运行示例SD->listfiles 时遇到问题
#include <SPI.h>
#include “TF.h”
File root;
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print(“Initializing SD card…”);
if (!SD.begin()) {
Serial.println(“initialization failed!”);
return;
Serial.println(“initialization done.”);
root = SD.open(“/”);
printDirectory(root, 0);
Serial.println(“done!”);
void loop() {
// nothing happens after setup finishes.
void printDirectory(File dir, int numTabs) {
while (true) {
File entry =  dir.openNextFile();
if (! entry) {
  // no more files
  break;
for (uint8_t i = 0; i < numTabs; i++) {
  Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
  Serial.println("/");
  printDirectory(entry, numTabs + 1);
} else {
  // files have sizes, directories do not
  Serial.print("\t\t");
  Serial.println(entry.size(), DEC);
entry.close();
提示如下错误:
C:\Users\钂插叕鑻盶AppData\Local\Temp\arduino_modified_sketch_157250\listfiles.ino: In function ‘void printDirectory(LFile, int)’:
listfiles:59: error: ‘class LFile’ has no member named ‘openNextFile’
listfiles:67: error: ‘class LFile’ has no member named ‘name’
listfiles:68: error: ‘class LFile’ has no member named ‘isDirectory’
exit status 1
我是小白,不知如何解决,希望好心人能帮帮忙,在此谢过。
某些例程并不能完全兼容arduino 的api 接口,如果使用Fireduino 请使用Fireduino 的例程。
Fireduino 的sd 口支持的接口请参考维基。
Fireduino 的sd …
谢谢你的回答。
