3.060173] rootfs:grow: 0x00b400000 – 0x1d1c00000 (7272 MB)
[ 3.061156] mmcblk1: p1 p2 p3 p4 p5
[ 3.061157] vcc_otg_vbus: disabling
[ 3.061162] vcc_sdmmc: disabling
[ 3.061316] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘15:55:39’, on ‘Apr 4 2019’.
[ 3.061658] Mali: Mali device driver loaded
[ 3.062443] ALSA device list:
[ 3.062450] #0: rockchip,codec-hdmi
[ 3.062453] #1: ROCKCHIP,SPDIF
[ 3.118610] hid-generic 0003:0603:2801.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 0603:2801] on usb-101c0000.usb-1.1/input0
[ 3.126128] input: HID 0603:2801 as /devices/platform/101c0000.usb/usb2/2-1/2-1.1/2-1.1:1.1/0003:0603:2801.0002/input/input4
[ 3.188200] hid-generic 0003:0603:2801.0002: input,hidraw1: USB HID v1.10 Mouse [HID 0603:2801] on usb-101c0000.usb-1.1/input1
[ 3.337704] wifi_platform_bus_enumerate device present 1
[ 3.337707] ======== Card detection to detect SDIO card! ========
[ 3.337711] mmc0:mmc host rescan start!
[ 3.539286] vendor storage:20160801 ret = 0
[ 3.713366] Waiting for root device PARTUUID=614e0000-0000…
[ 3.721666] mmc0: new high speed SDIO card at address 0001
[ 3.744038] bcmsdh_register: register client driver
[ 3.749067] bcmsdh_sdmmc_probe: Enter num=1
[ 3.753521] bcmsdh_sdmmc_probe: Enter num=2
[ 3.757834] bus num (host idx)=0, slot num (rca)=1
[ 3.762629] found adapter info ‘DHD generic adapter’
[ 3.767732] sdioh_attach: set sd_f2_blocksize 256
[ 3.772492] sdioh_attach: sd clock rate = 0
[ 3.777118] F1 signature read @0x18000000=0x1541a9a6
[ 3.785362] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 3.792921] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 3.799566] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[ 3.805146] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 3.812364] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 3.818981] wl_escan_attach: Enter
[ 3.822439] wl_escan_init: Enter
[ 3.825813] wl_create_event_handler(): thread:wl_escan_handler:77 started
[ 3.827739] tsk Enter, tsk = 0xee070170
[ 3.836749] dhd_attach(): thread:dhd_watchdog_thread:78 started
[ 3.842814] dhd_attach(): thread:dhd_dpc:79 started
[ 3.847813] dhd_attach(): thread:dhd_rxf:7a started
[ 3.852694] dhd_deferred_work_init: work queue initialized
[ 3.858269] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 3.864483] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 3.881926] Dongle Host Driver, version 1.579.77.41.2 (r)
[ 3.888142] Register interface [wlan0] MAC: 10:d0:7a:56:d2:3a
[ 3.888142]
[ 3.895551] dhd_wl_ioctl: returning as busstate=0
[ 3.900288] dhd_dbg_detach_pkt_monitor, 2204
[ 3.904564] dhd_bus_devreset: == Power OFF ==
[ 3.909252] bcmsdh_oob_intr_unregister: Enter
[ 3.913609] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.919385] dhd_txglom_enable: enable 0
[ 3.923217] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 3.931157] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[ 3.938828] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[ 3.945530] sdioh_set_mode: set txglom_mode to copy
[ 3.950415] dhd_bus_devreset: WLAN OFF DONE
[ 3.954787] wifi_platform_set_power = 0
[ 3.958662] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3.963710] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.968439] [WLAN_RFKILL]: wifi shut off power.
[ 3.973064] dhd_module_init: Exit err=0
[ 6.027865] rk312x_delay_workq
