(已解决)ubuntu15.04 apt-get update无法更新
打印信息如下,请教怎么搞?
root@firefly:/# sudo apt-get update
Hit http://ports.ubuntu.com vivid InRelease
Hit http://ports.ubuntu.com vivid-updates InRelease
Hit http://ports.ubuntu.com vivid-backports InRelease
Hit http://ports.ubuntu.com vivid-security InRelease
Get:1 http://ports.ubuntu.com vivid/main Sources [7,181 B]
Get:2 http://ports.ubuntu.com vivid/restricted Sources [7,181 B]
Get:3 http://ports.ubuntu.com vivid/universe Sources [1,118 kB]
Get:4 http://ports.ubuntu.com vivid/main armhf Packages [6,582 kB]
Get:5 http://ports.ubuntu.com vivid/restricted armhf Packages [231 kB]
Get:6 http://ports.ubuntu.com vivid/main Translation-en [793 kB]
Get:7 http://ports.ubuntu.com vivid/restricted Translation-en [839 kB]
Get:8 http://ports.ubuntu.com vivid/universe armhf Packages [6,582 kB]
Get:9 http://ports.ubuntu.com vivid-updates/main Sources [7,181 B]
Get:10 http://ports.ubuntu.com vivid/universe Translation-en [4,456 kB]
Get:11 http://ports.ubuntu.com vivid-updates/restricted Sources [4,351 B]
Get:12 http://ports.ubuntu.com vivid-updates/universe Sources [1,118 kB]
Get:13 http://ports.ubuntu.com vivid-updates/main armhf Packages [279 kB]
Get:14 http://ports.ubuntu.com vivid-updates/restricted armhf Packages [7,701 B]
Get:15 http://ports.ubuntu.com vivid-updates/universe armhf Packages [5,710 kB]
Get:16 http://ports.ubuntu.com vivid-updates/main Translation-en [839 kB]
Get:17 http://ports.ubuntu.com vivid-updates/restricted Translation-en [426 kB]
Get:18 http://ports.ubuntu.com vivid-backports/restricted Sources [7,181 B]
Get:19 http://ports.ubuntu.com vivid-updates/universe Translation-en [426 kB]
Get:20 http://ports.ubuntu.com vivid-backports/main Sources [1,118 kB]
Get:21 http://ports.ubuntu.com vivid-backports/main armhf Packages [612 B]
Get:22 http://ports.ubuntu.com vivid-backports/restricted armhf Packages [28 B]
Get:23 http://ports.ubuntu.com vivid-backports/main Translation-en [426 kB]
Get:24 http://ports.ubuntu.com vivid-backports/restricted Translation-en [426 kB]
Get:25 http://ports.ubuntu.com vivid-security/main Sources [28 B]
Get:26 http://ports.ubuntu.com vivid-security/restricted Sources [1,118 kB]
Get:27 http://ports.ubuntu.com vivid-security/universe Sources [1,118 kB]
Get:28 http://ports.ubuntu.com vivid-security/multiverse Sources [7,181 B]
Get:29 http://ports.ubuntu.com vivid-security/main armhf Packages [193 kB]
Get:30 http://ports.ubuntu.com vivid-security/restricted armhf Packages [231 kB]
Get:31 http://ports.ubuntu.com vivid-security/universe armhf Packages [74.2 kB]
Get:32 http://ports.ubuntu.com vivid-security/multiverse armhf Packages [2,647 B]
Get:33 http://ports.ubuntu.com vivid-security/main Translation-en [426 kB]
Get:34 http://ports.ubuntu.com vivid-security/multiverse Translation-en [89.1 kB]
Get:35 http://ports.ubuntu.com vivid-security/restricted Translation-en [2,774 B]
Get:36 http://ports.ubuntu.com vivid-security/universe Translation-en [426 kB]
Fetched 29.3 MB in 1min 33s (315 kB/s)
W: Failed to fetch http://ports.ubuntu.com/ubuntu-p … main/source/Sources Hash Sum mismatch
W: Failed to fetch http://ports.ubuntu.com/ubuntu-p … cted/source/Sources Hash Sum mismatch
W: Failed to fetch http://ports.ubuntu.com/ubuntu-p … erse/source/Sources Hash Sum mismatch
W: Failed to fetch http://ports.ubuntu.com/ubuntu-p … nary-armhf/Packages Hash Sum mismatch
W: Failed to fetch http://ports.ubuntu.com/ubuntu-p … i18n/Translation-en Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
试试清空 apt 的列表文件再重新 “apt-get update”:
rm -rf /var/lib/apt/lists/*
还是不得行啊,网上好多办法都试了,还是搞不定。
不知道fire 的ubuntu15.04的系统和ubuntu官网上的系统在网络配置上有什么区别,我在虚拟机上面
是可以的,在这个fire上面不行,最后还是直接挂了代理解决了。
