请教求助: rk3288 + rk818 无法正常启动
各位好!
用RK3288 做了一个板子, PMIC用的是 RK818;
用的系统是android5.1的,内核中的dst文件开始时是没有添加rk818的相关的; 我参考其它的dts文件,添加了对rk818的支持;
这样改动后,把各个映像烧写进去,uboot启动能够识别到rk818,内核启动也能识别到rk818;
但是遇到了问题,就是系统只能进入到recovery模式,每次重启后,uboot引导内核,然后内核也是调到recovery模式下,无法正常进入系统。
以下是启动时uboot的打印:
U-Boot 2014.10-RK3288-10-g791753e-dirty (Oct 16 2016 - 16:37:12)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
battery: gl=100 dl=100 rl=100, v=4400, m=0
pmic:rk818
#Boot ver: 2016-10-16#2.30
empty serial no.
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a32e0)
ramdisk @ 0x05bf0000 (0x002c6788)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561cb7c … OK
Add bank:0000000000000000, 00000000fe000000
它应该是识别到rk818的;
以下内核的打印:
[ 0.000000] ion_reserve: cma reserved base d3c00000 size 671088640
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c2edd000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1039360
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x000000002
[ 1.056473] act8846_i2c_probe,line=898
[ 1.057913] act8846 set 0xf4 error!
[ 1.057997] act8846: probe of 0-005a failed with error -11
[ 1.062510] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 1.063534] The device is not syr82x fffffff5
[ 1.063552] syr82x: probe of 0-0041 failed with error -11
[ 1.064004] rk808_i2c_probe,line=1355
[ 1.065336] The device is not rk808 -11
[ 1.065407] rk808: probe of 0-001b failed with error -11
[ 1.065480] rk818_i2c_probe,line=1239
[ 1.065730] rk818_pre_init,line=1154
[ 1.075607] vdd_logic: 712 ↔ 1500 mV at 1100 mV
[ 1.080434] rk818_dcdc2: 1200 mV
[ 1.084013] rk818_dcdc3: 1200 mV
[ 1.087755] vccio: 1800 ↔ 3300 mV at 3300 mV
[ 1.091332] rk818_ldo1: 3300 mV
[ 1.094892] rk818_ldo2: 3300 mV
[ 1.098477] rk818_ldo3: 1000 mV
[ 1.102056] rk818_ldo4: 1800 mV
[ 1.105632] rk818_ldo5: 3300 mV
[ 1.109189] rk818_ldo6: 1000 mV
[ 1.112757] rk818_ldo7: 1800 mV
[ 1.116318] rk818_ldo8: 1800 mV
[ 1.118799] vcc_sd: 1800 ↔ 3300 mV at 3300 mV
[ 1.120016] rk818_ldo10: at 3300 mV
[ 1.121568] rk818_irq_init: rk818_pmic_irq=1
[ 1.121929] i2c-core: driver [rk818] using legacy suspend method
[ 1.121942] i2c-core: driver [rk818] using legacy resume method
[ 1.122421] rk818_rtc_probe,line=542
[ 1.131680] rk818-rtc rk818-rtc: rtc core: registered rk818 as rtc0
[ 1.133649] rk818_rtc_probe:ok
[ 1.135047] Switching to clocksource arch_sys_counter
[ 1.143701] rk_battery_charger_detect_cb , battery_charger_detect 1
然后后面启动到recovery模式的命令行。
1)我把这些我改动后,编译出来的所有映像,下载到firefly3288 reload 板子, reload板子能够正常启动到android系统中; 并不会像我的板子那样一直进入recovery模式;
2)我查看了内核的代码,它是会读取cpu的pmu相关的寄存器来决定是进入recovery模式,还是 normal模式的, 我想咨询下,哪些方面会影响这些寄存器的值呢? 是不是我rk818配置的哪组电压不对吗?
3)一直进入recovery模式,我做了排除,应该是和我板子的recovery按键没关的,在uboot启动时,如果不按recovery按键,它是不会进入升级状态的;
4)有哪个朋友,也是用rk3288 + rk818 做板子的吗? 若有,能否给一下建议,是不是我的哪里的改动不对?
谢谢!
这个是否没有清空 misc 分区所致?
busybee 发表于 2016-11-2 17:41
这个是否没有清空 misc 分区所致?
怎么清空 misc分区呢? 我有把misc.img也烧写进去;
dd if=/dev/zero of=misc_zero.img bs=16k count=3
然后把这个 misc_zero.img 烧写到 misc 分区即可。具体见
http://developer.t-firefly.com/forum.php?mod=viewthread&tid=190&page=1#pid25653
然后把这个 misc_zero.img 烧写到 misc 分区即可。具体 …
谢谢;
我根据你的建议,改动了misc映像升级进去;
板子现在不会进入recovery模式下了;但是启动后,死掉了,停在以下的地方:(每次重启,基本是停在同样的地方)
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Oct 28 2016 - 17:10:59)
CPU: rk3288
david debug cpu version = 0
128 MiB
david debug board_init_r
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
david debug initr_env env_relocate
david debug board_late_init
david debug getenv: bootdelay = 3
GetParam
david debug pmic_init
david debug pmic_init bus0 rk818.
pmic:rk818
david debug pwm_regulator_init
david debug fg_init
#Boot ver: 2016-10-28#2.30
empty serial no.
david debug fbt preboot
checkKey
vbus = 1
david debug run_main_loop
david debug main loop
david debug bootdelay process 3s
david debug main loop autoboot
david debug ### main_loop: bootcmd=“bootrk”
kernel @ 0x02000000 (0x006a3348)
ramdisk @ 0x05bf0000 (0x001460a0)
[ 0.000000] Linux version 3.10.0 (david@david) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #17 SMP PREEMPT Thu Nov 3 09:59:41 CST 2016
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0xfbc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0xfbc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
[ 0.000000] cma: CMA: reserved 640 MiB at d3c00000
[ 0.000000] david debug rk3288_boot_mode_init mode: 00000000, flag: c3524200, rst_st: 00000000
[ 0.000000] david debug rockchip_boot_mode_init mode: 00000000, flag: c3524200
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x000020009
[ 0.000000] battery charged in loader
[ 0.000000] allocated 8323072 bytes of page_cgroup
[ 0.000000] Memory: 4064MB = 4064MB total
[ 0.000000] Memory: 3398908k/3398908k available, 762628k reserved, 2949120K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmemp : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bab710 (11918 kB)
[ 0.000000] .init : 0xc0bac000 - 0xc0c05440 ( 358 kB)
[ 0.000000] .data : 0xc0c06000 - 0xc0d98840 (1611 kB)
[ 0.000000] .bss : 0xc0d98840 - 0xc0eb9afc (1157 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 28
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 2
[ 0.000000] channel:0, lkg:31
[ 0.000000] channel:1, lkg:27
[ 0.855685] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.855700] pid_max: default: 32768 minimum: 301
[ 0.855813] Security Framework initialized
[ 0.855830] SELinux: Initializing.
[ 0.855903] Mount-cache hash table entries: 512
[ 0.856544] Initializing cgroup subsys debug
[ 0.856559] Initializing cgroup subsys memory
[ 0.856585] Initializing cgroup subsys freezer
[ 0.856614] CPU: Testing write buffer coherency: ok
[ 0.856934] /cpus/cpu@0 missing clock-frequency property
[ 0.856949] /cpus/cpu@1 missing clock-frequency property
[ 0.856958] /cpus/cpu@2 missing clock-frequency property
[ 0.856967] /cpus/cpu@3 missing clock-frequency property
[ 0.857025] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.857078] Setting up static identity map for 0xc0858180 - 0xc08581d8
[ 0.859260] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x18d7 (version 3.1)
[ 0.933776] CPU1: Booted secondary processor
[ 0.933810] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.953455] CPU2: Booted secondary processor
1、同样在firefly3288 reload中用了一样的固件,reload的正常;
2、请教,能从这个启动的打印判断问题出在哪里吗? 谢谢;
从内核日志上确实看不出哪里出问题了。仔细比对一下硬件吧。
我現在在弄 RK3128 + RK818
發現有兩組電源不知道源碼在哪裡被 disable掉了
在內核中打印並略過 disable動作
FILE: ./driver/mfd/rk818.c
FUNC: static int rk818_ldo_disable(struct regulator_dev *dev)
printk(“### %s> ldo=%d\n”,func, ldo);
if (ldo == 3 || ldo == 7) return 0;
看看這樣去加印一些訊息, 對你有沒有幫助
在內核中打印並略過 disable …
谢谢;
你现在的板子能正常跑起来了吗?
是的,
因為目前遇到了 開機不穩定的現象, 有先將 dvfs ddr 的部分 在 dts檔案中 先做 disable的動作,
也有試著根據下方連結嘗試做修改驗證
http://www.voidcn.com/blog/huangkaiyue1/article/p-6112359.html
仍然無解,
目前 ddr Freq 固定跑在 300M,
持續驗證釐清中…
woody.lee 发表于 2016-11-4 12:21
是的,
我看到有3128的dts文件,关于rk818部分,有以下的设置:
&rk818 {
gpios =<&gpio1 GPIO_B1 GPIO_ACTIVE_HIGH>,<&gpio1 GPIO_A1 GPIO_ACTIVE_LOW>;
cpu_det_gpio = <&gpio0 GPIO_D0 GPIO_ACTIVE_HIGH>;
power_hold_gpio = <&gpio0 GPIO_D6 GPIO_ACTIVE_HIGH>;
rk818,system-power-controller;
rk818,support_dc_chg = <1>;/1: dc chg; 0:usb chg/
而我现在用的,只是:
&rk818 {
没有这两句:
这个有什么影响吗?
我看到我的电路没有这两路管脚接过去;
&rk818 {
gpios =,;
對你來說應該沒有影響,
估計是 RK3128 + DDR2 與 RK3128 + DDR3 的差異
FirePrime FirePrimeS+
你好,麻烦问一下,是否电源正常以后,3288芯片电路和USB-OTG电路焊接好,用那个烧写固件程序就应该能够识别的这个设备啊,我也是自己做的板子,3288+RK808B,现在想烧写U-boot,烧写固件工具识别不到设备什么原因呢?麻烦指导一下吧。
你好,请问下你的问题解决没有,你用RK818有没有遇到待机重启的问题呢?
rk818配置如下, 已验证可以解决无法开机的问题, 希望有帮助.
/include/ “rk818.dtsi”
&rk818 {
gpios = <&gpio0 GPIO_A4 GPIO_ACTIVE_HIGH>,
<&gpio0 GPIO_A0 GPIO_ACTIVE_LOW>;
 regulators {
     rk818_dcdc1_reg: regulator@0{
         regulator-name= "vdd_logic";
         regulator-min-microvolt = <700000>;
         regulator-max-microvolt = <1500000>;
         regulator-initial-mode = <0x2>;
         regulator-initial-state = <3>;
         regulator-boot-on-volt = <1150000>;
         regulator-state-mem {
             regulator-state-mode = <0x2>;
             regulator-state-enabled;
             regulator-state-uv = <1000000>;
     rk818_dcdc2_reg: regulator@1 {
         regulator-name= "vdd_gpu";
             regulator-state-disabled;
             regulator-state-uv = <900000>;
     rk818_dcdc3_reg: regulator@2 {
         regulator-name= "rk818_dcdc3";
         regulator-min-microvolt = <1200000>;
         regulator-max-microvolt = <1200000>;
             regulator-state-uv = <1200000>;
     rk818_dcdc4_reg: regulator@3 {
         regulator-name= "vccio";
         regulator-min-microvolt = <1800000>;
         regulator-max-microvolt = <3300000>;
             regulator-state-uv = <3000000>;
     rk818_ldo1_reg: regulator@4 {
         regulator-name= "rk818_ldo1";
         regulator-min-microvolt = <3300000>;
             regulator-state-uv = <3300000>;
     rk818_ldo2_reg: regulator@5 {
         regulator-name= "rk818_ldo2";
         regulator-always-on;
     rk818_ldo3_reg: regulator@6 {
         regulator-name= "rk818_ldo3";
         regulator-min-microvolt = <1000000>;
         regulator-max-microvolt = <1000000>;
     rk818_ldo4_reg:regulator@7 {
         regulator-name= "rk818_ldo4";
         regulator-max-microvolt = <1800000>;
             regulator-state-uv = <1800000>;
     rk818_ldo5_reg: regulator@8 {
         regulator-name= "rk818_ldo5";
     rk818_ldo6_reg: regulator@9 {
         regulator-name= "rk818_ldo6";
     rk818_ldo7_reg: regulator@10 {
         regulator-name= "rk818_ldo7";
     rk818_ldo8_reg: regulator@11 {
         regulator-name= "rk818_ldo8";
     rk818_ldo9_reg: regulator@12 {
         regulator-name= "vcc_sd";
     rk818_ldo10_reg: regulator@13 {
         regulator-name= "rk818_ldo10";
 battery {
     ocv_table =
         <3400 3599 3671 3701 3728 3746 3762 3772 3781 3792 3816 3836
         3866 3910 3942 3971 4002 4050 4088 4132 4183 >;
     design_capacity = <4000>;
     design_qmax = <4100>;
     bat_res = <100>;
     max_input_current = <2000>;
     max_chrg_current = <1800>;
     max_chrg_voltage = <4200>;
     sleep_enter_current = <300>;
     sleep_exit_current = <300>;
     power_off_thresd = <3400>;
     zero_algorithm_vol = <3850>;
     fb_temperature = <115>;
     max_soc_offset = <60>;
     monitor_sec = <5>;
     virtual_power = <0>;
     power_dc2otg = <0>;
     dc_det_adc = <0>;
请问楼主的问题解决了吗,我做了一个RK3368+RK818-1的 也是系统进入到RECVRY就不运行了,跟楼主的现象一致,跪求解决办法搞了几天了。
立豕殳 发表于 2018-12-14 18:45
请问楼主的问题解决了吗,我做了一个RK3368+RK818-1的 也是系统进入到RECVRY就不运行了,跟楼主的现象一致 …
你现在好了吗
