(已解决)FirePrime开机卡着了,求助!!!
打印信息如下:
[ 3.272374] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.310512] Cam_Powerdowm
[ 3.344795] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
[ 3.346165] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 3.347493] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 3.348823] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 3.348860] ov2659_front_4(rk_cam_sensor:387): write array failed!
[ 3.348876] ov2659_front_4(rk_cam_sensor:671): soft reset failed
[ 3.348876]
[ 3.361426] ov2659_front_4(rk_cam_sensor:335): read reg(0x300a val:0x0) failed, try to read again!
[ 3.361461] ov2659_front_4(rk_cam_sensor:699): read chip id failed
[ 3.372248] systemd[1]: Failed to insert module ‘autofs4’
[ 3.379379] [WLAN_RFKILL]: wifi shut off power.
[ 3.379410] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.379424] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.379518] dhd_module_init: Exit err=0
[ 3.385212] systemd[1]: systemd 219 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 3.385593] systemd[1]: Detected architecture arm.
[ 3.390667] systemd[1]: Set hostname to .
[ 3.467960] Cam_Powerdowm
[ 3.536872] ret: 0
[ 3.566392] soc-camera-pdrv gc0329_front_5: Probing gc0329_front_5
[ 3.635250] ret: 0
[ 3.639883] systemd[1]: [/lib/systemd/system/fbset.service:7] Unknown lvalue ‘type’ in section ‘Service’
[ 3.642862] systemd[1]: [/lib/systemd/system/wifi-on.service:7] Unknown lvalue ‘type’ in section ‘Service’
[ 3.661411] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.661503] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.665982] systemd[1]: Created slice Root Slice.
[ 3.666078] systemd[1]: Starting Root Slice.
[ 3.672612] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.672695] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.677656] systemd[1]: Listening on Journal Audit Socket.
[ 3.677741] systemd[1]: Starting Journal Audit Socket.
[ 3.683275] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.683360] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.688653] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.688738] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.693250] systemd[1]: Listening on Journal Socket.
[ 3.693354] systemd[1]: Starting Journal Socket.
[ 3.698290] systemd[1]: Listening on udev Control Socket.
[ 3.698375] systemd[1]: Starting udev Control Socket.
[ 3.703813] systemd[1]: Reached target Remote File Systems (Pre).
[ 3.703891] systemd[1]: Starting Remote File Systems (Pre).
[ 3.709286] systemd[1]: Created slice User and Session Slice.
[ 3.709370] systemd[1]: Starting User and Session Slice.
[ 3.714200] systemd[1]: Reached target Encrypted Volumes.
[ 3.714278] systemd[1]: Starting Encrypted Volumes.
[ 3.719090] systemd[1]: Listening on udev Kernel Socket.
[ 3.719168] systemd[1]: Starting udev Kernel Socket.
[ 3.723607] systemd[1]: Created slice System Slice.
[ 3.723711] systemd[1]: Starting System Slice.
[ 3.728732] systemd[1]: Starting Load Kernel Modules…
[ 3.736556] systemd[1]: Reached target Slices.
[ 3.736672] systemd[1]: Starting Slices.
[ 3.739356] systemd[1]: Starting Setup Virtual Console…
[ 3.743600] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 3.746853] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 3.752243] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.755477] systemd[1]: Starting Journal Service…
[ 3.761829] systemd[1]: Starting udev Coldplug all Devices…
[ 3.772361] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.772491] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 3.775469] systemd[1]: Mounting Debug File System…
[ 3.779741] systemd[1]: Mounted Huge Pages File System.
[ 3.780021] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.781848] systemd[1]: Started Set Up Additional Binary Formats.
[ 3.782854] Cam_Powerdowm
[ 3.785283] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 3.794803] systemd[1]: Reached target Swap.
[ 3.794940] systemd[1]: Starting Swap.
[ 3.796004] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
[ 3.801355] systemd[1]: Created slice system-getty.slice.
[ 3.801463] systemd[1]: Starting system-getty.slice.
[ 3.803861] systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE
[ 3.813420] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 3.814428] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 3.815544] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 3.816389] systemd[1]: Failed to start Load Kernel Modules.
[ 3.816479] systemd[1]: Unit systemd-modules-load.service entered failed state.
[ 3.817171] systemd[1]: systemd-modules-load.service failed.
[ 3.820610] systemd[1]: Started Setup Virtual Console.
[ 3.827801] systemd[1]: Started Remount Root and Kernel File Systems.
[ 3.843380] gc0329_front_5(rk_cam_sensor:335): read reg(0x0 val:0x0) failed, try to read again!
[ 3.843426] gc0329(917): gc0329 read chip id high byte failed
[ 3.843426]
[ 3.843449] gc0329(924): error: gc0329 mismatched pid = 0x0
[ 3.843449]
[ 3.843476] gc0329_front_5(rk_cam_sensor:718): error: mismatched pid = 0x0
[ 3.843476]
[ 3.850156] systemd[1]: Mounted Debug File System.
[ 3.863605] systemd[1]: Started Create Static Device Nodes in /dev.
[ 3.943052] systemd[1]: Starting udev Kernel Device Manager…
[ 3.949213] systemd[1]: Started Rebuild Hardware Database.
[ 3.949471] systemd[1]: Started Various fixups to make systemd work better on Debian.
[ 3.950150] Cam_Powerdowm
[ 3.957274] systemd[1]: Reached target Local File Systems (Pre).
[ 3.957398] systemd[1]: Starting Local File Systems (Pre).
[ 3.962640] systemd[1]: Reached target Local File Systems.
[ 3.962782] systemd[1]: Starting Local File Systems.
[ 3.965706] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data…
[ 3.973992] systemd[1]: Starting Set console keymap…
[ 3.985811] systemd[1]: Reached target Remote File Systems.
[ 3.985932] systemd[1]: Starting Remote File Systems.
[ 3.986086] systemd[1]: Started Commit a transient machine-id on disk.
[ 3.989050] systemd[1]: Starting Load/Save Random Seed…
[ 3.996107] systemd[1]: Mounting Configuration File System…
[ 4.006636] systemd[1]: Mounting FUSE Control File System…
[ 4.011433] systemd[1]: Starting Apply Kernel Variables…
[ 4.025311] systemd[1]: Started udev Coldplug all Devices.
[ 4.028894] ret: 0
[ 4.035594] systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
[ 4.036644] systemd[1]: console-setup.service: main process exited, code=exited, status=203/EXEC
[ 4.058662] soc-camera-pdrv gc2035_back_6: Probing gc2035_back_6
[ 4.061062] systemd[1]: Failed to start Set console keymap.
[ 4.061144] systemd[1]: Unit console-setup.service entered failed state.
[ 4.061289] systemd[1]: console-setup.service failed.
[ 4.067902] systemd[1]: Started Load/Save Random Seed.
[ 4.294598] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
[ 4.294691] soc-camera-pdrv gc2035_back_6: Cannot get I2C adapter #2. No driver?
[ 4.402829] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
[ 4.402848] rk_cam_io(1117):SENSOR_PWRSEQ_HWRST failed
[ 4.776783] soc-camera-pdrv gc0308_front_7: Cannot get I2C adapter #2. No driver?
[ *** ] A start job is running for LSB: Rai…nterfaces. (1min 24s / no limit)
没看清最后一行是什么。接显示器有图形界面吗?之前有做过什么操作?
直接重装了系统,和网口的配置有关系,上网了就没有最后一行了。
