rk 3288开发板有没有谁开机自动修改过ip的,比如我想开机把开发板的ip通过命令修改为 sudo ifconfig eth0 192.168.0.11修改为192.168.0.11,
我写了一个脚本内容如下:
#! /bin/sh
脚本放在了/etc/rc.local里面
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will “exit 0” on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
sh /home/ds/tsarixp/ip.sh
exit 0
好像不能修改成功,同样的文件,放在同样的位置放在虚拟机下就可以修改成功,谁知道怎么回事啊?
